  4. *Gelöst* requestPath: 'coffee-script'
39 Beiträge 5 Kommentatoren 6.2k Aufrufe 5 Beobachtet
  • Stephan SchleichS Stephan Schleich
    @thomas-braun das kommt rum
    root@ioBroker:/opt/iobroker# uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    x86_64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.15.1
    v16.15.1
    8.11.0
    root
    /opt/iobroker
    Hit:1 https://repos.influxdata.com/debian focal InRelease
    Hit:2 https://deb.nodesource.com/node_16.x focal InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu focal InRelease
    Get:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
    Get:5 http://archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
    Fetched 228 kB in 1s (261 kB/s)
    Reading package lists... Done
    Building dependency tree
    40 packages can be upgraded. Run 'apt list --upgradable' to see them.
    nodejs:
      Installed: 16.15.1-deb-1nodesource1
      Candidate: 16.16.0-deb-1nodesource1
      Version table:
         16.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x focal/main amd64 Packages
     *** 16.15.1-deb-1nodesource1 100
         10.19.0~dfsg-3ubuntu1 500
            500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    root@ioBroker:/opt/iobroker# sudo apt install nodejs --reinstall
    The following package was automatically installed and is no longer required:
      libllvm11
    Use 'sudo apt autoremove' to remove it.
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 39 not upgraded.
    Need to get 26.5 MB of archives.
    After this operation, 6144 B of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_16.x focal/main amd64 nodejs amd64 16.16.0-deb-1nodesource1 [26.5 MB]
    Fetched 26.5 MB in 4s (7135 kB/s)
    (Reading database ... 34743 files and directories currently installed.)
    Preparing to unpack .../nodejs_16.16.0-deb-1nodesource1_amd64.deb ...
    Unpacking nodejs (16.16.0-deb-1nodesource1) over (16.15.1-deb-1nodesource1) ...
    Setting up nodejs (16.16.0-deb-1nodesource1) ...
    Processing triggers for man-db (2.9.1-1) ...
    @stephan-schleich
    Auf ubuntu rumpelt man nicht als root durch das System. Punkt.
    Stephan SchleichS 1 Antwort Letzte Antwort
      @stephan-schleich
      Stephan SchleichS Offline
      Stephan Schleich
      @thomas-braun Das hat derzeit nix mit dem Problem zu tun, ich schau mir das später an, das Problem ist mir derzeit wichtiger weil nix mehr läuft
        @stephan-schleich sagte in requestPath: 'coffee-script':
        Sehe ich anders. Aber viel Erfolg noch weiterhin.
        • Stephan SchleichS Offline
          Stephan Schleich
          Für jeden dem dieses root gelaber in jedem Post auch aufn Sack geht, es mag seine Berechtigung haben, aber es ist jedem das seine:
          Die Lösung war folgende:
          1. /opt/iobroker/node_modules/iobroker.javascript\node_modules umbenennen z.b. *.old
          2. npm rebuild iobroker.javascript
          dann läufts wieder.
          Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
            dann läufts wieder.
            Dann änder es halt. Dann musst du auch nicht 'angelabert' werden.
              dann läufts wieder.
              GlasfaserG Offline
              GlasfaserG Offline
              @stephan-schleich sagte in *Gelöst* requestPath: 'coffee-script':
              eigentlich nicht , denn @Thomas-Braun hat recht .... bzw. auch darauf hinzuweisen .
