  4. Test Adapter TrashSchedule
    6.3k
adaptercalendaricalkalendermülltrash
1.4k Beiträge 186 Kommentatoren 688.0k Aufrufe 171 Beobachtet
  • S Superdad
    @haus-automatisierung Vielen Dank für die schnelle Antwort.
    Aber?! Wo ist dieses Debug-Log?
    Wie komme ich da ran?
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    #1166
    @superdad sagte in Test Adapter TrashSchedule:
    hier von Info auf Debug ändern.
    Und dann wieder ins Log schaun.
    ° Fixer ---> iob fix
    • S Superdad
      @haus-automatisierung Hilft dir vielleicht das?
      trashschedule.0
      	2022-04-22 09:38:21.533	warn	nextAfter has no entries. Check configuration of iCal and trashschedule!
      trashschedule.0
      	2022-04-22 09:38:21.465	warn	no events matches type "Restmüll" with match "Restmüll". Check configuration of iCal (increase preview) and trashschedule!
      trashschedule.0
      	2022-04-22 09:38:21.410	warn	no events matches type "Papiertonne" with match "Papiertonne". Check configuration of iCal (increase preview) and trashschedule!
      trashschedule.0
      	2022-04-22 09:38:21.357	info	State value to set for "trashschedule.0.type.gelberSack.nextWeekday" has to be type "string" but received type "number"
      trashschedule.0
      	2022-04-22 09:38:20.998	info	configurured iCal preview is 50 days - increase this value to find more events in the future
      trashschedule.0
      	2022-04-22 09:38:20.803	info	starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.22.10, js-controller: 4.0.21
      host.andreas-ubuntu
      	2022-04-22 09:38:19.831	info	instance system.adapter.trashschedule.0 started with pid 5789
      host.andreas-ubuntu
      	2022-04-22 09:38:17.266	info	instance system.adapter.trashschedule.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.andreas-ubuntu
      	2022-04-22 09:38:16.750	info	stopInstance system.adapter.trashschedule.0 send kill signal
      trashschedule.0
      	2022-04-22 09:38:16.711	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      trashschedule.0
      	2022-04-22 09:38:16.711	info	terminating
      trashschedule.0
      	2022-04-22 09:38:16.711	info	cleaned everything up...
      trashschedule.0
      	2022-04-22 09:38:16.710	info	Got terminate signal TERMINATE_YOURSELF
      host.andreas-ubuntu
      	2022-04-22 09:38:16.707	info	stopInstance system.adapter.trashschedule.0 (force=false, process=true)
      Mod-Edit: Code in </> Code-Tag gepackt!
      haus-automatisierungH Offline
      #1167
      @superdad Im Prinzip siehst Du da ja schon, dass keine Termine für "Restmüll" und "Papiertonne" gefunden werden. Gibts die Events wirklich im Kalender?
      Ansonsten: Lösch bitte einmal alle Objekte unter trashschedule.0 und starte die Instanz neu. Dann wird alles neu angelegt. Scheinbar hast Du noch sehr alte Objekte mit dem falschen Datentyp aus der Beta-Phase.
      📚 Meine Dokumentation
        Superdad
        #1168
        @haus-automatisierung Ich probiere das mal.
        CCU3
        iOBroker auf IntelNUC Proxmox
          Superdad
          schrieb am zuletzt editiert von Superdad
          #1169
          Es scheint am iCal-Adapter zu liegen.
          Bekomme immer Error Reading beim verbinden mit dem iCloud Kalender.
          Kann mir jemand sagen wie die URL zur iCloud aussehen muss?
          Ich glaube, dass die verändert ist.
          War da nur ein "http" davor zu setzen?
          Danke, ich habe es.
          URL muss mit "http://p121-calendarws.icloud.com/published/xxxxxxxxxxx" beginnen.
          CCU3
          R 1 Antwort Letzte Antwort
          • S Superdad
            Danke, ich habe es.
            rotamint
            schrieb am zuletzt editiert von rotamint
            #1170
            Danke für den Adapter! Habe ihn nach Anleitung installiert und möchte mich herzlich bedanken!
