  4. Update/Installation von zigbee 1.7.0 schlägt fehl
159 Beiträge 13 Kommentatoren 26.4k Aufrufe 16 Beobachtet
    @arteck bei mir ging das update von 1.7.2. auf die .4 gerade schief, zurück auf die .2 funktioniert aber auch nicht mehr
    2022-05-30 23:48:42.616 - info: zigbee.0 (3779541) Starting Zigbee npm ...
    2022-05-30 23:48:43.040 - info: zigbee.0 (3779541) Installed Version: iobroker.zigbee@1.7.4
    2022-05-30 23:48:44.221 - warn: zigbee.0 (3779541) Extended PAN ID is reversed (expected=aadddddddddddddd, actual=ddddddddddddddaa)
    2022-05-30 23:48:44.443 - info: zigbee.0 (3779541) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210120}}
    2022-05-30 23:48:44.454 - info: zigbee.0 (3779541) Unable to disable LED, unsupported function.
    2022-05-30 23:48:44.469 - info: zigbee.0 (3779541) --> transmitPower : high
    2022-05-30 23:48:44.530 - info: zigbee.0 (3779541) Currently 62 devices are joined:
    2022-05-30 23:48:44.672 - info: zigbee.0 (3779541) 0x680ae2fffe9233b1 (addr 1940): E1746 - IKEA TRADFRI signal repeater (Router)
    2022-05-30 23:48:44.680 - info: zigbee.0 (3779541) 0x680ae2fffe8b8621 (addr 21106): E1746 - IKEA TRADFRI signal repeater (Router)
    2022-05-30 23:48:44.682 - info: zigbee.0 (3779541) 0x680ae2fffe660f0d (addr 12628): E1746 - IKEA TRADFRI signal repeater (Router)
    2022-05-30 23:48:44.683 - info: zigbee.0 (3779541) 0x14b457fffe3640bf (addr 39588): TS0207_repeater - TuYa Repeater (Router)
    2022-05-30 23:48:44.686 - info: zigbee.0 (3779541) 0xf0d1b8000012c809 (addr 53449): AC08559 - OSRAM SMART+ Spot GU10 Multicolor (Router)
    2022-05-30 23:48:44.687 - info: zigbee.0 (3779541) 0x7cb03eaa00aee10f (addr 63861): AB35996 - OSRAM Smart+ Spot GU10 Multicolor (Router)
    2022-05-30 23:48:44.689 - info: zigbee.0 (3779541) 0x00158d0003233286 (addr 59749): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
    2022-05-30 23:48:44.690 - info: zigbee.0 (3779541) 0x60a423fffef8d573 (addr 55568): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
    2022-05-30 23:48:44.692 - info: zigbee.0 (3779541) 0x588e81fffeecc826 (addr 45673): HG06106A - Lidl Livarno Lux GU10 spot RGB (Router)
    2022-05-30 23:48:44.693 - info: zigbee.0 (3779541) 0x588e81fffef1b6ac (addr 47268): HG06106A - Lidl Livarno Lux GU10 spot RGB (Router)
    2022-05-30 23:48:44.696 - info: zigbee.0 (3779541) 0x588e81fffee3a113 (addr 26130): HG06106A - Lidl Livarno Lux GU10 spot RGB (Router)
    2022-05-30 23:48:44.700 - info: zigbee.0 (3779541) 0x588e81fffed12eb2 (addr 36520): HG06106A - Lidl Livarno Lux GU10 spot RGB (Router)
    2022-05-30 23:48:44.702 - info: zigbee.0 (3779541) 0x00158d0002486a98 (addr 41159): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
    2022-05-30 23:48:44.704 - info: zigbee.0 (3779541) 0x00158d0002fd50c5 (addr 38177): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:48:44.708 - info: zigbee.0 (3779541) 0x00158d000236b3f9 (addr 18828): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:48:44.710 - info: zigbee.0 (3779541) 0x00158d0002ebc9a9 (addr 34830): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:48:44.711 - info: zigbee.0 (3779541) 0x04cf8cdf3c77d764 (addr 46234): WXCJKG11LM - Xiaomi Aqara Opple switch 1 band (EndDevice)
    2022-05-30 23:48:44.715 - info: zigbee.0 (3779541) 0x00158d00044b132b (addr 64577): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:48:44.717 - info: zigbee.0 (3779541) 0x00158d000321e534 (addr 46146): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.718 - info: zigbee.0 (3779541) 0x00158d000252acc4 (addr 37724): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.722 - info: zigbee.0 (3779541) 0x00158d00024369e0 (addr 51129): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.724 - info: zigbee.0 (3779541) 0x00158d00036b3fef (addr 5294): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.725 - info: zigbee.0 (3779541) 0x00158d000252aca5 (addr 41511): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.727 - info: zigbee.0 (3779541) 0x00158d00023700c4 (addr 40426): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.729 - info: zigbee.0 (3779541) 0x00158d0003d2e10d (addr 4826): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-05-30 23:48:44.733 - info: zigbee.0 (3779541) 0x00158d00041474d5 (addr 14067): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.734 - info: zigbee.0 (3779541) 0x00158d00042409f0 (addr 403): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.736 - info: zigbee.0 (3779541) 0x00158d0004147b5a (addr 42213): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:48:44.738 - info: zigbee.0 (3779541) 0x00158d00044ab1e5 (addr 53661): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.752 - info: zigbee.0 (3779541) 0x00158d00057f7b68 (addr 10104): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:48:44.753 - info: zigbee.0 (3779541) 0x00158d0002ca30de (addr 9469): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.757 - info: zigbee.0 (3779541) 0x00158d00023368c4 (addr 21995): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
    2022-05-30 23:48:44.759 - info: zigbee.0 (3779541) 0x04cf8cdf3c7cf5ce (addr 52012): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
    2022-05-30 23:48:44.761 - info: zigbee.0 (3779541) 0x00158d00044d6056 (addr 21612): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:48:44.763 - info: zigbee.0 (3779541) 0x00158d000449b589 (addr 48269): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:48:44.765 - info: zigbee.0 (3779541) 0x00158d000221a574 (addr 14679): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    2022-05-30 23:48:44.767 - info: zigbee.0 (3779541) 0x00158d0003fa6762 (addr 9743): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
