  4. Backup über Backitup oder Konsole läuft nicht durch
    5.9k
43 Beiträge 7 Kommentatoren 5.1k Aufrufe 7 Beobachtet
  • D DrHouse03
    Guten Morgen,
    seit neuesten funktioniert das ioBroker Backup nicht mehr. Bekomme diese Fehlermeldung.
    [DEBUG] [iobroker] - host.raspberrypi 2583 states saved
    [DEBUG] [iobroker] - host.raspberrypi 3301 objects saved
    [ERROR] [iobroker] - host.raspberrypi Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: ENOENT: no such file or directory, open '/opt/iobroker/backups/iobroker_2022_05_26-08_22_17_backupiobroker.tar.gz'
    Verzeichnis ist aber vorhanden.
    Den Fixer habe ich auch schon versucht.
    Bitte um Hilfe.
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @drhouse03 siehe einen Post über Deinem
    Lehrling seit 1975 !!!
      DrHouse03
      Sorry hier der ganze Log von Backitup
      Started iobroker ...
      [DEBUG] [iobroker] start with {"type":"creator","time":"01:00","debugging":true,"slaveBackup":"Single","everyXDays":"30","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/G/ioBroker_Backup","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [iobroker] - host.raspberrypi 2568 states saved
      [ERROR] [iobroker] - host.raspberrypi Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: ENOENT: no such file or directory, open '/opt/iobroker/backups/iobroker_2022_05_26-09_16_59_backupiobroker.tar.gz'
      [DEBUG] [iobroker] - done
      [DEBUG] [ftp] - FTP connected.
      [DEBUG] [ftp] - Send iobroker_2022_05_26-09_16_59_backupiobroker.tar.gz
      [ERROR] [ftp] - File "/opt/iobroker/backups/iobroker_2022_05_26-09_16_59_backupiobroker.tar.gz" not found
      [DEBUG] [ftp] - done
      [DEBUG] [ftp] start with {"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/G/ioBroker_Backup","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","ignoreErrors":false,"deleteBackupAfter":0}
      [DEBUG] [clean] - done
      [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0
      [DEBUG] [telegram] - done
      [DEBUG] [telegram] start with {"type":"creator","time":"01:00","debugging":true,"slaveBackup":"Single","everyXDays":"30","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/G/ioBroker_Backup","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de","time":"26. Mai 2022 um 09:17 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [historyHTML] start with {"type":"creator","time":"01:00","debugging":true,"slaveBackup":"Single","everyXDays":"30","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/G/ioBroker_Backup","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"26. Mai 2022 um 09:17 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [historyJSON] start with {"type":"creator","time":"01:00","debugging":true,"slaveBackup":"Single","everyXDays":"30","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.1","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/G/ioBroker_Backup","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"26. Mai 2022 um 09:17 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [EXIT] 9
      • D DrHouse03
        [EXIT] 9
        simatecS Offline
        simatecS Offline
        simatec
        @drhouse03
        Schaue mal bitte, wie die Rechte des Backup Ordners aussehen.
        ls -lah /opt/iobroker/backups
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • simatecS simatec
          @drhouse03
          DrHouse03
          @simatec Wenn ich das versuche bekomm ich die Meldung
          "Zugriff auf '/opt/iobroker/backups' nicht möglich: Datei oder Verzeichnis nicht gefunden"
          • D DrHouse03
            @drhouse03
              @drhouse03
              DrHouse03
              schrieb am zuletzt editiert von DrHouse03
              @DJMarc75
              pi@raspberrypi:/opt/iobroker/backups $ ls -lah /opt/iobroker/
              ls: Zugriff auf '/opt/iobroker/backups' nicht möglich: Datei oder Verzeichnis nicht gefunden
              insgesamt 628K
              drwxrwxr-x+   8 iobroker iobroker 4,0K Mai 26 08:19 .
              drwxr-xr-x    4 root     root     4,0K Sep 29  2020 ..
              d??????????   ? ?        ?           ?            ? backups
              -rw-rwxr--+   1 iobroker iobroker 1,1K Sep 29  2020 CHANGELOG_FIXER_LINUX.md
              -rw-rwxr--+   1 iobroker iobroker 3,5K Sep 29  2020 CHANGELOG_INSTALLER_LINUX.md
              -rw-rwxr--+   1 iobroker iobroker  24K Sep 29  2020 fix_installation.sh
              drwxrwxr-x+   3 iobroker iobroker 4,0K Sep 29  2020 install
              -rwxrwxrwx+   1 iobroker iobroker 1001 Mai 26 08:17 INSTALLER_INFO.txt
              lrwxrwxrwx    1 iobroker iobroker   22 Mai 26 08:17 iob -> /opt/iobroker/iobroker
              -rwxr-xr-x+   1 iobroker iobroker  305 Mai 26 08:17 iobroker
              drwxrwxr-x+  13 iobroker iobroker 4,0K Mai 26 10:29 iobroker-data
              drwxrwxr-x+   2 iobroker iobroker 4,0K Sep 29  2020 lib
              -rw-rwxr--+   1 iobroker iobroker 1,2K Sep 29  2020 LICENSE
              drwxrwxr-x+   2 iobroker iobroker 4,0K Mai 26 08:21 log
              drwxrwxr-x+ 753 iobroker iobroker  32K Mai 26 08:19 node_modules
              -rw-rwxr--+   1 iobroker iobroker  155 Mai 26 08:17 .npmrc
              -rw-rwxr--+   1 iobroker iobroker 1,4K Mai 26 08:19 package.json
              -rw-rwxr--+   1 iobroker iobroker 497K Mai 26 08:19 package-lock.json
              -rw-rwxr--+   1 iobroker iobroker 6,0K Sep 29  2020 README.md
              -rw-rwxr--+   1 iobroker iobroker 5,6K Aug  1  2021 reinstall.js
              DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
              • D DrHouse03
                @DJMarc75
                insgesamt 628K
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @drhouse03 bitte in Codetags
                • D DrHouse03
                  @DJMarc75
                  insgesamt 628K
                  @drhouse03
                  Wie schafft man das denn? Da sind die ganzen Rechte und Eigentümer verbogen.
