  4. Test PV Forecast Adapter
    6.3k
forecastphotovoltaik
881 Beiträge 114 Kommentatoren 376.5k Aufrufe 108 Beobachtet
  • JB_SullivanJ JB_Sullivan
    V2.1. läuft bei mir leider nicht mehr.
    pvforecast.0
    11016	2022-05-22 08:40:12.740	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    pvforecast.0
    11016	2022-05-22 08:40:12.740	info	terminating
    pvforecast.0
    11016	2022-05-22 08:40:12.735	error	Cannot read property 'filter' of undefined
    pvforecast.0
    11016	2022-05-22 08:40:12.735	error	TypeError: Cannot read property 'filter' of undefined at C:\iobroker\GLT\node_modules\iobroker.pvforecast\main.js:640:7 at asyncForEach (C:\iobroker\GLT\node_modules\iobroker.pvforecast\main.js:12:9) at C:\iobroker\GLT\node_modules\iobroker.pvforecast\main.js:637:10 at asyncForEach (C:\iobroker\GLT\node_modules\iobroker.pvforecast\main.js:12:9) at Pvforecast.saveEveryHourSummary (C:\iobroker\GLT\node_modules\iobroker.pvforecast\main.js:634:9) at Pvforecast.updateActualDataInterval (C:\iobroker\GLT\node_modules\iobroker.pvforecast\main.js:404:15) at async Pvforecast.onReady (C:\iobroker\GLT\node_modules\iobroker.pvforecast\main.js:148:3)
    pvforecast.0
    11016	2022-05-22 08:40:12.734	error	unhandled promise rejection: Cannot read property 'filter' of undefined
    pvforecast.0
    11016	2022-05-22 08:40:12.734	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    pvforecast.0
    11016	2022-05-22 08:40:12.726	error	Axios Error AxiosError: Request failed with status code 403
    pvforecast.0
    11016	2022-05-22 08:40:12.647	error	Axios Error AxiosError: Request failed with status code 403
    pvforecast.0
    11016	2022-05-22 08:40:07.432	info	starting. Version 2.1.0 in C:/iobroker/GLT/node_modules/iobroker.pvforecast, node: v14.16.0, js-controller: 4.0.23
    SORRY - jetzt geht es - hatte nicht gesehen, das der API Key nach dem Update nicht übernommen wurde.
    Um bei der Gelegenheit nochmal auf meine Frage von weiter oben zurück zu kommen - kann man die Solarwerte im Adapter nicht irgendwie auf 3 Stellen nach dem Komma begrenzen?
    In der Tabellenansicht sieht das sehr unschön aus.
    haus-automatisierungH Offline
    #377
    @jb_sullivan Das kann an der Stelle eigentlich nur passieren, wenn keine Daten vom Dienst abgeholt werden konnten. Hast Du den Adapter frisch installiert oder ein Update gemacht?
    Kümmere mich drum
    📚 Meine Dokumentation
      pvforecast.0
      pvforecast.0
      pvforecast.0
      pvforecast.0
      pvforecast.0
      pvforecast.0
      pvforecast.0
      pvforecast.0
      pvforecast.0
      #378
      @jb_sullivan sagte in Test PV Forecast Adapter:
      Doch, klar. Kann ich auch direkt mit in die nächste Version aufnehmen. Gibts ja auch einen Issue zu.
      • haus-automatisierungH Offline
        #379
        Bitte 2.1.1 testen
          Bitte 2.1.1 testen
          JB_SullivanJ Offline
          JB_Sullivan
          schrieb am zuletzt editiert von JB_Sullivan
          #380
          @haus-automatisierung sagte in Test PV Forecast Adapter:
          Bitte 2.1.1 testen
          OK - Rundung auf 3 Stellen funktioniert ...... aber beim Diagramm, soll die Darstellung so sein? Es ist "Nur den aktuellen Tag auswählen" NICHT angehakt. Der Graph geht dabei in den nächsten Tag hinein und die letzten Balken sind ohne farbliche Darstellung. Wieviel Tage im voraus sollte er denn eigentlich in der Einstellung anzeigen? Beim Ur-javascript des Adapters waren es 3 Tage.
            Bitte 2.1.1 testen
            #381
            Bitte 2.1.1 testen
            Alles was es an Daten gibt. Wie vorher auch. Was hast Du als Datums-Format eingestellt?
              Bitte 2.1.1 testen
              JB_Sullivan
              #382
              @haus-automatisierung So wie es voreingestellt ist - HH:mm - weil die Tabelle geht mit der Einstellung 3 Tage in die Zukunft.
              Woran liegt es eigentlich das beim Momentanwert mal eine 0 und mal ein Wert drin steht. Ich habe nur den 12€ Account von forecast Solar gebucht. Hängt das damit zusammen?
