  3. Off Topic
  4. Grafana
  5. Grafana / InfluxDB / VIS
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 8 Kommentatoren 11.6k Aufrufe 6 Beobachtet
  • GlasfaserG Glasfaser
    @kimukao
    Ausgabe von :
    iobroker update -i
    uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    kimukao
    @glasfaser said in Grafana / InfluxDB / VIS:
    iobroker update -i sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
    Adapter    "heos"         : 1.10.0   , installed 1.10.0
    Adapter    "history"      : 1.11.1   , installed 1.11.1
    Adapter    "ical"         : 1.12.1   , installed 1.12.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "km200"        : 2.0.3    , installed 2.0.3
    Adapter    "lupusec"      : 1.3.6    , installed 1.3.6
    Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
    Adapter    "nuki-extended": 2.3.1    , installed 2.4.0
    Adapter    "onvif"        : 0.4.4    , installed 0.4.4
    Adapter    "parcel"       : 0.0.15   , installed 0.0.15
    Adapter    "pushover"     : 2.1.0    , installed 2.1.0
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "sonos"        : 2.1.7    , installed 2.1.7
    Adapter    "sony-bravia"  : 1.0.3    , installed 1.0.3
    Adapter    "synology"     : 2.1.7    , installed 2.1.7
    Adapter    "telegram"     : 1.13.0   , installed 1.13.0
    Adapter    "text2command" : 2.2.1    , installed 2.2.1
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "trashschedule": 2.0.2    , installed 2.0.2
    Adapter    "uv-protect"   : 0.3.5    , installed 0.3.5
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "vw-connect"   : 0.0.50   , installed 0.0.50
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.15.1
    v16.15.1
    8.11.0
    pi
    /home/pi
    OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    OK:4 https://packages.grafana.com/oss/deb stable InRelease
    OK:5 https://phoscon.de/apt/deconz bullseye InRelease
    OK:6 https://repos.influxdata.com/debian bullseye InRelease
    Alle Pakete sind aktuell.
    nodejs:
      Installiert:           16.15.1-deb-1nodesource1
      Installationskandidat: 16.15.1-deb-1nodesource1
      Versionstabelle:
     *** 16.15.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u1 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages```
    • K kimukao
      Liebe Alle, gestern musste ich meinen pi neu booten, jetzt zeigt mir die VIS meine Grafana Diagramme nicht mehr an. Woran kann das liegen? Über die IP Adresse meines pi samt Port 3000 komme ich per Browser drauf, d.h. doch Grafana funktioniert?! Danke!
      GlasfaserG Offline
      GlasfaserG Offline
      @kimukao sagte in Grafana / InfluxDB / VIS:
      Nach dem Update auf :
      Node js :
      16.15.1
      8.11.0
      • K kimukao
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @kimukao
        evtl fehlermeldungen des browser wären auch hilfreich.
        diese können in der developer console (bspw bei chrome/edge mit F12) im Reiter Konsole/Console angeschaut werden. Am besten das auch per Copy/Paste hier im Forum in Code-Tags (Knopf </> oben) einfügen.
        Meine Adapter und Widgets
        Links im Profil
        GlasfaserG K 2 Antworten Letzte Antwort
        • OliverIOO OliverIO
          @kimukao
          GlasfaserG Offline
          GlasfaserG Offline
          @oliverio
          Was merkwürdig ist , das hier viele nach dem Update auf Nodejs 16 , Probleme mit VIS haben.
          Die Teillösung ist auf ws umstellen
          Beispiel :
          https://forum.iobroker.net/topic/55874/gelöst-vis-kann-nicht-geändert-werden-verbindungsfehler/85
            Node js :
            16.15.1
            8.11.0
            kimukao
            @glasfaser Ich wollte meine SD Karte durch eine SSD ersetzen. Hab vorher, wie in einem YT Video von haus-automatisierung.com bschrieben, mein System auf Stand gebracht, die SSD mittels balenaEtcher geflasht und den pi dann ordnungsgemäß heruntergefahren. Boot von USB klappte leider nicht, obwohl die Option im System des pi angehakt ist. In der FB Gruppe bekam ich den Hinweis, dass es wahrscheinlich eine Inkompatibilität der SSD ist. Also habe ich wieder von SD gebootet. Seither werden die Diagramme nicht mehr dargestellt.