            • JB_SullivanJ Offline
              JB_Sullivan
              schrieb am zuletzt editiert von JB_Sullivan
              #1171
              Kurze Rückmeldung zur neuesten Version 2.0.1 - mit 2.0.0 läuft alles ohne Fehlermeldung.
              trashschedule.0
              9324	2022-05-26 07:58:01.577	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              trashschedule.0
              9324	2022-05-26 07:58:01.576	info	terminating
              trashschedule.0
              9324	2022-05-26 07:58:01.575	info	cleaned everything up...
              trashschedule.0
              9324	2022-05-26 07:58:01.556	error	The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "."
              trashschedule.0
              9324	2022-05-26 07:58:01.555	error	Error: The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "." at Utils.validateId (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\utils.ts:215:23) at Trashschedule.delForeignObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3267:23) at Trashschedule.delObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3209:18) at C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2116:16 at new Promise (<anonymous>) at Trashschedule.delObjectAsync (C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2115:16) at Trashschedule.onReady (C:\iobroker\GLT\node_modules\iobroker.trashschedule\main.js:257:28)
              trashschedule.0
              9324	2022-05-26 07:58:01.264	error	unhandled promise rejection: The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "."
              trashschedule.0
              9324	2022-05-26 07:58:01.263	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              trashschedule.0
              9324	2022-05-26 07:58:01.096	info	starting. Version 2.0.1 in C:/iobroker/GLT/node_modules/iobroker.trashschedule, node: v14.16.0, js-controller: 4.0.23
              • JB_SullivanJ JB_Sullivan
                trashschedule.0
                trashschedule.0
                trashschedule.0
                trashschedule.0
                trashschedule.0
                trashschedule.0
                trashschedule.0
                trashschedule.0
                #1172
                @jb_sullivan Mh, hast Du einen Typ ohne Namen?! Normalerweise kann das nicht passieren an der Stelle. Muss ich nochmal in allen Varianten testen
                  JB_Sullivan
                  #1173
                  Trashscheduler stürzt unter 2.0.2 immer noch ab. ..... und ich habe auch keinen leeren Typen definiert.
                  host.GLTGLT)
                  2022-05-27 18:46:33.519	warn	host.GLT(GLT) Do not restart adapter system.adapter.trashschedule.0 because restart loop detected
                  host.GLTGLT)
                  2022-05-27 18:46:33.518	info	host.GLT(GLT) Restart adapter system.adapter.trashschedule.0 because enabled
                  host.GLTGLT)
                  2022-05-27 18:46:33.518	error	host.GLT(GLT) instance system.adapter.trashschedule.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  host.GLTGLT)
                  2022-05-27 18:46:33.518	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.onReady (C:\iobroker\GLT\node_modules\iobroker.trashschedule\main.js:260:28)
                  host.GLTGLT)
                  2022-05-27 18:46:33.518	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.delObjectAsync (C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2115:16)
                  host.GLTGLT)
                  2022-05-27 18:46:33.518	error	host.GLT(GLT) Caught by controller[1]: at new Promise (<anonymous>)
                  host.GLTGLT)
                  2022-05-27 18:46:33.518	error	host.GLT(GLT) Caught by controller[1]: at C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2116:16
                  host.GLTGLT)
                  2022-05-27 18:46:33.518	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.delObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3209:18)
                  host.GLTGLT)
                  2022-05-27 18:46:33.518	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.delForeignObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3267:23)
                  host.GLTGLT)
                  2022-05-27 18:46:33.518	error	host.GLT(GLT) Caught by controller[1]: at Utils.validateId (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\utils.ts:215:23)
                  host.GLTGLT)
                  2022-05-27 18:46:33.518	error	host.GLT(GLT) Caught by controller[1]: Error: The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "."
                  host.GLTGLT)
                  2022-05-27 18:46:33.517	error	host.GLT(GLT) Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                  trashschedule.0
                  12044	2022-05-27 18:46:32.852	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  trashschedule.0
                  12044	2022-05-27 18:46:32.851	info	terminating
                  trashschedule.0
                  12044	2022-05-27 18:46:32.851	info	cleaned everything up...
                  trashschedule.0
                  12044	2022-05-27 18:46:32.837	error	The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "."
                  trashschedule.0
                  12044	2022-05-27 18:46:32.837	error	Error: The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "." at Utils.validateId (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\utils.ts:215:23) at Trashschedule.delForeignObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3267:23) at Trashschedule.delObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3209:18) at C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2116:16 at new Promise (<anonymous>) at Trashschedule.delObjectAsync (C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2115:16) at Trashschedule.onReady (C:\iobroker\GLT\node_modules\iobroker.trashschedule\main.js:260:28)
                  trashschedule.0
                  12044	2022-05-27 18:46:32.592	error	unhandled promise rejection: The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "."
