  4. ERROR: Process exited with code 25
    5.1k
updateerror
147 Beiträge 11 Kommentatoren 50.2k Aufrufe 10 Beobachtet
    @joeysch sagte in ERROR: Process exited with code 25:
    Process exited with code 0
    Ist aber eigentlich die Positiv-Meldung.
    iobroker update -i
    iobroker upgrade
    liefert?
    joeysch
    guido@iobroker:~$ iobroker update -i
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "backitup"     : 2.4.6    , installed 2.4.6
    Adapter    "bring"        : 1.7.13   , installed 1.7.13
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "daswetter"    : 3.0.9    , installed 3.0.9
    Adapter    "denon"        : 1.13.3   , installed 1.13.3
    Adapter    "devices"      : 1.0.10   , installed 1.0.10
    Adapter    "discovery"    : 3.0.3    , installed 2.8.0  [Updatable]
    Adapter    "fullybrowser" : 2.1.1    , installed 2.1.1
    Adapter    "heos"         : 1.9.1    , installed 1.9.1
    Adapter    "homeconnect"  : 1.0.1    , installed 1.0.1
    Adapter    "ical"         : 1.12.1   , installed 1.12.1
    Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
    Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
    Adapter    "info"         : 1.9.18   , installed 1.9.18
    Adapter    "iot"          : 1.11.4   , installed 1.11.4
    Adapter    "javascript"   : 5.2.21   , installed 5.2.21
    Controller "js-controller": 4.0.21   , installed 4.0.21
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "material"     : 1.1.2    , installed 1.1.2
    Adapter    "melcloud"     : 1.1.6    , installed 1.1.6
    Adapter    "node-red"     : 3.2.0    , installed 3.2.0
    Adapter    "simple-api"   : 2.6.4    , installed 2.6.3  [Updatable]
    Adapter    "socketio"     : 4.2.0    , installed 4.1.4  [Updatable]
    Adapter    "sonoff"       : 2.5.0    , installed 2.4.7  [Updatable]
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.12.2   , installed 1.11.1 [Updatable]
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.15 [Updatable]
    Adapter    "trashschedule": 1.4.5    , installed 1.4.1  [Updatable]
    Adapter    "vis"          : 1.4.5    , installed 1.4.5
    Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
    Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "web"          : 4.2.3    , installed 4.2.0  [Updatable]
    Adapter    "ws"           : 1.2.0    , installed 1.2.0
    Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
    Ich habe dann das upgrade ausgeführt, es ist auch alles durchgelaufen, am Ende war aber nichts upgedatet
    guido@iobroker:~$ iobroker upgrade
    This upgrade of "web" will introduce the following changes:
    -> 4.2.3:
    Updated ws and socketio to have `log` method in sockets
    -> 4.2.2:
    -> 4.2.1:
    Provide state and object changes for simple-api
    Would you like to upgrade web from @4.2.0 to @4.2.3 now? [(y)es, (n)o]: y
    Update web from @4.2.0 to @4.2.3
    host.iobroker Adapter "system.adapter.web.0" is stopped.
    NPM version: 6.14.16
    Installing iobroker.web@4.2.3... (System call)
    The authenticity of host 'github.com (140.82.121.3)' can't be established.
    ECDSA key fingerprint is SHA256:p2QAMXNIC1TJYWeIOttrVc98/R1BUFWu3/LiyKgUfQM.
    Are you sure you want to continue connecting (yes/no/[fingerprint])? y
    Please type 'yes', 'no' or the fingerprint: yes
    Please type 'yes', 'no' or the fingerprint: 'yes'
    Please type 'yes', 'no' or the fingerprint: ^[^[
    Please type 'yes', 'no' or the fingerprint: ^X
    yes
    upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
    upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
    upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
    upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
    upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
    upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
    upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
    upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
    upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
    upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
    upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
    upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
    upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
    upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
    upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
    upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
    upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
    upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
    upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
    upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
    upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
    upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
    upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
    upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
    upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
    upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
    upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
    upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
    upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
    upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
    upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
    upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
    upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
    upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
    upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
    upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
    upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
    upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
    upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
    upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
    upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
    upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
    upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js static/js/2.83d9909b.chunk.js application/javascript
    upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js.LICENSE.txt static/js/2.83d9909b.chunk.js.LICENSE.txt text/plain
    upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js.map static/js/2.83d9909b.chunk.js.map application/json
    upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.205b2673.chunk.js static/js/main.205b2673.chunk.js application/javascript
    upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.205b2673.chunk.js.map static/js/main.205b2673.chunk.js.map application/json
    upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js static/js/runtime-main.8b37c647.js application/javascript
    upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js.map static/js/runtime-main.8b37c647.js.map application/json
    upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
    upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
    host.iobroker Adapter "system.adapter.web.0" is started
    This upgrade of "trashschedule" will introduce the following changes:
    -> 1.4.5:
    Allow spaces in next text seperator
    -> 1.4.4:
    Updated dependencies
    -> 1.4.3:
    Updated state roles
    Added hint for Admin 4 configuration
    -> 1.4.2:
    Added check for ical configuration
    Would you like to upgrade trashschedule from @1.4.1 to @1.4.5 now? [(y)es, (n)o]: y
    Update trashschedule from @1.4.1 to @1.4.5
    Installing iobroker.trashschedule@1.4.5... (System call)
    Adapter "system.adapter.vis.0" restarted.
    upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
    This upgrade of "tr-064" will introduce the following changes:
    -> 4.2.16:
    Fix info logs on callee/caller
    Add special handling for potential broken external image links in phonebook
    Prevent some crash cases reported by Sentry
    Would you like to upgrade tr-064 from @4.2.15 to @4.2.16 now? [(y)es, (n)o]: y
    Update tr-064 from @4.2.15 to @4.2.16
    Installing iobroker.tr-064@4.2.16... (System call)
    upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
    upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
    upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
    This upgrade of "telegram" will introduce the following changes:
    -> 1.12.2:
    Fix crash cases reported by Sentry
    -> 1.12.0:
    Add new JSON states communication.responseJson and communication.responseSilentJson to also accept json structures (stringified!) to send messages
    Try to prevent adapter crashes when internet is not available
    Add Sentry for crash reporting
    Would you like to upgrade telegram from @1.11.1 to @1.12.2 now? [(y)es, (n)o]: y
    Update telegram from @1.11.1 to @1.12.2
    Installing iobroker.telegram@1.12.2... (System call)
    upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
    upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
    upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
    upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
    upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
    upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
    upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
    This upgrade of "sonoff" will introduce the following changes:
    -> 2.5.0:
    Implement writing of NSPanel Widget changes
    Fix crash case reported by Sentry
    Would you like to upgrade sonoff from @2.4.7 to @2.5.0 now? [(y)es, (n)o]: y
    Update sonoff from @2.4.7 to @2.5.0
    Installing iobroker.sonoff@2.5.0... (System call)
    upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
    upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
    upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
    upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
    This upgrade of "socketio" will introduce the following changes:
    -> 4.2.0:
    Added `log` socket command
    -> 4.1.5:
    make sure patterns are handled as strings on subscribe/unsubscribe
    when getHistory is called with instance as string correct the data into an object
    Would you like to upgrade socketio from @4.1.4 to @4.2.0 now? [(y)es, (n)o]: y
    Update socketio from @4.1.4 to @4.2.0
    host.iobroker Adapter "system.adapter.socketio.0" is stopped.
    Installing iobroker.socketio@4.2.0... (System call)
    Adapter "system.adapter.web.0" restarted.
    upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
    host.iobroker Adapter "system.adapter.socketio.0" is started
    This upgrade of "simple-api" will introduce the following changes:
    -> 2.6.4:
    Optimize performance, especially when using names instead of object ids
    Would you like to upgrade simple-api from @2.6.3 to @2.6.4 now? [(y)es, (n)o]: y
    Update simple-api from @2.6.3 to @2.6.4
    Installing iobroker.simple-api@2.6.4... (System call)
    upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
    upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
    upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
    upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
    This upgrade of "discovery" will introduce the following changes:
    -> 3.0.3:
    -> 3.0.2:
    Updated serialport package
    -> 3.0.1:
    -> 3.0.0:
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade discovery from @2.8.0 to @3.0.3 now? [(y)es, (n)o]: y
    Update discovery from @2.8.0 to @3.0.3
    Installing iobroker.discovery@3.0.3... (System call)
    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    • J joeysch
      -> 4.2.3:
      -> 4.2.2:
      -> 4.2.1:
      yes
      -> 1.4.5:
      -> 1.4.4:
      -> 1.4.3:
      Updated state roles
      -> 1.4.2:
      -> 4.2.16:
      -> 1.12.2:
      -> 1.12.0:
      -> 2.5.0:
      -> 4.2.0:
      -> 4.1.5:
      -> 2.6.4:
      -> 3.0.3:
      -> 3.0.2:
      -> 3.0.1:
      -> 3.0.0:
      The authenticity of host 'github.com (140.82.121.3)' can't be established. ECDSA key fingerprint is SHA256:p2QAMXNIC1TJYWeIOttrVc98/R1BUFWu3/LiyKgUfQM.
      Die Meldung hab ich auch noch nie gesehen.
      iobroker repo list
      sagt?
        iobroker repo list
        sagt?
        joeysch
        guido@iobroker:~$ iobroker repo list
        Active repo(s): stable
        • J joeysch
          @joeysch
          Das passt. Warum da keys nicht gefunden werden... Keine Ahnung.
          • J joeysch
            am Wochenende hatte ich einige Adapter zum updaten angezeigt bekommen.
            Ich glaube die Admin Instanz konnte ich noch Updaten, alle anderen Updates brechen mit dieser Meldung ab:
            $ iobroker upgrade simple-api@2.6.4
            NPM version: 7.5.2
            host.iobroker Cannot install iobroker.simple-api@2.6.4: 217
            VIS ist seit dem auch nicht mehr zu erreichen.
            Was könnte das sein?
            Petholdinho
            @joeysch Ich hatte das selbe Problem.
            Ich habe es wie folgt gelöst:
            • Node downgrade auf die empfohlene Version (vorher NodeJs 16) 14.19.1
            sudo npm install -g n
            node -v
            nun siehst du deine Version. Dann...
            sudo n. 14.19.1
            node -v
            Nun solltest du auf dem richtigen Stand sein.
            Danach lief iobroker nach dem Neustart. Allerdings funktionierten die Updates nicht und ich wollte den Fixer drüber laufen lassen. Mir wurde angezeigt das iobroker nicht installiert ist... PANIK...
            Dann habe ich folgenden gemacht:
            iobroker stop
            sudo su
            cd /opt/iobroker
            chown -R iobroker /opt/iobroker
            npm install -y iobroker.js-controller --unsafe-perm --production --save --prefix
            curl -sL https://iobroker.net/fix.sh | bash -
            iobroker start
            Danach lief wieder alles richtig gut. Der Fehler ist seit dem weg.
            Evtl. hilft es dir ja.
            • P Petholdinho
              node -v
              sudo n. 14.19.1
              node -v
              iobroker stop
              sudo su
              cd /opt/iobroker
              iobroker start
              @petholdinho sagte in ERROR: Process exited with code 25:
              Bitte nodejs/npm NICHT auf diese Art am System vorbei reinknüppeln.
              Das sorgt hinten und vorne für Probleme.