            • K kimukao
              GlasfaserG Offline
              GlasfaserG Offline
              @kimukao
              Kannst du mal das testen mit WS ... siehe über deinen Beitrag
                @kimukao
                kimukao
                @glasfaser Hab den ws Adapter grade mal installiert, er springt aber nicht auf grün. Kann das also noch nicht nutzen oder auswählen. Probiere mal ein bisschen damit rum.
                  @oliverio
                  Beispiel :
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @glasfaser
                  aber er fragt doch mittels iframe grafana ab.
                  da hat ws, ausser die bereitstellung der view nicht viel zu tun.
                  wenn da was nicht funktioniert, dann würde die view überhaupt nicht tun
                  Links im Profil
                    @kimukao
                    kimukao
                    @glasfaser Sorry, im Beitrag stand ja auch, dass Socket ausgeschaltet werden muss wegen der simultanen Verwendung von Port 8084. Hab ich jetzt gemacht, WS ist grün, im Web.0 ausgewählt, Diagramme trotzdem Fehlanzeige...
                      @kimukao
                      kimukao
                      @oliverio Danke. In Safari finde ich das leider nicht. Probiere es später mal in anderen Browsern.
                        @glasfaser
                        kimukao
                        @oliverio Hab mir das grade mal in Chrome angeschaut. Da wird u.a. folgender Platzhalter angezeigt (das Menu habe ich nicht gescreenshottet):
                        Und nach Druck von F12 kommen diese Meldungen:
                        Failed to load resource: the server responded with a status of 404 (Not Found)
                        metro-bootstrap.css:1          Failed to load resource: the server responded with a status of 404 (Not Found)
                        fritzdect.js:46 Version fritzdect: 0.0.2
                        metro.js:1          Failed to load resource: the server responded with a status of 404 (Not Found)
                        trashschedule.js:152 Version trashschedule: 2.0.2
                        vis-material-advanced.js:184 Version vis-material-advanced: 1.6.0
                        index.html:12305 Version vis-weather: 2.5.4
                        socket.io.js:66 [2022-07-01T16:01:22.029Z] Try to connect
                        conn.js:305 2022-07-01T16:01:22.040Z Connected => authenticate
                        conn.js:326 2022-07-01T16:01:22.094Z Authenticated: true
                        VM82:2 Uncaught ReferenceError: on is not defined
                            at <anonymous>:2:1
                            at Object.<anonymous> (vis.js:3693:47)
                            at vis.js:2062:34
                            at conn.js:580:25
                        vis.js:3543 Create inner vis object 0_userdata.0.VIS.Kamera
                        vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.OverviewTable
                        vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.NextExpectedLowBatt
                        vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.AllBatterysOk
                        vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.LastMessage
                        vis.js:3543 Create inner vis object 0_userdata.0.VIS.auf-zu
                        vis.js:3543 Create inner vis object 0_userdata.0.VIS.Wetter
                        vis.js:3543 Create inner vis object lupusec.0.devices.RF:04cf8c10.status_ex
                        vis.js:3543 Create inner vis object 0_userdata.0.VIS.Fenster_Switch
                        vis.js:3543 Create inner vis object lupusec.0.devices.RF:04d05810.status_ex
                        vis.js:3543 Create inner vis object lupusec.0.devices.RF:04d06e10.status_ex
                        vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bfe110.status_ex
                        vis.js:3543 Create inner vis object lupusec.0.devices.RF:04c86710.status_ex
                        vis.js:3543 Create inner vis object lupusec.0.devices.RF:04cdcb10.status_ex
                        vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bf9410.status_ex
                        vis.js:3543 Create inner vis object lupusec.0.devices.RF:04c20010.status_ex
                        vis.js:3543 Create inner vis object lupusec.0.devices.RF:04af0b10.status_ex
                        vis.js:3543 Create inner vis object lupusec.0.devices.RF:0017a210.status_ex
                        vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bb7610.status_ex
                        vis.js:3543 Create inner vis object deconz.0.Sensors.4.open
                        vis.js:3543 Create inner vis object deconz.0.Sensors.5.open
                        vis.js:3543 Create inner vis object deconz.0.Sensors.6.open
                        vis.js:3543 Create inner vis object deconz.0.Sensors.7.open
                        vis.js:3543 Create inner vis object deconz.0.Sensors.8.open
                        vis.js:3543 Create inner vis object deconz.0.Sensors.9.open
                        vis.js:3543 Create inner vis object deconz.0.Sensors.10.open
                        vis.js:3543 Create inner vis object 0_userdata.0.Tor.Torautomatik
                        vis.js:3543 Create inner vis object nuki.0.724531834.actions.rtoAction
                        vis.js:3543 Create inner vis object deconz.0.Sensors.15.open
                        vis.js:3543 Create inner vis object deconz.0.Sensors.16.open
                        vis.js:3543 Create inner vis object deconz.0.Sensors.17.open
                        vis.js:3543 Create inner vis object deconz.0.Lights.28.on
                        vis.js:3543 Create inner vis object deconz.0.Lights.9.on
                        vis.js:3543 Create inner vis object deconz.0.Lights.6.on
                        vis.js:3543 Create inner vis object deconz.0.Lights.27.on
                        vis.js:3543 Create inner vis object deconz.0.Lights.19.on
                        vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Wohnbereich.Temperature.Temperature
