  4. Zigbee Adapter - restart loop detected
    5.8k
66 Beiträge 3 Kommentatoren 7.9k Aufrufe 3 Beobachtet
  • B brokeling
    na ich weiß nicht so recht welche....
    was soll ich eingeben?
    @brokeling
    MANN...
    Das was bei einem NEUSTART des ADAPTERS im LOGFILE NEU ERSCHEINT.
      @brokeling
      MANN...
      brokeling
      ...soory, ich dachte das hatten wir alles schon...
      hier jetzt aber:
      pi@raspi:~ $ tail -f /opt/iobroker/log/iobroker.current.log
      2022-07-05 00:00:39.615  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC033DC.boostactiveendtime" has to be type "number" but received type "string"
      2022-07-05 00:00:39.615  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC033DC.endperiod" has to be type "number" but received type "string"
      2022-07-05 00:00:39.617  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC03168.windowopenactiveendtime" has to be type "number" but received type "string"
      2022-07-05 00:00:39.634  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC03168.boostactiveendtime" has to be type "number" but received type "string"
      2022-07-05 00:00:39.635  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC03168.endperiod" has to be type "number" but received type "string"
      2022-07-05 00:00:39.637  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC032FE.windowopenactiveendtime" has to be type "number" but received type "string"
      2022-07-05 00:00:39.637  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC032FE.boostactiveendtime" has to be type "number" but received type "string"
      2022-07-05 00:00:39.638  - info: fritzdect.0 (2320) State value to set for "fritzdect.0.DECT_grpC786EA-3BDC032FE.endperiod" has to be type "number" but received type "string"
      2022-07-05 00:01:00.082  - info: javascript.0 (19239) script.js.common.Pool.Laufzeit_Filter___d: Minute
      2022-07-05 00:01:08.485  - info: javascript.0 (19239) script.js.common.Display.Display3_TFT.Alternativ.L8_CO2_WoZi1: 3
      2022-07-05 00:01:30.982  - info: host.raspi "system.adapter.zigbee.0" enabled
      2022-07-05 00:01:31.722  - info: host.raspi instance system.adapter.zigbee.0 started with pid 3931
      2022-07-05 00:01:36.283  - info: zigbee.0 (3931) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
      2022-07-05 00:01:36.413  - info: zigbee.0 (3931) delete old Backup files. keep only last 10
      2022-07-05 00:01:36.416  - info: zigbee.0 (3931) Starting Zigbee  npm ...
      2022-07-05 00:01:36.998  - info: zigbee.0 (3931) Installed Version: iobroker.zigbee@1.7.5
      2022-07-05 00:01:37.156  - warn: zigbee.0 (3931) Extended PAN ID is reversed (expected=c6b9aa1c004b1200, actual=00124b001caab9c6)
      2022-07-05 00:01:37.291  - info: zigbee.0 (3931) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
      2022-07-05 00:01:37.298  - info: zigbee.0 (3931) Unable to disable LED, unsupported function.
      2022-07-05 00:01:37.314  - info: zigbee.0 (3931)   --> transmitPower : high
      2022-07-05 00:01:37.327  - info: zigbee.0 (3931) Currently 46 devices are joined:
      2022-07-05 00:01:37.539  - info: zigbee.0 (3931) 0x00158d0006f783af (addr 64267): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2022-07-05 00:01:37.559  - info: zigbee.0 (3931) 0x00158d0006f24719 (addr 41432): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2022-07-05 00:01:37.562  - info: zigbee.0 (3931) 0x000d6ffffea04475 (addr 44106): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
      2022-07-05 00:01:37.564  - info: zigbee.0 (3931) 0x00158d0003d092f2 (addr 62419): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      2022-07-05 00:01:37.566  - info: zigbee.0 (3931) 0x842e14fffe43865c (addr 27459): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
      2022-07-05 00:01:37.568  - info: zigbee.0 (3931) 0x00158d0005d11326 (addr 55919): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2022-07-05 00:01:37.569  - info: zigbee.0 (3931) 0x00158d000171ba9f (addr 55416): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      2022-07-05 00:01:37.571  - info: zigbee.0 (3931) 0xccccccfffee9a795 (addr 48387): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