    2022-05-30 23:48:44.769 - info: zigbee.0 (3779541) 0x00158d0002c3af20 (addr 44739): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.770 - info: zigbee.0 (3779541) 0x00158d0002c78e2f (addr 49019): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.772 - info: zigbee.0 (3779541) 0x00158d00035ffbfb (addr 18330): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:48:44.774 - info: zigbee.0 (3779541) 0x00158d000221a5d5 (addr 38034): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    2022-05-30 23:48:44.775 - info: zigbee.0 (3779541) 0x00158d0003e81044 (addr 53297): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.777 - info: zigbee.0 (3779541) 0x00158d00052da0d3 (addr 33824): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.779 - info: zigbee.0 (3779541) 0x00158d0001bbb0dd (addr 46367): JTYJ-GD-01LM/BW - Xiaomi MiJia Honeywell smoke detector (EndDevice)
    2022-05-30 23:48:44.780 - info: zigbee.0 (3779541) 0x00158d0003173ec1 (addr 65134): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.784 - info: zigbee.0 (3779541) 0x60a423fffe6207db (addr 18725): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
    2022-05-30 23:48:44.786 - info: zigbee.0 (3779541) 0x00158d00044e879b (addr 5746): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.787 - info: zigbee.0 (3779541) 0x00158d0005a16a64 (addr 49932): RB 265 - Innr E27 bulb (Router)
    2022-05-30 23:48:44.788 - info: zigbee.0 (3779541) 0x00158d0005062d72 (addr 43950): RB 265 - Innr E27 bulb (Router)
    2022-05-30 23:48:44.789 - info: zigbee.0 (3779541) 0x847127fffed07fc7 (addr 46789): PSBZS A1 - Lidl Parkside smart watering timer (EndDevice)
    2022-05-30 23:48:44.791 - info: zigbee.0 (3779541) 0xbc33acfffe049a47 (addr 50771): HG06668 - Lidl Silvercrest smart wireless door bell button (EndDevice)
    2022-05-30 23:48:44.792 - info: zigbee.0 (3779541) 0x00158d00054dd0e2 (addr 37534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:48:44.795 - info: zigbee.0 (3779541) 0x00158d000579e391 (addr 26500): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.796 - info: zigbee.0 (3779541) 0x7cb03eaa0a047179 (addr 13395): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
    2022-05-30 23:48:44.798 - info: zigbee.0 (3779541) 0x00158d00054d9944 (addr 15426): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:48:44.800 - info: zigbee.0 (3779541) 0xf0d1b8000012d59b (addr 16996): AC08559 - OSRAM SMART+ Spot GU10 Multicolor (Router)
    2022-05-30 23:48:44.802 - info: zigbee.0 (3779541) 0xf0d1b8000012d9fc (addr 56286): AC08559 - OSRAM SMART+ Spot GU10 Multicolor (Router)
    2022-05-30 23:48:44.804 - info: zigbee.0 (3779541) 0x842e14fffe05ea44 (addr 44598): HG06467 - Lidl Melinera smart LED string lights (Router)
    2022-05-30 23:48:44.806 - info: zigbee.0 (3779541) 0x001788010bcdc15b (addr 58881): 9290030675 - Philips Hue motion sensor (EndDevice)
    2022-05-30 23:48:44.808 - info: zigbee.0 (3779541) 0x04cf8cdf3c77cb51 (addr 32968): WXCJKG12LM - Xiaomi Aqara Opple switch 2 bands (EndDevice)
    2022-05-30 23:48:44.810 - info: zigbee.0 (3779541) 0x00158d0008072bdb (addr 60677): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2022-05-30 23:48:44.810 - info: zigbee.0 (3779541) 0x0000000000000000 (addr 53661): Not supported (model undefined)(Unknown)
    2022-05-30 23:48:44.812 - info: zigbee.0 (3779541) Zigbee started
    2022-05-30 23:48:44.825 - warn: zigbee.0 (3779541) download icon from https://www.zigbee2mqtt.io/images/devices/HG06106A.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06106A.png
    2022-05-30 23:48:44.834 - warn: zigbee.0 (3779541) download icon from https://www.zigbee2mqtt.io/images/devices/HG06106A.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06106A.png
    2022-05-30 23:48:44.838 - warn: zigbee.0 (3779541) download icon from https://www.zigbee2mqtt.io/images/devices/HG06106A.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06106A.png
    2022-05-30 23:48:44.841 - warn: zigbee.0 (3779541) download icon from https://www.zigbee2mqtt.io/images/devices/HG06106A.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06106A.png
    2022-05-30 23:48:44.894 - warn: zigbee.0 (3779541) download icon from https://www.zigbee2mqtt.io/images/devices/PSBZS-A1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/PSBZS A1.png
    2022-05-30 23:48:44.897 - warn: zigbee.0 (3779541) download icon from https://www.zigbee2mqtt.io/images/devices/HG06668.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06668.png
    2022-05-30 23:48:44.909 - warn: zigbee.0 (3779541) download icon from https://www.zigbee2mqtt.io/images/devices/9290030675.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/9290030675.png
    2022-05-30 23:48:44.918 - error: zigbee.0 (3779541) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-05-30 23:48:44.919 - error: zigbee.0 (3779541) unhandled promise rejection: Cannot read property 'replace' of undefined
    2022-05-30 23:48:44.920 - error: zigbee.0 (3779541) TypeError: Cannot read property 'replace' of undefined
    at StatesController.updateDev (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:495:35)
    at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:370:35)
    at processTicksAndRejections (internal/process/task_queues.js:95:5)
    2022-05-30 23:48:44.921 - error: zigbee.0 (3779541) Cannot read property 'replace' of undefined
    2022-05-30 23:48:45.044 - info: zigbee.0 (3779541) cleaned everything up...