              Genauso wie
              sudo su
              Macht man auch NIE.
              Die anderen Befehle sind auch unsauber.
              Also ein super Beispiel, wie man es gerade nicht macht.
              P 1 Antwort Letzte Antwort
                Genauso wie
                sudo su
                Macht man auch NIE.
                Petholdinho
                @thomas-braun sorry, ich habe den ersten Teil aus einem YouTube Video zum Thema downgrade und den Rest aus einem bekannten Tool das Recht bekannt ist. Wenn du rech hast und das alles falsch ist, dann sollte man meine Schritte definitiv nicht nachmachen. Ich habe nur dargestellt was bei mir geholfen hat. Falls du einen sauberen Weg nennen kannst, wäre es cool wenn du diesen hier teilen könntest.
                • P Petholdinho
                  @petholdinho
                  Meine beiden Lieblingsquellen für stetige Freude mit verpfuschten nodejs-Installationen...
                  Die meisten yt-Filmchen kannste in die Tonne kloppen, da wird oft irgendwelcher Murks fabriziert.
                  Und das 'bekannte Tool' vom PiepmatzGuppy ist eigentlich nur dafür bekannt, das es mehr kaputt macht als das es zu einer sauberen Installation verhilft.
                  Finger weg von dem Schrott.
                  Den sauberen Weg, wie man über den Paketmanager z. B. nodejs nach belieben rauf und runter installiert findet sich in meiner Signatur.
                    @petholdinho
                    joeysch
                    Vielleicht kannst du nochmal helfen, ich bekomme weder irgend einen Adapter geupdatet
                    noch irgend einen Adapter neu installiert
                    Error:Process exited with code 25
                    Auch der Host lässt sich nicht aktualisieren.
                    Nach Anweisung läuft zwar alles durch aber der Stand bleibt
                    • J joeysch
                      @joeysch
                      iobroker update -i
                      iobroker upgrade
                        @joeysch
                        iobroker update -i
                        iobroker upgrade
                        joeysch
                        Hatte ich gerade gemacht, läuft alles problemlos durch, mit Abfrage die mit "y" bestätigt werden muß.
                        Nichts, kein einziger Adapter wurde aktualisiert.
                        • J joeysch
                          @joeysch
                          Bitte Ausgaben zeigen. So kann man da nur raten.
                          Zusätzlich noch:
                          cd /opt/iobroker
                          npm ls --depth=0
                            @joeysch
                            Zusätzlich noch:
                            cd /opt/iobroker
                            npm ls --depth=0
                            joeysch
                            @thomas-braun sagte in ERROR: Process exited with code 25:
                            Das sieht ja aus als fehlt da alles mögliche. Die ersten Zeilen sind nicht mehr da.
                            npm ERR! missing: component-emitter@1.2.1, required by socket.io-parser@3.4.1
                            npm ERR! missing: debug@4.1.1, required by socket.io-parser@3.4.1
                            npm ERR! missing: isarray@2.0.1, required by socket.io-parser@3.4.1
                            npm ERR! missing: imap@0.8.19, required by node-red-node-email@1.14.0
                            npm ERR! missing: mailparser@3.4.0, required by node-red-node-email@1.14.0
                            npm ERR! missing: nodemailer@6.7.2, required by node-red-node-email@1.14.0
                            npm ERR! missing: smtp-server@3.9.0, required by node-red-node-email@1.14.0
                            npm ERR! missing: readable-stream@1.1.14, required by imap@0.8.19
                            npm ERR! missing: utf7@1.0.2, required by imap@0.8.19
                            npm ERR! missing: core-util-is@1.0.2, required by readable-stream@1.1.14
                            npm ERR! missing: inherits@2.0.4, required by readable-stream@1.1.14
                            npm ERR! missing: isarray@0.0.1, required by readable-stream@1.1.14
                            npm ERR! missing: string_decoder@0.10.31, required by readable-stream@1.1.14
                            npm ERR! missing: semver@5.3.0, required by utf7@1.0.2
                            npm ERR! missing: encoding-japanese@1.0.30, required by mailparser@3.4.0
                            npm ERR! missing: he@1.2.0, required by mailparser@3.4.0
                            npm ERR! missing: html-to-text@8.0.0, required by mailparser@3.4.0
                            npm ERR! missing: iconv-lite@0.6.3, required by mailparser@3.4.0
                            npm ERR! missing: libmime@5.0.0, required by mailparser@3.4.0
                            npm ERR! missing: linkify-it@3.0.3, required by mailparser@3.4.0
                            npm ERR! missing: nodemailer@6.7.0, required by mailparser@3.4.0
                            npm ERR! missing: mailsplit@5.3.1, required by mailparser@3.4.0
                            npm ERR! missing: tlds@1.224.0, required by mailparser@3.4.0
                            npm ERR! missing: @selderee/plugin-htmlparser2@0.6.0, required by html-to-text@8.0.0
                            npm ERR! missing: deepmerge@4.2.2, required by html-to-text@8.0.0
                            npm ERR! missing: he@1.2.0, required by html-to-text@8.0.0
                            npm ERR! missing: htmlparser2@6.1.0, required by html-to-text@8.0.0
                            npm ERR! missing: minimist@1.2.5, required by html-to-text@8.0.0
                            npm ERR! missing: selderee@0.6.0, required by html-to-text@8.0.0
                            npm ERR! missing: domhandler@4.2.2, required by @selderee/plugin-htmlparser2@0.6.0
                            npm ERR! missing: selderee@0.6.0, required by @selderee/plugin-htmlparser2@0.6.0
                            npm ERR! missing: domelementtype@2.2.0, required by domhandler@4.2.2
                            npm ERR! missing: domelementtype@2.2.0, required by htmlparser2@6.1.0
