  3. Off Topic
  4. [erledigt] Updates der Adapter schlagen fehl
29 Beiträge 4 Kommentatoren 1.2k Aufrufe 3 Beobachtet
    @erl
    Dann fang von vorne an:
    uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    iobroker update -i
    Erl
    @thomas-braun said in Updates der Adapter schlagen fehl:
    pi@broker:~ $ iobroker update -i sudo ln -s /usr/bin/node /usr/bin/nodejs
    Used repository: sudo
    failed to download new sources, use cached sources
    update done
    Adapter    "admin"         : 5.3.8    , installed 4.2.2 [Updateable]
    Adapter    "backitup"      : 2.4.9    , installed 2.1.13 [Updateable]
    Adapter    "discovery"     : 3.0.3    , installed 3.0.3
    Adapter    "influxdb"      : 2.6.3    , installed 1.9.5 [Updateable]
    Adapter    "info"          : 1.9.19   , installed 1.9.19
    Adapter    "javascript"    : 5.7.0    , installed 5.1.3 [Updateable]
    Controller "js-controller" : 4.0.23   , installed 3.2.16 [Updateable]
    Adapter    "mqtt"          : 3.0.6    , installed 2.4.0 [Updateable]
    Adapter    "terminal"      : 0.2.6    , installed 0.2.6
    Adapter    "worx"          : 1.5.5    , installed 1.5.5
    Adapter    "xterm"         : 0.3.2    , installed 0.3.2
    pi@broker:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v12.22.2
    v12.22.2
    6.14.13
    pi
    /home/pi
    OK:1 http://archive.raspberrypi.org/debian buster InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:3 https://repos.influxdata.com/debian stretch InRelease
    OK:4 https://deb.nodesource.com/node_12.x buster InRelease
    OK:5 https://packages.grafana.com/oss/deb stable InRelease
    Aktualisierung für 97 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
    nodejs:
      Installiert:           12.22.2-1nodesource1
      Installationskandidat: 12.22.12-deb-1nodesource1
      Versionstabelle:
         12.22.12-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
     *** 12.22.2-1nodesource1 100
         10.24.0~dfsg-1~deb10u1 500
    Used repository: default
    hash unchanged, use cached sources
    update done
    • E Erl
      update done
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.22.2
      v12.22.2
      6.14.13
      pi
      /home/pi
      nodejs:
        Versionstabelle:
      update done
      @erl
      Das was du da eingetippt hast habe ich nicht geschrieben!
      E 1 Antwort Letzte Antwort
        @erl
        Erl
        @erl
        pi@broker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
        pi@broker:~ $ name -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /
        -bash: name: Kommando nicht gefunden.
        pi@broker:~ $ name -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        update done
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v12.22.2
        v12.22.2
        6.14.13
        pi
        /home/pi
        nodejs:
          Versionstabelle:
        update done
        pi@broker:~ $
        Ich dachte jede Zeile sei ein Befehl...habe dann alle 3 Zeilen komplett abgeschickt
        • E Erl
          @erl
          update done
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v12.22.2
          v12.22.2
          6.14.13
          pi
          /home/pi
          nodejs:
            Versionstabelle:
          update done
          pi@broker:~ $
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @erl stretch und buster verquirrlt... node auch falsch... 97 Pakete verfügbar, WOHOOOO....
          Lehrling seit 1975 !!!
          • DJMarc75D DJMarc75
            Erl
            @djmarc75 said in Updates der Adapter schlagen fehl:
            Danke für die Info.
            Ja ich habe lange keine updates gefahren, aber warum Stretch und bester "verquirlt" sind Weißich nicht. ich habe das System nur einmal aufgesetzt und dann ioBroker benutzt. das war alles stressfrei...
            • E Erl
              Danke für die Info.
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @erl sagte in Updates der Adapter schlagen fehl:
              ich auch nicht 😬 aber da hast Du iwann mal was verbogen... seis drum... musst halt korrigieren😳
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @djmarc75 node ist auch krumm (alt)
                  Erl
                  Wie kann ich das fixen "node" und "influxdata"?
                  Bzw.: Kann ich das fixen?
                  DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                  • E Erl
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    influxdata
                    Das vergiss mal hier bitte in diesem Thread... hat hier nix zu suchen (wenn dann eigenen influx Thread aufmachen - offtopic)
                    Um dein System zu korrigieren gibts bei @thomas-braun in der Signatur perfekte Anleitungen.
                      ich hatte diesen schon in OffTopic geschoben, weil es zuerst nur ims Passwort für SSH ging.
                      und zwar sehr lange. Inzwischen gibt es Bei Updates Versionen, die nur noch unter einem höheren Node und höheren Controller laufen.
                      ich an deiner Stelle würde eine neue Karte nehmen, neu installieren und Backup einspielen.
                      dann hast du dein altes System noch als Hardware backup auf der alten Karte
                      • E Erl
                        Ja, kann man alles fixen. Die Frage ist eher, lohnt es sich nicht hier einen Schnitt zu machen und einen frischen 'Bullseye' (64bit - Lite) neuaufzusetzen. Der 'Buster' wird in wenigen Wochen ohnehin sein End-of-Life erreichen.
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @thomas-braun sagte in Updates der Adapter schlagen fehl:
                          'Buster'
                          da ist sogar noch STRETCH im Einsatz ....
                            'Buster'
                            @djmarc75 sagte in Updates der Adapter schlagen fehl:
                            Nein, da ist nur die .list-Datei für Grafana falsch.
                            Die hätte auf buster eingestellt sein müssen.
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              Wenn Profis online sind, dann leg ich meine Brille lieber weg 😁 😂 👍
