  4. mi home vacuum cleaner spinnt??
mi home vacuum
5 Beiträge 3 Kommentatoren 191 Aufrufe 3 Beobachtet
    denjo
    mein mi home vacuum adapter spinnt immer rum.
    mal grün mal rot immer springt er hin und her, hat jemand rat oder noch das problem??
    Node.js v16.15.1
    Admin 5.3.8
    mihome 3.3.3
    js controller 4.0.23
    host.raspberrypi
    2022-06-11 12:53:41.791	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
    host.raspberrypi
    2022-06-11 12:53:41.790	info	instance system.adapter.mihome-vacuum.0 terminated with code 0 (NO_ERROR)
    mihome-vacuum.0
    1000	2022-06-11 12:53:41.316	info	starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.15.1, js-controller: 4.0.23
    host.raspberrypi
    2022-06-11 12:53:35.432	info	instance system.adapter.mihome-vacuum.0 started with pid 1000
    host.raspberrypi
    2022-06-11 12:53:05.106	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
    host.raspberrypi
    2022-06-11 12:53:05.106	info	instance system.adapter.mihome-vacuum.0 terminated with code 0 (NO_ERROR)
    mihome-vacuum.0
    26875	2022-06-11 12:53:04.928	info	IOT enabled, create state
    mihome-vacuum.0
    26875	2022-06-11 12:53:04.347	info	starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.15.1, js-controller: 4.0.23
    host.raspberrypi
    2022-06-11 12:52:59.163	info	instance system.adapter.mihome-vacuum.0 started with pid 26875
    host.raspberrypi
    2022-06-11 12:52:57.782	info	"system.adapter.mihome-vacuum.0" enabled
    host.raspberrypi
    2022-06-11 12:52:57.559	info	stopInstance system.adapter.mihome-vacuum.0 killing pid 9310
    host.raspberrypi
    2022-06-11 12:52:56.451	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
    host.raspberrypi
    2022-06-11 12:52:52.668	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
    host.raspberrypi
    2022-06-11 12:52:52.667	info	"system.adapter.mihome-vacuum.0" disabled
    host.raspberrypi
    2022-06-11 12:52:37.585	info	instance system.adapter.web.0 started with pid 22278
    host.raspberrypi
    2022-06-11 12:52:35.164	info	instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    • D denjo
      Node.js v16.15.1
      Admin 5.3.8
      mihome 3.3.3
      host.raspberrypi
      host.raspberrypi
      mihome-vacuum.0
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      mihome-vacuum.0
      mihome-vacuum.0
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      D Nicht stören
      D Nicht stören
      dirkhe
      @denjo sinnvoll wäre erstmal ein debug log, aber ich vermute mal, dass es an nodejs16 + raspberry liegt, bzw. Canvas. Mach mal die karte aus, ob es dann immer noch passiert.
      Dein raspberry läuft wahrscheinlich auf 32 bit?
      • D dirkhe
        @dirkhe sagte in mi home vacuum cleaner spinnt??:
        Nicht grundsätzlich. Der Adapter läuft mit nodejs14 - nodejs18 einwandfrei.
          D Nicht stören
          D Nicht stören
          dirkhe
          @thomas-braun naja, soweit ich das gelesen habe, kann das canvas mit nodejs >= 14 unter 32 big nicht mehr direkt compiliert werden. Es jann natürlich sein, dass msn es per cross compiling hinbekommt.
          Aber die meisten probleme tauchen in der tat mif dem canvas unter raspberry auf.
          Ich habe mich damit nicht tiefer beschäftigt, da ich Den mihome adapter auf meinen main server betreibe, wss ein debin pc ist und 2. Ich die karte nicht nutze.
          Ivh sehe halt nur fie isues auf github
          • D dirkhe
            Ah, das kann sein. Ich fahre hier auf einem 64bit-RaspberryOS herum.
