  4. Backup über Backitup oder Konsole läuft nicht durch
    5.9k
43 Beiträge 7 Kommentatoren 5.1k Aufrufe 7 Beobachtet
  • G grisu1000
    @thomas-braun said in Backup über Backitup oder Konsole läuft nicht durch:
    Stell den Adapter mal auf ein gesprächigeres Log Level, z. B. auf 'debug'.
    Dann nochmal
    Also das Log vom BackItUP Adapter auf Debug gestellt ... vorher den iobroker neu gestartet ...
    Backup gestartet aber mehr als
    backitup.0
    	2022-05-25 20:42:02.387	info	[iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.0
    	2022-05-25 20:42:02.091	info	starting. Version 2.4.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.3, js-controller: 4.0.21
    bringt das Log nicht zum Vorschein 🙄 ...
    @grisu1000 sagte in Backup über Backitup oder Konsole läuft nicht durch:
    Patch dein System. Aktuell ist js-controller: 4.0.23
    Debug aktiv?
    • G grisu1000
      Dann nochmal
      backitup.0
      backitup.0
      grisu1000
      js-controller ist aktualisiert 4.0.23
      debug jetzt aktiv 🙄
      [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"_XXXXXXXXXXX","dropboxTokenType":"default","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [iobroker] - host.raspberrypi 15971 states saved
      • G grisu1000
        debug jetzt aktiv 🙄
        @grisu1000
        Etwas mehr als die beiden Zeilen wird wohl ausgespuckt. Lass dir doch nicht alles aus der Nase ziehen...
        G 1 Antwort Letzte Antwort
          DrHouse03
          Guten Morgen,
          seit neuesten funktioniert das ioBroker Backup nicht mehr. Bekomme diese Fehlermeldung.
          [DEBUG] [iobroker] - host.raspberrypi 2583 states saved
          [DEBUG] [iobroker] - host.raspberrypi 3301 objects saved
          [ERROR] [iobroker] - host.raspberrypi Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: ENOENT: no such file or directory, open '/opt/iobroker/backups/iobroker_2022_05_26-08_22_17_backupiobroker.tar.gz'
          Verzeichnis ist aber vorhanden.
          Den Fixer habe ich auch schon versucht.
          Bitte um Hilfe.
          • D DrHouse03
            Guten Morgen,
            Bitte um Hilfe.
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @drhouse03 siehe einen Post über Deinem
            Lehrling seit 1975 !!!
              DrHouse03
              Sorry hier der ganze Log von Backitup
              Started iobroker ...
              [DEBUG] [iobroker] start with {"type":"creator","time":"01:00","debugging":true,"slaveBackup":"Single","everyXDays":"30","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/G/ioBroker_Backup","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
              [DEBUG] [iobroker] - host.raspberrypi 2568 states saved
              [ERROR] [iobroker] - host.raspberrypi Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: ENOENT: no such file or directory, open '/opt/iobroker/backups/iobroker_2022_05_26-09_16_59_backupiobroker.tar.gz'
              [DEBUG] [iobroker] - done
              [DEBUG] [ftp] - FTP connected.
              [DEBUG] [ftp] - Send iobroker_2022_05_26-09_16_59_backupiobroker.tar.gz
              [ERROR] [ftp] - File "/opt/iobroker/backups/iobroker_2022_05_26-09_16_59_backupiobroker.tar.gz" not found
              [DEBUG] [ftp] - done
              [DEBUG] [ftp] start with {"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/G/ioBroker_Backup","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","ignoreErrors":false,"deleteBackupAfter":0}
              [DEBUG] [clean] - done
              [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0
              [DEBUG] [telegram] - done
              [DEBUG] [telegram] start with {"type":"creator","time":"01:00","debugging":true,"slaveBackup":"Single","everyXDays":"30","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/G/ioBroker_Backup","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de","time":"26. Mai 2022 um 09:17 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
              [DEBUG] [historyHTML] - new history html values created
              [DEBUG] [historyHTML] - done
              [DEBUG] [historyJSON] - new history json values created
              [DEBUG] [historyJSON] - done
              [DEBUG] [historyHTML] start with {"type":"creator","time":"01:00","debugging":true,"slaveBackup":"Single","everyXDays":"30","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/G/ioBroker_Backup","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"26. Mai 2022 um 09:17 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
              [DEBUG] [historyJSON] start with {"type":"creator","time":"01:00","debugging":true,"slaveBackup":"Single","everyXDays":"30","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/G/ioBroker_Backup","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"26. Mai 2022 um 09:17 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
              [EXIT] 9
              • D DrHouse03
                [EXIT] 9
                simatecS Offline
                simatecS Offline
                simatec
                @drhouse03
                Schaue mal bitte, wie die Rechte des Backup Ordners aussehen.
                ls -lah /opt/iobroker/backups
                • Besuche meine Github Seite
                • HowTo Restore ioBroker
                • simatecS simatec
                  @drhouse03
                  DrHouse03
                  @simatec Wenn ich das versuche bekomm ich die Meldung
                  "Zugriff auf '/opt/iobroker/backups' nicht möglich: Datei oder Verzeichnis nicht gefunden"
                  • D DrHouse03
                    @drhouse03
                      @drhouse03
                      DrHouse03
                      schrieb am zuletzt editiert von DrHouse03
                      @DJMarc75
                      pi@raspberrypi:/opt/iobroker/backups $ ls -lah /opt/iobroker/
                      ls: Zugriff auf '/opt/iobroker/backups' nicht möglich: Datei oder Verzeichnis nicht gefunden
                      insgesamt 628K
                      drwxrwxr-x+   8 iobroker iobroker 4,0K Mai 26 08:19 .
