  4. ZigBee neue Version 1.6.x
    6.4k
509 Beiträge 61 Kommentatoren 150.5k Aufrufe 62 Beobachtet
  • arteckA arteck
    @diwoma jo korrigiert.. schau nochmal
    diwoma
    #488
    @arteck
    Danke für die schnelle Reaktion und dem Fix. Start ist wieder normal:
    2022-05-24 13:25:59.360 - info: zigbee.0 (25592) starting. Version 1.6.18 (non-npm: ioBroker/ioBroker.zigbee#nobackups) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 4.0.23
    2022-05-24 13:25:59.576 - info: zigbee.0 (25592) delete old Backup files. keep only last 10
    2022-05-24 13:25:59.580 - info: zigbee.0 (25592) Starting Zigbee npm ...
    2022-05-24 13:26:00.102 - error: zigbee.0 (25592) Device 0xa4c13879937e5fa8 "TS011F_plug_3" not described in statesMapping.
    2022-05-24 13:26:00.108 - info: zigbee.0 (25592) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
    2022-05-24 13:26:00.441 - info: zigbee.0 (25592) Installed Version: ioBroker/ioBroker.zigbee#nobackups
    2022-05-24 13:26:00.464 - info: zigbee.0 (25592) Unable to disable LED, unsupported function.
    2022-05-24 13:26:00.468 - info: zigbee.0 (25592) --> transmitPower : normal
    2022-05-24 13:26:00.640 - info: zigbee.0 (25592) Unable to set transmit power, unsupported function.
    2022-05-24 13:26:00.652 - info: zigbee.0 (25592) Currently 22 devices are joined:
    2022-05-24 13:26:00.715 - info: zigbee.0 (25592) 0xcc86ecfffefa8e75 (addr 10983): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
    2022-05-24 13:26:00.718 - info: zigbee.0 (25592) 0xcc86ecfffefa8c81 (addr 40351): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
    2022-05-24 13:26:00.720 - info: zigbee.0 (25592) 0xcc86ecfffefa8fbf (addr 46151): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
    2022-05-24 13:26:00.723 - info: zigbee.0 (25592) 0xb4e3f9fffed0a7d3 (addr 54857): LED1949C5 - IKEA TRADFRI LED bulb E14 470 lumen, wireless dimmable white spectrum/chandelier opal white (Router)
    2022-05-24 13:26:00.725 - info: zigbee.0 (25592) 0x00158d0007014491 (addr 60981): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2022-05-24 13:26:00.727 - info: zigbee.0 (25592) 0x00158d000705d7eb (addr 5306): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-05-24 13:26:00.730 - info: zigbee.0 (25592) 0x84fd27fffe636592 (addr 16279): ZTS-EU_1gang - Moes Wall touch light switch (1 gang) (EndDevice)
    2022-05-24 13:26:00.732 - info: zigbee.0 (25592) 0x5c0272fffe1a08fc (addr 22569): ZTS-EU_2gang - Moes Wall touch light switch (2 gang) (EndDevice)
    2022-05-24 13:26:00.733 - info: zigbee.0 (25592) 0x00158d0007e4df68 (addr 19189): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-24 13:26:00.735 - info: zigbee.0 (25592) 0xa4c1380b13a7ccdc (addr 62650): TS0503B - TuYa Zigbee RGB light (Router)
    2022-05-24 13:26:00.737 - info: zigbee.0 (25592) 0x00158d0007e0e614 (addr 42568): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    2022-05-24 13:26:00.738 - info: zigbee.0 (25592) 0x00158d0006d0d895 (addr 48195): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2022-05-24 13:26:00.740 - info: zigbee.0 (25592) 0x00158d000704fe0a (addr 10152): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-05-24 13:26:00.742 - info: zigbee.0 (25592) 0xa4c1389993af0e21 (addr 27159): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
    2022-05-24 13:26:00.745 - info: zigbee.0 (25592) 0xa4c1387a0ae125eb (addr 13955): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
    2022-05-24 13:26:00.746 - info: zigbee.0 (25592) 0x00158d000705e33b (addr 63043): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-05-24 13:26:00.748 - info: zigbee.0 (25592) 0x00158d0007e0a744 (addr 63795): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-05-24 13:26:00.749 - info: zigbee.0 (25592) 0x00158d0007e086a3 (addr 7819): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-05-24 13:26:00.751 - info: zigbee.0 (25592) 0x847127fffec6ac1c (addr 52994): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
    2022-05-24 13:26:00.756 - info: zigbee.0 (25592) 0xa4c13879937e5fa8 (addr 38175): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
    2022-05-24 13:26:00.758 - info: zigbee.0 (25592) 0x0c4314fffe98da63 (addr 55684): ZTS-EUR-C - Moes Zigbee + RF curtain switch (Router)
    2022-05-24 13:26:00.760 - info: zigbee.0 (25592) 0xa4c138fa86b402b3 (addr 42671): TS130F - TuYa Curtain/blind switch (Router)
    2022-05-24 13:26:00.761 - info: zigbee.0 (25592) Zigbee started
    2022-05-24 13:27:06.014 - warn: zigbee.0 (25592) DeviceAvailability:Failed to ping 0xa4c138fa86b402b3 TS130F
    2022-05-24 13:27:06.017 - warn: zigbee.0 (25592) DeviceAvailability:Failed to ping 0x0c4314fffe98da63 TS0601
    Picture noch nicht gefunden, soll ich jetzt das Device in den Objects löschen und neu starten?
