VIS unterbricht Ansicht
unter Protokolle stand noch info habe auf debug gestellt.
hier das Logweb.0 2022-05-24 18:42:20.931 debug error web.0 2022-05-24 18:42:20.931 debug error web.0 2022-05-24 18:42:20.931 debug error web.0 2022-05-24 18:42:20.930 debug error web.0 2022-05-24 18:42:20.930 debug error web.0 2022-05-24 18:42:20.930 debug error web.0 2022-05-24 18:42:20.930 debug error web.0 2022-05-24 18:42:20.930 debug error web.0 2022-05-24 18:42:20.929 debug error web.0 2022-05-24 18:42:20.929 debug error web.0 2022-05-24 18:42:20.929 debug error web.0 2022-05-24 18:42:20.929 debug error web.0 2022-05-24 18:42:20.929 debug error web.0 2022-05-24 18:42:20.928 debug error web.0 2022-05-24 18:42:20.928 debug error web.0 2022-05-24 18:42:20.928 debug error web.0 2022-05-24 18:42:20.928 debug error web.0 2022-05-24 18:42:20.928 debug error web.0 2022-05-24 18:42:20.927 debug error web.0 2022-05-24 18:42:20.927 debug error web.0 2022-05-24 18:42:20.923 debug error web.0 2022-05-24 18:42:20.923 debug error web.0 2022-05-24 18:42:20.923 debug error web.0 2022-05-24 18:42:20.922 debug error web.0 2022-05-24 18:42:20.858 debug error web.0 2022-05-24 18:42:20.857 debug error web.0 2022-05-24 18:42:20.857 debug error web.0 2022-05-24 18:42:20.857 debug error web.0 2022-05-24 18:42:20.855 debug error web.0 2022-05-24 18:42:20.855 debug error web.0 2022-05-24 18:42:20.855 debug error web.0 2022-05-24 18:42:20.854 debug error web.0 2022-05-24 18:42:20.854 debug error web.0 2022-05-24 18:42:20.854 debug error web.0 2022-05-24 18:42:20.854 debug error web.0 2022-05-24 18:42:20.853 debug error web.0 2022-05-24 18:42:20.853 debug error web.0 2022-05-24 18:42:20.853 debug error web.0 2022-05-24 18:42:20.853 debug error web.0 2022-05-24 18:42:20.853 debug error web.0 2022-05-24 18:42:20.852 debug error web.0 2022-05-24 18:42:20.852 debug error web.0 2022-05-24 18:42:20.852 debug error web.0 2022-05-24 18:42:20.851 debug error web.0 2022-05-24 18:42:20.851 debug error web.0 2022-05-24 18:42:20.851 debug error web.0 2022-05-24 18:42:20.851 debug error web.0 2022-05-24 18:42:20.850 debug error web.0 2022-05-24 18:42:20.850 debug error web.0 2022-05-24 18:42:20.850 debug error web.0 2022-05-24 18:42:20.850 debug error web.0 2022-05-24 18:42:20.849 debug error web.0 2022-05-24 18:42:20.849 debug error web.0 2022-05-24 18:42:20.849 debug error web.0 2022-05-24 18:42:20.848 debug error web.0 2022-05-24 18:42:20.848 debug error web.0 2022-05-24 18:42:20.847 debug error web.0 2022-05-24 18:42:20.837 debug error web.0 2022-05-24 18:42:20.837 debug error web.0 2022-05-24 18:42:20.836 debug error web.0 2022-05-24 18:42:20.836 debug Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, 0_userdata.0.vis.View_Status.Links, 0_userdata.0.vis.View_Status.Menu_Links, daswetter.0.NextDays.Location_1.Day_1.Minimale_Temperatur_value, daswetter.0.NextDays.Location_1.Day_1.Maximale_Temperatur_value, javascript.0.Wetterstation.Aussentemperatur, accuweather.0.Current.WeatherIconURL, trashschedule.0.next.typesText, trashschedule.0.next.dateFormat web.0 2022-05-24 18:42:20.700 debug Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command web.0 2022-05-24 18:42:20.357 debug 2022-05-24T16:42:20.357Z Request authenticate [system.user.admin] web.0 2022-05-24 18:42:20.249 debug Connection from vis.0 web.0 2022-05-24 18:42:20.225 info ==> Connected system.user.admin from ::ffff:192.168.178.21 web.0 2022-05-24 18:42:19.691 info <== Disconnect system.user.admin from ::ffff:192.168.178.21 vis.0Wastl
doch
@langer sagte in VIS unterbricht Ansicht:
aber dann nur noch error ohne weitere Infos???