                            npm ERR! missing: domhandler@4.2.2, required by htmlparser2@6.1.0
                            npm ERR! missing: domutils@2.8.0, required by htmlparser2@6.1.0
                            npm ERR! missing: entities@2.2.0, required by htmlparser2@6.1.0
                            npm ERR! missing: dom-serializer@1.3.2, required by domutils@2.8.0
                            npm ERR! missing: domelementtype@2.2.0, required by domutils@2.8.0
                            npm ERR! missing: domhandler@4.2.2, required by domutils@2.8.0
                            npm ERR! missing: domelementtype@2.2.0, required by dom-serializer@1.3.2
                            npm ERR! missing: domhandler@4.2.2, required by dom-serializer@1.3.2
                            npm ERR! missing: entities@2.2.0, required by dom-serializer@1.3.2
                            npm ERR! missing: parseley@0.7.0, required by selderee@0.6.0
                            npm ERR! missing: moo@0.5.1, required by parseley@0.7.0
                            npm ERR! missing: nearley@2.20.1, required by parseley@0.7.0
                            npm ERR! missing: commander@2.20.3, required by nearley@2.20.1
                            npm ERR! missing: moo@0.5.1, required by nearley@2.20.1
                            npm ERR! missing: railroad-diagrams@1.0.0, required by nearley@2.20.1
                            npm ERR! missing: randexp@0.4.6, required by nearley@2.20.1
                            npm ERR! missing: discontinuous-range@1.0.0, required by randexp@0.4.6
                            npm ERR! missing: ret@0.1.15, required by randexp@0.4.6
                            npm ERR! missing: safer-buffer@2.1.2, required by iconv-lite@0.6.3
                            npm ERR! missing: encoding-japanese@1.0.30, required by libmime@5.0.0
                            npm ERR! missing: libbase64@1.2.1, required by libmime@5.0.0
                            npm ERR! missing: iconv-lite@0.6.2, required by libmime@5.0.0
                            npm ERR! missing: libqp@1.1.0, required by libmime@5.0.0
                            npm ERR! missing: safer-buffer@2.1.2, required by iconv-lite@0.6.2
                            npm ERR! missing: uc.micro@1.0.6, required by linkify-it@3.0.3
                            npm ERR! missing: libbase64@1.2.1, required by mailsplit@5.3.1
                            npm ERR! missing: libmime@5.0.0, required by mailsplit@5.3.1
                            npm ERR! missing: libqp@1.1.0, required by mailsplit@5.3.1
                            npm ERR! missing: base32.js@0.1.0, required by smtp-server@3.9.0
                            npm ERR! missing: ipv6-normalize@1.0.1, required by smtp-server@3.9.0
                            npm ERR! missing: nodemailer@6.6.1, required by smtp-server@3.9.0
                            npm ERR! missing: feedparser@2.2.10, required by node-red-node-feedparser@0.2.2
                            npm ERR! missing: request@2.88.2, required by node-red-node-feedparser@0.2.2
                            npm ERR! missing: sentiment@2.1.0, required by node-red-node-sentiment@0.1.6
                            npm ERR! missing: request@2.88.2, required by node-red-node-twitter@1.2.0
                            npm ERR! missing: twitter-ng@0.6.2, required by node-red-node-twitter@1.2.0
                            npm ERR! missing: oauth@0.9.15, required by twitter-ng@0.6.2
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.socketio@4.1.4
                            npm ERR! missing: cookie-parser@1.4.6, required by iobroker.socketio@4.1.4
                            npm ERR! missing: express-session@1.17.2, required by iobroker.socketio@4.1.4
                            npm ERR! missing: axios@0.26.1, required by iobroker.socketio@4.1.4
                            npm ERR! missing: socket.io@2.4.1, required by iobroker.socketio@4.1.4
                            npm ERR! missing: passport@0.5.2, required by iobroker.socketio@4.1.4
                            npm ERR! missing: follow-redirects@1.14.9, required by axios@0.26.1
                            npm ERR! missing: has-binary2@1.0.3, required by socket.io@2.4.1
                            npm ERR! missing: debug@4.1.1, required by socket.io@2.4.1
                            npm ERR! missing: engine.io@3.5.0, required by socket.io@2.4.1
                            npm ERR! missing: socket.io-adapter@1.1.2, required by socket.io@2.4.1
                            npm ERR! missing: socket.io-client@2.4.0, required by socket.io@2.4.1
                            npm ERR! missing: socket.io-parser@3.4.1, required by socket.io@2.4.1
                            npm ERR! missing: isarray@2.0.1, required by has-binary2@1.0.3
                            npm ERR! missing: ms@2.1.3, required by debug@4.1.1
                            npm ERR! missing: accepts@1.3.8, required by engine.io@3.5.0
                            npm ERR! missing: cookie@0.4.1, required by engine.io@3.5.0
                            npm ERR! missing: base64id@2.0.0, required by engine.io@3.5.0
                            npm ERR! missing: debug@4.1.1, required by engine.io@3.5.0
                            npm ERR! missing: engine.io-parser@2.2.1, required by engine.io@3.5.0
                            npm ERR! missing: ws@7.4.6, required by engine.io@3.5.0
                            npm ERR! missing: after@0.8.2, required by engine.io-parser@2.2.1
                            npm ERR! missing: has-binary2@1.0.3, required by engine.io-parser@2.2.1
                            npm ERR! missing: arraybuffer.slice@0.0.7, required by engine.io-parser@2.2.1
                            npm ERR! missing: base64-arraybuffer@0.1.4, required by engine.io-parser@2.2.1
                            npm ERR! missing: blob@0.0.5, required by engine.io-parser@2.2.1
                            npm ERR! missing: backo2@1.0.2, required by socket.io-client@2.4.0
                            npm ERR! missing: component-bind@1.0.0, required by socket.io-client@2.4.0
                            npm ERR! missing: has-binary2@1.0.3, required by socket.io-client@2.4.0
                            npm ERR! missing: indexof@0.0.1, required by socket.io-client@2.4.0
