  4. Adapter mbus - Fehler im log
mbuserror
67 Beiträge 4 Kommentatoren 9.4k Aufrufe 3 Beobachtet
  • apollon77A apollon77
    @bahnuhr :-)) Cool das es so einfach war :-)
    Danke für Deine Rückmeldung
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    @apollon77
    Nochmal von mir.
    Irgendwie scheint immer noch etwas nicht zu stimmen.
    Im log kommt immer mal wieder:
    mbus.0
    2022-01-12 19:28:44.668	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
    mbus.0
    2022-01-12 19:28:44.650	error	All M-Bus devices could not be read, reinitialize and start over
    mbus.0
    2022-01-12 19:28:44.648	warn	M-Bus Devices with errors: 1 from 1
    mbus.0
    2022-01-12 19:28:44.646	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
    mbus.0
    2022-01-12 19:28:41.102	error	All M-Bus devices could not be read, reinitialize and start over
    mbus.0
    2022-01-12 19:28:41.100	warn	M-Bus Devices with errors: 1 from 1
    mbus.0
    2022-01-12 19:28:41.096	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
    mbus.0
    2022-01-12 17:56:23.758	error	All M-Bus devices could not be read, reinitialize and start over
    mbus.0
    2022-01-12 17:56:23.757	warn	M-Bus Devices with errors: 1 from 1
    mbus.0
    2022-01-12 17:56:23.756	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
    hm-rpc.0
    2022-01-12 17:55:15.825	error	Cannot call setValue: XML-RPC fault: Failure
    hm-rpc.0
    2022-01-12 17:55:15.820	error	xmlrpc -> setValue ["MEQ0276622:1","STATE",true] BOOL
    mbus.0
    2022-01-12 17:26:13.635	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
    mbus.0
    2022-01-12 17:26:13.617	error	All M-Bus devices could not be read, reinitialize and start over
    mbus.0
    2022-01-12 17:26:13.617	warn	M-Bus Devices with errors: 1 from 1
    mbus.0
    2022-01-12 17:26:13.616	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
    mbus.0
    2022-01-12 17:26:08.276	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
    mbus.0
    2022-01-12 17:26:08.258	error	All M-Bus devices could not be read, reinitialize and start over
    mbus.0
    2022-01-12 17:26:08.257	warn	M-Bus Devices with errors: 1 from 1
    mbus.0
    2022-01-12 17:26:08.256	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
    mbus.0
    2022-01-12 17:26:02.852	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
    mbus.0
    2022-01-12 17:26:02.838	error	All M-Bus devices could not be read, reinitialize and start over
    mbus.0
    2022-01-12 17:26:02.837	warn	M-Bus Devices with errors: 1 from 1
    mbus.0
    2022-01-12 17:26:02.836	warn	M-Bus ID 17834338B4090107 err: Error: Error: Failed to send/receive M-Bus request frame[17834338B4090107].
    mbus.0
    2022-01-12 17:25:57.463	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
    Das hört auch wieder von alleine auf.
    Hab eben in der config auch mal auf suchen geklickt. mbus wird nicht gefunden.
    Geb ich die Zahl manuell ein wird der Wert im objekt aktualisiert.
    Die Instanz ist grün.
    Vielleicht hast du ja noch ne idee.
    Da läuft noch etwas falsch.
    Da der Wert ja aktualisiert wird, schließen ich jetzt mal das kabel aus.
    Könnte eine Macke am Gerät selber sein; oder bei Adapter (oder meinem Raspi slave System) stimmt etwas nicht.
    Hast du noch ne Idee wie ich da nun ran gehen könnte?
    Danke.
    • bahnuhrB bahnuhr
      @apollon77
      Nochmal von mir.
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      hm-rpc.0
      hm-rpc.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      mbus.0
      @bahnuhr naja nochmal anfangen mit usb ab und Master Stromlos machen. Vllt mal Rechner reboot.
      Nächster Schritt wenn das nicht hilft wäre dann eher debug Modus. Das man mal genauer sieht was los ist.
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @apollon77 sagte in Adapter mbus - Fehler im log:
        master stromlos.
        raspi neu gestartet.
        Ist es normal, dass sowas beim smartmeter jedes mal bei neustart kommt:
        adapter "smartmeter" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
        Und dann bei mbus debug ein.
        Schaun wir mal.
        Ich meld mich.
        Danke.
        • bahnuhrB bahnuhr
          master stromlos.
          Schaun wir mal.
          Ich meld mich.
          @bahnuhr sagte in Adapter mbus - Fehler im log:
          Nope, hier siehe ANnleitung zum Rebuild von Smartmeter im Node.js Upgrade thread im Forum
          • Hant0rH Offline
            Hant0rH Offline
            Hant0r
            Moin zusammen,
            ich habe den gleichen MBUS USB Master Adapter wie bahnuhr.
            Habe heute meinen Wasserzähler angeschlossen, am Rechner kann ich mit der SW den Zähler auslesen (Baudrate 2400).