              deshalb .... sei froh das @Thomas-Braun dir noch soweit geholfen hat ;)
                Kueppert
                schrieb am zuletzt editiert von Kueppert
                Hallo @Thomas-Braun
                hab m.E. fast das gleiche Problem seit dem letzten JS-Update. Sieht bei mir trotzdem anders aus :)
                thorsten@ioBroker2:/opt/iobroker$ npm ls coffee-script                          iobroker.inst@2.0.3 /opt/iobroker
                └─┬ iobroker.javascript@5.8.8
                  └── UNMET PEER DEPENDENCY coffee-script@1.12.7
                npm ERR! peer dep missing: coffee-script@>=1.6.2, required by coffee-compiler@0.3.2
                thorsten@ioBroker2:/opt/iobroker$ npm ls tough-cookie
                ├─┬ iobroker.backitup@2.4.10
                │ ├─┬ dropbox-v2-api@2.5.3
                │ │ └─┬ request@2.88.2
                │ │   └── tough-cookie@2.5.0
                ├─┬ iobroker.echarts@1.0.12
                │ └─┬ jsdom@19.0.0
                │   └── tough-cookie@4.0.0
                ├─┬ iobroker.harmony@1.2.2
                │ └─┬ harmonyhubws@1.0.6
                │   └─┬ request-promise-native@1.0.7
                │     └── tough-cookie@2.4.3  deduped
                ├─┬ iobroker.hm-rega@3.0.40
                ├─┬ iobroker.javascript@5.8.8
                ├─┬ iobroker.js-controller@4.0.23
                │ ├─┬ @iobroker/js-controller-common@4.0.23
                ├─┬ iobroker.pi-hole@1.4.0 (github:unltdnetworx/ioBroker.pi-hole#8af228102edc7ee8356183670187a8cd00263428)
                ├─┬ iobroker.pollenflug@1.0.6
                │ ├─┬ request@2.88.2
                │ └─┬ request-promise-native@1.0.8
                │   └── tough-cookie@2.5.0  deduped
                ├─┬ iobroker.proxmox@1.3.4
                ├─┬ iobroker.tankerkoenig@2.1.1
                │ └─┬ request@2.88.0
                ├─┬ iobroker.telegram@1.14.1
                │ └─┬ node-telegram-bot-api@0.58.0
                │   └─┬ request-promise@4.2.6
                ├─┬ iobroker.unifi@0.6.1
                │ └─┬ node-unifi@2.1.0
                │   └── UNMET PEER DEPENDENCY tough-cookie@4.0.0
                └─┬ iobroker.whatsapp-cmb@0.2.2
                  └─┬ request@2.88.2
                npm ERR! peer dep missing: tough-cookie@^4.0.0, required by http-cookie-agent@4.0.1
                Das sieht echt schräg aus...hab da nix (mehr) mit Root auf der Konsole rumgefummelt ;)
                Ein NPM-rebuild vom iobroker.javascript (ging nur mit root, nicht mal mit sudo) hat auch nichts gebracht :( habs gemäß dem Hinweis von Stephan hier im Thread gemacht. Fehlermeldung im ioBroker bleibt die Gleiche:
                host.ioBroker2
                2022-07-14 09:01:44.445	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.ioBroker2
                2022-07-14 09:01:44.445	error	Caught by controller[0]: }
                host.ioBroker2
                2022-07-14 09:01:44.445	error	Caught by controller[0]: ]
                host.ioBroker2
                2022-07-14 09:01:44.444	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
                host.ioBroker2
                2022-07-14 09:01:44.444	error	Caught by controller[0]: '/opt/iobroker/node_modules/coffee-compiler/coffee-compiler.js',
                host.ioBroker2
                2022-07-14 09:01:44.444	error	Caught by controller[0]: requireStack: [
                host.ioBroker2
                2022-07-14 09:01:44.444	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                host.ioBroker2
                2022-07-14 09:01:44.443	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19) {
                host.ioBroker2
                2022-07-14 09:01:44.443	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                host.ioBroker2
                2022-07-14 09:01:44.443	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                host.ioBroker2
                2022-07-14 09:01:44.442	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                host.ioBroker2
                2022-07-14 09:01:44.442	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                host.ioBroker2
                2022-07-14 09:01:44.442	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/coffee-compiler/coffee-compiler.js:7:10)
                host.ioBroker2
                2022-07-14 09:01:44.441	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                host.ioBroker2
                2022-07-14 09:01:44.441	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                host.ioBroker2
                2022-07-14 09:01:44.441	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                host.ioBroker2
                2022-07-14 09:01:44.440	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                host.ioBroker2
                2022-07-14 09:01:44.440	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
                host.ioBroker2
                2022-07-14 09:01:44.440	error	Caught by controller[0]: - /opt/iobroker/node_modules/coffee-compiler/coffee-compiler.js
                host.ioBroker2
                2022-07-14 09:01:44.439	error	Caught by controller[0]: Require stack:
                host.ioBroker2
                2022-07-14 09:01:44.439	error	Caught by controller[0]: Error: Cannot find module 'coffee-script'
                host.ioBroker2
                2022-07-14 09:01:44.438	error	Caught by controller[0]: ^
                host.ioBroker2
                2022-07-14 09:01:44.438	error	Caught by controller[0]: throw err;
                host.ioBroker2
                2022-07-14 09:01:44.430	error	Caught by controller[0]: internal/modules/cjs/loader.js:905
                • Thomas BraunT Online
                  @kueppert sagte in *Gelöst* requestPath: 'coffee-script':
                  Dann ist das komplett krumm alles bei dir. In einer sauberen Installation MUSS das auch als User funktionieren, das ist so in den sudoers angelegt.