    2022-05-30 23:48:45.256 - info: zigbee.0 (3779541) Zigbee: disabling joining new devices.
    2022-05-30 23:48:45.278 - info: zigbee.0 (3779541) debug devices set to []
    2022-05-30 23:48:45.313 - info: zigbee.0 (3779541) deregister device Ping for deactivated device "0x847127fffed07fc7"
    2022-05-30 23:48:45.314 - info: zigbee.0 (3779541) deregister device Ping for deactivated device "0xbc33acfffe049a47"
    2022-05-30 23:48:45.316 - info: zigbee.0 (3779541) deregister device Ping for deactivated device "0x842e14fffe05ea44"
    2022-05-30 23:48:45.548 - info: zigbee.0 (3779541) terminating
    2022-05-30 23:48:45.550 - warn: zigbee.0 (3779541) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-05-30 23:48:46.554 - info: zigbee.0 (3779541) terminating with timeout
    2022-05-30 23:48:47.437 - warn: zigbee.0 (3779541) get state error: Connection is closed.
    2022-05-30 23:48:47.482 - warn: zigbee.0 (3779541) get state error: Connection is closed.
    2022-05-30 23:48:47.483 - warn: zigbee.0 (3779541) get state error: Connection is closed.
    2022-05-30 23:48:47.484 - warn: zigbee.0 (3779541) get state error: Connection is closed.
    2022-05-30 23:48:47.485 - warn: zigbee.0 (3779541) get state error: Connection is closed.
    2022-05-30 23:48:47.486 - warn: zigbee.0 (3779541) get state error: Connection is closed.
    2022-05-30 23:48:48.186 - warn: zigbee.0 (3779541) get state error: Connection is closed.
    2022-05-30 23:48:48.188 - warn: zigbee.0 (3779541) get state error: Connection is closed.
    2022-05-30 23:48:48.191 - warn: zigbee.0 (3779541) get state error: Connection is closed.
    2022-05-30 23:48:48.866 - error: host.IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-05-30 23:48:48.890 - error: host.IoBroker Caught by controller[1]: TypeError: Cannot read property 'replace' of undefined
    2022-05-30 23:48:48.891 - error: host.IoBroker Caught by controller[1]: at StatesController.updateDev (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:495:35)
    2022-05-30 23:48:48.892 - error: host.IoBroker Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:370:35)
    2022-05-30 23:48:48.893 - error: host.IoBroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
    2022-05-30 23:48:48.893 - error: host.IoBroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-05-30 23:49:24.869 - info: zigbee.0 (3779761) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.2, js-controller: 4.0.23
    2022-05-30 23:49:24.977 - info: zigbee.0 (3779761) delete old Backup files. keep only last 10
    2022-05-30 23:49:24.980 - info: zigbee.0 (3779761) Starting Zigbee npm ...
    2022-05-30 23:49:25.333 - info: zigbee.0 (3779761) Installed Version: iobroker.zigbee@1.7.4
    2022-05-30 23:49:26.511 - warn: zigbee.0 (3779761) Extended PAN ID is reversed (expected=aadddddddddddddd, actual=ddddddddddddddaa)
    2022-05-30 23:49:26.773 - info: zigbee.0 (3779761) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210120}}
    2022-05-30 23:49:26.784 - info: zigbee.0 (3779761) Unable to disable LED, unsupported function.