Ich hatte noch andere auf debug gestellt, mein Fehler jetzt ist nur noch der WEB adapter auf debug.
Nächstes Log kommt
Entschuldigung
Wastl
Nächstes Log kommt
Entschuldigung
Wastl
Nächstes Log kommt
Bitte alles zeigen ( nichts Filtern ) ,was kommt im Log vor und nach dem Absturz / Neustart .
Hier der LOG
web.0 2022-05-24 19:02:13.152 debug Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, 0_userdata.0.vis.View_Status.Links, 0_userdata.0.vis.View_Status.Menu_Links, daswetter.0.NextDays.Location_1.Day_1.Minimale_Temperatur_value, daswetter.0.NextDays.Location_1.Day_1.Maximale_Temperatur_value, javascript.0.Wetterstation.Aussentemperatur, accuweather.0.Current.WeatherIconURL, trashschedule.0.next.typesText, trashschedule.0.next.dateFormat, bshb.0.roomClimateControl_hz_8.TemperatureLevel.temperature, bshb.0.roomClimateControl_hz_8.RoomClimateControl.boostMode, 0_userdata.0.vis.Status.Raeume.Schlafzimmer.StatusFensterLinks, bshb.0.roomClimateControl_hz_8.RoomClimateControl.operationMode, bshb.0.roomClimateControl_hz_8.RoomClimateControl.summerMode, 0_userdata.0.vis.Status.Raeume.Kueche.FarbeKuehlschrank, bshb.0.hdm:ZigBee:847127fffe7f1a8b.PowerSwitch.switchState, bshb.0.hdm:ZigBee:847127fffe7f1a8b.PowerMeter.powerConsumption, 0_userdata.0.vis.Status.Geraete.Walter_PC.Farbe, bshb.0.hdm:ZigBee:847127fffe1a3a48.PowerSwitch.switchState, bshb.0.hdm:ZigBee:847127fffe1a3a48.PowerMeter.powerConsumption, bshb.0.hdm:HomeMaticIP:3014F711A000191BB85AFD8C.PowerSwitch.switchState, 0_userdata.0.vis.Status.Licht.Keller.Farbe, bshb.0.hdm:HomeMaticIP:3014F711A000191BB85AFE2B.PowerSwitch.switchState, 0_userdata.0.vis.Status.Raeume.Schlafzimmer.FarbeLichtTuer, bshb.0.hdm:HomeMaticIP:3014F711A000191BB85AFCE6.PowerSwitch.switchState, 0_userdata.0.vis.Status.Licht.Toilette.Farbe, bshb.0.hdm:HomeMaticIP:3014F711A0001918785A0B84.PowerSwitch.switchState, 0_userdata.0.vis.Status.Licht.Flur_unten.Farbe, ham.0.Kueche-Max.Switch.On, 0_userdata.0.vis.Status.Licht.Kueche_Max.Farbe, ham.0.Kueche-Min.Switch.On, 0_userdata.0.vis.Status.Licht.Kueche_Min.Farbe, govee.0.DA:5D:A4:C1:38:D4:7E:F3.powerState, 0_userdata.0.vis.Status.Licht.Nachtlicht.Farbe, bshb.0.hdm:HomeMaticIP:3014F711A0001918785A0940.PowerSwitch.switchState, 0_userdata.0.vis.Status.Licht.Flur_oben.Farbe, ham.0.Buero-Tuer.Switch.On, 0_userdata.0.vis.Status.Licht.Buero_Tuer.Farbe, bshb.0.hdm:HomeMaticIP:3014F711A000191BB85AFE01.PowerSwitch.switchState, 0_userdata.0.vis.Status.Licht.Badezimmer.Farbe, bshb.0.roomClimateControl_hz_4.TemperatureLevel.temperature, bshb.0.roomClimateControl_hz_4.RoomClimateControl.boostMode, bshb.0.roomClimateControl_hz_4.RoomClimateControl.operationMode, bshb.0.roomClimateControl_hz_4.RoomClimateControl.summerMode, bshb.0.roomClimateControl_hz_1.TemperatureLevel.temperature, bshb.0.roomClimateControl_hz_1.RoomClimateControl.boostMode, bshb.0.roomClimateControl_hz_1.RoomClimateControl.operationMode, bshb.0.roomClimateControl_hz_1.RoomClimateControl.summerMode, bshb.0.roomClimateControl_hz_5.TemperatureLevel.temperature, bshb.0.roomClimateControl_hz_5.RoomClimateControl.boostMode, bshb.0.roomClimateControl_hz_5.RoomClimateControl.operationMode, bshb.0.roomClimateControl_hz_5.RoomClimateControl.summerMode, bshb.0.roomClimateControl_hz_6.TemperatureLevel.temperature, bshb.0.roomClimateControl_hz_6.RoomClimateControl.boostMode, bshb.0.roomClimateControl_hz_6.RoomClimateControl.operationMode, bshb.0.roomClimateControl_hz_6.RoomClimateControl.summerMode, bshb.0.roomClimateControl_hz_2.TemperatureLevel.temperature, bshb.0.roomClimateControl_hz_2.RoomClimateControl.boostMode, bshb.0.roomClimateControl_hz_2.RoomClimateControl.operationMode, bshb.0.roomClimateControl_hz_2.RoomClimateControl.summerMode, bshb.0.roomClimateControl_hz_10.TemperatureLevel.temperature, bshb.0.roomClimateControl_hz_10.RoomClimateControl.boostMode, bshb.0.roomClimateControl_hz_10.RoomClimateControl.operationMode, bshb.0.roomClimateControl_hz_10.RoomClimateControl.summerMode, bshb.0.roomClimateControl_hz_3.TemperatureLevel.temperature, bshb.0.roomClimateControl_hz_3.RoomClimateControl.boostMode, bshb.0.roomClimateControl_hz_3.RoomClimateControl.operationMode, bshb.0.roomClimateControl_hz_3.RoomClimateControl.summerMode, bshb.0.roomClimateControl_hz_7.TemperatureLevel.temperature, bshb.0.roomClimateControl_hz_7.RoomClimateControl.boostMode, bshb.0.roomClimateControl_hz_7.RoomClimateControl.operationMode, bshb.0.roomClimateControl_hz_7.RoomClimateControl.summerMode, bshb.0.roomClimateControl_hz_14.TemperatureLevel.temperature, bshb.0.roomClimateControl_hz_14.RoomClimateControl.boostMode, bshb.0.roomClimateControl_hz_14.RoomClimateControl.operationMode, bshb.0.roomClimateControl_hz_14.RoomClimateControl.summerMode, 0_userdata.0.vis.Status.Raeume.Schlafzimmer.StatusFensterRechts, 0_userdata.0.vis.Status.Raeume.Toilette.StatusFenster, 0_userdata.0.vis.Status.Raeume.Kueche.StatusFensterLinks, 0_userdata.0.vis.Status.Raeume.Kueche.StatusFensterRechts, 0_userdata.0.vis.Status.Raeume.Wohnzimmer.StatusFenster, 0_userdata.0.vis.Status.Raeume.Buero.StatusFensterStrasse, 0_userdata.0.vis.Status.Raeume.Buero.StatusFensterHaustuer, 0_userdata.0.vis.Status.Raeume.Badezimmer.StatusFenster, 0_userdata.0.vis.Status.Raeume.Kino.ZustandFensterSitze, 0_userdata.0.vis.Status.Raeume.Kino.StatusFensterLeinwandLinks, 0_userdata.0.vis.Status.Raeume.Kino.StatusFensterLeinwandRechts, 0_userdata.0.vis.Status.Raeume.Schlafzimmer.StatusTuer, 0_userdata.0.vis.Status.Raeume.Toilette.StatusTuer, 0_userdata.0.vis.Status.Raeume.Flur_unten.StatusTuer, 0_userdata.0.vis.Status.Raeume.Kueche.StatusTuer, 0_userdata.0.vis.Status.Raeume.Wohnzimmer.StatusTuerLinks, 0_userdata.0.vis.Status.Raeume.Wohnzimmer.StatusTuerRechts, 0_userdata.0.vis.Status.Raeume.Flur_oben.StatusTuerDachboden, 0_userdata.0.vis.Status.Raeume.Flur_oben.StatusTuerBalkon, 0_userdata.0.vis.Status.Raeume.Badezimmer.StatusTuer, 0_userdata.0.vis.Status.Raeume.Kino.StatusTuer, 0_userdata.0.vis.Status.Raeume.Buero.StatusTuerFlur, 0_userdata.0.vis.Status.Raeume.Buero.StatusTuerKino, 0_userdata.0.vis.Status.Raeume.Technik.StatusTuerBalkon, 0_userdata.0.vis.Status.Raeume.Technik.StatusTuerKino, 0_userdata.0.vis.Status.Geraete.Kuehlschrank.Farbe web.0 2022-05-24 19:02:13.107 debug error web.0 2022-05-24 19:02:13.106 debug error web.0 2022-05-24 19:02:13.103 debug error web.0 2022-05-24 19:02:13.103 debug error web.0 2022-05-24 19:02:13.102 debug error web.0 2022-05-24 19:02:13.102 debug error web.0 2022-05-24 19:02:13.102 debug error web.0 2022-05-24 19:02:13.102 debug error web.0 2022-05-24 19:02:13.102 debug error