  3. Off Topic
  4. Grafana
  5. Grafana / InfluxDB / VIS
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 8 Kommentatoren 11.6k Aufrufe 6 Beobachtet
  • K kimukao
    @oliverio Hab mir das grade mal in Chrome angeschaut. Da wird u.a. folgender Platzhalter angezeigt (das Menu habe ich nicht gescreenshottet):
    Und nach Druck von F12 kommen diese Meldungen:
    Failed to load resource: the server responded with a status of 404 (Not Found)
    metro-bootstrap.css:1          Failed to load resource: the server responded with a status of 404 (Not Found)
    fritzdect.js:46 Version fritzdect: 0.0.2
    metro.js:1          Failed to load resource: the server responded with a status of 404 (Not Found)
    trashschedule.js:152 Version trashschedule: 2.0.2
    vis-material-advanced.js:184 Version vis-material-advanced: 1.6.0
    index.html:12305 Version vis-weather: 2.5.4
    socket.io.js:66 [2022-07-01T16:01:22.029Z] Try to connect
    conn.js:305 2022-07-01T16:01:22.040Z Connected => authenticate
    conn.js:326 2022-07-01T16:01:22.094Z Authenticated: true
    VM82:2 Uncaught ReferenceError: on is not defined
        at <anonymous>:2:1
        at Object.<anonymous> (vis.js:3693:47)
        at vis.js:2062:34
        at conn.js:580:25
    vis.js:3543 Create inner vis object 0_userdata.0.VIS.Kamera
    vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.OverviewTable
    vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.NextExpectedLowBatt
    vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.AllBatterysOk
    vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.LastMessage
    vis.js:3543 Create inner vis object 0_userdata.0.VIS.auf-zu
    vis.js:3543 Create inner vis object 0_userdata.0.VIS.Wetter
    vis.js:3543 Create inner vis object lupusec.0.devices.RF:04cf8c10.status_ex
    vis.js:3543 Create inner vis object 0_userdata.0.VIS.Fenster_Switch
    vis.js:3543 Create inner vis object lupusec.0.devices.RF:04d05810.status_ex
    vis.js:3543 Create inner vis object lupusec.0.devices.RF:04d06e10.status_ex
    vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bfe110.status_ex
    vis.js:3543 Create inner vis object lupusec.0.devices.RF:04c86710.status_ex
    vis.js:3543 Create inner vis object lupusec.0.devices.RF:04cdcb10.status_ex
    vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bf9410.status_ex
    vis.js:3543 Create inner vis object lupusec.0.devices.RF:04c20010.status_ex
    vis.js:3543 Create inner vis object lupusec.0.devices.RF:04af0b10.status_ex
    vis.js:3543 Create inner vis object lupusec.0.devices.RF:0017a210.status_ex
    vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bb7610.status_ex
    vis.js:3543 Create inner vis object deconz.0.Sensors.4.open
    vis.js:3543 Create inner vis object deconz.0.Sensors.5.open
    vis.js:3543 Create inner vis object deconz.0.Sensors.6.open
    vis.js:3543 Create inner vis object deconz.0.Sensors.7.open
    vis.js:3543 Create inner vis object deconz.0.Sensors.8.open
    vis.js:3543 Create inner vis object deconz.0.Sensors.9.open
    vis.js:3543 Create inner vis object deconz.0.Sensors.10.open
    vis.js:3543 Create inner vis object 0_userdata.0.Tor.Torautomatik
    vis.js:3543 Create inner vis object nuki.0.724531834.actions.rtoAction
    vis.js:3543 Create inner vis object deconz.0.Sensors.15.open
    vis.js:3543 Create inner vis object deconz.0.Sensors.16.open
    vis.js:3543 Create inner vis object deconz.0.Sensors.17.open
    vis.js:3543 Create inner vis object deconz.0.Lights.28.on
    vis.js:3543 Create inner vis object deconz.0.Lights.9.on
    vis.js:3543 Create inner vis object deconz.0.Lights.6.on
    vis.js:3543 Create inner vis object deconz.0.Lights.27.on
    vis.js:3543 Create inner vis object deconz.0.Lights.19.on
    vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Wohnbereich.Temperature.Temperature
    vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Wohnbereich.Humidity.Humidity
    vis.js:3543 Create inner vis object deconz.0.Lights.2.on
    vis.js:3543 Create inner vis object deconz.0.Lights.22.level
    vis.js:3543 Create inner vis object deconz.0.Lights.22.on
    vis.js:3543 Create inner vis object deconz.0.Lights.3.on
    vis.js:3543 Create inner vis object deconz.0.Lights.41.on
    vis.js:3543 Create inner vis object deconz.0.Lights.24.level
    vis.js:3543 Create inner vis object deconz.0.Lights.24.on
    vis.js:3543 Create inner vis object deconz.0.Lights.5.on
    vis.js:3543 Create inner vis object deconz.0.Lights.14.on
    vis.js:3543 Create inner vis object lupusec.0.devices.ZS:b11501.level
    vis.js:3543 Create inner vis object deconz.0.Lights.54.on
    vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.actualTemp
    vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.waterFlow
    vis.js:3543 Create inner vis object km200.0.heatSources.systemPressure
    vis.js:3543 Create inner vis object km200.0.heatSources.actualSupplyTemperature
    vis.js:3543 Create inner vis object km200.0.heatingCircuits.hc2.actualSupplyTemperature
    vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.charge
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.connected
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.state
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_mid
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_elapsed
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_duration
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.group_leader_pid
    vis.js:2596 Error in eval[value]: {pid:heos.0.players.-2129318115.group_leader_pid;pidToRgbColor(pid)}
    formatBinding @ vis.js:2596
    vis.js:2597 Error in eval[script]: var pid = "undefined";return pidToRgbColor(pid);
    formatBinding @ vis.js:2597
    vis.js:2598 Error in eval[error]: ReferenceError: pidToRgbColor is not defined
    formatBinding @ vis.js:2598
