  4. Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta)
391 Beiträge 39 Kommentatoren 86.9k Aufrufe 38 Beobachtet
  • ESP8266E ESP8266
    Moin,
    ich bekomme das Upgrade garnicht erst installiert....
    $ iobroker upgrade alexa2@3.15.2 --debug
    Update alexa2 from @3.14.0 to @3.15.2
    NPM version: 8.11.0Installing iobroker.alexa2@3.15.2... (System call)
    npm WARN old lockfile npm WARN old lockfile The package-lock.json file was created with an old version of npm,npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile npm WARN old lockfile This is a one-time fix-up, please be patient...npm WARN old lockfile
    npm WARN old lockfile HttpErrorGeneral: 404 Not Found - GET https://github.com/instalator/kodi-ws/tarball/master/npm WARN old lockfile at /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/lib/check-response.js:93:15npm WARN old lockfile at processTicksAndRejections (node:internal/process/task_queues:96:5)npm WARN old lockfile Could not fetch metadata for kodi-ws@https://github.com/instalator/kodi-ws/tarball/master/ HttpErrorGeneral: 404 Not Found - GET https://github.com/instalator/kodi-ws/tarball/master/npm WARN old lockfile at /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/lib/check-response.js:93:15npm WARN old lockfile at processTicksAndRejections (node:internal/process/task_queues:96:5) {npm WARN old lockfile headers: [Object: null prototype] {npm WARN old lockfile server: [ 'GitHub.com' ],npm WARN old lockfile date: [ 'Sun, 10 Jul 2022 09:42:46 GMT' ],npm WARN old lockfile 'content-type': [ 'text/plain; charset=utf-8' ],npm WARN old lockfile vary: [npm WARN old lockfile 'X-PJAX, X-PJAX-Container, Turbo-Visit, Turbo-Frame, Accept-Encoding, Accept, X-Requested-With'npm WARN old lockfile ],npm WARN old lockfile 'permissions-policy': [ 'interest-cohort=()' ],npm WARN old lockfile 'cache-control': [ 'no-cache' ],npm WARN old lockfile 'strict-transport-security': [ 'max-age=31536000; includeSubdomains; preload' ],npm WARN old lockfile 'x-frame-options': [ 'deny' ],npm WARN old lockfile 'x-content-type-options': [ 'nosniff' ],npm WARN old lockfile 'x-xss-protection': [ '0' ],npm WARN old lockfile 'referrer-policy': [ 'origin-when-cross-origin, strict-origin-when-cross-origin' ],npm WARN old lockfile 'expect-ct': [npm WARN old lockfile 'max-age=2592000, report-uri="https://api.github.com/_private/browser/errors"'npm WARN old lockfile ],npm WARN old lockfile 'content-security-policy': [npm WARN old lockfile "default-src 'none'; base-uri 'self'; connect-src 'self'; form-action 'self'; img-src 'self' data:; script-src 'self'; style-src 'unsafe-inline'"npm WARN old lockfile ],npm WARN old lockfile 'content-encoding': [ 'gzip' ],npm WARN old lockfile 'content-length': [ '29' ],npm WARN old lockfile 'x-github-request-id': [ '8F16:DE18:20043C:21F2C8:62CA9F16' ],npm WARN old lockfile 'x-fetch-attempts': [ '1' ],npm WARN old lockfile 'x-local-cache-status': [ 'skip' ]npm WARN old lockfile },npm WARN old lockfile statusCode: 404,npm WARN old lockfile code: 'E404',npm WARN old lockfile method: 'GET',npm WARN old lockfile uri: 'https://github.com/instalator/kodi-ws/tarball/master/',npm WARN old lockfile body: <Buffer 4e 6f 74 20 46 6f 75 6e 64>,npm WARN old lockfile pkgid: 'kodi-ws@https://github.com/instalator/kodi-ws/tarball/master/'npm WARN old lockfile }
    npm ERR! code E404npm ERR! 404 Not Found - GET https://github.com/instalator/kodi-ws/tarball/master/npm ERR! 404 npm ERR! 404 'kodi-ws@https://github.com/instalator/kodi-ws/tarball/master/' is not in this registry.npm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-07-10T09_42_22_388Z-debug-0.log
    upload [27] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
    upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
    upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
    Process exited with code 0
    #91
    @esp8266 sagte in Alexa2 Adapter 3.13/3.14/3.15 (Beta):
    Dein npm tree ist nicht sauber. Vermutlich kürzlich node 16 installiert?