                        vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Wohnbereich.Humidity.Humidity
                        vis.js:3543 Create inner vis object deconz.0.Lights.2.on
                        vis.js:3543 Create inner vis object deconz.0.Lights.22.level
                        vis.js:3543 Create inner vis object deconz.0.Lights.22.on
                        vis.js:3543 Create inner vis object deconz.0.Lights.3.on
                        vis.js:3543 Create inner vis object deconz.0.Lights.41.on
                        vis.js:3543 Create inner vis object deconz.0.Lights.24.level
                        vis.js:3543 Create inner vis object deconz.0.Lights.24.on
                        vis.js:3543 Create inner vis object deconz.0.Lights.5.on
                        vis.js:3543 Create inner vis object deconz.0.Lights.14.on
                        vis.js:3543 Create inner vis object lupusec.0.devices.ZS:b11501.level
                        vis.js:3543 Create inner vis object deconz.0.Lights.54.on
                        vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.actualTemp
                        vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.waterFlow
                        vis.js:3543 Create inner vis object km200.0.heatSources.systemPressure
                        vis.js:3543 Create inner vis object km200.0.heatSources.actualSupplyTemperature
                        vis.js:3543 Create inner vis object km200.0.heatingCircuits.hc2.actualSupplyTemperature
                        vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.charge
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.connected
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.state
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_mid
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_elapsed
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_duration
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.group_leader_pid
                        vis.js:2596 Error in eval[value]: {pid:heos.0.players.-2129318115.group_leader_pid;pidToRgbColor(pid)}
                        formatBinding @ vis.js:2596
                        vis.js:2597 Error in eval[script]: var pid = "undefined";return pidToRgbColor(pid);
                        formatBinding @ vis.js:2597
                        vis.js:2598 Error in eval[error]: ReferenceError: pidToRgbColor is not defined
                        formatBinding @ vis.js:2598
                        vis.js:3543 Create inner vis object heos.0.sources.1028.4.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.4.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.5.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.5.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.8.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.8.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.9.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.9.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.10.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.10.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.11.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.11.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.12.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.12.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.13.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.13.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.14.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.14.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.15.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.15.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.16.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.16.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.1.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.1.image_url
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_audio_format
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_bitrate
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_sample_rate
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_bitdepth
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.muted
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.volume_up
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.state_simple
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.volume_down
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.prev
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.next
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.name
                        vis.js:3543 Create inner vis object heos.0.sources.1028.6.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.6.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.7.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.7.image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.2.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.2.image_url
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_artist
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_image_color_background
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_source_image_url
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_station
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.last_error
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.error
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_title
                        vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_image_url
                        vis.js:3543 Create inner vis object heos.0.sources.1028.3.play
                        vis.js:3543 Create inner vis object heos.0.sources.1028.3.image_url
                        vis.js:3543 Create inner vis object 0_userdata.0.heos.browse_result_html
                        vis.js:3543 Create inner vis object 0_userdata.0.heos.queue_html
                        vis.js:3543 Create inner vis object lupusec.0.status.apple_home_a1
                        vis.js:3543 Create inner vis object 0_userdata.0.Tor.varTargetDoorState