    vis.js:3543 Create inner vis object heos.0.sources.1028.4.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.4.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.5.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.5.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.8.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.8.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.9.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.9.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.10.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.10.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.11.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.11.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.12.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.12.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.13.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.13.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.14.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.14.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.15.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.15.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.16.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.16.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.1.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.1.image_url
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_audio_format
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_bitrate
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_sample_rate
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_bitdepth
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.muted
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.volume_up
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.state_simple
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.volume_down
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.prev
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.next
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.name
    vis.js:3543 Create inner vis object heos.0.sources.1028.6.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.6.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.7.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.7.image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.2.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.2.image_url
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_artist
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_image_color_background
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_source_image_url
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_station
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.last_error
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.error
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_title
    vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_image_url
    vis.js:3543 Create inner vis object heos.0.sources.1028.3.play
    vis.js:3543 Create inner vis object heos.0.sources.1028.3.image_url
    vis.js:3543 Create inner vis object 0_userdata.0.heos.browse_result_html
    vis.js:3543 Create inner vis object 0_userdata.0.heos.queue_html
    vis.js:3543 Create inner vis object lupusec.0.status.apple_home_a1
    vis.js:3543 Create inner vis object 0_userdata.0.Tor.varTargetDoorState
    vis.js:3543 Create inner vis object 0_userdata.0.Tor.Torstatus
    vis.js:3543 Create inner vis object 0_userdata.0.Nuki.Tuerstatus
    vis.js:3543 Create inner vis object nuki-extended.0.smartlocks.haustür.state.batteryCritical
    vis.js:3543 Create inner vis object 0_userdata.0.Nuki.Garagentuer_Status
    vis.js:3543 Create inner vis object nuki-extended.0.smartlocks.garage.state.batteryCritical
    vis.js:3543 Create inner vis object trashschedule.0.type.json
    vis.js:3543 Create inner vis object lupusec.0.devices.NK:2c005dec.nuki_action
    vis.js:3543 Create inner vis object lupusec.0.devices.NK:1d5d05f5.nuki_action
    vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Außenmodul.Temperature.Temperature
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.symbol_desc
    vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Außenmodul.Humidity.Humidity
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.tempmin_value
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.tempmax_value
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.windgusts_value
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.wind_dir
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.iconURL
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.symbol_desc
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.tempmin_value
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.tempmax_value
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.iconURL
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.symbol_desc
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.tempmin_value
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.tempmax_value
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.iconURL
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.symbol_desc
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.tempmin_value
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.tempmax_value
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.iconURL
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.symbol_desc
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.tempmin_value
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.tempmax_value
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.iconURL
    vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Keller-Innenstation.Temperature.Temperature
    vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.symbol_value
    vis.js:2597 Error in eval[script]: var pid = "";return pidToRgbColor(pid);
    hqwidgets.js:907 Version vis-hqwidgets: 1.2.0
    7Refused to display '<URL>' in a frame because it set 'X-Frame-Options' to 'deny'.
    undefined:1          Failed to load resource: the server responded with a status of 404 (Not Found)
    (index):6775 crbug/1173575, non-JS module files deprecated.