    2022-05-30 23:49:26.798 - info: zigbee.0 (3779761) --> transmitPower : high
    2022-05-30 23:49:26.853 - info: zigbee.0 (3779761) Currently 62 devices are joined:
    2022-05-30 23:49:27.026 - info: zigbee.0 (3779761) 0x680ae2fffe9233b1 (addr 1940): E1746 - IKEA TRADFRI signal repeater (Router)
    2022-05-30 23:49:27.033 - info: zigbee.0 (3779761) 0x680ae2fffe8b8621 (addr 21106): E1746 - IKEA TRADFRI signal repeater (Router)
    2022-05-30 23:49:27.034 - info: zigbee.0 (3779761) 0x680ae2fffe660f0d (addr 12628): E1746 - IKEA TRADFRI signal repeater (Router)
    2022-05-30 23:49:27.037 - info: zigbee.0 (3779761) 0x14b457fffe3640bf (addr 39588): TS0207_repeater - TuYa Repeater (Router)
    2022-05-30 23:49:27.039 - info: zigbee.0 (3779761) 0xf0d1b8000012c809 (addr 53449): AC08559 - OSRAM SMART+ Spot GU10 Multicolor (Router)
    2022-05-30 23:49:27.041 - info: zigbee.0 (3779761) 0x7cb03eaa00aee10f (addr 63861): AB35996 - OSRAM Smart+ Spot GU10 Multicolor (Router)
    2022-05-30 23:49:27.044 - info: zigbee.0 (3779761) 0x00158d0003233286 (addr 59749): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
    2022-05-30 23:49:27.046 - info: zigbee.0 (3779761) 0x60a423fffef8d573 (addr 55568): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
    2022-05-30 23:49:27.048 - info: zigbee.0 (3779761) 0x588e81fffeecc826 (addr 45673): HG06106A - Lidl Livarno Lux GU10 spot RGB (Router)
    2022-05-30 23:49:27.050 - info: zigbee.0 (3779761) 0x588e81fffef1b6ac (addr 47268): HG06106A - Lidl Livarno Lux GU10 spot RGB (Router)
    2022-05-30 23:49:27.052 - info: zigbee.0 (3779761) 0x588e81fffee3a113 (addr 26130): HG06106A - Lidl Livarno Lux GU10 spot RGB (Router)
    2022-05-30 23:49:27.056 - info: zigbee.0 (3779761) 0x588e81fffed12eb2 (addr 36520): HG06106A - Lidl Livarno Lux GU10 spot RGB (Router)
    2022-05-30 23:49:27.059 - info: zigbee.0 (3779761) 0x00158d0002486a98 (addr 41159): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
    2022-05-30 23:49:27.061 - info: zigbee.0 (3779761) 0x00158d0002fd50c5 (addr 38177): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:49:27.064 - info: zigbee.0 (3779761) 0x00158d000236b3f9 (addr 18828): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:49:27.066 - info: zigbee.0 (3779761) 0x00158d0002ebc9a9 (addr 34830): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:49:27.068 - info: zigbee.0 (3779761) 0x04cf8cdf3c77d764 (addr 46234): WXCJKG11LM - Xiaomi Aqara Opple switch 1 band (EndDevice)
    2022-05-30 23:49:27.070 - info: zigbee.0 (3779761) 0x00158d00044b132b (addr 64577): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:49:27.073 - info: zigbee.0 (3779761) 0x00158d000321e534 (addr 46146): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.075 - info: zigbee.0 (3779761) 0x00158d000252acc4 (addr 37724): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.076 - info: zigbee.0 (3779761) 0x00158d00024369e0 (addr 51129): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.078 - info: zigbee.0 (3779761) 0x00158d00036b3fef (addr 5294): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.080 - info: zigbee.0 (3779761) 0x00158d000252aca5 (addr 41511): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.082 - info: zigbee.0 (3779761) 0x00158d00023700c4 (addr 40426): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.083 - info: zigbee.0 (3779761) 0x00158d0003d2e10d (addr 4826): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-05-30 23:49:27.085 - info: zigbee.0 (3779761) 0x00158d00041474d5 (addr 14067): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.086 - info: zigbee.0 (3779761) 0x00158d00042409f0 (addr 403): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.088 - info: zigbee.0 (3779761) 0x00158d0004147b5a (addr 42213): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:49:27.089 - info: zigbee.0 (3779761) 0x00158d00044ab1e5 (addr 53661): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.091 - info: zigbee.0 (3779761) 0x00158d00057f7b68 (addr 10104): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:49:27.092 - info: zigbee.0 (3779761) 0x00158d0002ca30de (addr 9469): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.094 - info: zigbee.0 (3779761) 0x00158d00023368c4 (addr 21995): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
    2022-05-30 23:49:27.095 - info: zigbee.0 (3779761) 0x04cf8cdf3c7cf5ce (addr 52012): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
    2022-05-30 23:49:27.096 - info: zigbee.0 (3779761) 0x00158d00044d6056 (addr 21612): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:49:27.097 - info: zigbee.0 (3779761) 0x00158d000449b589 (addr 48269): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:49:27.099 - info: zigbee.0 (3779761) 0x00158d000221a574 (addr 14679): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    2022-05-30 23:49:27.100 - info: zigbee.0 (3779761) 0x00158d0003fa6762 (addr 9743): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
    2022-05-30 23:49:27.101 - info: zigbee.0 (3779761) 0x00158d0002c3af20 (addr 44739): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.103 - info: zigbee.0 (3779761) 0x00158d0002c78e2f (addr 49019): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.104 - info: zigbee.0 (3779761) 0x00158d00035ffbfb (addr 18330): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:49:27.105 - info: zigbee.0 (3779761) 0x00158d000221a5d5 (addr 38034): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    2022-05-30 23:49:27.106 - info: zigbee.0 (3779761) 0x00158d0003e81044 (addr 53297): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.108 - info: zigbee.0 (3779761) 0x00158d00052da0d3 (addr 33824): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.109 - info: zigbee.0 (3779761) 0x00158d0001bbb0dd (addr 46367): JTYJ-GD-01LM/BW - Xiaomi MiJia Honeywell smoke detector (EndDevice)
