  3. Off Topic
  4. Proxmox
  5. Proxmox und iobroker
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
226 Beiträge 8 Kommentatoren 34.8k Aufrufe 5 Beobachtet
  • Marko1974M Marko1974
    @homoran dass er nach nem start aber nicht direkt verbindet ist normal?
    System successfully restored!
    openhabian@ioBroker:/opt/iobroker$ iobroker start
    openhabian@ioBroker:/opt/iobroker$ iob status
    Objects type: jsonl
    States  type: jsonl
    openhabian@ioBroker:/opt/iobroker$ iobroker list instances
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8111, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : ioBroker                                 - disabled
      system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
      system.adapter.amazon-dash.0            : amazon-dash           : ioBroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.cul.0                    : cul                   : ioBroker                                 - disabled, port: 23
      system.adapter.deconz.0                 : deconz                : ioBroker                                 - disabled, port: 80
      system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
      system.adapter.device-reminder.1        : device-reminder       : ioBroker                                 - disabled
      system.adapter.eusec.0                  : eusec                 : ioBroker                                 - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
      system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 - disabled
      system.adapter.habpanel.0               : habpanel              : ioBroker                                 - disabled
      system.adapter.harmony.0                : harmony               : ioBroker                                 - disabled
      system.adapter.history.0                : history               : ioBroker                                 - disabled
      system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 - disabled
      system.adapter.hue.0                    : hue                   : ioBroker                                 - disabled, port: 443
      system.adapter.javascript.0             : javascript            : ioBroker                                 - disabled
      system.adapter.maxcube.0                : maxcube               : ioBroker                                 - disabled, port: 62910, bind: 0.0.0.0
      system.adapter.mihome.0                 : mihome                : ioBroker                                 - disabled, port: 9898, bind: 192.168.178.72
      system.adapter.node-red.0               : node-red              : ioBroker                                 - disabled, port: 1880, bind: 0.0.0.0
      system.adapter.shelly.0                 : shelly                : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 - disabled
      system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 - disabled
      system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wled.0                   : wled                  : ioBroker                                 - disabled
      system.adapter.yahka.1                  : yahka                 : ioBroker                                 - disabled
      system.adapter.yahka.2                  : yahka                 : ioBroker                                 - disabled
    + instance is alive
    Ich war falsch....anderer port :-)
    Marko1974M Offline
    Marko1974M Offline
    Marko1974
    #184
    @marko1974 node red hat er aber nicht gemacht....oder dauert das?
    crunchipC HomoranH 2 Antworten Letzte Antwort
      crunchipC Abwesend
      crunchipC Abwesend
      #185
      @marko1974 das dauert ne Weile
      Marko1974M 1 Antwort Letzte Antwort
        Marko1974M Offline
        Marko1974M Offline
        Marko1974
        #186
        @crunchip jetzt muss ich den raspberry abnabeln und dem neuen Teil die gleiche IP geben. da kann ich doch einfach nur den ip im container ändern, richtig?
          #187
          @marko1974 sagte in Proxmox und iobroker:
          jetzt warte doch bis er fertig ist.
          kann bis zu einer Stunde dauern
            Marko1974M Offline
            Marko1974M Offline
            Marko1974
            #188
            @homoran mit instanzen installieren ist er fertig...steht alles auf stop
              #189
              und "hunderte" andere Instanzen auch noch nicht.
              Die müssen jetzt alle erst neu für die geänderte Hardware und node-Version (?) gebaut werden
              sicher?
              oder nur das Einlesen der Konfigs
                crunchipC Abwesend
                crunchipC Abwesend
                #190
                @marko1974
                welche IP
                  sicher?
                  Marko1974M Offline
                  Marko1974M Offline
                  Marko1974
                  #191
                  @homoran im protokoll ist er aber fertig
                    @marko1974
                    welche IP
                    Marko1974M Offline
                    Marko1974M Offline
                    Marko1974
                    #192
                    @crunchip die vom alten raspberry....sonst muss ich jeden adapter manuell anpassen, oder?
                      #193
                      Mann!!
                      Beweise! Keine Nacherzählungen!!
                      Sonst sind wir es nachher schuld.
                      Im Protokoll steht Restore fertig
                      Das heisst nur dass die Dateien zurückgeschrieben wurde
                      wieso jeden?
                      nur die paar wenigen, die eine Callback.- oder Adapteradresse drin haben
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #194
                        @marko1974 ich raffs immer noch nicht, dein Iobroker lief doch in einem ganz anderen Netz
                        HomoranH Marko1974M 2 Antworten Letzte Antwort
                          Mann!!
                          wieso jeden?
                          Marko1974M Offline
                          Marko1974M Offline
                          Marko1974
                          #195
                          @homoran ich kann ihn auch einfach auf der ip lassen....ich dachte nur, wenn ich zu Geräten wie xiaomi connecte wäre es gut, wenn alles gleich wäre
                            #196
                            @crunchip sagte in Proxmox und iobroker:
                            Ich glaube den Pi hat er auch kurz bei seinen Eltern installiert um ein neues Backup zu ziehen
                            kenne ich nicht, klingt aber wie MQTT, wo in den Geräten die MQTT-Broker-IP angegeben ist.
                            Dann kann es durchaus sinnvoll sein.
                            ABER erst, wenn wirklich alles fertig ist
                              Marko1974M Offline
                              Marko1974M Offline
                              Marko1974
                              schrieb am zuletzt editiert von Marko1974
                              #197
                              @crunchip said in Proxmox und iobroker:
                              NEIN! Der iobroker lief hier bei meinen Eltern. Auf nem Raspberry der jetzt aktuell auch läuft.
                              Stand jetzt ist: Wir ziehen einfach nur um auf ein neues system.
                              Genau das hatte ich versucht bei MIR ZUHAUSE vorzubereiten. In einem anderem Netz.
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #198
                                per mihome?
                                Instanzen die z.b. mqtt sprechen musst du die IP anpassen
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #199
                                  @marko1974 ach jetzt hats geklingelt
                                    per mihome?
                                    Marko1974M Offline
                                    Marko1974M Offline
                                    Marko1974
                                    #200
                                    @crunchip Eben...und ich dachte wenn ich jetzt den Raspberry ausmache und vom netz trenne....dann dem Container die IP des RPI gebe....der ja dann nicht mehr am Netz ist, wäre es einfacher
                                      #201
                                      @homoran sagte in Proxmox und iobroker:
                                      und???
                                      Marko1974M HomoranH 2 Antworten Letzte Antwort
                                        und???
                                        Marko1974M Offline
                                        Marko1974M Offline
                                        Marko1974
                                        #202
                                        @homoran said in Proxmox und iobroker:
                                        und???
                                        na was ist besser?
                                          und???
                                          #203
                                          und????