            Angeschlossen an meiner Diskstation "/dev/ttyUSB1" kommt im MBUS Adapter (grün) aber leider immer folgendes im Log (alle paar Sekunden):
            mbus.0
            2022-06-06 23:45:12.840	error	All M-Bus devices could not be read, reinitialize and start over
            mbus.0
            2022-06-06 23:45:12.839	warn	M-Bus Devices with errors: 1 from 1
            mbus.0
            2022-06-06 23:45:12.838	warn	M-Bus ID 1 err: Error: Error: Failed to send/receive M-Bus request frame[1].
            host.ioBroker
            2022-06-06 23:45:10.924	info	instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            mbus.0
            2022-06-06 23:45:10.158	warn	State "mbus.0.undefined.data.lastStatus" has no existing object, this might lead to an error in future versions
            mbus.0
            2022-06-06 23:45:10.153	info	Schedule initialization for M-Bus-ID 1 with update interval 3600
            mbus.0
            2022-06-06 23:45:10.151	info	Initialize M-Bus Serial to /dev/ttyUSB1 with 2400baud
            mbus.0
            2022-06-06 23:45:10.151	info	Default Update Interval: 3600
            Habe ich was vergesssen oder falsch gemacht?
            • Hant0rH Hant0r
              Moin zusammen,
              mbus.0
              mbus.0
              mbus.0
              host.ioBroker
              mbus.0
              mbus.0
              mbus.0
              mbus.0
              @hant0r Zeig mal die Konfiguration ...
              Hant0rH 1 Antwort Letzte Antwort
                Hant0rH Offline
                Hant0rH Offline
                Hant0r
                apollon77A bahnuhrB 3 Antworten Letzte Antwort
                • Hant0rH Hant0r
                  @hant0r ok, ich muss genauer sein ...die Konfig der Geräte
                  • Hant0rH Hant0r
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    @hant0r
                    Bei mir so:
                    An meinem Raspi hängen:
                    2 x Smartmeter
                    1 x mbus
                    Somit habe ich mir eine extra Rule erstellt.
                    70-lesekopf.rules
                    Diskussion war auch hier im Forum.
                    pdf davon habe ich mal angehängt.
                    smartmeter _ mbus - ttyUSB klar benennen - Seite 1 .pdf
                    smartmeter _ mbus - ttyUSB klar benennen - Seite 2 .pdf
                    Danke.
                    • Hant0rH Hant0r
                      @hant0r hast Du mal verschiednee Baudrates versucht? Bzw ging die geräte erkennung mit 2400 Baud? Recht langsam :-)
                      Bzw die Frage ist ja ob die ID 1 korrekt ist
                        Hant0rH Offline
                        Hant0rH Offline
                        Hant0r
                        @apollon77
                        Sorry, kam erst jetzt dazu die Kommentare zu lesen.
                        Danke, deine Nachfrage mit der ID war der Knackpunkt :D
                        Steht Standardmäßig auf "1" und meine ID vom Gerät war die "0". Das habe ich in der Konfigapp des Moduls gesehen.
                        Also fix im Adapter auf 0 geändert und nun scheint es zu laufen. freu
                        Nun bin ich gespannt wie der Adapter funktioniert, werde es mal paar Tage testen.
                        @bahnuhr - vielen Dank, schaue ich mir die Woche mal an wenn ich was Zeit habe :)
                        • Hant0rH Offline
                          Hant0rH Offline
                          Hant0r
                          schrieb am zuletzt editiert von Hant0r
                          Sehe ich im Adapter nicht live (also nach Ablauf des Aktualisierungsintervals), wie der Wasserverbrauch ist?
                          Habe mal den Wasserhahn aufgedreht, aber es tut sich nichts :man-shrugging:
                          • Hant0rH Hant0r
                            @hant0r naja, welche EInheit meldet dein MBus-Wasserzähler denn ? Da gibts welche die Liter melden, 10l oder 100l oder halt nur den Kubikmeter ... Wenn ich die zahlen so bei Dir sehe hast Du den letzteren ... Damit lass mal 1000l laufen dann springt er auch 81 :-) duck
                              Hant0rH Offline
                              Hant0rH Offline
                              Hant0r
                              @apollon77 hmm... gerade extra nochmal nachgesehen. Soll pro Puls zwischen 1 bis 1000L einstellbar sein.
                              Muss ich wohl nochmal mit der Software schauen
                              Edit:
                              Ne, der Impuls stet auf 1l pro Puls
                              • Hant0rH Hant0r
                                Edit:
                                @hant0r Keine Ahnung ... Du kannst gern auf Debug stellen, dann siehst Du quasi die reinkommenden Rohdaten. Aber ist den "Puls" das gleiche wie "Was kommt in mbus raus"? Ich weiss es nicht.
                                Was zweigt die Haupt-Parameterisierungsseite?
                                  Hant0rH Offline
                                  Hant0rH Offline
                                  Hant0r
                                  Das sind beide Seiten aktuell von eben:
                                  • Hant0rH Hant0r
                                    @hant0r ich denke ließ nochmal genau die Beschreibung und im Zweifel schreib den Hersteller an. Er zeigt sie ja dort auch nur die 80m3 glatt an
                                      Hant0rH Offline
                                      Hant0rH Offline
                                      Hant0r
                                      @apollon77 Ja das wundert mich ehrlich gesagt auch. Gestern stand der Zähler auch noch auf 80m³ .. heute aber auf 81m³
                                      Habe den Adapter auch mal auf Debug gestellt + Aktualisierung auf 60 Sek und das Wasser laufen lassen. Passiert ist da aber auch nichts wirklich
                                      • Hant0rH Hant0r
                                        @hant0r Ok, was genau ist es denn? Ist es ein Zähler-Aufsatz oder ist es eine Kombi aus Zähler und dem mbus Teil oder was genau ist es?
                                          Hant0rH Offline
                                          Hant0rH Offline
                                          Hant0r
                                          @apollon77 Kombi meine ich:
                                          https://mysmartshop.de/products/honeywell-elster-falcon-mj-puls