      2022-07-05 00:01:37.572  - info: zigbee.0 (3931) 0x00158d0003d22159 (addr 56651): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      2022-07-05 00:01:37.575  - info: zigbee.0 (3931) 0xec1bbdfffeaa8f30 (addr 34651): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
      2022-07-05 00:01:37.576  - info: zigbee.0 (3931) 0xec1bbdfffea186d2 (addr 23525): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
      2022-07-05 00:01:37.578  - info: zigbee.0 (3931) 0xccccccfffea9ccd9 (addr 46171): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
      2022-07-05 00:01:37.581  - info: zigbee.0 (3931) 0xec1bbdfffea17968 (addr 59322): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
      2022-07-05 00:01:37.583  - info: zigbee.0 (3931) 0x00158d00057b0540 (addr 12256): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      2022-07-05 00:01:37.585  - info: zigbee.0 (3931) 0x00158d000586f719 (addr 46272): JTYJ-GD-01LM/BW - Xiaomi MiJia Honeywell smoke detector (EndDevice)
      2022-07-05 00:01:37.586  - info: zigbee.0 (3931) 0x842e14fffef6f646 (addr 39442): HS1SA - HEIMAN Smoke detector (EndDevice)
      2022-07-05 00:01:37.588  - info: zigbee.0 (3931) 0x00158d0001d56bd8 (addr 44376): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      2022-07-05 00:01:37.590  - info: zigbee.0 (3931) 0x0015bc003100c2ea (addr 53882): SMSZB-120 - Develco Smoke detector with siren (EndDevice)
      2022-07-05 00:01:37.591  - info: zigbee.0 (3931) 0x00158d00042d639d (addr 13713): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
      2022-07-05 00:01:37.593  - info: zigbee.0 (3931) 0xccccccfffee86c05 (addr 62590): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
      2022-07-05 00:01:37.594  - info: zigbee.0 (3931) 0x842e14fffe13965d (addr 37271): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2022-07-05 00:01:37.596  - info: zigbee.0 (3931) 0x842e14fffe4028b6 (addr 51203): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
      2022-07-05 00:01:37.597  - info: zigbee.0 (3931) 0x00158d0005226481 (addr 26815): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2022-07-05 00:01:37.599  - info: zigbee.0 (3931) 0x00158d0005cf4350 (addr 923): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2022-07-05 00:01:37.600  - info: zigbee.0 (3931) 0x00158d0005435ff6 (addr 27342): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2022-07-05 00:01:37.602  - info: zigbee.0 (3931) 0x54ef4410000345bd (addr 24768): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
      2022-07-05 00:01:37.604  - info: zigbee.0 (3931) 0x000d6ffffe04ac2a (addr 1520): LED1732G11 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white (Router)
      2022-07-05 00:01:37.606  - info: zigbee.0 (3931) 0x00158d0006f798ca (addr 29933): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2022-07-05 00:01:37.610  - info: zigbee.0 (3931) 0x00158d0006f798c4 (addr 11608): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2022-07-05 00:01:37.611  - info: zigbee.0 (3931) 0x842e14fffe13a855 (addr 701): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2022-07-05 00:01:37.613  - info: zigbee.0 (3931) 0xd0cf5efffefee1d0 (addr 19337): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      2022-07-05 00:01:37.614  - info: zigbee.0 (3931) 0xec1bbdfffea39be0 (addr 40361): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
      2022-07-05 00:01:37.616  - info: zigbee.0 (3931) 0x00158d0002b35ad2 (addr 21375): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2022-07-05 00:01:37.618  - info: zigbee.0 (3931) 0xec1bbdfffeaa888d (addr 35257): LED1836G9 - IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white (Router)
      2022-07-05 00:01:37.619  - info: zigbee.0 (3931) 0x84fd27fffe6029ba (addr 57452): TS0043 - TuYa Wireless switch with 3 buttons (EndDevice)
      2022-07-05 00:01:37.621  - info: zigbee.0 (3931) 0x00158d00047c6488 (addr 19040): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2022-07-05 00:01:37.623  - info: zigbee.0 (3931) 0x60a423fffe39daad (addr 54526): TT001ZAV20 - TuYa Temperature & humidity sensor (EndDevice)
      2022-07-05 00:01:37.624  - info: zigbee.0 (3931) 0x00158d0004868072 (addr 55508): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2022-07-05 00:01:37.626  - info: zigbee.0 (3931) 0x680ae2fffe723cf0 (addr 59119): SP 220 - Innr Smart plug (Router)