                  trashschedule.0
                  12044	2022-05-27 18:46:32.591	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  web.0
                  11340	2022-05-27 18:46:32.494	info	<== Disconnect system.user.admin from ::ffff:10.122.60.92 vis.0
                  trashschedule.0
                  12044	2022-05-27 18:46:32.293	info	starting. Version 2.0.2 in C:/iobroker/GLT/node_modules/iobroker.trashschedule, node: v14.16.0, js-controller: 4.0.23
                  GlasfaserG haus-automatisierungH 2 Antworten Letzte Antwort
                    host.GLTGLT)
                    host.GLTGLT)
                    host.GLTGLT)
                    host.GLTGLT)
                    host.GLTGLT)
                    host.GLTGLT)
                    host.GLTGLT)
                    host.GLTGLT)
                    host.GLTGLT)
                    host.GLTGLT)
                    host.GLTGLT)
                    host.GLTGLT)
                    trashschedule.0
                    trashschedule.0
                    trashschedule.0
                    trashschedule.0
                    trashschedule.0
                    trashschedule.0
                    trashschedule.0
                    web.0
                    trashschedule.0
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #1174
                    @jb_sullivan
                    Zeige mal bitte die DEBUG Ausgabe
                      host.GLTGLT)
                      host.GLTGLT)
                      host.GLTGLT)
                      host.GLTGLT)
                      host.GLTGLT)
                      host.GLTGLT)
                      host.GLTGLT)
                      host.GLTGLT)
                      host.GLTGLT)
                      host.GLTGLT)
                      host.GLTGLT)
                      host.GLTGLT)
                      trashschedule.0
                      trashschedule.0
                      trashschedule.0
                      trashschedule.0
                      trashschedule.0
                      trashschedule.0
                      trashschedule.0
                      web.0
                      trashschedule.0
                      #1175
                      @jb_sullivan Mal bitte einen Screenshot von der Objektstruktur teilen. Keine Ahnung was er da löschen möchte mit . am Ende.
                      SBorgS JB_SullivanJ 2 Antworten Letzte Antwort
                        SBorgS Offline
                        SBorgS Offline
                        SBorg
                        #1176
                        Hallo Matthias, da fehlt IMHO noch etwas für die "Info-Adapter-Anzeige":
                        ...oder ist der "stealth-mode" Absicht 😇
                        LG SBorg ( SBorg auf GitHub)
                          JB_Sullivan
                          #1177
                          Habe es mal so klein wie möglich gemacht, damit soviel wie möglich sehen kann - hoffe das ist noch ausreichend.
                          Hier das Debug der 2.0.0
                          trashschedule.0
                          14612	2022-05-28 12:41:59.670	debug	(5) filling "nextAfter" event with data: {"minDays":12,"minDate":"2022-06-08T22:00:00.000Z","minTypes":["Gelber Sack","Grünmüll","Papiertonne"]}
                          trashschedule.0
                          14612	2022-05-28 12:41:59.606	debug	(5) filling "next" event with data: {"minDays":4,"minDate":"2022-05-31T22:00:00.000Z","minTypes":["Restmüll","Grünmüll"]}
                          trashschedule.0
                          14612	2022-05-28 12:41:59.589	debug	(3) event match: "Biotonne" matches type "Grünmüll" with pattern "Bio"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.589	debug	(2) processing: "Biotonne" (1655848800000) // dayDiff: 25 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
                          trashschedule.0
                          14612	2022-05-28 12:41:59.589	debug	(1) parsing next event {"date":"22.06. ","event":"Biotonne","_class":"ical_Abfallkalender ","_date":"2022-06-21T22:00:00.000Z","_end":"2022-06-22T22:00:00.000Z","_section":"Biotonne muss bereitgestellt werden.","_IDID":"61171f35ab4c4cf0c6d229c4ff2e551e","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-21T22:00:00.000Z","datetype":"date","end":"2022-06-22T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"61171f35ab4c4cf0c6d229c4ff2e551e","created":"2022-01-05T10:24:58.000Z","description":"Biotonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Biotonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-21T22:00:00.000Z // calculated date (with offset): Wed Jun 22 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                          trashschedule.0
                          14612	2022-05-28 12:41:59.588	debug	(3) event match: "Biotonne" matches type "Grünmüll" with pattern "Bio"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.588	debug	(2) processing: "Biotonne" (1655244000000) // dayDiff: 18 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
                          trashschedule.0