                      drwxr-xr-x    4 root     root     4,0K Sep 29  2020 ..
                      d??????????   ? ?        ?           ?            ? backups
                      -rw-rwxr--+   1 iobroker iobroker 1,1K Sep 29  2020 CHANGELOG_FIXER_LINUX.md
                      -rw-rwxr--+   1 iobroker iobroker 3,5K Sep 29  2020 CHANGELOG_INSTALLER_LINUX.md
                      -rw-rwxr--+   1 iobroker iobroker  24K Sep 29  2020 fix_installation.sh
                      drwxrwxr-x+   3 iobroker iobroker 4,0K Sep 29  2020 install
                      -rwxrwxrwx+   1 iobroker iobroker 1001 Mai 26 08:17 INSTALLER_INFO.txt
                      lrwxrwxrwx    1 iobroker iobroker   22 Mai 26 08:17 iob -> /opt/iobroker/iobroker
                      -rwxr-xr-x+   1 iobroker iobroker  305 Mai 26 08:17 iobroker
                      drwxrwxr-x+  13 iobroker iobroker 4,0K Mai 26 10:29 iobroker-data
                      drwxrwxr-x+   2 iobroker iobroker 4,0K Sep 29  2020 lib
                      -rw-rwxr--+   1 iobroker iobroker 1,2K Sep 29  2020 LICENSE
                      drwxrwxr-x+   2 iobroker iobroker 4,0K Mai 26 08:21 log
                      drwxrwxr-x+ 753 iobroker iobroker  32K Mai 26 08:19 node_modules
                      -rw-rwxr--+   1 iobroker iobroker  155 Mai 26 08:17 .npmrc
                      -rw-rwxr--+   1 iobroker iobroker 1,4K Mai 26 08:19 package.json
                      -rw-rwxr--+   1 iobroker iobroker 497K Mai 26 08:19 package-lock.json
                      -rw-rwxr--+   1 iobroker iobroker 6,0K Sep 29  2020 README.md
                      -rw-rwxr--+   1 iobroker iobroker 5,6K Aug  1  2021 reinstall.js
                      DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                      • D DrHouse03
                        @DJMarc75
                        insgesamt 628K
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @drhouse03 bitte in Codetags
                        • D DrHouse03
                          @DJMarc75
                          insgesamt 628K
                          @drhouse03
                          Wie schafft man das denn? Da sind die ganzen Rechte und Eigentümer verbogen.
                            @drhouse03
                            DrHouse03
                            Ich habe im backitup adapter mal auf ftp umgestellt, und seitdem funktioniert es nicht mehr.
                            Hab gerade den Beitrag gefunden
                            https://forum.iobroker.net/topic/53989/backup-verzeichnis-und-rechte-fix-not-working/11
                            Werde aber auf CIFS umsteigen wenn es wieder geht
                            • D DrHouse03
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              @drhouse03 nicht ftp.... nfs oder cifs verweden.
                              • D DrHouse03
                                @drhouse03
                                Da stehst du auch im falschen Verzeichnis. Siehe den anderen Thread.
                                  @drhouse03
                                  DrHouse03
                                  Sorry bin auf Linux nicht so gut drauf
                                  Was ich noch gemacht habe ist, dass ich den USB Stick von der Fritzbox auf einen TP-Link Router umgesteckt habe, unten steht aber immer noch FRITZNAS
                                  Kanns daran liegen?
                                  pi@raspberrypi:/opt/iobroker/backups $ mount | sort
                                  //192.168.178.1/FRITZ.NAS/USB/ioBroker_Backup on /opt/iobroker/backups type cifs (rw,relatime,vers=3.0,cache=strict,username=ioBroker_Backup,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
                                  cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
                                  cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
                                  cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
                                  cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
                                  cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
                                  cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
                                  cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
                                  cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
                                  cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
                                  configfs on /sys/kernel/config type configfs (rw,relatime)
                                  debugfs on /sys/kernel/debug type debugfs (rw,relatime)
                                  devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
                                  /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
                                  /dev/sda2 on / type ext4 (rw,noatime)
                                  devtmpfs on /dev type devtmpfs (rw,relatime,size=3899872k,nr_inodes=85489,mode=755)
                                  mqueue on /dev/mqueue type mqueue (rw,relatime)
                                  none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
                                  proc on /proc type proc (rw,relatime)
                                  securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
                                  sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
                                  sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
                                  systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
                                  tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
                                  tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
                                  tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
                                  tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=806392k,mode=700,uid=1000,gid=1000)
                                  tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
                                  • D DrHouse03
                                    Kanns daran liegen?
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    @drhouse03 immernoch falsches Verzeichnis und einfach nur "umgesteckt" (ohne unmount) und womöglich ohne im Adapter alles neu einzustellen ?????? Uiuiui...
                                    • DJMarc75D DJMarc75
                                      DrHouse03
                                      @DJMarc75
                                      Im Adapter hätte ich es umgestellt. Hab den Stick jetzt wieder an die Fritzbox gesteckt, hier funktionierts wieder
                                      • D DrHouse03
                                        @DJMarc75
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        @drhouse03 said in Backup über Backitup oder Konsole läuft nicht durch:
                                        Und jetzt nochmals in der Konsole bitte
                                        vom home-Verzeichnis ausführen
                                          DrHouse03
                                          @djmarc75
                                          pi@raspberrypi:~ $ ls -lah /opt/iobroker
                                          insgesamt 652K
                                          drwxrwxr-x+   3 iobroker iobroker  20K Mai 26 13:24 backups
                                          drwxrwxr-x+   2 iobroker iobroker 4,0K Mai 26 13:23 log