    (anonymous) @ (index):6775
    iconFont.min.css:1          Failed to load resource: the server responded with a status of 404 (Not Found)
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    @kimukao sagte in Grafana / InfluxDB / VIS:
    at <anonymous>:2:1
    at vis.js:2062:34
    at conn.js:580:25
    an 2062 in vis scheint er die views laden zu wollen.
    dann stelle mal so wie oben schon mal erwähnt auf ws um
    in den einstellungen zum web adapter, reine websockets verwenden ankreuzen
    Meine Adapter und Widgets
    Links im Profil
    • OliverIOO OliverIO
      at <anonymous>:2:1
      at vis.js:2062:34
      at conn.js:580:25
      kimukao
      @oliverio said in Grafana / InfluxDB / VIS:
      Hab das so eingestellt, funktioniert aber leider nicht.
      • K kimukao
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @kimukao
        zur sicherheit seite broser cache leeren
        und seite komplett neu laden (nicht nur relaod)
        am besten browser schließen und dann wieder öffnen
        Links im Profil
          @kimukao
          kimukao
          Danke. Hab ich grade ein paar Mal gemacht. Hilft leider auch nicht. Es ist echt zum Mäusemelken.
          T OliverIOO 2 Antworten Letzte Antwort
          • K kimukao
            TT-Tom
            @kimukao
            Lege doch mal in der Vis ein Neues Projekt an mit einem view und iFrame. Zum Testen
            Gruß Tom
            Public Transport
            NSPanel Adapter Wiki
            • K kimukao
                  at <anonymous>:2:1
                  at vis.js:2062:34
                  at conn.js:580:25
              GlasfaserG Offline
              GlasfaserG Offline
              Das wundert mich , hast du nicht mal zum testen Firefox
              • GlasfaserG Glasfaser
                kimukao
                @glasfaser said in Grafana / InfluxDB / VIS:
                Da sieht es so aus:
                • K kimukao
                  Da sieht es so aus:
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  Da sieht es so aus:
                  Na dann ist die grafana.ini nicht korrekt konfiguriert
                  Lehrling seit 1975 !!!
                  • DJMarc75D DJMarc75
                    Da sieht es so aus:
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @djmarc75 sagte in Grafana / InfluxDB / VIS:
                    Das frage ich ja schon die Ganze Zeit !
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      @glasfaser sagte in Grafana / InfluxDB / VIS:
                      Habs gelesen und jetzt wundert mich nix mehr.
                        kimukao
                        @djmarc75 said in Grafana / InfluxDB / VIS:
                        Hab da aber eigentlich nichts geändert. Hast Du denn einen Tipp was ich machen kann?
                        • K kimukao
                          GlasfaserG Offline
                          GlasfaserG Offline
                          siehe im Link den Ich oben schon genannt habe !!!!!!!
                          • K kimukao
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            @kimukao
                            evtl tut es zum aktuellen problem nix zu sache, aber dir scheinen noch ein paar skript funktionen zu fehlen.
                            daher schlagen die ein oder anderen bindings fehl
                            pidToRgbColor
                            dann zu dem schon angemerkten fehler
                            hast du grafana neu aufgesetzt? damit diagramme in iframes angezeigt werden dürfen, muss man in grafana noch was umkonfigurieren. wurde hier im forum auch schon mehrfach behandelt
                            und ein adapter fehlt dir wohl noch in dem die folgende datei enthalten ist
                            metro-bootstrap.css
                            Links im Profil
                              @kimukao
                              pidToRgbColor
                              metro-bootstrap.css
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @oliverio sagte in Grafana / InfluxDB / VIS:
                              Die Frage habe ich oben auch schon gestellt :)
                              • DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                na klar, die grafana.ini anpassen 😀
                                sudo nano /etc/grafana/grafana.ini
                                und dann folgendes quasi aktivieren (so solls dann aussehen)
                                [security]
                                allow_embedding = true
                                [auth.anonymous]
                                enabled = true
                                org_name = Main Org.