    2022-05-30 23:49:27.110 - info: zigbee.0 (3779761) 0x00158d0003173ec1 (addr 65134): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.111 - info: zigbee.0 (3779761) 0x60a423fffe6207db (addr 18725): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
    2022-05-30 23:49:27.112 - info: zigbee.0 (3779761) 0x00158d00044e879b (addr 5746): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.113 - info: zigbee.0 (3779761) 0x00158d0005a16a64 (addr 49932): RB 265 - Innr E27 bulb (Router)
    2022-05-30 23:49:27.114 - info: zigbee.0 (3779761) 0x00158d0005062d72 (addr 43950): RB 265 - Innr E27 bulb (Router)
    2022-05-30 23:49:27.115 - info: zigbee.0 (3779761) 0x847127fffed07fc7 (addr 46789): PSBZS A1 - Lidl Parkside smart watering timer (EndDevice)
    2022-05-30 23:49:27.116 - info: zigbee.0 (3779761) 0xbc33acfffe049a47 (addr 50771): HG06668 - Lidl Silvercrest smart wireless door bell button (EndDevice)
    2022-05-30 23:49:27.117 - info: zigbee.0 (3779761) 0x00158d00054dd0e2 (addr 37534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-30 23:49:27.118 - info: zigbee.0 (3779761) 0x00158d000579e391 (addr 26500): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.119 - info: zigbee.0 (3779761) 0x7cb03eaa0a047179 (addr 13395): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
    2022-05-30 23:49:27.120 - info: zigbee.0 (3779761) 0x00158d00054d9944 (addr 15426): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-05-30 23:49:27.121 - info: zigbee.0 (3779761) 0xf0d1b8000012d59b (addr 16996): AC08559 - OSRAM SMART+ Spot GU10 Multicolor (Router)
    2022-05-30 23:49:27.123 - info: zigbee.0 (3779761) 0xf0d1b8000012d9fc (addr 56286): AC08559 - OSRAM SMART+ Spot GU10 Multicolor (Router)
    2022-05-30 23:49:27.124 - info: zigbee.0 (3779761) 0x842e14fffe05ea44 (addr 44598): HG06467 - Lidl Melinera smart LED string lights (Router)
    2022-05-30 23:49:27.125 - info: zigbee.0 (3779761) 0x001788010bcdc15b (addr 58881): 9290030675 - Philips Hue motion sensor (EndDevice)
    2022-05-30 23:49:27.126 - info: zigbee.0 (3779761) 0x04cf8cdf3c77cb51 (addr 32968): WXCJKG12LM - Xiaomi Aqara Opple switch 2 bands (EndDevice)
    2022-05-30 23:49:27.128 - info: zigbee.0 (3779761) 0x00158d0008072bdb (addr 60677): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2022-05-30 23:49:27.128 - info: zigbee.0 (3779761) 0x0000000000000000 (addr 53661): Not supported (model undefined)(Unknown)
    2022-05-30 23:49:27.129 - info: zigbee.0 (3779761) Zigbee started
    2022-05-30 23:49:27.190 - error: zigbee.0 (3779761) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-05-30 23:49:27.191 - error: zigbee.0 (3779761) unhandled promise rejection: Cannot read property 'replace' of undefined
    2022-05-30 23:49:27.193 - error: zigbee.0 (3779761) TypeError: Cannot read property 'replace' of undefined
    2022-05-30 23:49:27.193 - error: zigbee.0 (3779761) Cannot read property 'replace' of undefined
    2022-05-30 23:49:27.198 - info: zigbee.0 (3779761) cleaned everything up...
    2022-05-30 23:49:27.324 - info: zigbee.0 (3779761) Zigbee: disabling joining new devices.
    2022-05-30 23:49:27.390 - info: zigbee.0 (3779761) debug devices set to []
    2022-05-30 23:49:27.539 - info: zigbee.0 (3779761) deregister device Ping for deactivated device "0x847127fffed07fc7"
    2022-05-30 23:49:27.559 - info: zigbee.0 (3779761) deregister device Ping for deactivated device "0xbc33acfffe049a47"
    2022-05-30 23:49:27.562 - info: zigbee.0 (3779761) deregister device Ping for deactivated device "0x842e14fffe05ea44"
    2022-05-30 23:49:27.701 - info: zigbee.0 (3779761) terminating
    2022-05-30 23:49:27.703 - warn: zigbee.0 (3779761) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-05-30 23:49:28.704 - info: zigbee.0 (3779761) terminating with timeout
    2022-05-30 23:49:29.604 - warn: zigbee.0 (3779761) get state error: Connection is closed.
    2022-05-30 23:49:29.606 - warn: zigbee.0 (3779761) get state error: Connection is closed.
    2022-05-30 23:49:29.908 - warn: zigbee.0 (3779761) get state error: Connection is closed.
    zurück auf die 1.7.2
    zigbee.0
    2022-05-31 00:11:11.360	info	Installed Version: iobroker.zigbee@1.7.2
    zigbee.0
    2022-05-31 00:11:10.999	info	Starting Zigbee npm ...
    zigbee.0
    2022-05-31 00:11:10.996	info	delete old Backup files. keep only last 10
    zigbee.0
    2022-05-31 00:11:10.876	info	starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.2, js-controller: 4.0.23
    host.IoBroker
    2022-05-31 00:10:33.979	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.IoBroker
    2022-05-31 00:10:33.978	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
    host.IoBroker
    2022-05-31 00:10:33.978	error	Caught by controller[0]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:370:35)
    host.IoBroker
    2022-05-31 00:10:33.977	error	Caught by controller[0]: at StatesController.updateDev (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:495:35)
    host.IoBroker
    2022-05-31 00:10:33.976	error	Caught by controller[0]: TypeError: Cannot read property 'replace' of undefined
    host.IoBroker
    2022-05-31 00:10:33.970	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    2022-05-31 00:10:33.497	warn	This object will not be created in future versions. Please report this to the developer.