    Das Bild ist mir prinzipiell nicht so wichtig wie ein funktionierender Adapter und ein erkanntes Device, es geht nur um die Ästhetik
    -- diwoma
    ioBroker in LX-Container in Proxmox
    Zigbee-Coordinator: CC2652P2-TCP FW: 20230507
    • D diwoma
      @arteck
      arteckA Offline
      arteckA Offline
      arteck
      #489
      @diwoma sagte in ZigBee neue Version 1.6.x:
      jo dann adapter neu starten und dann nochmal leider ein upload
      • arteckA arteck
        diwoma
        #490
        @arteck
        mehrfach durchgeführt, kein Bild.
        Ist es nicht möglich, daß für dieses Device einfach kein Bild hinterlegt ist? Wenn es erst in den Converter eingetragen wurde?
        Wo wird denn eigentlich das Bild dafür hinterlegt?
        -- diwoma
        • D diwoma
          @arteck
          arteckA Offline
          arteckA Offline
          arteck
          #491
          @diwoma die bilder kommen entweder von uns.. oder neu in dem branch aus dem zigbee2mqtt
          https://www.zigbee2mqtt.io/supported-devices/ Projekt..
          kannst ja mal schauen ob es da vorhanden ist..da spielt der converter keine rolle
          • arteckA arteck
            diwoma
            #492
            @arteck said in ZigBee neue Version 1.6.x:
            Habe ich nachgeschaut, dort ist er nicht vorhanden. Soll ich auf GIT einen Issue eröffnen, das das Device eingetragen werden soll?
            -- diwoma
            • D diwoma
              arteckA Offline
              arteckA Offline
              arteck
              #493
              @diwoma wenn der da nicht vorhaden ist.. dann hilft dir der issue bei uns nicht. da es komplett unbekannt ist
              funktioniert das Ding den überhaupt..
              • arteckA arteck
                diwoma
                #494
                Ja, mit dem letzten Update habe ich auch die letzten Updates vom Herdsman bekommen, wo das Device eingetragen ist. Ich habe zwar noch keinen Rolladen-Motor angeschlossen, aber die Daten für Öffnen/Schliessen vom Device werden übermittelt, bzw. können von ioBroker-Zigbee-Device angesteuert werden
                -- diwoma
                • C Offline
                  Cino
                  #495
                  Ich will alle Geräte löschen. Habe den Zigbee Adapter komplett deinstalliert und dann über github wieder installiert.
                  Einige Geräte sind sofort wieder aufgetaucht.
                  Wie kann ich also alles löschen? Ich will alles neu anlernen.
                  IOB@RPI4
                  Shelly, Zigbee, ebus
                  AsgothianA arteckA 2 Antworten Letzte Antwort
                  • C Cino
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #496
                    @cino der einfachste weg ist alles über den Adapter löschen - im Zweifelsfall mit dem Haken bei “löschen erzwingen”
                    Dann adapter deinstallieren, Verzeichnis /opt/iobroker/iobroker-data/zigbee_0 löschen.
                    A.
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      #497
                      @asgothian na ja der einfache weg ist der button unter Einstellungen. Hard Reset..
                      • C Cino
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #498
                        @cino wozu wilst du alles neu nlernen ??
