  3. Einsteigerfragen
  4. iobroker läuft nicht mehr
    2.7k
    4.8k
    4.0k
87 Beiträge 4 Kommentatoren 8.8k Aufrufe 3 Beobachtet
    @emi-0 sagte in iobroker läuft nicht mehr:
    Wie kann ich das machen?
    eigentlich müsste das der Fixer machen:
    iobroker stop
    iobroker fix
    iobroker start
    Emi 0
    Anscheinend macht der fixer bei mir nicht das Richtige
    micros02@smartmeter:~ $ iobroker fix
    library: loaded
    Library version=2022-02-10
        Welcome to the ioBroker installation fixer!
        Script version: 2022-02-13
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
    Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
    Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [282 kB]
    Fetched 321 kB in 4s (89.5 kB/s)
    Reading package lists... Done
    Installed gcc-c++
    Installed python-dev
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    micros02@smartmeter:~ $ iobroker start
    micros02@smartmeter:~ $ iobroker status
    No connection to databases possible ...
    micros02@smartmeter:~ $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
    getfacl: Removing leading '/' from absolute path names
    # file: opt/iobroker/iobroker-data/objects.jsonl
    # owner: iobroker
    # group: iobroker
    user::rw-
    group::r--
    group:iobroker:rwx
    mask::rwx
    other::r--
    • E Emi 0
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      # owner: iobroker
      # group: iobroker
      user::rw-
      group::r--
      group:iobroker:rwx
      mask::rwx
      other::r--
      @emi-0
      systemctl status iobroker.service
      sagt?
      E 1 Antwort Letzte Antwort
        @emi-0
        sagt?
        Emi 0
        micros02@smartmeter:~ $ systemctl status iobroker.service
        ● iobroker.service - ioBroker Server
             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
             Active: active (running) since Tue 2022-05-03 17:35:03 CEST; 40s ago
               Docs: http://iobroker.net
           Main PID: 27228 (iobroker.js-con)
              Tasks: 18 (limit: 415)
                CPU: 40.513s
             CGroup: /system.slice/iobroker.service
                     ├─27228 iobroker.js-controller
                     └─27241 node /opt/iobroker/node_modules/iobroker.js-controller/iob>
        May 03 17:35:03 smartmeter systemd[1]: Started ioBroker Server.
        May 03 17:35:44 smartmeter systemd[1]: iobroker.service: Main process exited, c>
        May 03 17:35:44 smartmeter systemd[1]: iobroker.service: Failed with result 'ex>
        May 03 17:35:44 smartmeter systemd[1]: iobroker.service: Consumed 40.716s CPU t>
        lines 1-15/15 (END)
        • E Emi 0
                  CPU: 40.513s
          lines 1-15/15 (END)
          @emi-0
          Mach das Fenster mal breiter, damit man alles sieht.
            @emi-0
            Emi 0
            wie mache ich das?
            • E Emi 0
                      CPU: 40.513s
              lines 1-15/15 (END)
              HomoranH Offline
              HomoranH Offline
              irgendwo muss da mehr stehen
              Das Fenster der Konsole kannst du doch größer (breiter) ziehen, oder?
                Emi 0
                ja kann ich, aber die Zeile hört mit 'ex auf
                        CPU: 40.513s
                lines 1-15/15 (END)
                • E Emi 0
                          CPU: 40.513s
                  lines 1-15/15 (END)
                  HomoranH Offline
                  HomoranH Offline
                  hast du jetzt nur das Fenster breiter gemacht oder auch den Befehl nochmal abgedrückt?
                    Emi 0
                    nach erneutem Abschicken des Befehls sieht das Ergebnis ganz anders aus, warum, was hat sich geändert??
                            CPU: 40.513s
                    lines 1-15/15 (END)
                    micros02@smartmeter:~ $ ^C
                         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                         Active: active (running) since Tue 2022-05-03 17:49:00 CEST; 38s ago
                       Main PID: 27626 (iobroker.js-con)
                          Tasks: 11 (limit: 415)
                            CPU: 38.168s
                                 └─27626 iobroker.js-controller
                    May 03 17:49:00 smartmeter systemd[1]: Started ioBroker Server.
                    • E Emi 0
                              CPU: 40.513s
                      lines 1-15/15 (END)
                              CPU: 38.168s
                      Emi 0
                      #66
                      @emi-0
                      vielleicht eine kurze Frage zwischendrin:
                      Warum läuft ein System einen Monat stabil und auf einmal ist es tot. Wie kann das sein?
                      • E Emi 0
                        @emi-0
                        #67
                        Wie kann das sein?
                        Da gibt es mehrere Möglichkeiten.
                        Geänderte Software, geänderte URLs, Dateisystem hat 'nen Schuß, andere Hardware hat 'ne Macke... und noch zig andere.
                        • E Emi 0
                          @emi-0
                          #68
                          @emi-0
                          Der zweite Output sieht doch relativ gesund aus. Laufen halt keine Instanzen.
                          iobroker status
                          iobroker list instances
                            Wie kann das sein?
                            Emi 0
                            #69
                            und wenn ich nur die Daten vom host auf den PC kopiert aber sonst nichts geändert habe?
                            Wie können sich die genannten Dinge von alleine ändern und zwar so, dass wir jetzt schon tagelang herumdoktern und es nicht mehr zum Laufen bringen?
                            • E Emi 0
                              #70
                              Das ist eine große Fehlerquelle da die Rechte zu verbiegen.
                              Vermutich ein Windows im Spiel? Das kennt die POSIX-Dateirechte nicht. Deswegen wird beim zurückkopieren ein harmloser Standard gesetzt, wenn man nicht aufpasst.
                                Emi 0
                                #71
                                ich kopiere mit WinSCP. Mir war nicht bewusst, dass ich damit Rechte verbiege. Vor allem war 30x alles in Ordnung und auf einmal sind die Rechte verbogen?
                                Was passiert da?
                                • E Emi 0
                                  Was passiert da?
                                  HomoranH Offline
                                  HomoranH Offline
                                  #72
                                  Da wirst du schon mal nicht als user iobroker aktiv sein - geht ja auch nicht.
                                  Aber hoffentlich nicht als root, das wäre worst case
                                    Emi 0
                                    #73
                                    Das habe ich nicht verstanden.
                                    Was mache ich falsch?
                                    • E Emi 0
                                      HomoranH Offline
                                      HomoranH Offline
                                      #74
                                      Ich versuche es mal anders:
                                      mit welchem User loggst du dich über WINSP auf dem ioBroker ein?
                                      das versuchen wir ja herauszubekommen
                                        Emi 0
                                        #75
                                        micros02
                                        • E Emi 0
                                          micros02
                                          HomoranH Offline
                                          HomoranH Offline
                                          #76
                                          micros02
                                          und der ist vermutlich in der Gruppe ioBroker?
                                          Dann ist alles gut
                                          Aber einfach Dateien kopieren ist nie eine gute Idee