                          14612	2022-05-28 12:41:59.587	debug	(1) parsing next event {"date":"15.06. ","event":"Biotonne","_class":"ical_Abfallkalender ","_date":"2022-06-14T22:00:00.000Z","_end":"2022-06-15T22:00:00.000Z","_section":"Biotonne muss bereitgestellt werden.","_IDID":"47a99a698860ec971c837ad22d7ff188","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-14T22:00:00.000Z","datetype":"date","end":"2022-06-15T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"47a99a698860ec971c837ad22d7ff188","created":"2022-01-05T10:24:58.000Z","description":"Biotonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Biotonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-14T22:00:00.000Z // calculated date (with offset): Wed Jun 15 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                          trashschedule.0
                          14612	2022-05-28 12:41:59.587	debug	(3) event match: "Restmülltonne" matches type "Restmüll" with pattern "Restmüll"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.586	debug	(2) processing: "Restmülltonne" (1655244000000) // dayDiff: 18 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
                          trashschedule.0
                          14612	2022-05-28 12:41:59.586	debug	(1) parsing next event {"date":"15.06. ","event":"Restmülltonne","_class":"ical_Abfallkalender ","_date":"2022-06-14T22:00:00.000Z","_end":"2022-06-15T22:00:00.000Z","_section":"Restmülltonne muss bereitgestellt werden.","_IDID":"51e160564d57de83c65d140b7365983b","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-14T22:00:00.000Z","datetype":"date","end":"2022-06-15T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"51e160564d57de83c65d140b7365983b","created":"2022-01-05T10:24:58.000Z","description":"Restmülltonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Restmülltonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-14T22:00:00.000Z // calculated date (with offset): Wed Jun 15 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                          trashschedule.0
                          14612	2022-05-28 12:41:59.585	debug	(4) filled type: "Papiertonne"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.537	debug	(3) event match: "Altpapiertonne" matches type "Papiertonne" with pattern "Altpapier"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.537	debug	(2) processing: "Altpapiertonne" (1654725600000) // dayDiff: 12 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
                          trashschedule.0
                          14612	2022-05-28 12:41:59.536	debug	(1) parsing next event {"date":"09.06. ","event":"Altpapiertonne","_class":"ical_Abfallkalender ","_date":"2022-06-08T22:00:00.000Z","_end":"2022-06-09T22:00:00.000Z","_section":"Altpapiertonne muss bereitgestellt werden.","_IDID":"34595c6f0c822cd755177b3f86041d18","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-08T22:00:00.000Z","datetype":"date","end":"2022-06-09T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"34595c6f0c822cd755177b3f86041d18","created":"2022-01-05T10:24:58.000Z","description":"Altpapiertonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Altpapiertonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-08T22:00:00.000Z // calculated date (with offset): Thu Jun 09 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                          trashschedule.0
                          14612	2022-05-28 12:41:59.536	debug	(3) event match: "Biotonne" matches type "Grünmüll" with pattern "Bio"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.535	debug	(2) processing: "Biotonne" (1654725600000) // dayDiff: 12 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
                          trashschedule.0
                          14612	2022-05-28 12:41:59.535	debug	(1) parsing next event {"date":"09.06. ","event":"Biotonne","_class":"ical_Abfallkalender ","_date":"2022-06-08T22:00:00.000Z","_end":"2022-06-09T22:00:00.000Z","_section":"Biotonne muss bereitgestellt werden.","_IDID":"a45ac6cafa5882a7ddeb0d9b84a897f1","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-08T22:00:00.000Z","datetype":"date","end":"2022-06-09T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"a45ac6cafa5882a7ddeb0d9b84a897f1","created":"2022-01-05T10:24:58.000Z","description":"Biotonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Biotonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-08T22:00:00.000Z // calculated date (with offset): Thu Jun 09 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                          trashschedule.0
                          14612	2022-05-28 12:41:59.534	debug	(4) filled type: "Gelber Sack"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.491	debug	(3) event match: "Gelber Sack" matches type "Gelber Sack" with pattern "Gelber Sack"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.490	debug	(2) processing: "Gelber Sack" (1654725600000) // dayDiff: 12 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
                          trashschedule.0
                          14612	2022-05-28 12:41:59.490	debug	(1) parsing next event {"date":"09.06. ","event":"Gelber Sack","_class":"ical_Abfallkalender ","_date":"2022-06-08T22:00:00.000Z","_end":"2022-06-09T22:00:00.000Z","_section":"Gelber Sack muss bereitgestellt werden.","_IDID":"5149be8ead432939824c14246bfab23b","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-06-08T22:00:00.000Z","datetype":"date","end":"2022-06-09T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"5149be8ead432939824c14246bfab23b","created":"2022-01-05T10:24:58.000Z","description":"Gelber Sack muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Gelber Sack","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-06-08T22:00:00.000Z // calculated date (with offset): Thu Jun 09 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                          trashschedule.0
