  4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
    6.8k
errormeldungnodejs 16.15.1
169 Beiträge 15 Kommentatoren 37.7k Aufrufe 12 Beobachtet
    @taba_luga sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
    und hier npm audit und npm audit --force
    wieso machst du so etwas?
    taba_luga
    #74
    @homoran wie ich oben schon schrieb, ich bin leider kein Linux Profi. Hab ich das etwas getan, was ich nicht hätte machen sollen? :man-facepalming:
    • T taba_luga
      xx@iobroker-prod:~$ npm install iobroker.js-controller
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      added 309 packages, and audited 310 packages in 1m
      18 packages are looking for funding
        run `npm fund` for details
      4 vulnerabilities (3 moderate, 1 high)
      To address all issues, run:
        npm audit fix
      Run `npm audit` for details.
      xx@iobroker-prod:~$
      xx@iobroker-prod:~$ npm audit
      # npm audit report
      node-forge  <=1.2.1
      Severity: high
      Open Redirect in node-forge - https://github.com/advisories/GHSA-8fr3-hfg3-gpgp
      Prototype Pollution in node-forge debug API. - https://github.com/advisories/GHSA-5rrq-pxf6-6jx5
      Prototype Pollution in node-forge util.setPath API - https://github.com/advisories/GHSA-wxgw-qj99-44c2
      URL parsing in node-forge could lead to undesired behavior. - https://github.com/advisories/GHSA-gf8q-jrpm-jvxq
      Prototype Pollution in node-forge - https://github.com/advisories/GHSA-92xj-mqp7-vmcj
      Improper Verification of Cryptographic Signature in `node-forge` - https://github.com/advisories/GHSA-2r2c-g63r-vccr
      Improper Verification of Cryptographic Signature in node-forge - https://github.com/advisories/GHSA-x4jg-mjrx-434g
      Improper Verification of Cryptographic Signature in node-forge - https://github.com/advisories/GHSA-cfm4-qjh2-4765
      fix available via `npm audit fix --force`
      Will install iobroker.js-controller@1.5.3, which is a breaking change
      node_modules/rsa-compat/node_modules/node-forge
        rsa-compat  <=1.9.4
        Depends on vulnerable versions of node-forge
          le-acme-core  *
          Depends on vulnerable versions of rsa-compat
          node_modules/le-acme-core
            iobroker.js-controller  >=1.5.4
            Depends on vulnerable versions of le-acme-core
            node_modules/iobroker.js-controller
      To address all issues (including breaking changes), run:
      xx@iobroker-prod:~$ npm audit fix --force
      npm WARN using --force Recommended protections disabled.
      npm WARN audit Updating iobroker.js-controller to 1.5.3,which is a SemVer major change.
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
      added 173 packages, removed 145 packages, changed 48 packages, and audited 334 packages in 51s
      13 packages are looking for funding
      # npm audit report
      debug  <2.6.9
      Regular Expression Denial of Service in debug - https://github.com/advisories/GHSA-gxpj-cx7g-858c
      Will install iobroker.js-controller@4.0.23, which is a breaking change
      node_modules/engine.io-client/node_modules/debug
      node_modules/engine.io/node_modules/debug
      node_modules/socket.io-adapter/node_modules/debug
      node_modules/socket.io-client/node_modules/debug
      node_modules/socket.io-parser/node_modules/debug
      node_modules/socket.io/node_modules/debug
        engine.io  <=4.0.0-alpha.1
        Depends on vulnerable versions of debug
        Depends on vulnerable versions of ws
          socket.io  <=2.4.1
          Depends on vulnerable versions of engine.io
          Depends on vulnerable versions of socket.io-adapter
          Depends on vulnerable versions of socket.io-client
          Depends on vulnerable versions of socket.io-parser