                            npm ERR! missing: engine.io-client@3.5.2, required by socket.io-client@2.4.0
                            npm ERR! missing: parseqs@0.0.6, required by socket.io-client@2.4.0
                            npm ERR! missing: parseuri@0.0.6, required by socket.io-client@2.4.0
                            npm ERR! missing: component-emitter@1.3.0, required by socket.io-client@2.4.0
                            npm ERR! missing: debug@3.1.0, required by socket.io-client@2.4.0
                            npm ERR! missing: socket.io-parser@3.3.2, required by socket.io-client@2.4.0
                            npm ERR! missing: to-array@0.1.4, required by socket.io-client@2.4.0
                            npm ERR! missing: component-inherit@0.0.3, required by engine.io-client@3.5.2
                            npm ERR! missing: has-cors@1.1.0, required by engine.io-client@3.5.2
                            npm ERR! missing: indexof@0.0.1, required by engine.io-client@3.5.2
                            npm ERR! missing: component-emitter@1.3.0, required by engine.io-client@3.5.2
                            npm ERR! missing: debug@3.1.0, required by engine.io-client@3.5.2
                            npm ERR! missing: engine.io-parser@2.2.1, required by engine.io-client@3.5.2
                            npm ERR! missing: parseqs@0.0.6, required by engine.io-client@3.5.2
                            npm ERR! missing: parseuri@0.0.6, required by engine.io-client@3.5.2
                            npm ERR! missing: ws@7.4.6, required by engine.io-client@3.5.2
                            npm ERR! missing: xmlhttprequest-ssl@1.6.3, required by engine.io-client@3.5.2
                            npm ERR! missing: yeast@0.1.2, required by engine.io-client@3.5.2
                            npm ERR! missing: ms@2.0.0, required by debug@3.1.0
                            npm ERR! missing: isarray@2.0.1, required by socket.io-parser@3.3.2
                            npm ERR! missing: component-emitter@1.3.0, required by socket.io-parser@3.3.2
                            npm ERR! missing: debug@3.1.0, required by socket.io-parser@3.3.2
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.sonoff@2.4.7
                            npm ERR! missing: mqtt-connection@4.1.0, required by iobroker.sonoff@2.4.7
                            npm ERR! missing: duplexify@3.7.1, required by mqtt-connection@4.1.0
                            npm ERR! missing: inherits@2.0.4, required by mqtt-connection@4.1.0
                            npm ERR! missing: mqtt-packet@6.10.0, required by mqtt-connection@4.1.0
                            npm ERR! missing: safe-buffer@5.1.2, required by mqtt-connection@4.1.0
                            npm ERR! missing: through2@2.0.5, required by mqtt-connection@4.1.0
                            npm ERR! missing: readable-stream@2.3.7, required by duplexify@3.7.1
                            npm ERR! missing: end-of-stream@1.4.4, required by duplexify@3.7.1
                            npm ERR! missing: inherits@2.0.4, required by duplexify@3.7.1
                            npm ERR! missing: stream-shift@1.0.1, required by duplexify@3.7.1
                            npm ERR! missing: core-util-is@1.0.3, required by readable-stream@2.3.7
                            npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7
                            npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7
                            npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7
                            npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7
                            npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7
                            npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7
                            npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1
                            npm ERR! missing: bl@4.1.0, required by mqtt-packet@6.10.0
                            npm ERR! missing: debug@4.3.3, required by mqtt-packet@6.10.0
                            npm ERR! missing: process-nextick-args@2.0.1, required by mqtt-packet@6.10.0
                            npm ERR! missing: ms@2.1.2, required by debug@4.3.3
                            npm ERR! missing: readable-stream@2.3.7, required by through2@2.0.5
                            npm ERR! missing: xtend@4.0.2, required by through2@2.0.5
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#51f520bdc7822da388d7ebea21cc7be636f0eda6
                            npm ERR! missing: iobroker-adapter-helpers@0.0.8, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#51f520bdc7822da388d7ebea21cc7be636f0eda6
                            npm ERR! missing: @sentry/node@5.30.0, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#51f520bdc7822da388d7ebea21cc7be636f0eda6
                            npm ERR! missing: cron@1.8.2, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#51f520bdc7822da388d7ebea21cc7be636f0eda6
                            npm ERR! missing: node-schedule@1.3.3, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#51f520bdc7822da388d7ebea21cc7be636f0eda6
                            npm ERR! missing: @sentry/tracing@5.30.0, required by @sentry/node@5.30.0
                            npm ERR! missing: cookie@0.4.1, required by @sentry/node@5.30.0
                            npm ERR! missing: https-proxy-agent@5.0.0, required by @sentry/node@5.30.0
                            npm ERR! missing: @sentry/core@5.30.0, required by @sentry/node@5.30.0
                            npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/node@5.30.0
                            npm ERR! missing: @sentry/types@5.30.0, required by @sentry/node@5.30.0
                            npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/node@5.30.0
                            npm ERR! missing: lru_map@0.3.3, required by @sentry/node@5.30.0
                            npm ERR! missing: tslib@1.14.1, required by @sentry/node@5.30.0
                            npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/tracing@5.30.0
                            npm ERR! missing: @sentry/minimal@5.30.0, required by @sentry/tracing@5.30.0
