  2. English
  3. ioBroker general
  4. Javascripts update 5.7 - scripts lost...?
Geplant Angeheftet Gesperrt Verschoben ioBroker general
15 Beiträge 8 Kommentatoren 3.0k Aufrufe 8 Beobachtet
  • E erwinberlin
    I noticed that the javascript stops running after a restore attempt.
    Deutsch schreiben geht, und noch viel besser mit Google translate.
    @erwinberlin
    JS
    is not a valid entry. Either put the correct full path to your skripts or leave it empty.
    E 1 Antwort Letzte Antwort
      @erwinberlin
      JS
      erwinberlin
      Leaving it empty does not result in my scripts appearing again.
      And the back up issue still exists. Backups are stored on the file server and can be read. However, when decompressing there seems to be an issue. Could be rights or location. Right now I am searching for the javascript folder.
      • E erwinberlin
        @erwinberlin
        How do you create backups and how do you put the backup files back into your system?
          @erwinberlin
          erwinberlin
          backups to a synology (SMB3.0). Restoring on a clean install works fine.
          • E erwinberlin
            @erwinberlin sagte in Javascripts update 5.7 - scripts lost...?:
            Why don't you do this then?
              erwinberlin
              that is a last resort option. It is weird that the javascript update breaks the system.
              • E erwinberlin
                I think it's your faulty setup of the mirror directory.
                • E Offline
                  erwinberlin
                  @thomas-braun that may well be faulty. Now the question is how to fix it.
                  • E erwinberlin
                    @erwinberlin
                    iobroker stop
                    iobroker fix
                    iobroker start
                    Then pull back in your javaskript-Backup:
                      @erwinberlin
                      iobroker stop
                      iobroker fix
                      iobroker start
                      erwinberlin
                      @thomas-braun I did that already. Unfortunately, it does not help.
                      • E erwinberlin
                        erwinberlin
                        So I ended up doing a full clean install RPI4 3Gb with Bullseye 64 bit. Restoring worked for adapters and javascript; zigbee and history both came with errors:
                        {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
                        Still it all worked, so it is just a finding.
                        • E Offline
                          erwinberlin
                          My solution (which I did tried 4x today) is to do a clean install. And then do the following in this order:
                          1. restore history, java scripts and zigbee data
                          2. install VIS via the adapters
                          3. do an ioBroker restore
                          And then the history data is still missing unfortunately. at least the system is up and running again in 10 mins. Did it 4x to get the Tuya devices to connect. unfortunately to no avail... (separate thread)
                          BTW I changed from RPI to docker on Ubuntu server running on a Fujitsu Futro s740 with 8Gb and 128Gb SSD. That is a bit more stable and flexible than the RPi system.
