  4. JavaScript
  5. Octoprint-script für thumbnail des aktuellen Drucks
javascript
100 Beiträge 9 Kommentatoren 14.7k Aufrufe 8 Beobachtet
    Kuddel
    #90
    Ich lasse mir das Thumbnail ohne Skript und ohne DP in der VIS direkt anzeigen.
    Bei mir macht das alles direkt das VIS Widget:
    Quelle: http://IP_zum_Octorpint:80/plugin/prusaslicerthumbnails/thumbnail/{d:octoprint.0.printjob.file.name; d.split('.')[0]}.png
    Widget-Export
    [{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"!=","visibility-val":"0","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"http://192.168.4.37:80/plugin/prusaslicerthumbnails/thumbnail/{d:octoprint.0.printjob.file.name; d.split('.')[0]}.png ","class":"","visibility-oid":"octoprint.0.printjob.file.date","name":"Thumbnail"},"style":{"left":"5px","top":"45px","z-index":"10","width":"305px","height":"305px","position":"","transform":""},"widgetSet":"basic"}]
    frana120500F 1 Antwort Letzte Antwort
    • K Kuddel
      Widget-Export
      frana120500F Online
      frana120500F Online
      frana120500
      #91
      das muss ich mir mal anschauen. Ich würde damit eigentlich nur meine Telegram Statusmeldungen etwas aufhübschen wollen. Wichtig ist das nicht
      • frana120500F frana120500
        da_WoodyD Offline
        da_WoodyD Offline
        #92
        @frana120500 wozu brauchst du eine telegram meldung? mit welchem inhalt?
        schon mal https://plugins.octoprint.org/plugins/thespaghettidetective/ angelinst?
        • da_WoodyD da_Woody
          frana120500F Online
          frana120500F Online
          frana120500
          #93
          @da_woody Ich lasse mir den Druckstatus per Telegram übermitteln bzw. kann den per Telegram abfragen (inkl. Kamerabild)
            da_WoodyD Offline
            da_WoodyD Offline
            #94
            @frana120500 deswegen hab ich dir einen link geschrieben, wo du das telegram zeug nicht brauchst...
            abfragen kannst du auch mit octoremote incl live bild. mitsamt kompletter steuerung.
            sorry, aber bei telegram bekomm ich aufgestellte nacken haare. ;)
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #95
              @da_woody sagte in Octoprint-script für thumbnail des aktuellen Drucks:
              Telegram & Octoprint ist schon cool.
              Lass mir auch den Druckfortschritt und Screenshots der Cam schicken.
              Den Spaghettischnüffler hab ich (und sehr viele andere) verflucht, da gaaaanz oft ein Fehldruck erkannt wird, obwohl es keiner ist.
              TSD wird auch nicht wirklich mehr empfohlen. Macht mehr Ärger als Nutzen.
              ° Fixer ---> iob fix
              • NegaleinN Negalein
                da_WoodyD Offline
                da_WoodyD Offline
                #96
                @negalein sagte in Octoprint-script für thumbnail des aktuellen Drucks:
                haste schon recht. alleine der Ender aufdruck hat schon zu meldungen geführt, aber noch keinen druck kaputt gemacht. kommt ne mail mit pic, weitermachen, oder abbrechen. gedruckt wurde immer, außer ich hack auf abbrechen.
                aber ok, wenn ihr das telezeuch mögt, passt. ich hab den schrott (nicht wegen octo) nach einer woche von allen geräten nachhaltig entsorgt. :D
                  frana120500F Online
                  frana120500F Online
                  frana120500
                  #97
                  @da_woody für mich passt telegram sehr gut. benutze ich für fast alles und habe dadurch sämtliche Apps für Schalter, Sensoren, Haushaltsgeräte etc. abgeschafft.
                  aber jedem das seine :-)
                  Auch beim 3D Drucker reicht mir die gelegentliche Statusmeldung oder das ich sie bei Bedarf anfordern kann. Wie gesagt: Thumbnail würde nur der Aufhübschung dienen, aber es wird halt keine URL angezeigt. Warum auch immer
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #98
                    @frana120500 sagte in Octoprint-script für thumbnail des aktuellen Drucks:
                    mit Blockly? Könntest du es hier kopieren?
                      frana120500F Online
                      frana120500F Online
                      frana120500
                      #99
                      @negalein da wirst du nix mit anfangen können, da es voll auf mein System abgestimmt ist. Zudem benutze ich in dem Script BlocklyPlus. Ohne das du das installierst wird das Script nicht laufen.
                      Aber es bringt dir tatsächlich auch nix wenn ich es poste
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #100
                        BlocklyPlus
                        das ist schon installiert :)
                        ok, kann man nix machen. Muss ich mal die Blocklys von @dslraser durchschaun.