              Falls es hilft, hier ist der Export von Material Design Adapter Einstellungen wo ich den Graph Datenpunkt drin verwende (wie vorher den DP der aus dem javascript erzeugt wurde)
              Export_Materialdesign_Graph.txt
                #383
                @jb_sullivan Dann ist der Wert nicht mehr eindeutig auf der Achse. Weil 12:00 gibts ja jeden Tag. Ich glaube das mag der Graph nicht. Muss ich ausprobieren
                • DiginixD Offline
                  DiginixD Offline
                  Diginix
                  #384
                  @haus-automatisierung Ich bekomme leider keine Werte mehr für tomorrow und jsonTable enthält heute noch Werte seit gestern 20 Uhr. Auch nach Update auf 2.1.1 ist pvforecast.0.plants.1.energy.tomorrow weiterhin "null".
                  Adapter wurde vor Inst v2 komplett entfernt.
                  pvforecast.0.plants.1.JSONTable
                      "Time": "2022-05-21 20:00:00",
                      "Power": "0"
                      "Time": "2022-05-21 20:30:00",
                      "Power": "0"
                      "Time": "2022-05-21 21:00:00",
                      "Power": "0"
                      "Time": "2022-05-21 21:30:00",
                      "Power": "0"
                      "Time": "2022-05-22 06:00:00",
                      "Power": "1.679"
                      "Time": "2022-05-22 06:30:00",
                      "Power": "2.502"
                      "Time": "2022-05-22 07:00:00",
                      "Power": "3.287"
                      "Time": "2022-05-22 07:30:00",
                      "Power": "4.005"
                      "Time": "2022-05-22 08:00:00",
                      "Power": "4.640"
                      "Time": "2022-05-22 08:30:00",
                      "Power": "5.165"
                      "Time": "2022-05-22 09:00:00",
                      "Power": "5.571"
                      "Time": "2022-05-22 09:30:00",
                      "Power": "5.840"
                      "Time": "2022-05-22 10:00:00",
                      "Power": "5.966"
                      "Time": "2022-05-22 10:30:00",
                      "Power": "5.916"
                      "Time": "2022-05-22 11:00:00",
                      "Power": "5.689"
                      "Time": "2022-05-22 11:30:00",
                      "Power": "5.389"
                      "Time": "2022-05-22 12:00:00",
                      "Power": "5.033"
                      "Time": "2022-05-22 12:30:00",
                      "Power": "4.671"
                      "Time": "2022-05-22 13:00:00",
                      "Power": "4.314"
                      "Time": "2022-05-22 13:30:00",
                      "Power": "3.947"
                      "Time": "2022-05-22 14:00:00",
                      "Power": "3.580"
                      "Time": "2022-05-22 14:30:00",
                      "Power": "3.194"
                      "Time": "2022-05-22 15:00:00",
                      "Power": "2.794"
                      "Time": "2022-05-22 15:30:00",
                      "Power": "2.394"
                      "Time": "2022-05-22 16:00:00",
                      "Power": "1.999"
                      "Time": "2022-05-22 16:30:00",
                      "Power": "1.604"
                      "Time": "2022-05-22 17:00:00",
                      "Power": "1.198"
                      "Time": "2022-05-22 17:30:00",
                      "Power": "799"
                      "Time": "2022-05-22 18:00:00",
                      "Power": "429"
                      "Time": "2022-05-22 18:30:00",
                      "Power": "113"
                      "Time": "2022-05-22 19:00:00",
                      "Power": "0"
                      "Time": "2022-05-22 19:30:00",
                      "Power": "0"
                      "Time": "2022-05-22 20:00:00",
                      "Power": "0"
                      "Time": "2022-05-22 20:30:00",
                      "Power": "0"
                      "Time": "2022-05-22 21:00:00",
                      "Power": "0"
                      "Time": "2022-05-22 21:30:00",
                      "Power": "0"
                      "Time": "2022-05-23 06:00:00",
                      "Power": "1.020"
                      "Time": "2022-05-23 06:30:00",
                      "Power": "1.476"
                      "Time": "2022-05-23 07:00:00",
                      "Power": "1.941"
                      "Time": "2022-05-23 07:30:00",
                      "Power": "2.398"
                      "Time": "2022-05-23 08:00:00",
                      "Power": "2.848"
                      "Time": "2022-05-23 08:30:00",
                      "Power": "3.295"
                      "Time": "2022-05-23 09:00:00",
                      "Power": "3.686"
                      "Time": "2022-05-23 09:30:00",
                      "Power": "3.927"
                      "Time": "2022-05-23 10:00:00",
                      "Power": "3.997"
                      "Time": "2022-05-23 10:30:00",
                      "Power": "4.052"
                      "Time": "2022-05-23 11:00:00",
                      "Power": "4.108"
                      "Time": "2022-05-23 11:30:00",
                      "Power": "4.093"
                      "Time": "2022-05-23 12:00:00",
                      "Power": "4.006"
                      "Time": "2022-05-23 12:30:00",
                      "Power": "3.753"
                      "Time": "2022-05-23 13:00:00",
                      "Power": "3.426"
                      "Time": "2022-05-23 13:30:00",
                      "Power": "3.093"
                      "Time": "2022-05-23 14:00:00",
                      "Power": "2.747"
                      "Time": "2022-05-23 14:30:00",
                      "Power": "2.404"
                      "Time": "2022-05-23 15:00:00",
                      "Power": "2.062"
                      "Time": "2022-05-23 15:30:00",
                      "Power": "1.712"
                      "Time": "2022-05-23 16:00:00",
                      "Power": "1.358"
                      "Time": "2022-05-23 16:30:00",
                      "Power": "1.003"
                      "Time": "2022-05-23 17:00:00",
                      "Power": "647"
                      "Time": "2022-05-23 17:30:00",
                      "Power": "339"
                      "Time": "2022-05-23 18:00:00",
                      "Power": "103"
                      "Time": "2022-05-23 18:30:00",
                      "Power": "0"
                      "Time": "2022-05-23 19:00:00",
                      "Power": "0"
                      "Time": "2022-05-23 19:30:00",
                      "Power": "0"
                  Außerdem kam gestern im Log immer mal diese Info:
                  2022-05-21 21:30:02.082 - info: pvforecast.0 (830593) hourly states missed 15 items - please check if your license allows to request all values
                  Das kommt heute aber nicht meh, aber dafür eben auch keine sinnvollen Werte mehr.
