  4. Iobroker Backup läuft nicht
    6.3k
22 Beiträge 5 Kommentatoren 862 Aufrufe 3 Beobachtet
    @burns1111 sagte in Iobroker Backup läuft nicht:
    "mount":"//192.168.192.168.***.***"
    Bitte nicht die IPs aus privaten Netzwerken verunstalten. Es kann keiner diese IPs 'hacken'. Wenn die IP so drin steht ist das falsch.
    burns1111
    @thomas-braun said in Iobroker Backup läuft nicht:
    Wo hast du die IP gesehen normalerweise habe ich 192.168.178.44 für die Diskstation?
    In gleichen Subnet ist dann auch der Iobroker
    • B burns1111
      @burns1111
      [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"15","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.192.168.***.***","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/IoBroker/","dirMinimal":"Backup/IoBroker/","user":"backup","pass":"****","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["umount","mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        @burns1111
        burns1111
        das scheint durchs anpassen passiert zu sein. Hier nochmal die aktuelle Meldung:
        Started iobroker ...
        [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.44","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/IoBroker/","dirMinimal":"Backup/IoBroker/","user":"backup","pass":"****","ignoreErrors":false}
        [DEBUG] [mount] - noserverino option: false
        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.44/Backup/IoBroker/ /opt/iobroker/backups"
        [DEBUG] [mount] - mount successfully completed
        [DEBUG] [mount] - done
        [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"15","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.44","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/IoBroker/","dirMinimal":"Backup/IoBroker/","user":"backup","pass":"****","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [iobroker] - host.raspberrypi 5009 states saved
        • B burns1111
          FredFF Online
          FredFF Online
          FredF
          Most Active Forum Testing
          @burns1111 Leider zeigst du im Screenshot nicht den Backup Ordner...
          So wie das hier aussieht ist der aber falsch:
          • FredFF FredF
            burns1111
            @fredf said in Iobroker Backup läuft nicht:
            Das habe ich auch schon gesehen, aber wo kommt die Einstellung her?
            • B burns1111
              burns1111
              @burns1111 Das Backup der CCU findet ja auch den richtigen Weg. Das wird ja abgelegt
              • B burns1111
                @burns1111
                Schau da mal rein:
                sudo umount /opt/iobroker/backups
                ls -la /opt/iobroker/backups
                  @burns1111
                  Schau da mal rein:
                  burns1111
                  @thomas-braun ```
                  pi@raspberrypi:~ $ sudo umount /opt/iobroker/backups
                  umount: /opt/iobroker/backups: not mounted.
                  pi@raspberrypi:~ $ ls -la /opt/iobroker/backups
                  total 8
                  drwxrwxr-x+ 2 iobroker iobroker 4096 Feb 15 20:00 .
                  drwxrwxrwx+ 6 iobroker iobroker 4096 Jun  4 16:11 ..
                  pi@raspberrypi:~ $
                  • B burns1111
                    @thomas-braun ```
                    total 8
                    pi@raspberrypi:~ $
                    burns1111
                    @burns1111 Sollte ich den Adapter mal deinstallieren und neu machen?
                    • B burns1111
                      @burns1111
                      Ich vermute da eher einen 'Klemmer' auf dem SMB-Server.
                        @burns1111
                        burns1111
                        @thomas-braun Was könnte ich da tun? Sorry ich bin wirklich nur Endanwender ohne Backround :-)
                        • B burns1111
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @burns1111
                          Was sagt
                          showmount -e 192.168.178.44
                          • GlasfaserG Glasfaser
                            @burns1111
                            Was sagt
                            burns1111
                            @glasfaser said in Iobroker Backup läuft nicht:
                            pi@raspberrypi:~ $ showmount -e 192.168.178.44
                            clnt_create: RPC: Unable to receive
                            • B burns1111
                              @thomas-braun Hallo,
                              leider scheint es noch nicht los zu laufen. Die Meldungen haben sich nicht verändert. Ich habe mal ein paar Screenshots gemacht zu den Einstellung:
                              SMB Synology.png Einstellung der Diskstation
                              Einstellung IoBroker
                              Der Iobroker stand vorher auf Version 1 von SMB.
                              Ich habe aktuell mal die Version 3.0 eingestellt auf Grund der Diskstation. Da ist maximal Version 3 auswählbar. Im IoBroker könnte ich auf 3.1.1 einstellen.
                              Die Diskstation ist eine Synology DS214se.
                              Sorry für die späte Rückmeldung, aber ich war Unterwegs und konnte nicht auf das System zugreifen.
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Das ist DSM 6 , warum hast du kein DSM 7 auf der Synology
                              • B burns1111
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Schau dir diesen Thread dazu an :
                                https://forum.iobroker.net/topic/50705/gelöst-backitup-auf-raspi-verbindet-sich-nicht-mit-synology