                          14612	2022-05-28 12:41:59.489	debug	(4) filled type: "Grünmüll"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.449	debug	(3) event match: "Biotonne" matches type "Grünmüll" with pattern "Bio"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.448	debug	(2) processing: "Biotonne" (1654034400000) // dayDiff: 4 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
                          trashschedule.0
                          14612	2022-05-28 12:41:59.448	debug	(1) parsing next event {"date":"In 4 Tagen ","event":"Biotonne","_class":"ical_Abfallkalender ical_4days","_date":"2022-05-31T22:00:00.000Z","_end":"2022-06-01T22:00:00.000Z","_section":"Biotonne muss bereitgestellt werden.","_IDID":"4d53673e99ea2b08018e4fdd56115fc5","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-05-31T22:00:00.000Z","datetype":"date","end":"2022-06-01T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"4d53673e99ea2b08018e4fdd56115fc5","created":"2022-01-05T10:24:58.000Z","description":"Biotonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Biotonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-05-31T22:00:00.000Z // calculated date (with offset): Wed Jun 01 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                          trashschedule.0
                          14612	2022-05-28 12:41:59.447	debug	(4) filled type: "Restmüll"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.406	debug	(3) event match: "Restmülltonne" matches type "Restmüll" with pattern "Restmüll"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.406	debug	(2) processing: "Restmülltonne" (1654034400000) // dayDiff: 4 // current hour (date): 12 (1653688800000) // skipsamedayathour (config): 22
                          trashschedule.0
                          14612	2022-05-28 12:41:59.405	debug	(1) parsing next event {"date":"In 4 Tagen ","event":"Restmülltonne","_class":"ical_Abfallkalender ical_4days","_date":"2022-05-31T22:00:00.000Z","_end":"2022-06-01T22:00:00.000Z","_section":"Restmülltonne muss bereitgestellt werden.","_IDID":"2d289aecf55e7fc52c1f3feaaa9611af","_allDay":true,"_private":false,"_rule":" ","location":"Peine Ortschaften AIa1","_calName":"Abfallkalender","_calColor":"#af6161","_object":{"type":"VEVENT","params":[],"start":"2022-05-31T22:00:00.000Z","datetype":"date","end":"2022-06-01T22:00:00.000Z","dtstamp":"2022-05-28T10:18:17.000Z","uid":"2d289aecf55e7fc52c1f3feaaa9611af","created":"2022-01-05T10:24:58.000Z","description":"Restmülltonne muss bereitgestellt werden.","lastmodified":"2022-01-17T09:49:35.000Z","location":"Peine Ortschaften AIa1","sequence":"0","status":"CONFIRMED","summary":"Restmülltonne","transparency":"OPAQUE","method":"PUBLISH"}} // originalDate: 2022-05-31T22:00:00.000Z // calculated date (with offset): Wed Jun 01 2022 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                          trashschedule.0
                          14612	2022-05-28 12:41:59.404	debug	(0) offset (config): 0
                          trashschedule.0
                          14612	2022-05-28 12:41:59.403	debug	(0) start processing 8 iCal events
                          trashschedule.0
                          14612	2022-05-28 12:41:59.389	debug	(0) updating data
                          trashschedule.0
                          14612	2022-05-28 12:41:59.387	debug	(0) update started by foreign state value - lc: 2022-05-28T10:15:17.952Z - ts: 2022-05-28T10:15:17.952Z
                          trashschedule.0
                          14612	2022-05-28 12:41:59.203	debug	re-creating refresh timeout in 1085799ms (in 00:18:05)
                          trashschedule.0
                          14612	2022-05-28 12:41:59.200	debug	[ical] found ical event(s): {"name":"Gelber Sack","enabled":true,"display":true}
                          trashschedule.0
                          14612	2022-05-28 12:41:59.200	debug	[ical] found ical event(s): {"name":"Biotonne","enabled":true,"display":true}
                          trashschedule.0
                          14612	2022-05-28 12:41:59.200	debug	[ical] found ical event(s): {"name":"Altpapiertonne","enabled":true,"display":true}
                          trashschedule.0
                          14612	2022-05-28 12:41:59.199	debug	[ical] found ical event(s): {"name":"Restmülltonne","enabled":true,"display":true}
                          trashschedule.0
                          14612	2022-05-28 12:41:59.199	info	[ical] configurured ical preview is 30 days - increase this value to find more events in the future
                          trashschedule.0
                          14612	2022-05-28 12:41:59.199	debug	[ical] current ical version: 1.12.1
                          trashschedule.0
                          14612	2022-05-28 12:41:59.193	debug	Trash type deleted: "type."
