  2. English
  3. ioBroker general
  4. Javascripts update 5.7 - scripts lost...?
Geplant Angeheftet Gesperrt Verschoben ioBroker general
15 Beiträge 8 Kommentatoren 3.0k Aufrufe 8 Beobachtet
    @erwinberlin sagte in Javascripts update 5.7 - scripts lost...?:
    I tried to restore a back up
    Ich vermute mit einem Erwin aus Berlin kann man auch Deutsch schreiben.
    Wie wurde das Backup angelegt und wie wieder zurückgespielt?
    Und wie ist das 'Spiegelverzeichnis' im javascript-Adapter angelegt?
    erwinberlin
    I noticed that the javascript stops running after a restore attempt.
    Deutsch schreiben geht, und noch viel besser mit Google translate.
    • E erwinberlin
      @erwinberlin
      JS
      is not a valid entry. Either put the correct full path to your skripts or leave it empty.
      E 1 Antwort Letzte Antwort
        @erwinberlin
        JS
        erwinberlin
        Leaving it empty does not result in my scripts appearing again.
        And the back up issue still exists. Backups are stored on the file server and can be read. However, when decompressing there seems to be an issue. Could be rights or location. Right now I am searching for the javascript folder.
        • E erwinberlin
          @erwinberlin
          How do you create backups and how do you put the backup files back into your system?
            @erwinberlin
            erwinberlin
            backups to a synology (SMB3.0). Restoring on a clean install works fine.
            • E erwinberlin
              Why don't you do this then?
                erwinberlin
                that is a last resort option. It is weird that the javascript update breaks the system.
                • E erwinberlin
                  I think it's your faulty setup of the mirror directory.
                  • E Offline
                    erwinberlin
                    @thomas-braun that may well be faulty. Now the question is how to fix it.
                    • E erwinberlin
                      @erwinberlin
                      iobroker stop
                      iobroker fix
                      iobroker start
                      Then pull back in your javaskript-Backup:
                        @erwinberlin
                        iobroker stop
                        iobroker fix
                        iobroker start
                        erwinberlin
                        @thomas-braun I did that already. Unfortunately, it does not help.
                        • E erwinberlin
                          erwinberlin
                          So I ended up doing a full clean install RPI4 3Gb with Bullseye 64 bit. Restoring worked for adapters and javascript; zigbee and history both came with errors:
                          {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
                          Still it all worked, so it is just a finding.
                          • E Offline
                            erwinberlin
                            My solution (which I did tried 4x today) is to do a clean install. And then do the following in this order:
                            1. restore history, java scripts and zigbee data
                            2. install VIS via the adapters
                            3. do an ioBroker restore
                            And then the history data is still missing unfortunately. at least the system is up and running again in 10 mins. Did it 4x to get the Tuya devices to connect. unfortunately to no avail... (separate thread)
                            BTW I changed from RPI to docker on Ubuntu server running on a Fujitsu Futro s740 with 8Gb and 128Gb SSD. That is a bit more stable and flexible than the RPi system.