            iobroker.js-controller  <=2.1.1
            Depends on vulnerable versions of redis
            Depends on vulnerable versions of winston-daily-rotate-file
            Depends on vulnerable versions of yargs
        engine.io-client  <=3.3.2 || 3.4.0 - 3.5.1 || 4.0.0-alpha.0 - 4.1.3
        Depends on vulnerable versions of parsejson
        Depends on vulnerable versions of xmlhttprequest-ssl
          socket.io-client  1.0.0-pre - 2.1.1 || 2.3.0 - 2.3.1 || 3.0.0-rc1 - 3.0.5
          Depends on vulnerable versions of engine.io-client
        socket.io-adapter  <=1.1.0
        socket.io-parser  <=3.3.1
      minimist  <=1.2.5
      Severity: critical
      Prototype Pollution in minimist - https://github.com/advisories/GHSA-xvch-5gv4-984h
      Prototype Pollution in minimist - https://github.com/advisories/GHSA-vh95-rmgr-6w4m
      node_modules/winston-daily-rotate-file/node_modules/minimist
        mkdirp  0.4.1 - 0.5.1
        Depends on vulnerable versions of minimist
        node_modules/winston-daily-rotate-file/node_modules/mkdirp
          winston-daily-rotate-file  1.7.0 - 1.7.2
          Depends on vulnerable versions of mkdirp
      parsejson  *
      Severity: high
      Regular Expression Denial of Service in parsejson - https://github.com/advisories/GHSA-q75g-2496-mxpp
      node_modules/parsejson
      redis  2.6.0 - 3.1.0
      Severity: high
      Potential exponential regex in monitor mode - https://github.com/advisories/GHSA-35q2-47q7-3pc3
      node_modules/redis
      ws  <=1.1.4
      Severity: high
      Denial of Service in ws - https://github.com/advisories/GHSA-5v72-xg48-5rpm
      node_modules/engine.io-client/node_modules/ws
      node_modules/engine.io/node_modules/ws
      xmlhttprequest-ssl  <=1.6.1
      Severity: critical
      Improper Certificate Validation in xmlhttprequest-ssl - https://github.com/advisories/GHSA-72mh-269x-7mh5
      Arbitrary Code Injection - https://github.com/advisories/GHSA-h4j5-c7cj-74xg
      node_modules/xmlhttprequest-ssl
      yargs-parser  6.0.0 - 13.1.1
      Severity: moderate
      Prototype Pollution in yargs-parser - https://github.com/advisories/GHSA-p9pc-299p-vxgp
      node_modules/yargs-parser
        yargs  8.0.0-candidate.0 - 12.0.5
        Depends on vulnerable versions of yargs-parser
        node_modules/yargs
      17 vulnerabilities (1 low, 4 moderate, 8 high, 4 critical)
      To address issues that do not require attention, run:
        npm audit fix
      xx@iobroker-prod:~$
      Das hat leider zu keiner Verbesserung geführt
      #75
      @taba_luga hoffe das npm install war im richtigen ordner (/opt/iobroker) und ja audit fix lassen
      • T taba_luga
          npm audit fix
        xx@iobroker-prod:~$
        # npm audit report
        node-forge  <=1.2.1
        Severity: high
          rsa-compat  <=1.9.4
            le-acme-core  *
        # npm audit report
        debug  <2.6.9
            socket.io  <=2.4.1
        minimist  <=1.2.5
        Severity: critical
        parsejson  *
        Severity: high
        redis  2.6.0 - 3.1.0
        Severity: high
        node_modules/redis
        ws  <=1.1.4
        Severity: high
        Severity: critical
        Severity: moderate
          node_modules/yargs
          npm audit fix
        xx@iobroker-prod:~$
        #76
        Falsches Verzeichnis:
        Naja, jetzt hast du es doppelt 'installiert'...
        Mach es so:
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        • apollon77A apollon77
          taba_luga
          schrieb am zuletzt editiert von taba_luga
          #77
          @apollon77 ich befürchte nicht... Ich hatte vorher nicht das Verzeichnis gewechselt. Habe ich mir jetzt restlos alles zerschossen? Dann würde ich meinen Snapshot wieder hervor holen und bis zu diesem Punkt erst mal alles wiederholen.
