<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[mi home vacuum cleaner spinnt??]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">mein mi home vacuum adapter spinnt immer rum.<br />
mal grün mal rot immer springt er hin und her, hat jemand rat oder noch das problem??</p>
<p dir="auto">Node.js v16.15.1<br />
Admin 5.3.8<br />
mihome 3.3.3<br />
js controller 4.0.23</p>
<pre><code>host.raspberrypi
2022-06-11 12:53:41.791	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
host.raspberrypi
2022-06-11 12:53:41.790	info	instance system.adapter.mihome-vacuum.0 terminated with code 0 (NO_ERROR)
mihome-vacuum.0
1000	2022-06-11 12:53:41.316	info	starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.15.1, js-controller: 4.0.23
host.raspberrypi
2022-06-11 12:53:35.432	info	instance system.adapter.mihome-vacuum.0 started with pid 1000
host.raspberrypi
2022-06-11 12:53:05.106	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
host.raspberrypi
2022-06-11 12:53:05.106	info	instance system.adapter.mihome-vacuum.0 terminated with code 0 (NO_ERROR)
mihome-vacuum.0
26875	2022-06-11 12:53:04.928	info	IOT enabled, create state
mihome-vacuum.0
26875	2022-06-11 12:53:04.347	info	starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.15.1, js-controller: 4.0.23
host.raspberrypi
2022-06-11 12:52:59.163	info	instance system.adapter.mihome-vacuum.0 started with pid 26875
host.raspberrypi
2022-06-11 12:52:57.782	info	"system.adapter.mihome-vacuum.0" enabled
host.raspberrypi
2022-06-11 12:52:57.559	info	stopInstance system.adapter.mihome-vacuum.0 killing pid 9310
host.raspberrypi
2022-06-11 12:52:56.451	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
host.raspberrypi
2022-06-11 12:52:52.668	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
host.raspberrypi
2022-06-11 12:52:52.667	info	"system.adapter.mihome-vacuum.0" disabled
host.raspberrypi
2022-06-11 12:52:37.585	info	instance system.adapter.web.0 started with pid 22278
host.raspberrypi
2022-06-11 12:52:35.164	info	instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/55568/mi-home-vacuum-cleaner-spinnt</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 03:24:58 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/55568.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Jun 2022 10:58:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to mi home vacuum cleaner spinnt?? on Mon, 13 Jun 2022 20:47:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dirkhe" aria-label="Profile: dirkhe">@<bdi>dirkhe</bdi></a> sagte in <a href="/post/814159">mi home vacuum cleaner spinnt??</a>:</p>
<blockquote>
<p dir="auto">kann das canvas mit nodejs &gt;= 14 unter 32 big nicht mehr direkt compiliert werden.</p>
</blockquote>
<p dir="auto">Ah, das kann sein. Ich fahre hier auf einem 64bit-RaspberryOS herum.</p>
]]></description><link>https://forum.iobroker.net/post/814163</link><guid isPermaLink="true">https://forum.iobroker.net/post/814163</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 13 Jun 2022 20:47:28 GMT</pubDate></item><item><title><![CDATA[Reply to mi home vacuum cleaner spinnt?? on Mon, 13 Jun 2022 20:42:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> naja, soweit ich das gelesen habe, kann das canvas mit nodejs &gt;= 14 unter 32 big nicht mehr direkt compiliert werden. Es jann natürlich sein, dass msn es per cross compiling hinbekommt.<br />
Aber die meisten probleme tauchen in der tat mif dem canvas unter raspberry auf.<br />
Ich habe mich damit nicht tiefer beschäftigt, da ich Den mihome adapter auf meinen main server betreibe, wss ein debin pc ist und 2. Ich die karte nicht nutze.<br />
Ivh sehe halt nur fie isues auf github</p>
]]></description><link>https://forum.iobroker.net/post/814159</link><guid isPermaLink="true">https://forum.iobroker.net/post/814159</guid><dc:creator><![CDATA[dirkhe]]></dc:creator><pubDate>Mon, 13 Jun 2022 20:42:08 GMT</pubDate></item><item><title><![CDATA[Reply to mi home vacuum cleaner spinnt?? on Mon, 13 Jun 2022 19:46:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dirkhe" aria-label="Profile: dirkhe">@<bdi>dirkhe</bdi></a> sagte in <a href="/post/814127">mi home vacuum cleaner spinnt??</a>:</p>
<blockquote>
<p dir="auto">dass es an nodejs16 + raspberry liegt</p>
</blockquote>
<p dir="auto">Nicht grundsätzlich. Der Adapter läuft mit nodejs14 - nodejs18 einwandfrei.</p>
]]></description><link>https://forum.iobroker.net/post/814134</link><guid isPermaLink="true">https://forum.iobroker.net/post/814134</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 13 Jun 2022 19:46:03 GMT</pubDate></item><item><title><![CDATA[Reply to mi home vacuum cleaner spinnt?? on Mon, 13 Jun 2022 19:28:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/denjo" aria-label="Profile: denjo">@<bdi>denjo</bdi></a> sinnvoll wäre erstmal ein debug log, aber ich vermute mal, dass es an nodejs16 + raspberry liegt, bzw. Canvas. Mach mal die karte aus, ob es dann immer noch passiert.<br />
Dein raspberry läuft wahrscheinlich auf 32 bit?</p>
]]></description><link>https://forum.iobroker.net/post/814127</link><guid isPermaLink="true">https://forum.iobroker.net/post/814127</guid><dc:creator><![CDATA[dirkhe]]></dc:creator><pubDate>Mon, 13 Jun 2022 19:28:01 GMT</pubDate></item></channel></rss>