      2022-07-05 00:01:37.627  - info: zigbee.0 (3931) 0x00158d0003d47777 (addr 16788): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
      2022-07-05 00:01:37.629  - info: zigbee.0 (3931) 0x847127fffed3f100 (addr 17702): PSBZS A1 - Lidl Parkside smart watering timer (EndDevice)
      2022-07-05 00:01:37.631  - info: zigbee.0 (3931) 0x842e14fffe5507a8 (addr 41833): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      2022-07-05 00:01:37.632  - info: zigbee.0 (3931) 0xec1bbdfffeae2d87 (addr 45315): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
      2022-07-05 00:01:37.634  - info: zigbee.0 (3931) 0x2c1165fffe2d49c0 (addr 347): HG08164 - Lidl Silvercrest smart button (EndDevice)
      2022-07-05 00:01:37.635  - info: zigbee.0 (3931) 0x2c1165fffe3f28a8 (addr 28076): HG08164 - Lidl Silvercrest smart button (EndDevice)
      2022-07-05 00:01:37.637  - info: zigbee.0 (3931) 0x842e14fffe359b01 (addr 11367): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
      2022-07-05 00:01:37.638  - info: zigbee.0 (3931) Zigbee started
      2022-07-05 00:01:37.842  - info: zigbee.0 (3931) deregister device Ping for deactivated device "0x2c1165fffe2d49c0"
      2022-07-05 00:01:37.843  - info: zigbee.0 (3931) deregister device Ping for deactivated device "0x2c1165fffe3f28a8"
      2022-07-05 00:01:37.844  - info: zigbee.0 (3931) deregister device Ping for deactivated device "0x842e14fffe359b01"
      2022-07-05 00:01:56.883  - warn: zigbee.0 (3931) DeviceAvailability:Failed to ping 0xec1bbdfffeaa8f30 TRADFRI bulb E27 WW 806lm
      2022-07-05 00:01:56.994  - warn: zigbee.0 (3931) DeviceAvailability:Failed to ping 0xec1bbdfffea186d2 TRADFRI bulb E27 WW 806lm
      2022-07-05 00:01:57.151  - warn: zigbee.0 (3931) DeviceAvailability:Failed to ping 0xec1bbdfffea17968 TRADFRI bulb E27 WW 806lm
      2022-07-05 00:01:58.163  - warn: zigbee.0 (3931) DeviceAvailability:Failed to ping 0xec1bbdfffeaa888d TRADFRI bulb E27 WW 806lm
      2022-07-05 00:02:00.082  - info: javascript.0 (19239) script.js.common.Pool.Laufzeit_Filter___d: Minute
      2022-07-05 00:02:08.531  - info: javascript.0 (19239) script.js.common.Display.Display3_TFT.Alternativ.L8_CO2_WoZi1: 3
      2022-07-05 00:03:00.083  - info: javascript.0 (19239) script.js.common.Pool.Laufzeit_Filter___d: Minute
      2022-07-05 00:03:08.494  - info: javascript.0 (19239) script.js.common.Display.Display3_TFT.Alternativ.L8_CO2_WoZi1: 3
      • B brokeling
        hier jetzt aber:
        @brokeling
        Ich würde nodeJS auf die empfohlene Version 16 bringen.
        Das log ist jetzt um 0Uhr rotiert worden, das ist also jetzt wieder handlich.
        iobroker logs --watch
        dürfte jetzt funktionieren.
        Hast du noch weitere Adapter auf dem log level debug stehen? Setzt die alle auf INFO oder WARN.
          @brokeling
          brokeling
          mir war nicht bewusst, dass für einzelne Adapter das log-level separat vergeben werden kann.
          wo ist dies einzustellen?
          • B brokeling
            @brokeling
              @brokeling
              brokeling
              ok, das ist nur im "Expertenmodus" sichtbar.
              Bei mir ist alles auf Info.
              • B brokeling
                @brokeling
                Wo hattest du denn dann das log level auf debug gesetzt, wenn nicht da?
                B 2 Antworten Letzte Antwort
                  @brokeling
                  brokeling
                  schrieb am zuletzt editiert von brokeling
                  Alle, unter Protokolle. War nur sporadisch umgestellt, aber wohl nicht mehr zurückgestellt auf info.
                    @brokeling
                    brokeling
                    Morgen mach ich nodeJS auf Version 16...
                    Und wünsche eine gute Nacht!!!
                    und danke schonmal.
                    • B brokeling
                      und danke schonmal.
                      @brokeling
                      Das ist aber nur ein Filter, das log level kann man da nicht einstellen.
                      • B brokeling
                        und danke schonmal.