          [edit] der Post von @Thomas-Braun hat sich mit meiner Antwort hier überschnitten.
          apollon77A Thomas BraunT 2 Antworten Letzte Antwort
          • T taba_luga
            #78
            @taba_luga In welchem verzeichnis haste es denn ausgeführt? WEnn in deinem User verzeichnis dann liegt da jetzt nur ein node_modules mit Zeug drin ... löschen und ende
            • T taba_luga
              #79
              Nein, du hast nur den js-controller im /home-Verzeichnis des users xx versenkt.
              Aber da den den ja auch dort auditiert und gefixt hast...
              ...lösch das dort.
              Die Hauptinstallation immer noch defekt.
                Mach es so:
                cd /opt/iobroker
                taba_luga
                #80
                jetzt geht der Spaß mit den Ordnern wieder los...
                xx@iobroker-prod:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                npm ERR! code ENOTEMPTY
                npm ERR! syscall rename
                npm ERR! path /opt/iobroker/node_modules/alexa-cookie2
                npm ERR! dest /opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/alexa-cookie2' -> '/opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw'
                npm ERR!     /home/iobroker/.npm/_logs/2022-06-24T11_45_06_568Z-debug-0.log
                Die benenne ich dann erst mal wieder um und melde mich dann wieder bei euch. Vielen DANK schon mal zwischendurch für euren super Support!!!
                • N Offline
                  N Offline
                  nhbischo
                  #81
                  Moin !
                  Leider habe auch ich ein kleines Problem. Update nach
                  https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition
                  Danach den berühmten Error 25 bei der Installation von Adaptern. Es geht weder ein Update noch eine Neuinstallation eines Adapters. Nun also hier die Meldung im Forum, da ich nun auch nicht mehr ohne Hilfe weiter komme.
                  Nach dem Durchlesen hier habe ich mal einige Snapshots gemacht und diese stelle ich hier mit ein. Da der Fehler in der Regel beim User sitzt .............. Es ist ja leider meist so.
                  Wer mir da helfen kann ......... VG Mathias
                  • N nhbischo
                    Moin !
                    #82
                    @nhbischo sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                    keine Screenshots von Text!
                    Diesen als Text in code-tags posten
                    • N nhbischo
                      Moin !
                      #83
                      @nhbischo
                      Keine krümeligen Screenshots aus der Konsole.
                      Als Text in CodeTags eingebettet hier rein.
                      • N Offline
                        N Offline
                        nhbischo
                        #84
                        pi@raspberrypi:/opt/iobroker $ iobroker upgrade smartgarden --debug
                        This upgrade of "smartgarden" will introduce the following changes:
                        -> 2.0.0:
                        support for new login procedure to Gardena webservice; admin5 is necessary
                        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING C        HANGES!
                        Would you like to upgrade smartgarden from @1.0.6 to @2.0.0 now? [(y)es, (n)o]:        y
                        Update smartgarden from @1.0.6 to @2.0.0
                        NPM version: 8.11.0
                        Installing iobroker.smartgarden@2.0.0... (System call)
                        npm WARN old lockfile
                        npm WARN old lockfile The package-lock.json file was created with an old version        of npm,
                        npm WARN old lockfile so supplemental metadata must be fetched from the registry        .
                        npm WARN old lockfile This is a one-time fix-up, please be patient...
                        npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT        +z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying again.