                        C 1 Antwort Letzte Antwort
                        • JackDanielJ Online
                          JackDanielJ Online
                          JackDaniel
                          #499
                          bei mir crasht der adapter wenn ich ein firmware update starte
                          anbei ein debug log, hoffe da sieht man etwas
                          debug_log.txt
                          Carpe diem
                          • JackDanielJ JackDaniel
                            debug_log.txt
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #500
                            @jackdaniel jo
                            das hätte aber gereicht
                            zigbee.0 2022-05-27 12:18:21.592	info	cleaned everything up...
                            zigbee.0 2022-05-27 12:18:21.591	error	Timeout - 27803 - 1 - null - 25 - 1 after 30000ms
                            zigbee.0 2022-05-27 12:18:21.591	error	Error: Timeout - 27803 - 1 - null - 25 - 1 after 30000ms at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:37:35) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
                            zigbee.0 2022-05-27 12:18:21.590	error	unhandled promise rejection: Timeout - 27803 - 1 - null - 25 - 1 after 30000ms
                            zigbee.0 2022-05-27 12:18:21.590	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            • arteckA arteck
                              Cino
                              #501
                              Bei mir lief nichts mehr. War aber ein Hardwaredefekt. Jetzt mit neuem Stick geht wieder alles.
                              IOB@RPI4
                              • arteckA arteck
                                wit haben gestern abend eine neue Version des Adapter publiziert..
                                in der latest die ihr im Admin sieht ist die allgemeine Version die wir normalerweise auch preferieren.. hier sind alle Geräte auch gepflegt bzw. der converter immer akuell
                                ABER
                                sollte diese Version nicht funktionieren bitte diese aus dem GIT installieren
                                https://github.com/ioBroker/ioBroker.zigbee/tarball/old_herdsman
                                sollte der Adapter immer noch nicht starten
                                hierzu muss noch die nvbackup.json gelöscht werden
                                adapter stoppen
                                rm /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json
                                adapter starten
                                warum so ein hickmeck....
                                es betrifft nicht die conbee Sticks
                                es hängt mit der Firmware zusammen die auf den Sticks drauf ist. Vor allem auf den CC2538 + CC2592 hat sich die Firmware nach und nach weiter entwickelt und
                                NUR die CC2538 + CC2592 sind BETROFFEN
                                alle die eine Firmware 20201010 haben sollten keine Probleme bekommen. Diese Firmware unterstützt das sichern und zurückspielen der Zigbee Netz Parameter.
                                alles was älter ist kann laufen was eher unwarscheinlich ist.
                                darüberhinaus hat das Projekt zigbee2mqtt erst jetzt damit begonen das zu unterstützen und da wir drauf aufsetzten sind wir von abhängig
                                wo sehe ich meine Firmware :
                                in der Kachel
                                p.s: wenn ihr wollt kann ich euch meine Sticks auf die neue Firmware bringen. Bedenkt aber auch dass es ein komplettes neu anlernen der Geräte mit sich zieht.
                                hierzu PM an mich
                                ZarelloZ Offline
                                ZarelloZ Offline
                                Zarello
                                #502
                                @arteck Ich habe eben mal den Zigbee-Adapter von Git installiert, da eine frisch gekaufte Ikea-Lampe bei mir nicht funktionieren wollte. Es gab nach dem Koppeln nur eine leere Karte mit der Bezeichnung "undefined". Das ist zwar mit der aktuellen Version genauso, aber im Log tauchen einige Hinweise über die Lampe auf mit der Bitte, dies an den Entwickler zu schicken. Das mache ich hiermit mal.
                                Das Log kürze ich um die ganzen Geräte, die keine Probleme machen:
                                2022-05-29 19:37:13.606 - info: zigbee.0 (1198128) Zigbee: allowing new devices to join.