    zigbee.0
    2022-05-31 00:10:33.497	warn	Object 001788010bcdc15b.motion_sensitivity is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    zigbee.0
    2022-05-31 00:10:33.494	warn	This object will not be created in future versions. Please report this to the developer.
    zigbee.0
    2022-05-31 00:10:33.493	warn	Object 60a423fffe6207db.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    zigbee.0
    2022-05-31 00:10:33.492	warn	This object will not be created in future versions. Please report this to the developer.
    zigbee.0
    2022-05-31 00:10:33.491	warn	Object 00158d0001bbb0dd.sensitivity is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    zigbee.0
    2022-05-31 00:10:33.077	warn	get state error: Connection is closed.
    zigbee.0
    2022-05-31 00:10:33.076	warn	get state error: Connection is closed.
    zigbee.0
    2022-05-31 00:10:32.987	warn	get state error: Connection is closed.
    zigbee.0
    2022-05-31 00:10:32.811	info	terminating with timeout
    zigbee.0
    2022-05-31 00:10:32.801	warn	get state error: Connection is closed.
    zigbee.0
    2022-05-31 00:10:32.799	warn	get state error: Connection is closed.
    zigbee.0
    2022-05-31 00:10:32.550	warn	get state error: Connection is closed.
    zigbee.0
    2022-05-31 00:10:32.549	warn	get state error: Connection is closed.
    zigbee.0
    2022-05-31 00:10:32.506	warn	get state error: DB closed
    zigbee.0
    2022-05-31 00:10:32.504	warn	get state error: DB closed
    zigbee.0
    2022-05-31 00:10:32.420	warn	get state error: DB closed
    zigbee.0
    2022-05-31 00:10:32.419	warn	get state error: DB closed
    zigbee.0
    2022-05-31 00:10:32.418	warn	get state error: Connection is closed.
    zigbee.0
    2022-05-31 00:10:31.753	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2022-05-31 00:10:31.751	info	terminating
    zigbee.0
    2022-05-31 00:10:31.368	info	deregister device Ping for deactivated device "0x842e14fffe05ea44"
    zigbee.0
    2022-05-31 00:10:31.366	info	deregister device Ping for deactivated device "0xbc33acfffe049a47"
    zigbee.0
    2022-05-31 00:10:31.365	info	deregister device Ping for deactivated device "0x847127fffed07fc7"
    zigbee.0
    2022-05-31 00:10:31.307	info	Zigbee: disabling joining new devices.
    zigbee.0
    2022-05-31 00:10:31.109	info	cleaned everything up...
    zigbee.0
    2022-05-31 00:10:30.831	info	debug devices set to []
    zigbee.0
    2022-05-31 00:10:30.752	error	Cannot read property 'replace' of undefined
    zigbee.0
    2022-05-31 00:10:30.751	error	TypeError: Cannot read property 'replace' of undefined at StatesController.updateDev (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:495:35) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:370:35) at processTicksAndRejections (internal/process/task_queues.js:95:5)
    zigbee.0
    2022-05-31 00:10:30.750	error	unhandled promise rejection: Cannot read property 'replace' of undefined
    zigbee.0
    2022-05-31 00:10:30.748	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2022-05-31 00:10:30.740	warn	download icon from https://www.zigbee2mqtt.io/images/devices/9290030675.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/9290030675.png
    zigbee.0
    2022-05-31 00:10:30.727	warn	download icon from https://www.zigbee2mqtt.io/images/devices/HG06668.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06668.png
    zigbee.0
    2022-05-31 00:10:30.724	warn	download icon from https://www.zigbee2mqtt.io/images/devices/PSBZS-A1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/PSBZS A1.png
    zigbee.0
    2022-05-31 00:10:30.660	warn	download icon from https://www.zigbee2mqtt.io/images/devices/HG06106A.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06106A.png
    zigbee.0
    2022-05-31 00:10:30.656	warn	download icon from https://www.zigbee2mqtt.io/images/devices/HG06106A.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06106A.png
    zigbee.0
    2022-05-31 00:10:30.654	warn	download icon from https://www.zigbee2mqtt.io/images/devices/HG06106A.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06106A.png
    zigbee.0
    2022-05-31 00:10:30.650	warn	download icon from https://www.zigbee2mqtt.io/images/devices/HG06106A.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06106A.png
    zigbee.0
    2022-05-31 00:10:30.633	info	Zigbee started
    bin jetzt noch weiter zurück, auf die 1.6.18, da läuft es jetzt wieder
    arteckA Offline
    arteckA Offline
    arteck
    #129
    @crunchip sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
    undefined
    du hast ein unbeklannstes Gerät was nicht gelesen werden kann.. somit kein Icon ziehen kann.. das hab ich nicht berücksichtigt
    das auch noch..
    für dich neue version auf GIT
    • arteckA arteck
      undefined
      das auch noch..
      crunchipC Abwesend
      crunchipC Abwesend
      #130
      @arteck richtig, bin schon seit längerem auf der Suche, woher das Gerät kommt, habe diesbezüglich allen Ersatzsensoren schon die Batterien entzogen.
      Ich lösche das Gerät heraus jedoch nach unbestimmter Zeit taucht es wieder auf.
      Mittlerweile habe ich den Sensor allerdings lokalisiert. Ein xiaomi Bewegungsmelder(gelötet), der eigentlich funktioniert, versucht sich bei Bewegungserkennung, neu zu verbinden. Habe dieses auch schon auf deaktiv gesetz, nutz aber nix.