                        npm WARN old lockfile Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wan        ted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4        gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
                        npm WARN old lockfile     at IntegrityStream.[_onEnd] (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:118:19)
                        npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:88:19)
                        npm WARN old lockfile     at IntegrityStream.[maybeEmitEnd] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:370:12)
                        npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/minipass/index.js:434:29)
                        npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:90:18)
                        npm WARN old lockfile     at IntegrityStream.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:265:12)
                        npm WARN old lockfile     at IntegrityStream.resume (/usr/lib/node_modules/npm/node_modules/minipass/index.js:269:24)
                        npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/minipass-pipeline/index.js:105:19)
                        npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/pipeline.js:37:18)
                        npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10)
                        npm WARN old lockfile  Could not fetch metadata for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master Erro        r: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+        z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2D        Cg==. (64751136 bytes)
                        npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10) {
                        npm WARN old lockfile   code: 'EINTEGRITY',
                        npm WARN old lockfile   found: Integrity { sha512: [ [Hash] ] },
                        npm WARN old lockfile   expected: [
                        npm WARN old lockfile     Hash {
                        npm WARN old lockfile       source: 'sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
                        npm WARN old lockfile       digest: 'qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
                        npm WARN old lockfile       algorithm: 'sha512',
                        npm WARN old lockfile       options: []
                        npm WARN old lockfile     }
                        npm WARN old lockfile   ],
                        npm WARN old lockfile   sri: Integrity { sha512: [ [Hash] ] }
                        npm ERR! path /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
                        npm ERR! dest /opt/iobroker/node_modules/.iobroker.icons-open-icon-library-png-dWPxt8qG
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.icons-open-icon-library-png' -> '/opt/iobroker/node_modules/.iobroker.icons-open-icon-li        brary-png-dWPxt8qG'
                        npm ERR!     /home/iobroker/.npm/_logs/2022-06-26T15_08_41_333Z-debug-0.log
                        host.raspberrypi Cannot install iobroker.smartgarden@2.0.0: 217
                        pi@raspberrypi:/opt/iobroker $ npm ls canvas
                        iobroker.inst@2.0.3 /opt/iobroker
                        ├─┬ iobroker.echarts@1.0.10 extraneous
                        │ ├── canvas@2.9.1
                        │ └─┬ jsdom@19.0.0
                        │   └── canvas@2.9.1 deduped
                        ├─┬ iobroker.iot@1.11.7
                        └─┬ iobroker.mihome-vacuum@3.4.1
                        pi@raspberrypi:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt        policy nodejs
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.15.1
                        v16.15.1
                        8.11.0
                        pi
                        /opt/iobroker
                        OK:1 http://archive.raspberrypi.org/debian buster InRelease
                        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        OK:3 http://phoscon.de/apt/deconz buster InRelease
                        OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                        OK:5 https://www.pivccu.de/piVCCU stable InRelease
                        Alle Pakete sind aktuell.
                        nodejs:
                          Installiert:           16.15.1-deb-1nodesource1
                          Installationskandidat: 16.15.1-deb-1nodesource1
                          Versionstabelle:
                         *** 16.15.1-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                             10.24.0~dfsg-1~deb10u1 500
                        pi@raspberrypi:/opt/iobroker $ iobroker status
                        Objects type: jsonl
                        States  type: jsonl
                        pi@raspberrypi:/opt/iobroker $ iobroker list instances
                        + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
                          system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
                          system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
                          system.adapter.calendar.0               : calendar              : raspberrypi                              - disabled, port: 8095
                        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                        + system.adapter.contact.0                : contact               : raspberrypi                              -  enabled, port: 8096
                          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                          system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                          system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                        + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                        + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
                        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
                          system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                        + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                          system.adapter.gardena.0                : gardena               : raspberrypi                              - disabled
                          system.adapter.habpanel.0               : habpanel              : raspberrypi                              - disabled
                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                        + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                          system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                          system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
                          system.adapter.ical.3                   : ical                  : raspberrypi                              -  enabled
                          system.adapter.ical.4                   : ical                  : raspberrypi                              -  enabled
                          system.adapter.ical.5                   : ical                  : raspberrypi                              -  enabled
                          system.adapter.ical.6                   : ical                  : raspberrypi                              -  enabled
                          system.adapter.ical.7                   : ical                  : raspberrypi                              -  enabled
                          system.adapter.ical.8                   : ical                  : raspberrypi                              -  enabled
                          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
                          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                          system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
                        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                        + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
                          system.adapter.lovelace.0               : lovelace              : raspberrypi                              - disabled, port: 8091, bind: 192.168.178.147, run as: admin