                            npm ERR! missing: @sentry/types@5.30.0, required by @sentry/tracing@5.30.0
                            npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/tracing@5.30.0
                            npm ERR! missing: tslib@1.14.1, required by @sentry/tracing@5.30.0
                            npm ERR! missing: @sentry/types@5.30.0, required by @sentry/hub@5.30.0
                            npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/hub@5.30.0
                            npm ERR! missing: tslib@1.14.1, required by @sentry/hub@5.30.0
                            npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/minimal@5.30.0
                            npm ERR! missing: @sentry/types@5.30.0, required by @sentry/minimal@5.30.0
                            npm ERR! missing: tslib@1.14.1, required by @sentry/minimal@5.30.0
                            npm ERR! missing: @sentry/types@5.30.0, required by @sentry/utils@5.30.0
                            npm ERR! missing: tslib@1.14.1, required by @sentry/utils@5.30.0
                            npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/core@5.30.0
                            npm ERR! missing: @sentry/minimal@5.30.0, required by @sentry/core@5.30.0
                            npm ERR! missing: @sentry/types@5.30.0, required by @sentry/core@5.30.0
                            npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/core@5.30.0
                            npm ERR! missing: tslib@1.14.1, required by @sentry/core@5.30.0
                            npm ERR! missing: moment-timezone@0.5.33, required by cron@1.8.2
                            npm ERR! missing: cron-parser@2.18.0, required by node-schedule@1.3.3
                            npm ERR! missing: long-timeout@0.1.1, required by node-schedule@1.3.3
                            npm ERR! missing: sorted-array-functions@1.3.0, required by node-schedule@1.3.3
                            npm ERR! missing: is-nan@1.3.2, required by cron-parser@2.18.0
                            npm ERR! missing: moment-timezone@0.5.33, required by cron-parser@2.18.0
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.tankerkoenig@2.1.1
                            npm ERR! missing: request@2.88.2, required by iobroker.tankerkoenig@2.1.1
                            npm ERR! missing: xml2js@0.4.23, required by iobroker.tankerkoenig@2.1.1
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.telegram@1.11.1
                            npm ERR! missing: axios@0.25.0, required by iobroker.telegram@1.11.1
                            npm ERR! missing: node-telegram-bot-api@0.56.0, required by iobroker.telegram@1.11.1
                            npm ERR! missing: follow-redirects@1.14.9, required by axios@0.25.0
                            npm ERR! missing: array.prototype.findindex@2.1.0, required by node-telegram-bot-api@0.56.0
                            npm ERR! missing: bluebird@3.7.2, required by node-telegram-bot-api@0.56.0
                            npm ERR! missing: depd@1.1.2, required by node-telegram-bot-api@0.56.0
                            npm ERR! missing: eventemitter3@3.1.2, required by node-telegram-bot-api@0.56.0
                            npm ERR! missing: file-type@3.9.0, required by node-telegram-bot-api@0.56.0
                            npm ERR! missing: bl@1.2.3, required by node-telegram-bot-api@0.56.0
                            npm ERR! missing: debug@3.2.7, required by node-telegram-bot-api@0.56.0
                            npm ERR! missing: mime@1.6.0, required by node-telegram-bot-api@0.56.0
                            npm ERR! missing: pump@2.0.1, required by node-telegram-bot-api@0.56.0
                            npm ERR! missing: request@2.88.2, required by node-telegram-bot-api@0.56.0
                            npm ERR! missing: request-promise@4.2.6, required by node-telegram-bot-api@0.56.0
                            npm ERR! missing: define-properties@1.1.3, required by array.prototype.findindex@2.1.0
                            npm ERR! missing: es-abstract@1.19.1, required by array.prototype.findindex@2.1.0
                            npm ERR! missing: object-keys@1.1.1, required by define-properties@1.1.3
                            npm ERR! missing: call-bind@1.0.2, required by es-abstract@1.19.1
                            npm ERR! missing: es-to-primitive@1.2.1, required by es-abstract@1.19.1
                            npm ERR! missing: function-bind@1.1.1, required by es-abstract@1.19.1
                            npm ERR! missing: get-intrinsic@1.1.1, required by es-abstract@1.19.1
                            npm ERR! missing: get-symbol-description@1.0.0, required by es-abstract@1.19.1
                            npm ERR! missing: has@1.0.3, required by es-abstract@1.19.1
                            npm ERR! missing: has-symbols@1.0.2, required by es-abstract@1.19.1
                            npm ERR! missing: internal-slot@1.0.3, required by es-abstract@1.19.1
                            npm ERR! missing: is-callable@1.2.4, required by es-abstract@1.19.1
                            npm ERR! missing: is-negative-zero@2.0.2, required by es-abstract@1.19.1
                            npm ERR! missing: is-regex@1.1.4, required by es-abstract@1.19.1
                            npm ERR! missing: is-shared-array-buffer@1.0.1, required by es-abstract@1.19.1
                            npm ERR! missing: is-string@1.0.7, required by es-abstract@1.19.1
                            npm ERR! missing: is-weakref@1.0.2, required by es-abstract@1.19.1
                            npm ERR! missing: object-inspect@1.12.0, required by es-abstract@1.19.1
                            npm ERR! missing: object-keys@1.1.1, required by es-abstract@1.19.1
                            npm ERR! missing: object.assign@4.1.2, required by es-abstract@1.19.1
                            npm ERR! missing: string.prototype.trimend@1.0.4, required by es-abstract@1.19.1
                            npm ERR! missing: string.prototype.trimstart@1.0.4, required by es-abstract@1.19.1
                            npm ERR! missing: unbox-primitive@1.0.1, required by es-abstract@1.19.1