      Dieses 000000000 Gerät
      Ich teste dann gleich mal die Version, danke dir
        arteckA Offline
        arteckA Offline
        arteck
        #131
        @crunchip dann wird der kaputt sein
        crunchipC ESP8266E 2 Antworten Letzte Antwort
        • arteckA arteck
          crunchipC Abwesend
          crunchipC Abwesend
          #132
          @arteck ja, hat scheinbar nen treffer, aber er funktioniert nach wie vor wie er soll und erkennt nach 5s eine Bewegung.
          Muss ich mal schauen, das ich noch 1-2 von den alten Modellen auftreibe, da die neuen sich ja nicht mehr "hacken" lassen
          • arteckA arteck
            ESP8266E Offline
            ESP8266E Offline
            ESP8266
            schrieb am zuletzt editiert von ESP8266
            #133
            @arteck , Moin, mir ist im Log einiges aufgefallen. Wie soll ich das deuten. Es werden errors gemeldet, die wiederum keine sind....auch die Warnmeldungen sind neu.
            Zeit
            Nachricht
            zigbee.0
            	2022-05-31 10:20:05.066	warn	DeviceAvailability:Failed to ping 0x00158d00053cc50d tint-ColorTemperature
            zigbee.0
            	2022-05-31 10:20:03.073	warn	DeviceAvailability:Failed to ping 0x00178801081d33a1 LWA001
            zigbee.0
            	2022-05-31 10:10:44.367	warn	unread state change for group members ["0x00158d000387a30b"]
            zigbee.0
            	2022-05-31 10:10:20.308	warn	unread state change for group members ["0x00158d000387a30b","0x00158d00053c3cf6"]
            zigbee.0
            	2022-05-31 10:10:19.043	warn	unread state change for group members ["0x84fd27fffe93d9f2","0x84fd27fffe9b3baf","0xbc33acfffebb3510"]
            zigbee.0
            	2022-05-31 10:09:18.734	error	Send command to 0x00158d000387a30b failed with no error code (Timeout - 18070 - 1 - 46 - 6 - 11 after 10000ms)
            zigbee.0
            	2022-05-31 10:09:13.137	error	Send command to 0x84fd27fffe68c2d3 failed with no error code (Timeout - 44967 - 1 - 42 - 6 - 11 after 10000ms)
            zigbee.0
            	2022-05-31 10:09:13.122	error	Send command to 0x847127fffe8f3279 failed with no error code (Timeout - 36578 - 1 - 41 - 6 - 11 after 10000ms)
            zigbee.0
            	2022-05-31 10:09:13.108	error	Send command to 0x14b457fffe42e9e9 failed with no error code (Timeout - 52835 - 1 - 40 - 6 - 11 after 10000ms)
            zigbee.0
            	2022-05-31 10:09:13.075	error	Send command to 0x00158d00053cc50d failed with no error code (Timeout - 10355 - 1 - 39 - 6 - 11 after 10000ms)
            zigbee.0
            	2022-05-31 10:09:10.455	warn	unread state change for group members ["0x84fd27fffe93d9f2","0xbc33acfffebb3510"]
            zigbee.0
            	2022-05-31 10:09:09.875	error	Send command to 0x84fd27fffe93d9f2 failed with no error code (SREQ '--> ZDO - extRouteDisc - {"dstAddr":62934,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)
            Es wurde das Küchenlicht eingeschaltet.
            Zusätzlich habe ich die neue MüllerLicht Fernbedienung angelernt. Das Icon dazu wird als 404022 interpretiert.
            https://www.zigbee2mqtt.io/images/devices/404022.jpg
            Es ist aber die neue 404049
            • arteckA Offline
              arteckA Offline
              arteck
              #134
              @esp8266 sagte in Update/Installation von zigbee 1.7.0 schlägt fehl:
              NWK_TABLE_FULL
              zieh mal den coordinator ab und steck den wieder rein.. da ist der speicher voll gelaufen
              ESP8266E 1 Antwort Letzte Antwort
              • arteckA arteck
                NWK_TABLE_FULL
                ESP8266E Offline
                ESP8266E Offline
                ESP8266
                #135
                @arteck , der fehler ist weg und das bleibt:
                zigbee.0
                	2022-05-31 11:21:33.648	warn	unread state change for group members ["0x84fd27fffe93d9f2","0x84fd27fffe9b3baf"]
                zigbee.0
                	2022-05-31 11:21:33.529	error	Send command to 0x84fd27fffe93d9f2 failed with no error code (Timeout - 62934 - 1 - 108 - 6 - 11 after 10000ms)
                zigbee.0
                	2022-05-31 11:21:09.602	error	Send command to 0x00178801081d33a1 failed with no error code (Timeout - 43384 - 11 - 117 - 6 - 11 after 10000ms)
                zigbee.0
                	2022-05-31 11:21:03.406	error	Send command to 0x84fd27fffe9b3baf failed with no error code (Timeout - 43482 - 1 - 109 - 6 - 11 after 10000ms)
                zigbee.0
                	2022-05-31 11:21:02.963	error	Send command to 0xbc33acfffee60b3b failed with no error code (Timeout - 10750 - 1 - 114 - 6 - 11 after 10000ms)
                zigbee.0
                	2022-05-31 11:20:47.401	error	Send command to 0x84fd27fffe93d9f2 failed with no error code (Timeout - 62934 - 1 - 103 - 6 - 11 after 10000ms)
                • ESP8266E ESP8266
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #136
                  @esp8266 was schickst du da an die gruppe ??
                  die Geräte in der gruppen sind nicht zu erreichen
                  • arteckA arteck
                    ESP8266E Offline
                    ESP8266E Offline
                    ESP8266
                    #137
                    @arteck , Alexa schickt ein Befehl an eine Gruppe. z.B einschalten. Dort sind mehrer devices die eingeschaltet werden sollen hinterlegt. Also eine Gruppe von devices.