                          trashschedule.0
                          14612	2022-05-28 12:41:59.171	debug	Trash type found: "Restmüll"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.094	debug	Trash type found: "Papiertonne"
                          trashschedule.0
                          14612	2022-05-28 12:41:59.069	debug	Trash type found: "Grünmüll"
                          trashschedule.0
                          14612	2022-05-28 12:41:58.830	debug	Trash type found: "Gelber Sack"
                          trashschedule.0
                          14612	2022-05-28 12:41:58.627	info	starting. Version 2.0.0 in C:/iobroker/GLT/node_modules/iobroker.trashschedule, node: v14.16.0, js-controller: 4.0.23
                          trashschedule.0
                          14612	2022-05-28 12:41:57.800	debug	Plugin sentry Initialize Plugin (enabled=true)
                          trashschedule.0
                          14612	2022-05-28 12:41:57.486	debug	States connected to redis: 127.0.0.1:9000
                          trashschedule.0
                          14612	2022-05-28 12:41:57.407	debug	States create User PubSub Client
                          trashschedule.0
                          14612	2022-05-28 12:41:57.406	debug	States create System PubSub Client
                          trashschedule.0
                          14612	2022-05-28 12:41:57.363	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                          trashschedule.0
                          14612	2022-05-28 12:41:57.280	debug	Objects connected to redis: 127.0.0.1:9001
                          trashschedule.0
                          14612	2022-05-28 12:41:57.275	debug	Objects client initialize lua scripts
                          trashschedule.0
                          14612	2022-05-28 12:41:57.186	debug	Objects create User PubSub Client
                          trashschedule.0
                          14612	2022-05-28 12:41:57.185	debug	Objects create System PubSub Client
                          trashschedule.0
                          14612	2022-05-28 12:41:57.184	debug	Objects client ready ... initialize now
                          trashschedule.0
                          14612	2022-05-28 12:41:57.122	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                          .... und von der 2.0.2
                          host.GLTGLT)
                          2022-05-28 12:44:28.077	info	host.GLT(GLT) Restart adapter system.adapter.trashschedule.0 because enabled
                          host.GLTGLT)
                          2022-05-28 12:44:28.076	error	host.GLT(GLT) instance system.adapter.trashschedule.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          host.GLTGLT)
                          2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.onReady (C:\iobroker\GLT\node_modules\iobroker.trashschedule\main.js:260:28)
                          host.GLTGLT)
                          2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.delObjectAsync (C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2115:16)
                          host.GLTGLT)
                          2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at new Promise (<anonymous>)
                          host.GLTGLT)
                          2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2116:16
                          host.GLTGLT)
                          2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.delObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3209:18)
                          host.GLTGLT)
                          2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at Trashschedule.delForeignObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3267:23)
                          host.GLTGLT)
                          2022-05-28 12:44:28.076	error	host.GLT(GLT) Caught by controller[1]: at Utils.validateId (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\utils.ts:215:23)
                          host.GLTGLT)
                          2022-05-28 12:44:28.075	error	host.GLT(GLT) Caught by controller[1]: Error: The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "."