    ESP8266E 1 Antwort Letzte Antwort
      ESP8266E Offline
      ESP8266E Offline
      ESP8266
      schrieb am zuletzt editiert von ESP8266
      #92
      @thomas-braun , jepp.
      Vorher den alten Node komplett runtergeschmissen dann auf 16 erhöht.
      • ESP8266E ESP8266
        #93
        @esp8266
        Da gibt es drölftrillionen Threads mit Lösungsvorschlägen zu. Such dir einen aus.
          @esp8266
          ESP8266E Offline
          ESP8266E Offline
          ESP8266
          #94
          @thomas-braun sagte in Alexa2 Adapter 3.13/3.14/3.15 (Beta):
          @esp8266
          Node komplett deinstalliert.....> installiert....
          Das ist alles schön und gut und der folgende Adapter wurde vorher deinstalliert, aber trotzdem stößt er noch Sauer auf.
          npm ls | grep -E 'github.com|ERR'
          ├── iobroker.fully-tablet-control@0.3.7-0.0 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#ee1a5495d78dd5094160c38919905055a9277890)
          pi@iobroker:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm        -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt p        olicy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.16.0
          v16.16.0
          8.11.0
          pi
          /home/pi
          OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
          OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
          Alle Pakete sind aktuell.
          nodejs:
            Installiert:           16.16.0-deb-1nodesource1
            Installationskandidat: 16.16.0-deb-1nodesource1
            Versionstabelle:
           *** 16.16.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
               12.22.12~dfsg-1~deb11u1 500
          pi@iobroker:~ $
          • padrinoP padrino
            @fuchs1978 sagte in Alexa2 Adapter 3.13/3.14/3.15 (Beta):
            Ich nutze das nur um Licht im Zimmer einzuschalten und die Heizung im Winter im Bad hochzufahren,
            Du nutz Wecker mit speziellen Liedern als Trigger?
            Das ist mal ein interessanter Ansatz, musste mir mal genauer erklären. :D
            @apollon77
            Hier geht so viel gerade ab, da freut man sich richtig drauf ausm Urlaub wieder nach Hause zu kommen. 😌
            fuchs1978
            #95
            @padrino nein bislang nicht. Ich mag einfach die Lieder zum Wecken. Ich unterscheide nicht nach Lied welche Aktivität ausgeführt wird falls du es so verstanden hast.
            Klingelt der Wecker, geht das Licht an, gleichzeitig wird die Heizung hochgefahren wenn Randbedingungen vorhanden sind, Außentemperatur, Fenster etc.
            Wäre aber auch eine interessante Idee die Trigger nach Titel zu starten 😂
            • ESP8266E ESP8266
              Moin,
              #96
              Dein Problem liegt dort (bzw. lag, die Quelle gibt es nicht mehr)
              Ist aber kein Thema für diesen Thread.
              Bei Bedarf einen eigenen eröffnen.
                ESP8266E Offline
                ESP8266E Offline
                ESP8266
                #97
                @thomas-braun , dann bleibe ich vorerst bei der alten Alexa2 Version. Ich werde den Teufel tun, den Kodi Adapter auf 2.0.8 hochzuziehen. Das Problem wurde schon vor geraumer Zeit auf dem GitHub gemeldet.
                • ESP8266E ESP8266
                  #98
                  Das ist kein Problem mit dem alexa-Adapter. Es wird kein einziger Adapter richtig updatebar sein, solange da der verwaiste kodi-ws noch im Tree eingetragen ist.