web.0 2022-05-24 19:02:13.101 debug error web.0 2022-05-24 19:02:13.101 debug error web.0 2022-05-24 19:02:13.101 debug error web.0 2022-05-24 19:02:13.101 debug error web.0 2022-05-24 19:02:13.101 debug error web.0 2022-05-24 19:02:13.100 debug error web.0 2022-05-24 19:02:13.100 debug error web.0 2022-05-24 19:02:13.100 debug error web.0 2022-05-24 19:02:13.100 debug error web.0 2022-05-24 19:02:13.100 debug error web.0 2022-05-24 19:02:13.100 debug error web.0 2022-05-24 19:02:13.099 debug error web.0 2022-05-24 19:02:13.099 debug error web.0 2022-05-24 19:02:13.099 debug error web.0 2022-05-24 19:02:13.096 debug error web.0 2022-05-24 19:02:13.055 debug error web.0 2022-05-24 19:02:13.055 debug error web.0 2022-05-24 19:02:13.055 debug error web.0 2022-05-24 19:02:13.054 debug error web.0 2022-05-24 19:02:13.054 debug error web.0 2022-05-24 19:02:13.054 debug error web.0 2022-05-24 19:02:13.054 debug error web.0 2022-05-24 19:02:13.054 debug error web.0 2022-05-24 19:02:13.053 debug error web.0 2022-05-24 19:02:13.053 debug error web.0 2022-05-24 19:02:13.053 debug error web.0 2022-05-24 19:02:13.053 debug error web.0 2022-05-24 19:02:13.053 debug error web.0 2022-05-24 19:02:13.052 debug error web.0 2022-05-24 19:02:13.052 debug error web.0 2022-05-24 19:02:13.052 debug error web.0 2022-05-24 19:02:13.052 debug error web.0 2022-05-24 19:02:13.052 debug error web.0 2022-05-24 19:02:13.051 debug error web.0 2022-05-24 19:02:13.051 debug error web.0 2022-05-24 19:02:13.051 debug error web.0 2022-05-24 19:02:13.051 debug error web.0 2022-05-24 19:02:13.051 debug error web.0 2022-05-24 19:02:13.051 debug error web.0 2022-05-24 19:02:13.050 debug error web.0 2022-05-24 19:02:13.050 debug error web.0 2022-05-24 19:02:13.050 debug error web.0 2022-05-24 19:02:13.050 debug error web.0 2022-05-24 19:02:13.050 debug error web.0 2022-05-24 19:02:13.049 debug error web.0 2022-05-24 19:02:13.049 debug error web.0 2022-05-24 19:02:13.049 debug error web.0 2022-05-24 19:02:13.049 debug error web.0 2022-05-24 19:02:13.049 debug error web.0 2022-05-24 19:02:13.045 debug error web.0 2022-05-24 19:02:13.044 debug error web.0 2022-05-24 19:02:12.986 debug Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, 0_userdata.0.vis.View_Status.Links, 0_userdata.0.vis.View_Status.Menu_Links, daswetter.0.NextDays.Location_1.Day_1.Minimale_Temperatur_value, daswetter.0.NextDays.Location_1.Day_1.Maximale_Temperatur_value, javascript.0.Wetterstation.Aussentemperatur, accuweather.0.Current.WeatherIconURL, trashschedule.0.next.typesText, trashschedule.0.next.dateFormat web.0 2022-05-24 19:02:12.913 debug Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command web.0 2022-05-24 19:02:12.607 debug 2022-05-24T17:02:12.607Z Request authenticate [system.user.admin] web.0 2022-05-24 19:02:12.490 debug Connection from vis.0 web.0 2022-05-24 19:02:12.474 info ==> Connected system.user.admin from ::ffff:192.168.178.21 web.0 2022-05-24 19:02:11.976 info <== Disconnect system.user.admin from ::ffff:192.168.178.21 vis.0 host.iobrokerslave 2022-05-24 19:00:17.477 info instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) host.iobrokerslave 2022-05-24 19:00:00.055 info instance system.adapter.daswetter.0 started with pid 4798wastl
Hier der LOG
alle 15 Minuten.
