mi home vacuum cleaner spinnt??
mein mi home vacuum adapter spinnt immer rum.
mal grün mal rot immer springt er hin und her, hat jemand rat oder noch das problem??Node.js v16.15.1
Admin 5.3.8
mihome 3.3.3
js controller 4.0.23host.raspberrypi 2022-06-11 12:53:41.791 info Restart adapter system.adapter.mihome-vacuum.0 because enabled host.raspberrypi 2022-06-11 12:53:41.790 info instance system.adapter.mihome-vacuum.0 terminated with code 0 (NO_ERROR) mihome-vacuum.0 1000 2022-06-11 12:53:41.316 info starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.15.1, js-controller: 4.0.23 host.raspberrypi 2022-06-11 12:53:35.432 info instance system.adapter.mihome-vacuum.0 started with pid 1000 host.raspberrypi 2022-06-11 12:53:05.106 info Restart adapter system.adapter.mihome-vacuum.0 because enabled host.raspberrypi 2022-06-11 12:53:05.106 info instance system.adapter.mihome-vacuum.0 terminated with code 0 (NO_ERROR) mihome-vacuum.0 26875 2022-06-11 12:53:04.928 info IOT enabled, create state mihome-vacuum.0 26875 2022-06-11 12:53:04.347 info starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.15.1, js-controller: 4.0.23 host.raspberrypi 2022-06-11 12:52:59.163 info instance system.adapter.mihome-vacuum.0 started with pid 26875 host.raspberrypi 2022-06-11 12:52:57.782 info "system.adapter.mihome-vacuum.0" enabled host.raspberrypi 2022-06-11 12:52:57.559 info stopInstance system.adapter.mihome-vacuum.0 killing pid 9310 host.raspberrypi 2022-06-11 12:52:56.451 info stopInstance system.adapter.mihome-vacuum.0 send kill signal host.raspberrypi 2022-06-11 12:52:52.668 info stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true) host.raspberrypi 2022-06-11 12:52:52.667 info "system.adapter.mihome-vacuum.0" disabled host.raspberrypi 2022-06-11 12:52:37.585 info instance system.adapter.web.0 started with pid 22278 host.raspberrypi 2022-06-11 12:52:35.164 info instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) -
Admin 5.3.8
mihome 3.3.3
@denjo sinnvoll wäre erstmal ein debug log, aber ich vermute mal, dass es an nodejs16 + raspberry liegt, bzw. Canvas. Mach mal die karte aus, ob es dann immer noch passiert.
Dein raspberry läuft wahrscheinlich auf 32 bit?@dirkhe sagte in mi home vacuum cleaner spinnt??:
Nicht grundsätzlich. Der Adapter läuft mit nodejs14 - nodejs18 einwandfrei.
@thomas-braun naja, soweit ich das gelesen habe, kann das canvas mit nodejs >= 14 unter 32 big nicht mehr direkt compiliert werden. Es jann natürlich sein, dass msn es per cross compiling hinbekommt.
Aber die meisten probleme tauchen in der tat mif dem canvas unter raspberry auf.
Ich habe mich damit nicht tiefer beschäftigt, da ich Den mihome adapter auf meinen main server betreibe, wss ein debin pc ist und 2. Ich die karte nicht nutze.
Ivh sehe halt nur fie isues auf github -
Ivh sehe halt nur fie isues auf github@dirkhe sagte in mi home vacuum cleaner spinnt??:
Ah, das kann sein. Ich fahre hier auf einem 64bit-RaspberryOS herum.