                  Meine Einstellungen sind und liefen mit v1.x Monate perfekt. Komisch ist auch dass in den Instanzeinstellungen oben noch 2.1.0 steht obwohl 2.1.1 installiert ist.
                  Im Log steht nach Adapter Start nichts auffälliges:
                  2022-05-22 21:00:04.819 - info: pvforecast.0 (991657) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v14.19.3, js-controller: 4.0.23
                  2022-05-22 21:00:04.936 - info: pvforecast.0 (991657) using system latitude: 50.******** longitude: 10.********
                  Die anonymisierten Koordinaten passen.
                  ..:: So long! Tom ::..
                  • DiginixD Diginix
                        "Power": "0"
                        "Power": "0"
                        "Power": "0"
                        "Power": "0"
                        "Power": "1.679"
                        "Power": "2.502"
                        "Power": "3.287"
                        "Power": "4.005"
                        "Power": "4.640"
                        "Power": "5.165"
                        "Power": "5.571"
                        "Power": "5.840"
                        "Power": "5.966"
                        "Power": "5.916"
                        "Power": "5.689"
                        "Power": "5.389"
                        "Power": "5.033"
                        "Power": "4.671"
                        "Power": "4.314"
                        "Power": "3.947"
                        "Power": "3.580"
                        "Power": "3.194"
                        "Power": "2.794"
                        "Power": "2.394"
                        "Power": "1.999"
                        "Power": "1.604"
                        "Power": "1.198"
                        "Power": "799"
                        "Power": "429"
                        "Power": "113"
                        "Power": "0"
                        "Power": "0"
                        "Power": "0"
                        "Power": "0"
                        "Power": "0"
                        "Power": "0"
                        "Power": "1.020"
                        "Power": "1.476"
                        "Power": "1.941"
                        "Power": "2.398"
                        "Power": "2.848"
                        "Power": "3.295"
                        "Power": "3.686"
                        "Power": "3.927"
                        "Power": "3.997"
                        "Power": "4.052"
                        "Power": "4.108"
                        "Power": "4.093"
                        "Power": "4.006"
                        "Power": "3.753"
                        "Power": "3.426"
                        "Power": "3.093"
                        "Power": "2.747"
                        "Power": "2.404"
                        "Power": "2.062"
                        "Power": "1.712"
                        "Power": "1.358"
                        "Power": "1.003"
                        "Power": "647"
                        "Power": "339"
                        "Power": "103"
                        "Power": "0"
                        "Power": "0"
                        "Power": "0"
                    #385
                    @diginix Führe nochmal manuell ein Adapter Upload aus. Und bei der Konfiguration der Peak Leistung bitte US Schreibweise. Also 7.7 statt 7,7
                      DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #386
                      @haus-automatisierung Punkt als Dezimaltrenner wird garnicht genommen.
                      Und im Instanz Objekt system.adapter.pvforecast.0 steht: "peakpower": 7.7,
                      Hab es mal im RAW auf 7 gesetzt und danach kamen nun Werte für tomorrow und jsonTable. Dafür aber auch wieder diese Log Zeile:
                      2022-05-22 21:27:40.996  - info: pvforecast.0 (995504) hourly states missed 15 items - please check if your license allows to request all values
                      Oder kommt die nur am Abend bei Neustart, weil er dann keine Werte mehr für 24h bekommt?
                      Wie bekomme ich nun meine 7,7 kWp korrekt in die Instanz?
                      • DiginixD Diginix
                        #387
                        @diginix Ich habe bei pvforecast nur den kleinsten Tarif. Da gibts zB keine Werte für :15 und :45. Das ist ein Hinweis dass die fehlen. Also auf halbstündig umstellen in der Adapter Konfiguration.