                            npm ERR! missing: is-callable@1.2.4, required by es-to-primitive@1.2.1
                            npm ERR! missing: is-date-object@1.0.5, required by es-to-primitive@1.2.1
                            npm ERR! missing: is-symbol@1.0.4, required by es-to-primitive@1.2.1
                            npm ERR! missing: has-tostringtag@1.0.0, required by is-date-object@1.0.5
                            npm ERR! missing: has-symbols@1.0.2, required by is-symbol@1.0.4
                            npm ERR! missing: call-bind@1.0.2, required by get-symbol-description@1.0.0
                            npm ERR! missing: get-intrinsic@1.1.1, required by get-symbol-description@1.0.0
                            npm ERR! missing: get-intrinsic@1.1.1, required by internal-slot@1.0.3
                            npm ERR! missing: has@1.0.3, required by internal-slot@1.0.3
                            npm ERR! missing: side-channel@1.0.4, required by internal-slot@1.0.3
                            npm ERR! missing: call-bind@1.0.2, required by is-regex@1.1.4
                            npm ERR! missing: has-tostringtag@1.0.0, required by is-regex@1.1.4
                            npm ERR! missing: has-symbols@1.0.2, required by has-tostringtag@1.0.0
                            npm ERR! missing: has-tostringtag@1.0.0, required by is-string@1.0.7
                            npm ERR! missing: call-bind@1.0.2, required by is-weakref@1.0.2
                            npm ERR! missing: call-bind@1.0.2, required by string.prototype.trimend@1.0.4
                            npm ERR! missing: define-properties@1.1.3, required by string.prototype.trimend@1.0.4
                            npm ERR! missing: call-bind@1.0.2, required by string.prototype.trimstart@1.0.4
                            npm ERR! missing: define-properties@1.1.3, required by string.prototype.trimstart@1.0.4
                            npm ERR! missing: function-bind@1.1.1, required by unbox-primitive@1.0.1
                            npm ERR! missing: has-bigints@1.0.1, required by unbox-primitive@1.0.1
                            npm ERR! missing: has-symbols@1.0.2, required by unbox-primitive@1.0.1
                            npm ERR! missing: which-boxed-primitive@1.0.2, required by unbox-primitive@1.0.1
                            npm ERR! missing: is-bigint@1.0.4, required by which-boxed-primitive@1.0.2
                            npm ERR! missing: is-boolean-object@1.1.2, required by which-boxed-primitive@1.0.2
                            npm ERR! missing: is-number-object@1.0.6, required by which-boxed-primitive@1.0.2
                            npm ERR! missing: is-string@1.0.7, required by which-boxed-primitive@1.0.2
                            npm ERR! missing: is-symbol@1.0.4, required by which-boxed-primitive@1.0.2
                            npm ERR! missing: has-bigints@1.0.1, required by is-bigint@1.0.4
                            npm ERR! missing: call-bind@1.0.2, required by is-boolean-object@1.1.2
                            npm ERR! missing: has-tostringtag@1.0.0, required by is-boolean-object@1.1.2
                            npm ERR! missing: has-tostringtag@1.0.0, required by is-number-object@1.0.6
                            npm ERR! missing: readable-stream@2.3.7, required by bl@1.2.3
                            npm ERR! missing: safe-buffer@5.1.2, required by bl@1.2.3
                            npm ERR! missing: ms@2.1.3, required by debug@3.2.7
                            npm ERR! missing: end-of-stream@1.4.4, required by pump@2.0.1
                            npm ERR! missing: once@1.4.0, required by pump@2.0.1
                            npm ERR! missing: bluebird@3.7.2, required by request-promise@4.2.6
                            npm ERR! missing: request-promise-core@1.1.4, required by request-promise@4.2.6
                            npm ERR! missing: stealthy-require@1.1.1, required by request-promise@4.2.6
                            npm ERR! missing: tough-cookie@2.5.0, required by request-promise@4.2.6
                            npm ERR! missing: cli@0.4.x, required by ipv6@3.1.1
                            npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.tr-064@4.2.15
                            npm ERR! missing: mdns-discovery@0.2.6, required by iobroker.tr-064@4.2.15
                            npm ERR! missing: tr-O64@0.2.4, required by iobroker.tr-064@4.2.15
                            npm ERR! missing: xml2js@0.4.23, required by iobroker.tr-064@4.2.15
                            npm ERR! missing: eyes@0.1.8, required by tr-O64@0.2.4
                            npm ERR! missing: request@2.88.2, required by tr-O64@0.2.4
                            npm ERR! missing: async@3.2.3, required by tr-O64@0.2.4
                            npm ERR! missing: xml2js@0.4.23, required by tr-O64@0.2.4
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.trashschedule@1.4.1
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.vis@1.4.5
                            npm ERR! missing: jsonwebtoken@8.5.1, required by iobroker.vis@1.4.5
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.vis-icontwo@0.87.0
                            npm ERR! missing: minimist@1.2.5, required by iobroker.vis-icontwo@0.87.0
                            npm ERR! missing: np@7.6.0, required by iobroker.vis-icontwo@0.87.0
                            npm ERR! missing: @samverschueren/stream-to-observable@0.3.1, required by np@7.6.0
                            npm ERR! missing: any-observable@0.5.1, required by np@7.6.0
                            npm ERR! missing: async-exit-hook@2.0.1, required by np@7.6.0
                            npm ERR! missing: chalk@4.1.2, required by np@7.6.0
                            npm ERR! missing: cosmiconfig@7.0.1, required by np@7.6.0
                            npm ERR! missing: del@6.0.0, required by np@7.6.0
                            npm ERR! missing: escape-goat@3.0.0, required by np@7.6.0
                            npm ERR! missing: escape-string-regexp@4.0.0, required by np@7.6.0
                            npm ERR! missing: execa@5.1.1, required by np@7.6.0