                        @brokeling
                        Könnte das bei dir auch sein?
                        https://forum.iobroker.net/topic/56069/zigbee-adpter-wird-immer-wieder-neu-gestartet
                        Da sind ja auch IKEA Leuchten ohne Strom bei dir. (Ist im Übrigen bei zigbee eine schlechte Idee, die auszuknipsen).
                          brokeling
                          @thomas-braun said in Zigbee Adapter - restart loop detected:
                          @brokeling
                          Ja, das könnte es genau sein.
                          Allerdings habe ich bisher keinen direkten zeitlichen Zusammenhang mit den bulbs entdeckt.
                          Das werde ich testen.
                          Jetzt aber noch das nodeJS upgrade.
                          habe eingetragen:
                          pi@raspi:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
                            GNU nano 3.2        /etc/apt/sources.list.d/nodesource.list
                          deb https://deb.nodesource.com/node_12.x buster main
                          deb-src https://deb.nodesource.com/node_12.x buster main
                          deb https://deb.nodesource.com/node_14.x buster main
                          deb-src https://deb.nodesource.com/node_14.x buster main
                          #node 16
                          deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/n$
                          deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.c$
                          muss ich jetzt
                          sudo apt install nodejs=16-deb-1nodesource1
                          • B brokeling
                            @brokeling
                            habe eingetragen:
                            #node 16
                            muss ich jetzt
                            brokeling
                            hier erscheint aber Version 16 nicht:
                            pi@raspi:~ $ apt policy nodejs
                            nodejs:
                              Installiert:           14.19.3-deb-1nodesource1
                              Installationskandidat: 14.19.3-deb-1nodesource1
                              Versionstabelle:
                             *** 14.19.3-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                 12.22.12-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                 10.24.0~dfsg-1~deb10u1 500
                            pi@raspi:~ $
                            • B brokeling
                              nodejs:
                                Versionstabelle:
                              pi@raspi:~ $
                              brokeling
                              Fehler:
                              pi@raspi:~ $ iobroker stop
                              pi@raspi:~ $ sudo apt update
                              Holen:1 http://phoscon.de/apt/deconz buster InRelease [2.869 B]
                              OK:2 http://archive.raspberrypi.org/debian buster InRelease
                              OK:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                              OK:5 https://deb.nodesource.com/node_14.x buster InRelease
                              Holen:6 https://deb.nodesource.com/node_16.x bullseye InRelease [4.586 B]
                              Fehl:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 1655A0AB68576280
                              W: GPG-Fehler: https://deb.nodesource.com/node_16.x bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 1655A0AB68576280
                              E: Das Depot »https://deb.nodesource.com/node_16.x bullseye InRelease« ist nicht signiert.
                              N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                              N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                              • B brokeling
                                Fehler:
                                @brokeling
                                  @brokeling
                                  brokeling
                                  ich mache das Ganze mit deiner Anleitung "Node richtig installieren".
                                  Das scheint aber etwas nicht zu passen, mit den Pfaden.
                                  • B brokeling
                                    @brokeling
                                    In der Anleitung passt alles.
                                    Deine Pfade sehe ich nicht (mal wieder).
                                    Hol die node16 über das nodesource-Installer-Skript rein, dann wird auch die Signaturprüfung angelegt, die oben angemeckert wird.
                                      @brokeling
                                      brokeling
                                      meinst du das hier:
                                      Für eine Node-Erstinstallation:
                                      Debian/RaspberryOS/Ubuntu und artverwandtes:
                                      curl -sL https://deb.nodesource.com/setup_VV.x | sudo -E bash
                                      Die gewünschte Version anpassen, also in
                                      setup_VV.x
                                      Ich dachte das ist nicht notwendig, weil keine Erstinstallation.
                                        @brokeling
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @brokeling
                                        @thomas-braun sagte in Zigbee Adapter - restart loop detected:
                                        @brokeling
                                        nur zur info dazu :
                                        arteck schrieb in den Thread dazu :
                                        @nole @Einstein67
                                        diese Änderung ist schon längst auf GIT..
                                        also von GIT installieren bitte und gut ist
                                        • B brokeling
                                          meinst du das hier:
                                          setup_VV.x
                                          @brokeling sagte in Zigbee Adapter - restart loop detected:
                                          In deinem Fall ist es notwendig, weil die Signaturprüfung bei deiner bestehenden nodesource.list (warum auch immer) nicht angelegt ist.