                        Wenn das bei Dir schon auf stündlich steht, dann waren einige Stunden nicht in der Antwort vom Server enthalten.
                        Ansonsten ist es gerade schwer zu raten was da schief läuft. Debug log anmachen und lesen. Ich habe das bei mir mit Kommawerten getestet und das funktioniert
                        DiginixD DancerVlt69D 2 Antworten Letzte Antwort
                          DiginixD Offline
                          DiginixD Offline
                          Diginix
                          #388
                          @haus-automatisierung Komma oder Punkt?
                          Du schriebst ich möge es mit Punkt eintragen. Der wird in der Admin Maske (admin v5.4.9) nicht angenommen. Komma schon. Im RAW stand mit Eingabe von Komma dann peakpower": 7.7
                          Damit kam ja aber kein Update mehr von tomorrow und jsonTable.
                          Liest sich für mich nach Deadlock.
                          Ich habe es nun erneut mit Komma in der Admin Maske gesetzt. Wieder steht peakpower": 7.7 in system.adapter.pvforecast.0. Damit hat er für morgen den Wert aktualisiert und den für heute mit 0, weil Tag zu Ende. So war es gestern aber auch. Und am Tag darauf (heute) kam dann kein Update für den morgigen Tag.
                          Mal sehen ob es dann morgen auch wieder so ist, dass für DI keine Prognose kommt und jsonTable nicht mehr aktualisiert wird.
                          • DiginixD Offline
                            DiginixD Offline
                            Diginix
                            #389
                            @haus-automatisierung Wie zu erwarten zeigt sich heute wieder der Fall, dass pvforecast.0.plants.1.energy.tomorrow null ist und jsonTable/Graph nicht mehr aktualisiert werden.
                            Durch die massiven Änderungen in der Objektstruktur möchte ich ungern auf v1 zurück. Ich nutze einige DP in Flot und Skripten, die ich überall ändern musste.
                            V1 lief allerdings perfekt mit allem was ich brauchte. Debuglog scheue ich mich noch weil das ja über x Stunden laufen muss und sicher explodiert. Das Problem ist mit an Sicherheit grenzender Wahrscheinlichkeit kein lokales. Sollte sich also auch bei dir reproduzieren lassen. Ich nutze allerdings solcast statt pvforecast.
                            • DiginixD Diginix
                              #390
                              @diginix sagte in Test PV Forecast Adapter:
                              Dann ist es auf jeden Fall richtig. Scheint an der eingestellten locale zu liegen, wie der Admin die Eingabe erlaubt.
                              Im Adapter ist es so, dass die Server-Response von Solcast in das Format von Foarecastsolar umgebaut wird. Daran habe ich nichts geändert. Ich registriere mich aber jetzt mal bei Solcast und teste was da schief läuft.
                              Was für einen Account-Typ hast Du dort?
                                DiginixD Offline
                                DiginixD Offline
                                Diginix
                                #391
                                @haus-automatisierung Den kostenfreien, aber man bekommt dort zwingend ein API Key.
                                Danke, dass du es dir selbst mal anschaust!
                                Im Log von heute gibt es bisher keine einzige Zeile vom Adapter. Aber die DPs sind alle 08:50 Uhr zuletzt aktualisiert und werden es auch alle 10 min, nur eben zT ohne Werte.
                                Wenn man den Adapter nach Sonnenuntergang neu startet, bekommt man für den aktuellen Tag 0 Wh, was logisch ist. Dafür aber eben für den Folgetag dann ein Wert. Ich starte den Adapter jetzt mal neu und schaue ob dann beide einen Wert bekommen. Noch stimmt der für heute.
                                Was ich gerade sehe, pvforecast.0.plants.1.energy.tomorrow wird angeblich auch immer alle 10 min geändert, obwohl den ganzen Tag schon null drin steht. Irgendwas macht der Adapter da also. Formatfehler oder Problem bei Umrechnung auf Watt?
                                • DiginixD Diginix
                                  #392
                                  Ein einfaches Debug-Log würde das alles zeigen. Aber so bekomme ich die Infos ja nur Häppchenweise und gucke auf dem eigenen System was falsch läuft :)
                                  Und ja, die Werte werden alle 10 Minuten neu geschrieben (aber nicht neu vom Server abgeholt). Auch das war bei der 1.x schon so.
