  4. ioBroker abgestürzt, Redis tot
16 Beiträge 4 Kommentatoren 363 Aufrufe 4 Beobachtet
  • GregorSG Offline
    GregorSG Offline
    GregorS
    Hallo
    mein ioB ist mal wieder abgestürzt.
    Leider kann ich ihn nicht mehr starten, da der Connect zu redis fehlt.
    code_tpi@TinkerboardS:/opt/iobroker$ systemctl status redis-server.service
    ● redis-server.service - Advanced key-value store
       Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Fri 2022-05-13 09:57:38 CEST; 29s ago
         Docs: http://redis.io/documentation,
               man:redis-server(1)
      Process: 13061 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=1/FAILURE)
      Process: 13057 ExecStartPre=/bin/run-parts --verbose /etc/redis/redis-server.pre-up.d (code=exited, status=0/SUCCESS)
          CPU: 28ms
    Mai 13 09:57:37 TinkerboardS systemd[1]: redis-server.service: Failed with result 'exit-code'.
    Mai 13 09:57:38 TinkerboardS systemd[1]: redis-server.service: Service hold-off time over, scheduling restart.
    Mai 13 09:57:38 TinkerboardS systemd[1]: Stopped Advanced key-value store.
    Mai 13 09:57:38 TinkerboardS systemd[1]: redis-server.service: Start request repeated too quickly.
    Mai 13 09:57:38 TinkerboardS systemd[1]: Failed to start Advanced key-value store.
    Mai 13 09:57:38 TinkerboardS systemd[1]: redis-server.service: Unit entered failed state.
    Mai 13 09:57:38 TinkerboardS systemd[1]: redis-server.service: Failed with result 'exit-code'.
    Mai 13 09:57:43 TinkerboardS systemd[1]: redis-server.service: Start request repeated too quickly.
    Mai 13 09:57:43 TinkerboardS systemd[1]: Failed to start Advanced key-value store.
    Mai 13 09:57:43 TinkerboardS systemd[1]: redis-server.service: Failed with result 'exit-code'.
    pi@TinkerboardS:/opt/iobroker$ sudo journalctl -xe
    Mai 13 09:58:57 TinkerboardS redis-server[13237]: Reading the configuration file, at line 163
    Mai 13 09:58:57 TinkerboardS redis-server[13237]: >>> 'logfile /var/log/redis/redis-server.log'
    Mai 13 09:58:57 TinkerboardS redis-server[13237]: Can't open the log file: Permission denied
    Mai 13 09:58:57 TinkerboardS systemd[1]: redis-server.service: Control process exited, code=exited status=1
    Mai 13 09:58:57 TinkerboardS systemd[1]: Failed to start Advanced key-value store.
    -- Subject: Unit redis-server.service has failed
    -- Defined-By: systemd
    -- Support: https://www.debian.org/support
    -- Unit redis-server.service has failed.
    -- The result is failed.
    Mai 13 09:58:57 TinkerboardS systemd[1]: redis-server.service: Unit entered failed state.
    Mai 13 09:58:57 TinkerboardS systemd[1]: redis-server.service: Failed with result 'exit-code'.
    Mai 13 09:58:58 TinkerboardS systemd[1]: redis-server.service: Service hold-off time over, scheduling restart.
    Mai 13 09:58:58 TinkerboardS systemd[1]: Stopped Advanced key-value store.
    -- Subject: Unit redis-server.service has finished shutting down
    -- Unit redis-server.service has finished shutting down.
    Mai 13 09:58:58 TinkerboardS systemd[1]: redis-server.service: Start request repeated too quickly.
    Mai 13 09:58:58 TinkerboardS systemd[1]: Failed to start Advanced key-value store.
    Mai 13 09:58:58 TinkerboardS systemd[1]: redis-server.service: Unit entered failed state.
    Mai 13 09:58:58 TinkerboardS systemd[1]: redis-server.service: Failed with result 'exit-code'.
    Mai 13 09:59:19 TinkerboardS sudo[13249]:       pi : TTY=pts/1 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/bin/journalctl -xe
    Mai 13 09:59:19 TinkerboardS sudo[13249]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
    lines 2639-2672/2672 (END)
    ext
    Habe auch schon versucht anstatt redis auf json umzustellen, aber er will immer mit redis verbinden.
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    • GregorSG GregorS
      Hallo
                 man:redis-server(1)
            CPU: 28ms
      ext
      crunchipC Abwesend
      crunchipC Abwesend
      @gregors sagte in ioBroker abgestürzt, Redis tot:
      was zeigt
      iob setup custom
      laufen da vllt mehrere Prozesse
      GregorSG 1 Antwort Letzte Antwort
        was zeigt
        iob setup custom
        GregorSG Offline
        GregorSG Offline
        GregorS
        @crunchip
        pi@TinkerboardS:~$ iob setup custom
        Current configuration:
        - Objects database:
          - Type: jsonl
          - Host/Unix Socket: 127.0.0.1
          - Port: 9001
        - States database:
          - Type: redis
          - Port: 6379
        - Data Directory: ../../iobroker-data/
        • GregorSG GregorS
          @crunchip
          - Objects database:
            - Type: jsonl
            - Port: 9001
          - States database:
            - Type: redis
            - Port: 6379
          crunchipC Abwesend
          crunchipC Abwesend
          States database:
          • Type: redis
          läuft auf redis, das hast du wohl nicht umgestellt
          GregorSG 2 Antworten Letzte Antwort
            States database:
            • Type: redis
            GregorSG Offline
            GregorSG Offline
            GregorS
            @crunchip
            Habe ich gemacht, aber er ändert es nicht.