                          host.GLTGLT)
                          2022-05-28 12:44:28.075	error	host.GLT(GLT) Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          trashschedule.0
                          7992	2022-05-28 12:44:27.123	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          trashschedule.0
                          7992	2022-05-28 12:44:27.122	debug	Plugin sentry destroyed
                          trashschedule.0
                          7992	2022-05-28 12:44:27.121	info	terminating
                          trashschedule.0
                          7992	2022-05-28 12:44:27.120	info	cleaned everything up...
                          trashschedule.0
                          7992	2022-05-28 12:44:27.080	error	The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "."
                          trashschedule.0
                          7992	2022-05-28 12:44:27.079	error	Error: The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "." at Utils.validateId (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\utils.ts:215:23) at Trashschedule.delForeignObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3267:23) at Trashschedule.delObject (C:\iobroker\GLT\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.js:3209:18) at C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2116:16 at new Promise (<anonymous>) at Trashschedule.delObjectAsync (C:\iobroker\GLT\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2115:16) at Trashschedule.onReady (C:\iobroker\GLT\node_modules\iobroker.trashschedule\main.js:260:28)
                          trashschedule.0
                          7992	2022-05-28 12:44:26.514	error	unhandled promise rejection: The id "trashschedule.0.type." is invalid. Ids are not allowed to end in "."
                          trashschedule.0
                          7992	2022-05-28 12:44:26.514	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          trashschedule.0
                          7992	2022-05-28 12:44:26.512	debug	deleting existing but unconfigured trash type with ID "type."
                          trashschedule.0
                          7992	2022-05-28 12:44:26.473	debug	found configured trash type: "Restmüll" with ID "type.restmüll"
                          trashschedule.0
                          7992	2022-05-28 12:44:26.452	debug	found configured trash type: "Papiertonne" with ID "type.papiertonne"
                          trashschedule.0
                          7992	2022-05-28 12:44:26.431	debug	found configured trash type: "Grünmüll" with ID "type.grünmüll"
                          trashschedule.0
                          7992	2022-05-28 12:44:26.318	debug	found configured trash type: "Gelber Sack" with ID "type.gelberSack"
                          trashschedule.0
                          7992	2022-05-28 12:44:26.313	debug	found existing trash type with ID "type.restmüll"
                          trashschedule.0
                          7992	2022-05-28 12:44:26.313	debug	found existing trash type with ID "type.papiertonne"
                          trashschedule.0
                          7992	2022-05-28 12:44:26.312	debug	found existing trash type with ID "type.grünmüll"
                          trashschedule.0
                          7992	2022-05-28 12:44:26.312	debug	found existing trash type with ID "type.gelberSack"
                          trashschedule.0
                          7992	2022-05-28 12:44:26.311	debug	found existing trash type with ID "type."
                          trashschedule.0
                          7992	2022-05-28 12:44:26.123	info	starting. Version 2.0.2 in C:/iobroker/GLT/node_modules/iobroker.trashschedule, node: v14.16.0, js-controller: 4.0.23
                          trashschedule.0
                          7992	2022-05-28 12:44:25.355	debug	Plugin sentry Initialize Plugin (enabled=true)
                          vis.0
                          3268	2022-05-28 12:44:25.112	info	vis license is OK.
                          trashschedule.0
                          7992	2022-05-28 12:44:24.965	debug	States connected to redis: 127.0.0.1:9000
                          trashschedule.0
                          7992	2022-05-28 12:44:24.838	debug	States create User PubSub Client
                          trashschedule.0
                          7992	2022-05-28 12:44:24.836	debug	States create System PubSub Client
                          vis.0
                          3268	2022-05-28 12:44:24.778	info	starting. Version 1.4.15 in C:/iobroker/GLT/node_modules/iobroker.vis, node: v14.16.0, js-controller: 4.0.23
                          trashschedule.0
                          7992	2022-05-28 12:44:24.776	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                          trashschedule.0
                          7992	2022-05-28 12:44:24.690	debug	Objects connected to redis: 127.0.0.1:9001
                          trashschedule.0
                          7992	2022-05-28 12:44:24.647	debug	Objects client initialize lua scripts
                          trashschedule.0
                          7992	2022-05-28 12:44:24.508	debug	Objects create User PubSub Client
                          trashschedule.0
                          7992	2022-05-28 12:44:24.507	debug	Objects create System PubSub Client
                          trashschedule.0
                          7992	2022-05-28 12:44:24.490	debug	Objects client ready ... initialize now
                          trashschedule.0
                          7992	2022-05-28 12:44:24.248	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            host.GLTGLT)
                            host.GLTGLT)
                            host.GLTGLT)
                            host.GLTGLT)
                            host.GLTGLT)
                            host.GLTGLT)
                            host.GLTGLT)
                            host.GLTGLT)
                            host.GLTGLT)
                            host.GLTGLT)
                            host.GLTGLT)
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            vis.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            vis.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            trashschedule.0
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #1178
                            @jb_sullivan sagte in Test Adapter TrashSchedule:
                            in der 2.0.0
                            EDIT:
                            kannst du den Inhalt im Spoiler nicht in Code-Tags </> packen , kann man schlecht lesen / kopieren
                            • Sa GöS Offline
                              Sa GöS Offline
                              Sa Gö
                              #1179
                              Hallo!