                                    DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #393
                                    @haus-automatisierung Ich stell ihn jetzt mal auf Loglevel debug. Ist ja kein Problem das mal 11 Minuten so zu lassen. Bisher dachte ich ja es passiert erst bei Datumswechsel und stundenlang ist debuglog nicht so toll. ;-)
                                    Hier ist das Debuglog:
                                    2022-05-23 09:17:25.880 - info: pvforecast.0 (1083421) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v14.19.3, js-controller: 4.0.23
                                    2022-05-23 09:17:25.900 - debug: pvforecast.0 (1083421) instance config: {"service":"solcast","intervall":60,"apiKey":"***","weatherEnabled":false,"latitude":"","longitude":"","everyhourEnabled":true,"everyhourStepsize":"full","watt_kw":true,"influxinstace":"","chartingEnabled":false,"chartingJustToday":false,"chartingLabelFormat":"HH:mm","chartingRoation":270,"chartingAxisStepY":1,"devices":[{"name":"1","azimuth":0,"tilt":30,"peakpower":7.7,"graphcolor":"#000000","labelcolor":"#000000"}]}
                                    2022-05-23 09:17:25.901 - debug: pvforecast.0 (1083421) longitude and/or latitude not set, loading system configuration
                                    2022-05-23 09:17:25.938 - info: pvforecast.0 (1083421) using system latitude: 50.******** longitude: 10.********
                                    2022-05-23 09:17:25.969 - debug: pvforecast.0 (1083421) Existing plant devices: [{"type":"device","common":{"name":"1"},"native":{},"from":"system.adapter.pvforecast.0","user":"system.user.admin","ts":1653254428333,"_id":"pvforecast.0.plants.1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}] - configured: ["pvforecast.0.plants.1"]
                                    2022-05-23 09:17:25.969 - debug: pvforecast.0 (1083421) The interval is set to 60 minutes.
                                    2022-05-23 09:17:25.995 - debug: pvforecast.0 (1083421) creating states for plant: "1" (1)
                                    2022-05-23 09:17:26.643 - debug: pvforecast.0 (1083421) init done
                                    2022-05-23 09:17:26.694 - debug: pvforecast.0 (1083421) plant "1" - last update: 1653254430372, service url: https://api.solcast.com.au/world_pv_power/forecasts?format=json&hours=48&loss_factor=1&latitude=50.********&longitude=10.********&tilt=30&azimuth=-180&capacity=7.7&api_key=***
                                    2022-05-23 09:17:26.696 - debug: pvforecast.0 (1083421) Last update of "1" is within refresh interval - skipping
                                    2022-05-23 09:17:26.696 - debug: pvforecast.0 (1083421) received all data
                                    2022-05-23 09:17:26.698 - debug: pvforecast.0 (1083421) updateServiceDataInterval (solcast) - next service refresh in 56553302
                                    2022-05-23 09:17:26.699 - debug: pvforecast.0 (1083421) starting actual data update by interval
                                    2022-05-23 09:17:26.711 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.06:00:00 - value: 921
                                    2022-05-23 09:17:26.715 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.07:00:00 - value: 1754
                                    2022-05-23 09:17:26.718 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.08:00:00 - value: 2552
                                    2022-05-23 09:17:26.720 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.09:00:00 - value: 3141
                                    2022-05-23 09:17:26.723 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.10:00:00 - value: 3610
                                    2022-05-23 09:17:26.726 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.11:00:00 - value: 4088
                                    2022-05-23 09:17:26.728 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.12:00:00 - value: 4615
                                    2022-05-23 09:17:26.731 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.13:00:00 - value: 4337
                                    2022-05-23 09:17:26.734 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.14:00:00 - value: 3437
                                    2022-05-23 09:17:26.736 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.15:00:00 - value: 2670
                                    2022-05-23 09:17:26.739 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.16:00:00 - value: 1710
                                    2022-05-23 09:17:26.742 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.17:00:00 - value: 760
                                    2022-05-23 09:17:26.744 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.18:00:00 - value: 144
                                    2022-05-23 09:17:26.756 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.19:00:00 - value: 0
                                    2022-05-23 09:17:26.759 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.20:00:00 - value: 0
                                    2022-05-23 09:17:26.762 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.21:00:00 - value: 0
                                    2022-05-23 09:17:26.765 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.06:00:00 - value: 918
                                    2022-05-23 09:17:26.768 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.07:00:00 - value: 1676
                                    2022-05-23 09:17:26.770 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.08:00:00 - value: 2475
                                    2022-05-23 09:17:26.772 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.09:00:00 - value: 3182
                                    2022-05-23 09:17:26.774 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.10:00:00 - value: 3740
                                    2022-05-23 09:17:26.777 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.11:00:00 - value: 4042
                                    2022-05-23 09:17:26.780 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.12:00:00 - value: 4265
                                    2022-05-23 09:17:26.782 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.13:00:00 - value: 4375
                                    2022-05-23 09:17:26.784 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.14:00:00 - value: 4260
                                    2022-05-23 09:17:26.786 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.15:00:00 - value: 3854
                                    2022-05-23 09:17:26.788 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.16:00:00 - value: 2684
                                    2022-05-23 09:17:26.790 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.17:00:00 - value: 1436
                                    2022-05-23 09:17:26.792 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.18:00:00 - value: 578
                                    2022-05-23 09:17:26.794 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.19:00:00 - value: 0
                                    2022-05-23 09:17:26.797 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.20:00:00 - value: 0
                                    2022-05-23 09:17:26.799 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.21:00:00 - value: 0
                                    2022-05-23 09:17:27.129 - debug: pvforecast.0 (1083421) finished plant update: "1"
                                    2022-05-23 09:17:27.129 - debug: pvforecast.0 (1083421) finished plants update
                                    2022-05-23 09:17:27.439 - debug: pvforecast.0 (1083421) global time: {"1":[{"dayOfMonth":23,"time":"06:00:00","value":921},{"dayOfMonth":23,"time":"07:00:00","value":1754},{"dayOfMonth":23,"time":"08:00:00","value":2552},{"dayOfMonth":23,"time":"09:00:00","value":3141},{"dayOfMonth":23,"time":"10:00:00","value":3610},{"dayOfMonth":23,"time":"11:00:00","value":4088},{"dayOfMonth":23,"time":"12:00:00","value":4615},{"dayOfMonth":23,"time":"13:00:00","value":4337},{"dayOfMonth":23,"time":"14:00:00","value":3437},{"dayOfMonth":23,"time":"15:00:00","value":2670},{"dayOfMonth":23,"time":"16:00:00","value":1710},{"dayOfMonth":23,"time":"17:00:00","value":760},{"dayOfMonth":23,"time":"18:00:00","value":144},{"dayOfMonth":23,"time":"19:00:00","value":0},{"dayOfMonth":23,"time":"20:00:00","value":0},{"dayOfMonth":23,"time":"21:00:00","value":0},{"dayOfMonth":24,"time":"06:00:00","value":918},{"dayOfMonth":24,"time":"07:00:00","value":1676},{"dayOfMonth":24,"time":"08:00:00","value":2475},{"dayOfMonth":24,"time":"09:00:00","value":3182},{"dayOfMonth":24,"time":"10:00:00","value":3740},{"dayOfMonth":24,"time":"11:00:00","value":4042},{"dayOfMonth":24,"time":"12:00:00","value":4265},{"dayOfMonth":24,"time":"13:00:00","value":4375},{"dayOfMonth":24,"time":"14:00:00","value":4260},{"dayOfMonth":24,"time":"15:00:00","value":3854},{"dayOfMonth":24,"time":"16:00:00","value":2684},{"dayOfMonth":24,"time":"17:00:00","value":1436},{"dayOfMonth":24,"time":"18:00:00","value":578},{"dayOfMonth":24,"time":"19:00:00","value":0},{"dayOfMonth":24,"time":"20:00:00","value":0},{"dayOfMonth":24,"time":"21:00:00","value":0}]}
                                    2022-05-23 09:27:27.477 - debug: pvforecast.0 (1083421) starting actual data update by interval
                                    2022-05-23 09:27:27.481 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.06:00:00 - value: 921
                                    2022-05-23 09:27:27.483 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.07:00:00 - value: 1754
                                    2022-05-23 09:27:27.486 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.08:00:00 - value: 2552
                                    2022-05-23 09:27:27.488 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.09:00:00 - value: 3141
                                    2022-05-23 09:27:27.552 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.10:00:00 - value: 3610
                                    2022-05-23 09:27:27.557 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.11:00:00 - value: 4088
                                    2022-05-23 09:27:27.559 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.12:00:00 - value: 4615
                                    2022-05-23 09:27:27.561 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.13:00:00 - value: 4337
                                    2022-05-23 09:27:27.563 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.14:00:00 - value: 3437
                                    2022-05-23 09:27:27.567 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.15:00:00 - value: 2670
                                    2022-05-23 09:27:27.569 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.16:00:00 - value: 1710
                                    2022-05-23 09:27:27.572 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.17:00:00 - value: 760
                                    2022-05-23 09:27:27.574 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.18:00:00 - value: 144
                                    2022-05-23 09:27:27.579 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.19:00:00 - value: 0
                                    2022-05-23 09:27:27.582 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.20:00:00 - value: 0
                                    2022-05-23 09:27:27.585 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.21:00:00 - value: 0
                                    2022-05-23 09:27:27.589 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.06:00:00 - value: 918
                                    2022-05-23 09:27:27.594 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.07:00:00 - value: 1676
                                    2022-05-23 09:27:27.596 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.08:00:00 - value: 2475
                                    2022-05-23 09:27:27.598 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.09:00:00 - value: 3182