                          system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
                          system.adapter.meteoalarm.0             : meteoalarm            : raspberrypi                              - disabled
                        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                          system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 192.168.178.145
                        + system.adapter.milight.0                : milight               : raspberrypi                              -  enabled, port: 8899
                          system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
                        + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                          system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                          system.adapter.parser.0                 : parser                : raspberrypi                              - disabled
                        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
                          system.adapter.radar2.0                 : radar2                : raspberrypi                              - disabled
                        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                          system.adapter.samsung.0                : samsung               : raspberrypi                              - disabled
                          system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi                              - disabled, port: 8002
                          system.adapter.samsung_tizen.1          : samsung_tizen         : raspberrypi                              - disabled, port: 8002
                        + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
                          system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                          system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
                          system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
                        + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
                        + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
                          system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 192.168.178.147
                        + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
                          system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5000
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                          system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
                        + system.adapter.tvprogram.0              : tvprogram             : raspberrypi                              -  enabled
                          system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                        + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                          system.adapter.uv-protect.0             : uv-protect            : raspberrypi                              -  enabled
                          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                          system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                          system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                          system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              - disabled
                          system.adapter.vis-material.0           : vis-material          : raspberrypi                              - disabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                          system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                        + system.adapter.withings.0               : withings              : raspberrypi                              -  enabled
                        + system.adapter.yamaha.0                 : yamaha                : raspberrypi                              -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                        • N Offline
                          N Offline
                          nhbischo
                          #85
                          Sorry. Hoffe nun in Ordnung
                          • N nhbischo
                            #86
                            @nhbischo
                            Mach das doch.
                            • N nhbischo
                              -> 2.0.0:
                              NPM version: 8.11.0
                              npm ERR! errno -39
                              │ ├── canvas@2.9.1
                              │ └─┬ jsdom@19.0.0
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.15.1
                              v16.15.1
                              8.11.0
                              pi
                              /opt/iobroker
                              nodejs:
                                Versionstabelle:
                              Objects type: jsonl
                              States  type: jsonl
                              #87
                              N 1 Antwort Letzte Antwort
                              • N Offline
                                N Offline
                                nhbischo
                                #88
                                @thomas-braun sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                                Unknown regexp modifier "/b" at (user-supplied code), at end of line
                                Unknown regexp modifier "/r" at (user-supplied code), at end of line
                                Unknown regexp modifier "/k" at (user-supplied code), at end of line
                                Unknown regexp modifier "/e" at (user-supplied code), at end of line
                                • N nhbischo
                                  #89
                                  @nhbischo
                                  Was machst du da?
                                    N Offline
                                    N Offline
                                    nhbischo
                                    #90
                                    Ich hatte wie hier ja schon beschrieben wurde in /opt/iobroker die Datei 'package-lock.json' auch schon umbenannt und gespeíchert. Dann den Updateprozess neu angestossen. Dort erschien der gleiche Fehler wieder. In der Vorgehensweise etwas falsch gewesen ?
                                    VG Mathias
                                    Thomas BraunT N 2 Antworten Letzte Antwort
                                      @nhbischo
                                      Was machst du da?
                                      N Offline
                                      N Offline
                                      nhbischo
                                      #91
                                      Erst rename installiert. War nicht installiert. Dann das Kommando aufgerufen.
                                      • N nhbischo
                                        VG Mathias
                                        #92
                                        @nhbischo
                                        Verzeichnis umbenennen:
                                        sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png /opt/iobroker/node_modules/.iobroker.icons-open-icon-library-png-dWPxt8qG
                                        • N Offline
                                          N Offline
                                          nhbischo
                                          #93
                                          sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png /opt/iobroker/node_modules/.iobroker.icons-open-icon-li brary-png-dWPxt8qG
                                          pi@raspberrypi:/opt/iobroker $ sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png /opt/iobroker/node_modules/.iobroker.icons-open-icon-li brary-png-dWPxt8qG
                                          mv: das angegebene Ziel 'brary-png-dWPxt8qG' ist kein Verzeichnis
