  4. Raspi setzt sporadisch aus
    5.8k
36 Beiträge 7 Kommentatoren 3.9k Aufrufe 6 Beobachtet
  • O Offline
    O Offline
    orfix
    @orfix
    Heute kam der Adapter, jetzt läuft der Modbus endlich.
    Leider funktioniert nun das Smartmeter nicht mehr?
    Hab schon alles probiert, update, neustart...
    smartmeter.0
    	743	2022-04-12 15:47:51.123	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	743	2022-04-12 15:45:50.111	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	743	2022-04-12 15:43:49.101	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	743	2022-04-12 15:41:48.090	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	743	2022-04-12 15:39:47.079	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	743	2022-04-12 15:37:46.063	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	693	2022-04-12 15:31:57.328	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	693	2022-04-12 15:29:56.313	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	673	2022-04-12 15:24:52.675	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	673	2022-04-12 15:22:51.664	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	673	2022-04-12 15:20:50.652	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	673	2022-04-12 15:18:49.643	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    	673	2022-04-12 15:16:48.633	warn	No or too long answer from Serial Device after last request.
    was fehlt jetzt?
    mfg
    orfix
    • O orfix
      @orfix
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      was fehlt jetzt?
      mfg
      orfix
      @orfix sagte in Raspi setzt sporadisch aus:
      was fehlt jetzt?
      Eine gescheite Spannungsversorgung.
      O 1 Antwort Letzte Antwort
        was fehlt jetzt?
        O Offline
        O Offline
        orfix
        hab jetzt einen Raspberry Pi 4 Model B Rev 1.1, läuft
        danke alle für die Unterstützung
        mfg
        orfix
        OpenSourceNomadO 1 Antwort Letzte Antwort
        • O orfix
          mfg
          orfix
          OpenSourceNomadO Offline
          OpenSourceNomad
          Most Active Gesperrt
          @orfix said in Raspi setzt sporadisch aus:
          Der kleine aber feine Unterschied zu deinem vorherigen Raspberry ist hier übrigens usb-c ⚠
          Model : Raspberry Pi 2 Model B Rev 1.1
          Habe mehrere Handy Netzteile getestet, zur Zeit ist ein Logilink mit 2,4 A montiert.
          Die Krux von diesem (theoretisch) maximal 2,4A liefernden Netzteil ist das Nadelöhr micro-usb, nach Spezifikation erlaubt dieses maximal 1,8A (und dabei entsteht schon ordentlich Hitze aufgrund der winzigen Kontakte). ⚡
          Dein Raspberry 4 mit usb-c sollte dagegen minimal 3A abkönnen 💡
          Allerdings gibt es auch bei den alten Raspberries mit micro-usb eine triviale Lösung indem man diese einfach über die GPIO Stiftleiste bestromt (hier sind locker 2,5A möglich). Je nach Modell muss aber aufgepasst werden weil teilweise dann Schutzschaltung (Überspannungschutz etc.) fehlen, da diese bei bestimmten Modellen direkt hinter dem micro-usb Eingang sitzen.
          • OpenSourceNomadO OpenSourceNomad
            O Offline
            O Offline
            orfix
            Servus,
            danke für deine Unterstützung, messe jetzt 3 W Gesamtleistung am NT das sind 0,6 A.
            Leider setzt der Raspi immer noch sproadisch alle 4-7 Tagen aus und liefert keine Daten mehr, meistens genügt ein sudo reboot. Einmal musste ich erst ein backup einspielen.
            Die 2 USB Konverter kann man Stromverbrauch mäßig ignorieren?
            Hab jetzt die Abtastrate vom sml Adapter auf von 1 Sek auf 10 Sek. Gesetzt, vielleicht hilft es?
            Vielleicht wäre ein reset all 2 Tage auch sinnvoll?
            Hab leider auch nur Wlan im Zählerkasten.
            Werde auch mal den dlan testen.
            Mit freundlichen Grüßen,
            orfix
            • O orfix
              Servus,
              orfix
              das klingt danach, als ob irgendetwas den RasPi überbeschäftigt.
              in fast allen Fällen ist dies ein Skript, das aus dem Ruder läuft.
              aussetzen ist dann die falsche Bezeichnung. Er braucht nur uuuuunheimlich lange, bis zum timeout.
                O Offline
                O Offline
                orfix
                danke für deine Antwort,
                es laufen nur das smartmeter und ein modbus am raspi.
                Influxdb läuft exten auf einen server.
                orfix
                • O orfix
                  orfix
                  @orfix
                  Auf dem Screenshot ist die RAM-Auslastung schon recht hoch. Wenn dann was wie ein Backup obendrauf kommt könnte die Kiste die Grätsche machen.
                    @orfix
                    O Offline
                    O Offline
                    orfix
                    servus Thomas,
                    danke für die info, ja hast recht ram belastung ist hoch.
                    Hab jetzt modbus,iobroker, sml gestoppt, brachte keine Reduzierung?
                    Wer verbraucht dann die leistung?
                    mfg
                    orfix
                    • O orfix
                      servus Thomas,
                      mfg
                      orfix
                      @orfix
                      Schau mit
                      top
                      nach.
                        @orfix
                        Schau mit
                        top
                        nach.
                        O Offline
                        O Offline
                        orfix
                        servus,
                        wieso sehe ich hier die große auslastung?
                        mfg
                        Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                        • O orfix
                          servus,
                          mfg
                          @orfix
                          Auf Screenshots sehe ich gar nichts
                          • O orfix
                            servus,
                            mfg
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            @orfix besser
                            htop
                            und dann hier keine Screenshots, wie @Thomas-Braun geschrieben hat, sondern in Codetags packen.
                            Lehrling seit 1975 !!!