                                    2022-05-23 09:27:27.600 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.10:00:00 - value: 3740
                                    2022-05-23 09:27:27.603 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.11:00:00 - value: 4042
                                    2022-05-23 09:27:27.605 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.12:00:00 - value: 4265
                                    2022-05-23 09:27:27.607 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.13:00:00 - value: 4375
                                    2022-05-23 09:27:27.609 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.14:00:00 - value: 4260
                                    2022-05-23 09:27:27.611 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.15:00:00 - value: 3854
                                    2022-05-23 09:27:27.613 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.16:00:00 - value: 2684
                                    2022-05-23 09:27:27.616 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.17:00:00 - value: 1436
                                    2022-05-23 09:27:27.617 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.18:00:00 - value: 578
                                    2022-05-23 09:27:27.619 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.19:00:00 - value: 0
                                    2022-05-23 09:27:27.621 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.20:00:00 - value: 0
                                    2022-05-23 09:27:27.623 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.21:00:00 - value: 0
                                    2022-05-23 09:27:27.823 - debug: pvforecast.0 (1083421) finished plant update: "1"
                                    2022-05-23 09:27:27.823 - debug: pvforecast.0 (1083421) finished plants update
                                    2022-05-23 09:27:28.717 - debug: pvforecast.0 (1083421) global time: {"1":[{"dayOfMonth":23,"time":"06:00:00","value":921},{"dayOfMonth":23,"time":"07:00:00","value":1754},{"dayOfMonth":23,"time":"08:00:00","value":2552},{"dayOfMonth":23,"time":"09:00:00","value":3141},{"dayOfMonth":23,"time":"10:00:00","value":3610},{"dayOfMonth":23,"time":"11:00:00","value":4088},{"dayOfMonth":23,"time":"12:00:00","value":4615},{"dayOfMonth":23,"time":"13:00:00","value":4337},{"dayOfMonth":23,"time":"14:00:00","value":3437},{"dayOfMonth":23,"time":"15:00:00","value":2670},{"dayOfMonth":23,"time":"16:00:00","value":1710},{"dayOfMonth":23,"time":"17:00:00","value":760},{"dayOfMonth":23,"time":"18:00:00","value":144},{"dayOfMonth":23,"time":"19:00:00","value":0},{"dayOfMonth":23,"time":"20:00:00","value":0},{"dayOfMonth":23,"time":"21:00:00","value":0},{"dayOfMonth":24,"time":"06:00:00","value":918},{"dayOfMonth":24,"time":"07:00:00","value":1676},{"dayOfMonth":24,"time":"08:00:00","value":2475},{"dayOfMonth":24,"time":"09:00:00","value":3182},{"dayOfMonth":24,"time":"10:00:00","value":3740},{"dayOfMonth":24,"time":"11:00:00","value":4042},{"dayOfMonth":24,"time":"12:00:00","value":4265},{"dayOfMonth":24,"time":"13:00:00","value":4375},{"dayOfMonth":24,"time":"14:00:00","value":4260},{"dayOfMonth":24,"time":"15:00:00","value":3854},{"dayOfMonth":24,"time":"16:00:00","value":2684},{"dayOfMonth":24,"time":"17:00:00","value":1436},{"dayOfMonth":24,"time":"18:00:00","value":578},{"dayOfMonth":24,"time":"19:00:00","value":0},{"dayOfMonth":24,"time":"20:00:00","value":0},{"dayOfMonth":24,"time":"21:00:00","value":0}]}
                                    2022-05-23 09:37:28.761 - debug: pvforecast.0 (1083421) starting actual data update by interval
                                    2022-05-23 09:37:28.767 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.06:00:00 - value: 921
                                    2022-05-23 09:37:28.770 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.07:00:00 - value: 1754
                                    2022-05-23 09:37:28.772 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.08:00:00 - value: 2552
                                    2022-05-23 09:37:28.775 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.09:00:00 - value: 3141
                                    2022-05-23 09:37:28.777 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.10:00:00 - value: 3610
                                    2022-05-23 09:37:28.779 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.11:00:00 - value: 4088
                                    2022-05-23 09:37:28.782 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.12:00:00 - value: 4615
                                    2022-05-23 09:37:28.785 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.13:00:00 - value: 4337
                                    2022-05-23 09:37:28.787 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.14:00:00 - value: 3437
                                    2022-05-23 09:37:28.790 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.15:00:00 - value: 2670
                                    2022-05-23 09:37:28.792 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.16:00:00 - value: 1710
                                    2022-05-23 09:37:28.795 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.17:00:00 - value: 760
                                    2022-05-23 09:37:28.797 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.18:00:00 - value: 144
                                    2022-05-23 09:37:28.800 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.19:00:00 - value: 0
                                    2022-05-23 09:37:28.810 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.20:00:00 - value: 0
                                    2022-05-23 09:37:28.812 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursToday.21:00:00 - value: 0
                                    2022-05-23 09:37:28.815 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.06:00:00 - value: 918
                                    2022-05-23 09:37:28.817 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.07:00:00 - value: 1676