                        vis.js:3543 Create inner vis object 0_userdata.0.Tor.Torstatus
                        vis.js:3543 Create inner vis object 0_userdata.0.Nuki.Tuerstatus
                        vis.js:3543 Create inner vis object nuki-extended.0.smartlocks.haustür.state.batteryCritical
                        vis.js:3543 Create inner vis object 0_userdata.0.Nuki.Garagentuer_Status
                        vis.js:3543 Create inner vis object nuki-extended.0.smartlocks.garage.state.batteryCritical
                        vis.js:3543 Create inner vis object trashschedule.0.type.json
                        vis.js:3543 Create inner vis object lupusec.0.devices.NK:2c005dec.nuki_action
                        vis.js:3543 Create inner vis object lupusec.0.devices.NK:1d5d05f5.nuki_action
                        vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Außenmodul.Temperature.Temperature
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.symbol_desc
                        vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Außenmodul.Humidity.Humidity
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.tempmin_value
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.tempmax_value
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.windgusts_value
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.wind_dir
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.iconURL
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.symbol_desc
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.tempmin_value
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.tempmax_value
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.iconURL
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.symbol_desc
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.tempmin_value
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.tempmax_value
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.iconURL
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.symbol_desc
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.tempmin_value
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.tempmax_value
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.iconURL
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.symbol_desc
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.tempmin_value
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.tempmax_value
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.iconURL
                        vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Keller-Innenstation.Temperature.Temperature
                        vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.symbol_value
                        vis.js:2597 Error in eval[script]: var pid = "";return pidToRgbColor(pid);
                        hqwidgets.js:907 Version vis-hqwidgets: 1.2.0
                        7Refused to display '<URL>' in a frame because it set 'X-Frame-Options' to 'deny'.
                        undefined:1          Failed to load resource: the server responded with a status of 404 (Not Found)
                        (index):6775 crbug/1173575, non-JS module files deprecated.
                        (anonymous) @ (index):6775
                        iconFont.min.css:1          Failed to load resource: the server responded with a status of 404 (Not Found)
                        GlasfaserG OliverIOO 3 Antworten Letzte Antwort
                        • K kimukao
                          TT-Tom
                          in safari muss du in die Einstellungen und das Entwicklermenü einblenden, dann kannst du die Seitenquelltext einschalten.
                          Gruß Tom
                          Public Transport
                          NSPanel Adapter Wiki
                          • K kimukao
                                at <anonymous>:2:1
                                at vis.js:2062:34
                                at conn.js:580:25
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @kimukao
                            Du schreibst SSD neu aufgesetzt ...
                            wo ist denn Grafana installiert , hast du die Grafana Config der Externen Freigabe verändert !?
                            K GlasfaserG 3 Antworten Letzte Antwort
                              @kimukao
                              kimukao
                              @glasfaser Konnte ja von der SSD nicht booten, deshalb kam die alte SD wieder zum Einsatz. Mit der wurden die Diagramme ja vor dem Wechselversuch in der VIS dargestellt.
                                @kimukao
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @glasfaser sagte in Grafana / InfluxDB / VIS:
                                  kimukao
                                  schrieb am zuletzt editiert von kimukao
                                  nicht, dass ich wüsste.. Grafana läuft auf demselben pi, auf dem auch iobroker läuft
                                  • K kimukao
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @kimukao
                                    Nochmal:
                                    WO IST GRAFANA INSTALLIERT !?
                                      @kimukao
                                      Nochmal:
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @kimukao
                                      Nochmal:
                                      EDIT :
                                      Ja OK , du hast EDIT dazu gemacht .
                                      • K kimukao
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        bitte nachschauen , ob es sich verändert hat !
                                        https://forum.iobroker.net/topic/26211/gelöst-grafana-ini-für-embed-in-vis-bearbeiten
                                          @kimukao
                                          kimukao
                                          Wie kann ich die Config denn abfragen, um zu prüfen, ob die Rechtezuweisung stimmt? Im Browser komme ich per Direkteingabe der per iframe eingebundenen URL ja zur Diagrammansicht. Heißt das nicht, dass die Rechte vorhanden sein müssten?