                              Ich habe seit kurzem das Problem, wenn ich die Instanz aufrufe, kommt folgende Meldung:
                              "This adapter version has no support for "Admin 4" configuration. Please switch to "Admin 5" UI or downgrade to an older version (see changelog for details)."
                              Von der Sache her sollte aber alles passen. Admin 5 habe ich "aktiviert", Node.js ist ist Version 14.19.2 und NPM ist 6.14.17.
                              Hat jemand eine Idee was das Problem ist? In der VIS ist alles in Ordnung ich kann ihn nur nicht konfigurieren.
                              Danke.
                              Thomas BraunT haus-automatisierungH 2 Antworten Letzte Antwort
                              • Sa GöS Sa Gö
                                Hallo!
                                Danke.
                                #1180
                                @sa-gö
                                'Alte Oberfläche' aktiv?
                                Sa GöS 1 Antwort Letzte Antwort
                                • Sa GöS Sa Gö
                                  Hallo!
                                  Danke.
                                  #1181
                                  @sa-gö Du hast aber in den Instanzeinstellungen vom Admin aktiviert, dass Du die alte Benutzeroberfläche nutzen möchtest. Die entwickle ich nicht mehr (wie viele andere Adapter auch).
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    host.GLTGLT)
                                    host.GLTGLT)
                                    host.GLTGLT)
                                    host.GLTGLT)
                                    host.GLTGLT)
                                    host.GLTGLT)
                                    host.GLTGLT)
                                    host.GLTGLT)
                                    host.GLTGLT)
                                    host.GLTGLT)
                                    host.GLTGLT)
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    vis.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    vis.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    trashschedule.0
                                    #1182
                                    @jb_sullivan Irgendwie hast Du ein leeres Objekt ohne ID unter Restmüll. Das verursacht das Problem. Wie auch immer das da hingekommen ist. Man kann (auch als Adapter) keine Objekte anlegen, welche auf . enden
                                      @sa-gö
                                      Sa GöS Offline
                                      Sa GöS Offline
                                      Sa Gö
                                      #1183
                                      @thomas-braun sagte in Test Adapter TrashSchedule:
                                      @sa-gö
                                      Danke, das wars. Gesehen habe ich den haken, aber natürlich nicht darüber nachgedacht das da mal was war. Habe ich doch glatt wieder vergessen umzustellen. Danke, auch @haus-automatisierung ! Schönes Wochenende.
                                      • SBorgS SBorg
                                        #1184
                                        @sborg sagte in Test Adapter TrashSchedule:
                                        Ich habe in meinen Adaptern das title-Attribut gelöscht (weil deprecated).
                                        Ist also ein Bug im Info-Adapter, welcher dort titleLang anzeigen sollte.
                                          JB_Sullivan
                                          #1185
                                          Kann da unter Restmüll nichts finden, egal ob 2.0.0 oder 2.0.2. Ich selber habe da aber noch nie irgend wann, irgend etwas als leeren Typen angelegt.
                                          Hier der Screenshot unter 2.0.2
                                          Es gibt ein leeres Typ Objekt, was sich aber nicht löschen läßt, weder unter 2.0.0 noch unter 2.0.2. - ich weiß auch nicht seit wann diese "Leiche" schon vorhanden ist. Wie gesagt, läßt sich aber weder unter der einen noch unter der anderen Version löschen.