                                2022-05-29 19:37:19.419 - info: javascript.0 (1197683) Stop script script.js.common.PairZigbeeIkeaLamp
                                2022-05-29 19:37:19.478 - info: javascript.0 (1197683) Start javascript script.js.common.PairZigbeeIkeaLamp
                                2022-05-29 19:37:19.482 - info: javascript.0 (1197683) script.js.common.PairZigbeeIkeaLamp: registered 0 subscriptions and 0 schedules
                                2022-05-29 19:37:42.765 - info: zigbee.0 (1198128) Starting interview of '0xb4e3f9fffec5070a'
                                2022-05-29 19:37:46.136 - warn: zigbee.0 (1198128) Device '0xb4e3f9fffec5070a' announced itself
                                2022-05-29 19:37:46.140 - error: zigbee.0 (1198128) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2022-05-29 19:37:46.140 - error: zigbee.0 (1198128) unhandled promise rejection: Cannot read property 'color_options' of undefined
                                2022-05-29 19:37:46.143 - error: zigbee.0 (1198128) TypeError: Cannot read property 'color_options' of undefined
                                at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
                                at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
                                at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
                                at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
                                at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
                                2022-05-29 19:37:46.143 - error: zigbee.0 (1198128) Cannot read property 'color_options' of undefined
                                2022-05-29 19:37:46.153 - info: zigbee.0 (1198128) cleaned everything up...
                                2022-05-29 19:37:46.302 - info: zigbee.0 (1198128) Zigbee: disabling joining new devices.
                                2022-05-29 19:37:46.654 - info: zigbee.0 (1198128) terminating
                                2022-05-29 19:37:46.656 - warn: zigbee.0 (1198128) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                2022-05-29 19:37:47.253 - error: host.music-pi2 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2022-05-29 19:37:47.254 - error: host.music-pi2 Caught by controller[1]: TypeError: Cannot read property 'color_options' of undefined
                                2022-05-29 19:37:47.254 - error: host.music-pi2 Caught by controller[1]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
                                2022-05-29 19:37:47.254 - error: host.music-pi2 Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
                                2022-05-29 19:37:47.255 - error: host.music-pi2 Caught by controller[1]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
                                2022-05-29 19:37:47.255 - error: host.music-pi2 Caught by controller[1]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
                                2022-05-29 19:37:47.255 - error: host.music-pi2 Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
                                2022-05-29 19:37:47.255 - error: host.music-pi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                2022-05-29 19:37:47.256 - info: host.music-pi2 Restart adapter system.adapter.zigbee.0 because enabled
                                2022-05-29 19:38:17.416 - info: host.music-pi2 instance system.adapter.zigbee.0 started with pid 1198450
                                2022-05-29 19:38:21.251 - info: zigbee.0 (1198450) starting. Version 1.7.2 (non-npm: ioBroker/ioBroker.zigbee#7126ffe5190e8aecc92053343c5713e877f6e01b) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.2, js-controller: 4.0.23
                                2022-05-29 19:38:21.367 - info: zigbee.0 (1198450) delete old Backup files. keep only last 10
                                2022-05-29 19:38:21.370 - info: zigbee.0 (1198450) Starting Zigbee npm ...
                                2022-05-29 19:38:21.975 - info: zigbee.0 (1198450) Installed Version: ioBroker/ioBroker.zigbee#7126ffe5190e8aecc92053343c5713e877f6e01b
                                2022-05-29 19:38:22.346 - info: zigbee.0 (1198450) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20201127}}
                                2022-05-29 19:38:22.353 - info: zigbee.0 (1198450) Unable to disable LED, unsupported function.
                                2022-05-29 19:38:22.368 - info: zigbee.0 (1198450) --> transmitPower : normal
                                2022-05-29 19:38:22.384 - info: zigbee.0 (1198450) Currently 29 devices are joined:
                                2022-05-29 19:38:22.521 - info: zigbee.0 (1198450) Configuring 0xb4e3f9fffec5070a TRADFRIbulbE14WScandleopal470lm
                                [hier die Logs der funktionierenden Geräte entfernt]
                                2022-05-29 19:38:22.596 - info: zigbee.0 (1198450) 0xb4e3f9fffec5070a (addr 23443): LED1949C5 - IKEA TRADFRI LED bulb E14 470 lumen, wireless dimmable white spectrum/chandelier opal white (Router)
                                2022-05-29 19:38:22.597 - info: zigbee.0 (1198450) Zigbee started
                                2022-05-29 19:38:22.804 - info: zigbee.0 (1198450) debug devices set to []
                                2022-05-29 19:38:22.991 - info: zigbee.0 (1198450) DeviceConfigure successful 0xb4e3f9fffec5070a TRADFRIbulbE14WScandleopal470lm
                                2022-05-29 19:38:23.800 - warn: zigbee.0 (1198450) Object b4e3f9fffec5070a.effect is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                2022-05-29 19:38:23.801 - warn: zigbee.0 (1198450) This object will not be created in future versions. Please report this to the developer.