                    @drhouse03
                    DrHouse03
                    Ich habe im backitup adapter mal auf ftp umgestellt, und seitdem funktioniert es nicht mehr.
                    Hab gerade den Beitrag gefunden
                    https://forum.iobroker.net/topic/53989/backup-verzeichnis-und-rechte-fix-not-working/11
                    Werde aber auf CIFS umsteigen wenn es wieder geht
                    • D DrHouse03
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      @drhouse03 nicht ftp.... nfs oder cifs verweden.
                      • D DrHouse03
                        @drhouse03
                        Da stehst du auch im falschen Verzeichnis. Siehe den anderen Thread.
                          @drhouse03
                          DrHouse03
                          Sorry bin auf Linux nicht so gut drauf
                          Was ich noch gemacht habe ist, dass ich den USB Stick von der Fritzbox auf einen TP-Link Router umgesteckt habe, unten steht aber immer noch FRITZNAS
                          Kanns daran liegen?
                          pi@raspberrypi:/opt/iobroker/backups $ mount | sort
                          //192.168.178.1/FRITZ.NAS/USB/ioBroker_Backup on /opt/iobroker/backups type cifs (rw,relatime,vers=3.0,cache=strict,username=ioBroker_Backup,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
                          cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
                          cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
                          cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
                          cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
                          cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
                          cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
                          cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
                          cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
                          cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
                          configfs on /sys/kernel/config type configfs (rw,relatime)
                          debugfs on /sys/kernel/debug type debugfs (rw,relatime)
                          devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
                          /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
                          /dev/sda2 on / type ext4 (rw,noatime)
                          devtmpfs on /dev type devtmpfs (rw,relatime,size=3899872k,nr_inodes=85489,mode=755)
                          mqueue on /dev/mqueue type mqueue (rw,relatime)
                          none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
                          proc on /proc type proc (rw,relatime)
                          securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
                          sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
                          sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
                          systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
                          tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
                          tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
                          tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
                          tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=806392k,mode=700,uid=1000,gid=1000)
                          tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
                          • D DrHouse03
                            Kanns daran liegen?
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            @drhouse03 immernoch falsches Verzeichnis und einfach nur "umgesteckt" (ohne unmount) und womöglich ohne im Adapter alles neu einzustellen ?????? Uiuiui...
                            • DJMarc75D DJMarc75
                              DrHouse03
                              @DJMarc75
                              Im Adapter hätte ich es umgestellt. Hab den Stick jetzt wieder an die Fritzbox gesteckt, hier funktionierts wieder
                              • D DrHouse03
                                @DJMarc75
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                @drhouse03 said in Backup über Backitup oder Konsole läuft nicht durch:
                                Und jetzt nochmals in der Konsole bitte
                                vom home-Verzeichnis ausführen
                                  DrHouse03
                                  @djmarc75
                                  pi@raspberrypi:~ $ ls -lah /opt/iobroker
                                  insgesamt 652K
                                  drwxrwxr-x+   3 iobroker iobroker  20K Mai 26 13:24 backups
                                  drwxrwxr-x+   2 iobroker iobroker 4,0K Mai 26 13:23 log
                                  • D DrHouse03
                                    @DJMarc75
                                    @drhouse03
                                    Watt denn nu?
                                    Jetzt bist du wieder mit CIFS/SMB unterwegs. Und das kann nicht gemountet werden, wenn du da im Weg rumstehst.
                                    Mach dich da mal vom Acker.
                                    cd ~
                                    [Edit:] Läuft das nun wieder?
                                      @drhouse03
                                      Watt denn nu?
                                      cd ~
                                      DrHouse03
                                      @DJMarc75
                                      Danke für eure Unterstützung, es funktioniert jetzt alles über CIFS am neuen Router.
                                        @grisu1000
                                        Etwas mehr als die beiden Zeilen wird wohl ausgespuckt. Lass dir doch nicht alles aus der Nase ziehen...
                                        grisu1000
                                        @thomas-braun tatsächlich kommt da exakt das und nicht mehr ... dann steht da ne ganze Zeit xx states saved und es tut sich nix. Irgendwann meldet sich mein Blockly Script (Waschmaschine ist fertig) ... als ob ich den iobroker neu gestartet hätte.
                                        • G grisu1000
                                          @grisu1000
                                          Das backup soll rein lokal erfolgen?
                                          Wie sehen die Rechte an /opt/iobroker/backups aus?
                                          iobroker fix
                                          mal ausgeführt?
                                          G 2 Antworten Letzte Antwort