                  Aber was sage ich. Per root verpfuschst du dir schneller alles als du gucken kannst. Aber das will ja keiner hören.
                  K 3 Antworten Letzte Antwort
                    Kueppert
                    @thomas-braun :( ja, damals als ich anfing mit ioBroker...viele Jahre her (und so alt ist meine Installation auch), hab ich das Betriebssystem gemäß irgendeiner Anleitung als Root aufgesetzt und dann ioBroker drauf gemacht. Puuuh...ich schaue mal, ob ich das gerade bekomme. Ansonsten beiß ich mal in den sauren Apfel und mach das System (VM) ganz neu...
                      Kueppert
                      @thomas-braun hab nen Reboot vom iob gemacht. Eine Meldung im LOG vom iob ist jetzt neu:
                      host.ioBroker2
                      2022-07-14 09:10:29.225	warn	adapter "javascript" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                      Vielleicht repariert es sich ja von selbst...ich berichte
                        Kueppert
                        @thomas-braun leider fehlgeschlagen:
                        host.ioBroker2
                        2022-07-14 09:16:30.862	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.ioBroker2
                        2022-07-14 09:16:30.862	error	Caught by controller[0]: }
                        host.ioBroker2
                        2022-07-14 09:16:30.862	error	Caught by controller[0]: ]
                        host.ioBroker2
                        2022-07-14 09:16:30.861	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
                        host.ioBroker2
                        2022-07-14 09:16:30.861	error	Caught by controller[0]: '/opt/iobroker/node_modules/coffee-compiler/coffee-compiler.js',
                        host.ioBroker2
                        2022-07-14 09:16:30.861	error	Caught by controller[0]: requireStack: [
                        host.ioBroker2
                        2022-07-14 09:16:30.861	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                        host.ioBroker2
                        2022-07-14 09:16:30.860	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19) {
                        host.ioBroker2
                        2022-07-14 09:16:30.860	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                        host.ioBroker2
                        2022-07-14 09:16:30.860	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                        host.ioBroker2
                        2022-07-14 09:16:30.860	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                        host.ioBroker2
                        2022-07-14 09:16:30.859	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                        host.ioBroker2
                        2022-07-14 09:16:30.859	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/coffee-compiler/coffee-compiler.js:7:10)
                        host.ioBroker2
                        2022-07-14 09:16:30.859	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                        host.ioBroker2
                        2022-07-14 09:16:30.859	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                        host.ioBroker2
                        2022-07-14 09:16:30.858	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                        host.ioBroker2
                        2022-07-14 09:16:30.858	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                        host.ioBroker2
                        2022-07-14 09:16:30.857	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
                        host.ioBroker2
                        2022-07-14 09:16:30.857	error	Caught by controller[0]: - /opt/iobroker/node_modules/coffee-compiler/coffee-compiler.js
                        host.ioBroker2
                        2022-07-14 09:16:30.857	error	Caught by controller[0]: Require stack:
                        host.ioBroker2
                        2022-07-14 09:16:30.856	error	Caught by controller[0]: Error: Cannot find module 'coffee-script'
                        host.ioBroker2
                        2022-07-14 09:16:30.856	error	Caught by controller[0]: ^
                        host.ioBroker2
                        2022-07-14 09:16:30.855	error	Caught by controller[0]: throw err;
                        host.ioBroker2
                        2022-07-14 09:16:30.854	error	Caught by controller[0]: internal/modules/cjs/loader.js:905
                        host.ioBroker2
                        2022-07-14 09:16:29.285	error	iobroker npm-rebuild: Rebuilding native modules failed
                        • K Kueppert
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          host.ioBroker2
                          Falls npm@8 jetzt verwendet wird.