                                2022-05-29 19:38:23.802 - warn: zigbee.0 (1198450) Object b4e3f9fffec5070a.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                2022-05-29 19:38:23.803 - warn: zigbee.0 (1198450) This object will not be created in future versions. Please report this to the developer.
                                2022-05-29 19:38:23.978 - warn: zigbee.0 (1198450) Object zigbee.0.b4e3f9fffec5070a.effect is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                2022-05-29 19:38:23.978 - warn: zigbee.0 (1198450) This object will not be created in future versions. Please report this to the developer.
                                2022-05-29 19:38:23.979 - warn: zigbee.0 (1198450) Object zigbee.0.b4e3f9fffec5070a.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                2022-05-29 19:38:23.980 - warn: zigbee.0 (1198450) This object will not be created in future versions. Please report this to the developer.
                                Als ich die Lampe neu gekoppelt habe, wurde die Instanz übrigens neu gestartet und das Koppeln wurde an der Stelle abgebrochen (im Browser wurden die Sekunden nicht weiter gezählt).
                                Falls Du noch weitere Infos benötigst, kann ich Dir die natürlich gerne noch nachreichen.
                                K arteckA 2 Antworten Letzte Antwort
                                • ZarelloZ Zarello
                                  K_o_bold
                                  #503
                                  Ich hatte heute das erste mal einen Ausfall des Zigbee Adapters.
                                  Nach Neustart des Adapters waren alle Geräte wieder funktionsfähig.
                                  Node.js : 14.19.1
                                  JS Controller: 4.0.23
                                  Zigbee Adapter: 1.6.18
                                  Mein Server läuft seit 39 Tagen 24/7.
                                  Eventuell hilft das einem der Entwickler. Ich kann schwer einschätzen ob es sich um einen Bug handelt.
                                  Folgender log war vorzufinden:
                                  zigbee.0 2022-05-29 20:41:29.465	error	Error herdsman start
                                  zigbee.0 2022-05-29 20:41:29.465	error	Failed to start Zigbee
                                  zigbee.0 2022-05-29 20:41:29.465	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                  zigbee.0 2022-05-29 20:41:19.296	error	Error herdsman start
                                  zigbee.0 2022-05-29 20:41:19.296	error	Failed to start Zigbee
                                  zigbee.0 2022-05-29 20:41:19.295	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                  zigbee.0 2022-05-29 20:41:09.146	error	Error herdsman start
                                  zigbee.0 2022-05-29 20:41:09.145	error	Failed to start Zigbee
                                  zigbee.0 2022-05-29 20:41:09.145	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                  zigbee.0 2022-05-29 20:40:58.956	error	Error herdsman start
                                  zigbee.0 2022-05-29 20:40:58.955	error	Failed to start Zigbee
                                  zigbee.0 2022-05-29 20:40:58.954	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                  zigbee.0 2022-05-29 20:40:48.762	error	Error herdsman start
                                  zigbee.0 2022-05-29 20:40:48.761	error	Failed to start Zigbee
                                  zigbee.0 2022-05-29 20:40:48.758	error	Starting zigbee-herdsman problem : "SRSP - SYS - getExtAddr after 6000ms"
                                  zigbee.0 2022-05-29 20:40:32.525	error	Adapter disconnected, stopping
                                  • K K_o_bold
                                    Node.js : 14.19.1
                                    #504
                                    @k_o_bold sagte in ZigBee neue Version 1.6.x:
                                    Welcher Stick/Chipsatz wird da verwendet?
                                      K_o_bold
                                      #505
                                      @thomas-braun ,
                                      Sonoff Zigbee 3.0 USB Dongle.
                                      • K K_o_bold
                                        @thomas-braun ,
                                        #506
                                        @k_o_bold
                                        Die Meldung SRSP - SYS - getExtAddr after 6000ms kommt gerne bei Schluckauf der Firmware der Sticks. Da ist die aktuellste installiert?
                                          @k_o_bold
                                          K_o_bold
                                          #507
                                          @thomas-braun ,
                                          ich habe eine Version aus 12.2021..
                                          So wie ich gesehen habe, gibt es eine neuere...02.2022.
                                          Danke für den Tipp. Eventuell liegt es an der Software.
                                          Sollte es nochmal vorkommen, werde ich mal updaten.