              States database:
              • Type: redis
              GregorSG Offline
              GregorSG Offline
              GregorS
              @crunchip
              - Objects database:
                - Type: jsonl
                - Port: 9001
              - States database:
                - Type: redis
                - Port: 6379
              Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: j
              Host / Unix Socket of objects DB(jsonl), default[127.0.0.1]:
              Port of objects DB(jsonl), default[9001]:
              Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [jsonl]: j
              Host / Unix Socket of states DB (jsonl), default[127.0.0.1]:
              Port of states DB (jsonl), default[9000]:
              Data directory (file), default[../../iobroker-data/]:
              Host name of this machine [TinkerboardS]:
              This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
              Do you want to migrate objects and states from "jsonl/redis" to "jsonl/jsonl" [y/N]: y
              Connecting to previous DB "jsonl"...
              No connection to states 127.0.0.1:6379[redis]
              • GregorSG GregorS
                @crunchip
                - Objects database:
                  - Type: jsonl
                  - Port: 9001
                - States database:
                  - Type: redis
                  - Port: 6379
                arteckA Offline
                arteckA Offline
                arteck
                @gregors
                wenn du eine migration willst dann musst redis auch laufen... sonst geht das nicht..
                • arteckA arteck
                  @gregors
                  GregorSG Offline
                  GregorSG Offline
                  GregorS
                  @arteck
                  Ok.
                  Aber redis startet ja nicht mehr, so dass ich nicht migrieren kann.
                  • GregorSG GregorS
                    Hallo
                               man:redis-server(1)
                          CPU: 28ms
                    ext
                    crunchipC Abwesend
                    crunchipC Abwesend
                    09:58:57 TinkerboardS redis-server[13237]: >>> 'logfile /var/log/redis/redis-server.log' Mai 13 09:58:57 TinkerboardS redis-server[13237]: Can't open the log file: Permission denied
                    hast du da neu installiert?
                    https://stackoverflow.com/questions/49670211/failed-to-start-advanced-key-value-store-redis-server-service-control-process-e
                      GregorSG Offline
                      GregorSG Offline
                      GregorS
                      @crunchip
                      Nicht bewusst.
                      Habe einiges versucht um redis wieder zum laufen zu bewegen.
                      • GregorSG GregorS
                        @crunchip
                        Nicht bewusst.
                        arteckA Offline
                        arteckA Offline
                        arteck
                        was heisst das.. wenn die dump datei kaputt ist dann kannst du nix machen.. ausser du hast eine sicherung davon.
                        und mit deinen Angaben kann man nix anfagen.. also
                        was hast du gemacht.. ?? warum ist der iobroker abgestürtzt ??
                        was hast du danach installiert ?? hast du eine Sicherung ?
                        • arteckA arteck
                          GregorSG Offline
                          GregorSG Offline
                          GregorS
                          schrieb am zuletzt editiert von GregorS
                          @arteck
                          Ich habe sudo apt-get update ausgeführt.
                          Die Dump-Datei ist vorhanden, habe aber noch Backups.
                          Warum der ioB abstürzt habe ich noch nicht herausgefunden.
                          Er ist aber weder über die GUI noch über die Konsole erreichbar und wird dann ziemlich heiß.
                          LAN-LED flackert wie irre.
                          Das Sytem ist auf dem letzten Stand gewesen, alle Apter (bis auf vis) waren aktuell
                          crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                          • GregorSG GregorS
                            @arteck
                            crunchipC Abwesend
                            crunchipC Abwesend
                            wahrscheinlich aufgrund dass das System am Limit rödelt und die Folge
                            mal mit top schauen was da so los ist
                              GregorSG Offline
                              GregorSG Offline
                              GregorS
                              @crunchip
                              top - 12:13:07 up  3:46,  1 user,  load average: 0,16, 0,23, 0,24
                              Tasks: 135 total,   1 running,  81 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0,9 us,  0,7 sy,  0,0 ni, 98,4 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
                              KiB Mem :  2050800 total,  1064036 free,   367352 used,   619412 buff/cache
                              KiB Swap:  1025396 total,  1025396 free,        0 used.  1601040 avail Mem
                              Leider kann ich top nicht mehr ausführen, wenn das System abschmiert, da ich keinen Zugriff mehr auf die Konsole habe
                              • GregorSG GregorS
                                @arteck
                                Da auf einem Server keine GUI läuft kann die also gar nicht erreichbar sein.
                                • GregorSG Offline
                                  GregorSG Offline
                                  GregorS
                                  Habe mein Reservesystem aktiviert.
                                  Läuft nun Alles wieder.
                                  Hoffe es bleibt auch so.