                                org_role = Viewer
                                [users]
                                allow_sign_up = false
                                musst halt viel scrollen und dann natürlich abspeichern und den grafana-dienst neu starten
                                  [security]
                                  [auth.anonymous]
                                  enabled = true
                                  org_role = Viewer
                                  [users]
                                  kimukao
                                  [security]
                                  [auth.anonymous]
                                  enabled = true
                                  org_role = Viewer
                                  [users]
                                  Mega. Danke. Hab alle Änderungen vorgenommen und ini Datei gespeichert. Tatsächlich entsprach das wohl alles nicht mehr der ursprünglichen Konfiguration. Warum kann ich mir nicht erklären. Habe Grafana nicht neu aufgesetzt. Wenn ich versuche, Grafana mit dem Befehl
                                  sudo service grafana-server restart
                                  neu zu starten kommt
                                  Failed to restart grafana-server.service: Unit grafana-server.service failed to load properly: Device or resource busy.
                                  See system logs and 'systemctl status grafana-server.service' for details.
                                  In der VIS werden die Diagramme auch noch nicht angezeigt (trotz Cache leeren).
                                  DJMarc75D crunchipC 2 Antworten Letzte Antwort
                                  • K kimukao
                                    [security]
                                    [auth.anonymous]
                                    enabled = true
                                    org_role = Viewer
                                    [users]
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    zeigt was?
                                    • K kimukao
                                      wo ist denn Grafana installiert , hast du die Grafana Config der Externen Freigabe verändert !?
                                      nicht, dass ich wüsste.. Grafana läuft auf demselben pi, auf dem auch iobroker läuft
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @kimukao
                                      Ich erinnere an ;)
                                        zeigt was?
                                        kimukao
                                        zeigt was?
                                        ● grafana-server.service - Grafana instance
                                             Loaded: error (Reason: Unit grafana-server.service failed to load properly: Device >
                                             Active: active (running) since Fri 2022-07-01 15:45:07 CEST; 5h 7min ago
                                               Docs: http://docs.grafana.org
                                           Main PID: 17903 (grafana-server)
                                                CPU: 21.510s
                                             CGroup: /system.slice/grafana-server.service
                                                     └─17903 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfil>
                                        Jul 01 20:48:36 raspberrypi grafana-server[17903]: t=2022-07-01T20:48:36+0200 lvl=info m>
                                        Jul 01 20:48:48 raspberrypi grafana-server[17903]: t=2022-07-01T20:48:48+0200 lvl=info m>
                                        Jul 01 20:49:25 raspberrypi grafana-server[17903]: t=2022-07-01T20:49:25+0200 lvl=info m>
                                        Jul 01 20:49:37 raspberrypi grafana-server[17903]: t=2022-07-01T20:49:37+0200 lvl=info m>
                                        Jul 01 20:50:15 raspberrypi grafana-server[17903]: t=2022-07-01T20:50:15+0200 lvl=info m>
                                        Jul 01 20:50:26 raspberrypi grafana-server[17903]: t=2022-07-01T20:50:26+0200 lvl=info m>
                                        Jul 01 20:51:04 raspberrypi grafana-server[17903]: t=2022-07-01T20:51:04+0200 lvl=info m>
                                        Jul 01 20:51:16 raspberrypi grafana-server[17903]: t=2022-07-01T20:51:16+0200 lvl=info m>
                                        Jul 01 20:51:53 raspberrypi grafana-server[17903]: t=2022-07-01T20:51:53+0200 lvl=info m>
                                        Jul 01 20:52:05 raspberrypi grafana-server[17903]: t=2022-07-01T20:52:05+0200 lvl=info m>
                                        lines 1-19/19 (END)
                                        • K kimukao
                                          zeigt was?
                                                  CPU: 21.510s
                                          lines 1-19/19 (END)
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          @kimukao hmpf.
                                          Hast Du Dein System schonmal rebootet?