                    Ich könnte die Gruppen entfernen und die devices direkt über die Aufzählungen steuern. Dann sind die Gruppen weg.
                    Diese Meldungen sind neu. In der 1.6.18 gab es die nicht.
                    • ESP8266E ESP8266
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #138
                      @esp8266 sind da nur Geräte in den Gruppen die geschaltet werden können .. oder auch Sensoren
                      • arteckA arteck
                        ESP8266E Offline
                        ESP8266E Offline
                        ESP8266
                        #139
                        @arteck , keine sensorik vorhanden von Zigbee. Habe die Gruppen gelöscht und Ruhe ist. Die Timeouts errors bleiben.
                        • ESP8266E ESP8266
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #140
                          @esp8266 was sind das für geräte..da antwortet was nicht
                          • arteckA arteck
                            ESP8266E Offline
                            ESP8266E Offline
                            ESP8266
                            #141
                            @arteck , geschaltete LED Bulbs und ein LED Panel in der Küche unter der Lichtleiste. Mehr habe ich nicht...alles andere ist 868 und 433 MHz. Angefangen vom Briefkasten bis zum Windmesser.
                            • arteckA arteck
                              ESP8266E Offline
                              ESP8266E Offline
                              ESP8266
                              #142
                              @arteck , ich habe jetzt alle Leuchtmittel kurz vom Netz getrennt. Derzeit kommt kein Timeout mehr....im Moment.....mal abwarten.
                              Hier ein .png von der Fernbedienung. Falls Interesse...256x256 Pixel Tranzparent.
                              • ESP8266E ESP8266
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #143
                                @esp8266 ne .. wir lassen die alte da drin.. ist ja ehh nur für den Admin..
                                • arteckA arteck
                                  ESP8266E Offline
                                  ESP8266E Offline
                                  ESP8266
                                  #144
                                  @arteck , ok aber das Bild passt garnicht was derzeit angezeigt wird und auch die Erkennung ist falsch. Deine Sache wollte nur darauf hinweisen.
                                  AlexAtHomeA 1 Antwort Letzte Antwort
                                  • ESP8266E ESP8266
                                    AlexAtHomeA Offline
                                    AlexAtHomeA Offline
                                    AlexAtHome
                                    #145
                                    Ich hänge mich hier mal dran. Ich habe auch Einbträge im Log, es könne ein group device (Osram Steckdose) nicht erreicht werden:
                                    unread state change for group members ["0x7cb03eaa0a013473"]
                                    Interessanterweise funktioniert das Schalten der Steckdose auch nur über die Gruppe. Steuere ich sie via VIS direkt an, reagiert sie nicht.
                                    Ich habe nun versucht, das Device aus der Gruppe zu entfernen, das endet nicht erfolgreich mit Fehler:
                                    remove dev from group Error: "Failed to remove dev 0x7cb03eaa0a013473 (ep 3) from group 0x7cb03eaa0a013473"
                                    Exception when trying remove 0x7cb03eaa0a013473 (ep 3) from group 0x7cb03eaa0a013473. Error: Command 0x7cb03eaa0a013473/3 genGroups.remove({"groupid":1}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
                                    Ein Reconfigure der Steckdose ergab ebenfalls einen Fehler:
                                    Reconfigure failed 0x7cb03eaa0a013473 Plug 01, (Error: Bind 0x7cb03eaa0a013473/3 genOnOff from '0x00124b00237ba6d2/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7))
                                    Ein Anstoßen des Kopplungsmodus und Announcement der Steckdose bewirkte nun immerhin, dass ich die Steckdose wieder sowohl via Gruppe als auch direkt schalten kann. Der Fehler
                                    bleibt aber, ebenso die Fehler beim Versuch, die Steckdose aus der Gruppe zu entfernen.
                                    Er meckert, er würde keine Route finden, aber die Steckdose ist doch erreichbar?!
                                    Ich habe die aktuelle Zigbee-Adapterversion drauf: 1.7.5
                                    • arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #146
                                      @alexathome osram und ledvance machen oft Probleme...
                                      • arteckA arteck
                                        AlexAtHomeA Offline
                                        AlexAtHomeA Offline
                                        AlexAtHome
                                        #147
                                        @arteck Kann ich das dann einfach ignorieren? Funzen tut es ja....
                                        • AlexAtHomeA AlexAtHome
                                          ESP8266E Offline
                                          ESP8266E Offline
                                          ESP8266
                                          #148
                                          @alexathome , da ich auch mehrere Osram Steckdosen besitze, habe ich folgendes gemacht. Gerät vom Netz entfernt einen Moment gewartet und wieder mit dem Netz verbunden. Antenne anders ausgerichtet. Seit dem ist Ruhe. Groups habe ich volltändig entfernt und steuere die Devices über die Aufzählungen. Auch Scripts und VIS greifen jetzt direkt auf die Devices zu.
                                          Wenn ich aber IOB neu starte kommt es hin und wieder zu Fehlermeldungen, die nach einiger Zeit dann verschwinden....