Mann ... mache nicht immer EDIT , da stand gerade 10 Minuten :(
@langer erstell doch mal ein neues Projekt, und da einfach nur mal ein widget rein und diese Visseite dann öffnen, ob es da auch passiert
Ich bin mit den Nerven am Ende:
Habe heute beide PI's neu Installiert, genauer Weg folgt.
Installationsvorgang:
Raspberry PI OS Lite auf SSD-Festplatte geschrieben.
sudo apt update
sudo apt-get dist-update
sudo reboot
sudo raspi-config
alle nötigen Einstellungen vorgenommen -
Neuen User eingerichtet
useradd -m test
usermod -a -G sudo test
chsh -s/bin/bash test
passwd test
cat /etc/passwd
Ausgeloggt und mit neuen User angemeldet. -
mit curl -sL https://iobroker.net/install.sh | bash - ioBroker installiert..
Bis hierhin auf beiden pi's der selbe Ablauf, bis auf den User-Namen.
Multihost eingerichtet
WLAN- Wetterstation auf dem Slave eingerichtet
simple-api Adapter installiert
Wetterstation gestartet, Daten sind da.
Bis hier nie ein Fehler aufgetreten.Installierte Adapter: (alles unter stable)
admin
backitup
bshb
discovery
javascript
simple-api
vis
webEine Einfache VIS erstellt und gestartet über den Windows PC.
Nach 10 Minuten ging es wieder los.web.0
2022-05-24 13:48:16.048 info ==> Connected system.user.admin from ::ffff:192.168.178.21web.0
2022-05-24 13:48:15.737 info <== Disconnect system.user.admin from ::ffff:192.168.178.21 vis.0web.0
2022-05-24 13:38:15.266 info ==> Connected system.user.admin from ::ffff:192.168.178.21web.0
2022-05-24 13:38:14.975 info <== Disconnect system.user.admin from ::ffff:192.168.178.21 vis.0Ich hoffe das man dieses Problem hier lösen kann!
Mfg
Wastl@langer sagte in VIS unterbricht Ansicht:
admin
backitup
bshb
discovery
javascript
simple-api
vis
web...... usw.
warum hast du nicht erstmal die Grundstrucktur gelassen , das wir bei dir den Fehler eingrenzen können
und jetzt ist schon der Adapter dasWetter installiert oder noch was weiteres was wir nicht wissen !?
admin
backitup
bshb
discovery
javascript
simple-api
vis
web...... usw.
@glasfaser und nicht zu verachten auch
etliche Javaskripte.
na die hat der Herr schon wieder per edit entfernt -
admin
backitup
bshb
discovery
javascript
simple-api
vis
web...... usw.
@glasfaser sagte in VIS unterbricht Ansicht:
oder gerade nicht!
und das Widget versucht alle 10 Minuten einen nicht vorhandenen Datenpunkt zu lesenaber @langer :
So ergibt das wirklich keinen Sinn.
Wie sollen wir dir bei dieser Informationslage helfen können.
Auch das nachträgliche Ändern ohne Kenntlichmachung ist da nicht hilfreich!
Erstrns liest ein Helfender nich einen Post nochmals, sondern geht von dem Inhalt aus, der beim ersten Lesen drin stand. Zweitens wird der inhaltliche Zusammenhang des Threads durch den manipulierten Inhalt zerstört! -
Es läuft jetzt seid ca. 20 Minuten ohne Reload.
An Javascript läuft nur meine Wetterstatistik, dafür auch dasWetter, Simple_API.
Kann durch CSS ein solcher Fehler auftreten?
MfG
Wastl -
MfG
Wastl