                          iobroker stop
                          iobroker fix
                          cd/opt/iobroker/node_modules/iobroker.javascript
                          sudo -H -u iobroker npm install --omit=dev
                          cd /opt/iobroker/node_modules/iobroker.javascript
                          iobroker start
                            iobroker stop
                            iobroker fix
                            iobroker start
                            Kueppert
                            @thomas-braun danke dir für deine Hilfe. Habe auf Grundlage deines Werkzeugkastens festgestellt, dass ich anders als vermutet noch auf Buster-Sourcen laufe (teilweise). Hab die Sources.list jetzt korrigiert und baller gerade bullseye drüber. Dann sind alle Sourcen hoffentlich auf bullseye umgeschrieben von mir...
                            Werde danach schauen, was noch geht. Das hat nun doch nichts mehr mit dem Thema hier zu tun und ich möchte den Thread nicht weiter zuspammen, da mein Problem anscheinend ganz wo anders lag/liegt :)
                            • K Kueppert
                              Ein Mix aus verschiedenen Releases ist auch brandgefährlich. Das muss alles stimmig sein.
                                Kueppert
                                @thomas-braun ich dachte bisher, dass sich alle .list-Inhalte automatisch updaten, wenn man zB auf Bullseye aktualisiert (komme noch von einer Version vor Buster...oder 2 Versionen vorher sogar). Entweder hab ich da war grundlegend falsch gemacht oder man muss da immer manuell rein?
                                • K Kueppert
                                  Kommt drauf an. Es gibt (z. B. bei Ubuntu) Skripte, die ein Release-Upgrade machen. Die klammern aber auch Third-Party-Repositories aus, da muss man also immer manuell ran.
                                  Hier hab ich das mal (halb)-manuell gemacht:
                                  https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                    Kueppert
                                    @thomas-braun hab jetzt omit=dev ausgeführt aus deinem Kommentar. Ich erhalte jetzt "nur" noch folgende Fehlermeldung im Protokoll iob:
                                    javascript.0 2022-07-14 10:34:33.272	error	WARN config production Use `--omit=dev` instead.
                                    javascript.0 2022-07-14 10:34:33.264	error	npm
                                    • K Kueppert
                                      @kueppert
                                      Mehr Kontext... Davor und danach die Zeilen.
                                      Ich vermute, das ist ein im javascript-Adapter zusätzlich eingefügtes Modul. Da ist das okay, die Installationsroutine läuft noch mit den 'alten' Befehlen wie --production.
                                      Wie schaut denn jetzt dein System aus? Immer noch 'zerrupft'?
                                        @kueppert
                                        Kueppert
                                        @thomas-braun bein Reboot der VM sind die Fehlermeldungen komplett verteilt im LOG aufgetreten. Einen Zusammenhang zu einem Adapter/Prozess kann ich da garnicht herauslesen...
                                        Kakke...komme nicht mehr via Putty auf die VM 😂 nur noch mit dem root-User
                                        • K Kueppert
                                          Kakke...komme nicht mehr via Putty auf die VM nur noch mit dem root-User
                                          Dein System ist komplett krumm. root kann sich eigentlich gar nicht von extern am System anmelden. In 'gescheiten' Setups jedenfalls.
