  3. Off Topic
  4. Proxmox
  5. Proxmox und iobroker
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
226 Beiträge 8 Kommentatoren 34.8k Aufrufe 5 Beobachtet
  • Marko1974M Offline
    Marko1974M Offline
    Marko1974
    schrieb am zuletzt editiert von Marko1974
    #214
    @crunchip
    2022-05-01 22:15:52.061  - info: host.ioBroker iobroker.js-controller version 4.0.21 js-controller starting
    2022-05-01 22:15:52.065  - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-05-01 22:15:52.066  - info: host.ioBroker hostname: ioBroker, node: v14.19.1
    2022-05-01 22:15:52.066  - info: host.ioBroker ip addresses: 192.168.178.70 fe80::28d0:9fff:feec:e166
    2022-05-01 22:15:52.825  - info: host.ioBroker connected to Objects and States
    2022-05-01 22:15:52.847  - info: host.ioBroker added notifications configuration of host
    2022-05-01 22:15:53.150  - info: host.ioBroker 28 instances found
    2022-05-01 22:15:53.176  - info: host.ioBroker starting 1 instance
    2022-05-01 22:15:53.247  - info: host.ioBroker instance system.adapter.admin.0 started with pid 2528
    2022-05-01 22:15:54.230  - info: admin.0 (2528) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.21
    2022-05-01 22:15:54.259  - info: admin.0 (2528) requesting all states
    2022-05-01 22:15:54.260  - info: admin.0 (2528) requesting all objects
    2022-05-01 22:15:54.947  - info: admin.0 (2528) received all objects
    2022-05-01 22:15:55.043  - info: admin.0 (2528) Request actual repository...
    2022-05-01 22:15:55.053  - info: admin.0 (2528) http server listening on port 8111
    2022-05-01 22:15:55.053  - info: admin.0 (2528) Use link "http://localhost:8111" to configure.
    2022-05-01 22:15:55.307  - info: host.ioBroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-05-01 22:15:56.634  - info: admin.0 (2528) Repository received successfully.
    • Marko1974M Marko1974
      @crunchip
      crunchipC Abwesend
      crunchipC Abwesend
      #215
      @marko1974 sagte in Proxmox und iobroker:
      immer noch der falsche Port
      Marko1974M 1 Antwort Letzte Antwort
        Marko1974M Offline
        Marko1974M Offline
        Marko1974
        #216
        @crunchip wieder :-)
        der ist ja aus dem backup
          Marko1974M Offline
          Marko1974
          #217
          @crunchip
          2022-05-01 22:38:02.845  - info: admin.0 (410) requesting all states
          2022-05-01 22:38:02.846  - info: admin.0 (410) requesting all objects
          2022-05-01 22:38:03.521  - info: admin.0 (410) received all objects
          2022-05-01 22:38:03.617  - info: admin.0 (410) Request actual repository...
          2022-05-01 22:38:03.626  - info: admin.0 (410) http server listening on port 8081
          2022-05-01 22:38:03.627  - info: admin.0 (410) Use link "http://localhost:8081" to configure.
          2022-05-01 22:38:03.905  - info: host.ioBroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
          2022-05-01 22:38:04.875  - info: admin.0 (410) Repository received successfully.
          hm?
            @crunchip
            hm?
            crunchipC Abwesend
            crunchipC Abwesend
            #218
            hm?
            passt ja jetzt, oder was meinst du?
              hm?
              Marko1974M Offline
              Marko1974M Offline
              Marko1974
              #219
              @crunchip ja passt doch oder?
                crunchipC Abwesend
                crunchipC Abwesend
                #220
                @marko1974 ja
                  @marko1974 ja
                  Marko1974M Offline
                  Marko1974M Offline
                  Marko1974
                  #221
                  @crunchip danke euch erstmal.....freut ihr euch schon auf den neuen thread "durchreichen von USB?" :-)
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #222
                    @marko1974 Doku lesen😜
                      Marko1974M Offline
                      Marko1974M Offline
                      Marko1974
                      #223
                      @crunchip das habe ich wahrhaftig gemacht. Aber eine andere.
                      Damit habe ich zumindest meinen CUL zum laufen bekommen.
                      gescheitert bin ich irgendwie an dem deconz teil.
                      Ist es eigentlich so, wenn ich das ganze system nicht im container laufen lasse sondern in einer vm - alle USB ganz normal erkannt würden?
                      Das Problem war halt, dass ich 2 USB Sticks habe - die beide auf ttyUSB0 laufen ...kann das denn so richtig sein? Sie haben zwar Unterschiedliche BUS Adressen und auch vendor und product id sind anders (logischerweise) .... aber beide auf USB0 fand ich irgendwie seltsam
                        #224
                        In einer VM ist das Handling 'normal'.
                        Das sollte nicht der Fall sein.
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #225
                          Ja
                          aber beide auf USB0
                          Kann ich dir gerade gar nicht beantworten
                            Ja
                            aber beide auf USB0
                            Marko1974M Offline
                            Marko1974M Offline
                            Marko1974
                            #226
                            @crunchip hab jetzt iobroker als VM angelegt - da funktionieren jetzt auch die USB Ports....lag wahrscheinlichg am unpriviligiertem container