                                    2022-05-23 09:37:28.820 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.08:00:00 - value: 2475
                                    2022-05-23 09:37:28.824 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.09:00:00 - value: 3182
                                    2022-05-23 09:37:28.826 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.10:00:00 - value: 3740
                                    2022-05-23 09:37:28.828 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.11:00:00 - value: 4042
                                    2022-05-23 09:37:28.830 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.12:00:00 - value: 4265
                                    2022-05-23 09:37:28.832 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.13:00:00 - value: 4375
                                    2022-05-23 09:37:28.835 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.14:00:00 - value: 4260
                                    2022-05-23 09:37:28.838 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.15:00:00 - value: 3854
                                    2022-05-23 09:37:28.841 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.16:00:00 - value: 2684
                                    2022-05-23 09:37:28.844 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.17:00:00 - value: 1436
                                    2022-05-23 09:37:28.846 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.18:00:00 - value: 578
                                    2022-05-23 09:37:28.849 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.19:00:00 - value: 0
                                    2022-05-23 09:37:28.851 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.20:00:00 - value: 0
                                    2022-05-23 09:37:28.854 - debug: pvforecast.0 (1083421) [saveEveryHour] found time plants.1.power.hoursTomorrow.21:00:00 - value: 0
                                    2022-05-23 09:37:29.142 - debug: pvforecast.0 (1083421) finished plant update: "1"
                                    2022-05-23 09:37:29.143 - debug: pvforecast.0 (1083421) finished plants update
                                    2022-05-23 09:37:29.276 - debug: pvforecast.0 (1083421) global time: {"1":[{"dayOfMonth":23,"time":"06:00:00","value":921},{"dayOfMonth":23,"time":"07:00:00","value":1754},{"dayOfMonth":23,"time":"08:00:00","value":2552},{"dayOfMonth":23,"time":"09:00:00","value":3141},{"dayOfMonth":23,"time":"10:00:00","value":3610},{"dayOfMonth":23,"time":"11:00:00","value":4088},{"dayOfMonth":23,"time":"12:00:00","value":4615},{"dayOfMonth":23,"time":"13:00:00","value":4337},{"dayOfMonth":23,"time":"14:00:00","value":3437},{"dayOfMonth":23,"time":"15:00:00","value":2670},{"dayOfMonth":23,"time":"16:00:00","value":1710},{"dayOfMonth":23,"time":"17:00:00","value":760},{"dayOfMonth":23,"time":"18:00:00","value":144},{"dayOfMonth":23,"time":"19:00:00","value":0},{"dayOfMonth":23,"time":"20:00:00","value":0},{"dayOfMonth":23,"time":"21:00:00","value":0},{"dayOfMonth":24,"time":"06:00:00","value":918},{"dayOfMonth":24,"time":"07:00:00","value":1676},{"dayOfMonth":24,"time":"08:00:00","value":2475},{"dayOfMonth":24,"time":"09:00:00","value":3182},{"dayOfMonth":24,"time":"10:00:00","value":3740},{"dayOfMonth":24,"time":"11:00:00","value":4042},{"dayOfMonth":24,"time":"12:00:00","value":4265},{"dayOfMonth":24,"time":"13:00:00","value":4375},{"dayOfMonth":24,"time":"14:00:00","value":4260},{"dayOfMonth":24,"time":"15:00:00","value":3854},{"dayOfMonth":24,"time":"16:00:00","value":2684},{"dayOfMonth":24,"time":"17:00:00","value":1436},{"dayOfMonth":24,"time":"18:00:00","value":578},{"dayOfMonth":24,"time":"19:00:00","value":0},{"dayOfMonth":24,"time":"20:00:00","value":0},{"dayOfMonth":24,"time":"21:00:00","value":0}]}
                                    2022-05-23 09:44:10.184 - info: pvforecast.0 (1083421) Got terminate signal TERMINATE_YOURSELF
                                    2022-05-23 09:44:10.185 - info: pvforecast.0 (1083421) terminating
                                    2022-05-23 09:44:10.186 - info: pvforecast.0 (1083421) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      #394
                                      Genau, das ist bei Solcast leider so. Forecastsolar gibt einem den kompletten Tag zurück - also auch in der Vergangenheit liegende Stunden beim ersten Adapter-Start / Neustart.
                                      Ich habe aber noch einen Bug gefunden, dass die Solcast-Daten ggf. nicht aktualisiert werden. Das erklärt aber noch nicht, warum
                                      ist. Das hat bei mir auch mit Solcast direkt funktioniert. Auch mit Version 2.1.1. Du könntest mal ein force update durchführen mit dem Datenpunkt pvforecast.0.plants.1.service.refresh
                                        DiginixD Offline
                                        DiginixD Offline
                                        Diginix
                                        #395
                                        Das stört mich nicht, da der Adapter ja idealerweise durchläuft. Ich brauche die Stundenwerte auch nicht wirklich. Außerdem sind nur die solcast Prognosen annährend brauchbar. pvforecast (zumindest kostenfrei) ist so weit weg von der Realität. Da kann ich auch würfeln.
                                        Sicher nicht verkehrt diesen gefunden und gefixt zu haben. ;-)
                                        Wie genau geht das?
                                        Im Debuglog war nichts sachdienliches zum Fehlverhalten?
                                        • DiginixD Diginix
                                          Wie genau geht das?
                                          DiginixD Offline
                                          DiginixD Offline
                                          Diginix
                                          #396
                                          @haus-automatisierung Mit 2.1.2 sind sofort alle Objekte aktuell. Ob morgen dann wieder pvforecast.0.plants.1.energy.tomorrow null zeigt, wissen wir in 12 Stunden.