                    ESP8266E Offline
                    ESP8266E Offline
                    ESP8266
                    #99
                    @thomas-braun , dann gehe ich wieder auf node 14....oder lass alles veralten. Solange es läuft, läuft es.....
                    OToff
                    • ESP8266E ESP8266
                      OToff
                      #100
                      @esp8266
                      Und was ist jetzt das Problem mit dem kodi?
                        @esp8266
                        ESP8266E Offline
                        ESP8266E Offline
                        ESP8266
                        #101
                        @thomas-braun , schau bitte auf dem Github
                        DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                        • ESP8266E ESP8266
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #102
                          Link ?
                          Lehrling seit 1975 !!!
                          • ESP8266E ESP8266
                            #103
                            @esp8266
                            Verlink das bitte. Woher soll ich wissen was genau du meinst?
                              @esp8266
                              ESP8266E Offline
                              ESP8266E Offline
                              ESP8266
                              #104
                              @thomas-braun ,
                              https://github.com/iobroker-community-adapters/iobroker.kodi/issues/6
                              • DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #105
                                Mensch hat sich da viel getan ... absolute klasse Arbeit @apollon77
                                Trotzdem eine Frage zu ein paar DPs:
                                Was macht man mit diesen ? Sind ja Write und nicht Read. Mag jetzt nicht irgendwas da reinschreiben, nicht dass meine Echos explodieren oder sogar implodieren 😰
                                • ESP8266E ESP8266
                                  @esp8266
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v16.16.0
                                  v16.16.0
                                  8.11.0
                                  pi
                                  /home/pi
                                  nodejs:
                                    Versionstabelle:
                                  pi@iobroker:~ $
                                  #106
                                  @esp8266 bitte in einem passenderen thread oder neuen machen. Danke.
                                  • DJMarc75D DJMarc75
                                    #107
                                    @djmarc75 mal readme gelesen?? ;-))
                                    Beide erlauben dir das starten eines skills. Beim Yours ist eine Liste mit „deinen skills“ hinterlegt zum direkt im Admin auswählen. Der andere ist das gleiche aber als Textfeld wenn du die skilled kennst und ggf einen anderen skill nutzen willst
                                    • apollon77A apollon77
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #108
                                      @apollon77 endgeil !! Da kann ich dann meine Skripte welche Skills enthalten quasi vereinfachen. Good Job 👍
                                      @apollon77 sagte in Alexa2 Adapter 3.13/3.14/3.15 (Beta):
                                      ja, und zwar JETZT erst 😰
                                        #109
                                        @djmarc75 Man kann mit dem ioBroker custom Skill zb dann den Skill starten und Sie sagt2 Hallo, was möchtest Du wissen oder steuern?" und hört zu... Wäre das wie man dem "sie hört zu" am nächsten käme
                                        • apollon77A Offline
                                          #110
                                          So, na dann weil es so schön ist und ich Music-Alarme neu kennengelernt habe kann die auch der Adapter jetzt :-))
                                          3.16.1 ist auf dem Weg:
                                          • (Apollon77) Add (official) support for Music-Alarms - they are now listed under "Alarms" together with the other Alarms! The "sound" list will contain the device specific music targets - so you can basically zse the ones that you created at least once via voice commands.
                                          • (Apollon77) For a Music Alarm the "customVolume" on the alarm is used to set the normal device volume 2s before the alarm but do not (!) reset it afterwards
                                          • (Apollon77) Prevent crashes on one time Alarms that just triggered
                                          Wichtig ist das man einen "Musik-Wunsch" einmalig mit einem Wecker per Sprache anlegen muss ... danach den Adapter neu starten. Dann sollte bei den Gerät!! in der "sound" Liste bei den Alarmen auch dieser Musik-Wunsch verfügbar sein. Es geht mindestens TuneIn und Amazon Music ... Spotify denke ich auch - habe ich nur nicht.
                                          EDIT: Korrektur ... 3.16.1 fixt auch Fehler beim löschen von Notifications die Sentry gesehen hat
                                          Bitte ALLE zeitnah updaten!!