                            npm ERR! missing: github-url-from-git@1.5.0, required by np@7.6.0
                            npm ERR! missing: has-yarn@2.1.0, required by np@7.6.0
                            npm ERR! missing: hosted-git-info@3.0.8, required by np@7.6.0
                            npm ERR! missing: ignore-walk@3.0.4, required by np@7.6.0
                            npm ERR! missing: import-local@3.1.0, required by np@7.6.0
                            npm ERR! missing: inquirer@7.3.3, required by np@7.6.0
                            npm ERR! missing: is-installed-globally@0.3.2, required by np@7.6.0
                            npm ERR! missing: is-interactive@1.0.0, required by np@7.6.0
                            npm ERR! missing: is-scoped@2.1.0, required by np@7.6.0
                            npm ERR! missing: issue-regex@3.1.0, required by np@7.6.0
                            npm ERR! missing: listr@0.14.3, required by np@7.6.0
                            npm ERR! missing: listr-input@0.2.1, required by np@7.6.0
                            npm ERR! missing: log-symbols@4.1.0, required by np@7.6.0
                            npm ERR! missing: meow@8.1.2, required by np@7.6.0
                            npm ERR! missing: minimatch@3.1.2, required by np@7.6.0
                            npm ERR! missing: new-github-release-url@1.0.0, required by np@7.6.0
                            npm ERR! missing: npm-name@6.0.1, required by np@7.6.0
                            npm ERR! missing: onetime@5.1.2, required by np@7.6.0
                            npm ERR! missing: open@7.4.2, required by np@7.6.0
                            npm ERR! missing: ow@0.21.0, required by np@7.6.0
                            npm ERR! missing: p-memoize@4.0.4, required by np@7.6.0
                            npm ERR! missing: p-timeout@4.1.0, required by np@7.6.0
                            npm ERR! missing: pkg-dir@5.0.0, required by np@7.6.0
                            npm ERR! missing: read-pkg-up@7.0.1, required by np@7.6.0
                            npm ERR! missing: rxjs@6.6.7, required by np@7.6.0
                            npm ERR! missing: semver@7.3.5, required by np@7.6.0
                            npm ERR! missing: split@1.0.1, required by np@7.6.0
                            npm ERR! missing: symbol-observable@3.0.0, required by np@7.6.0
                            npm ERR! missing: terminal-link@2.1.1, required by np@7.6.0
                            npm ERR! missing: update-notifier@5.1.0, required by np@7.6.0
                            npm ERR! missing: any-observable@0.3.0, required by @samverschueren/stream-to-observable@0.3.1
                            npm ERR! missing: ansi-styles@4.3.0, required by chalk@4.1.2
                            npm ERR! missing: supports-color@7.2.0, required by chalk@4.1.2
                            npm ERR! missing: color-convert@2.0.1, required by ansi-styles@4.3.0
                            npm ERR! missing: color-name@1.1.4, required by color-convert@2.0.1
                            npm ERR! missing: has-flag@4.0.0, required by supports-color@7.2.0
                            npm ERR! missing: @types/parse-json@4.0.0, required by cosmiconfig@7.0.1
                            npm ERR! missing: import-fresh@3.3.0, required by cosmiconfig@7.0.1
                            npm ERR! missing: parse-json@5.2.0, required by cosmiconfig@7.0.1
                            npm ERR! missing: path-type@4.0.0, required by cosmiconfig@7.0.1
                            npm ERR! missing: yaml@1.10.2, required by cosmiconfig@7.0.1
                            npm ERR! missing: parent-module@1.0.1, required by import-fresh@3.3.0
                            npm ERR! missing: resolve-from@4.0.0, required by import-fresh@3.3.0
                            npm ERR! missing: callsites@3.1.0, required by parent-module@1.0.1
                            npm ERR! missing: @babel/code-frame@7.16.7, required by parse-json@5.2.0
                            npm ERR! missing: error-ex@1.3.2, required by parse-json@5.2.0
                            npm ERR! missing: json-parse-even-better-errors@2.3.1, required by parse-json@5.2.0
                            npm ERR! missing: lines-and-columns@1.2.4, required by parse-json@5.2.0
                            npm ERR! missing: @babel/highlight@7.16.10, required by @babel/code-frame@7.16.7
                            npm ERR! missing: @babel/helper-validator-identifier@7.16.7, required by @babel/highlight@7.16.10
                            npm ERR! missing: chalk@2.4.2, required by @babel/highlight@7.16.10
                            npm ERR! missing: js-tokens@4.0.0, required by @babel/highlight@7.16.10
                            npm ERR! missing: ansi-styles@3.2.1, required by chalk@2.4.2
                            npm ERR! missing: escape-string-regexp@1.0.5, required by chalk@2.4.2
                            npm ERR! missing: supports-color@5.5.0, required by chalk@2.4.2
                            npm ERR! missing: color-convert@1.9.3, required by ansi-styles@3.2.1
                            npm ERR! missing: has-flag@3.0.0, required by supports-color@5.5.0
                            npm ERR! missing: is-arrayish@0.2.1, required by error-ex@1.3.2
                            npm ERR! missing: p-map@4.0.0, required by del@6.0.0
                            npm ERR! missing: globby@11.1.0, required by del@6.0.0
                            npm ERR! missing: graceful-fs@4.2.9, required by del@6.0.0
                            npm ERR! missing: is-glob@4.0.3, required by del@6.0.0
                            npm ERR! missing: is-path-cwd@2.2.0, required by del@6.0.0
                            npm ERR! missing: is-path-inside@3.0.3, required by del@6.0.0
                            npm ERR! missing: rimraf@3.0.2, required by del@6.0.0
                            npm ERR! missing: slash@3.0.0, required by del@6.0.0
                            npm ERR! missing: aggregate-error@3.1.0, required by p-map@4.0.0
                            npm ERR! missing: indent-string@4.0.0, required by aggregate-error@3.1.0
                            npm ERR! missing: clean-stack@2.2.0, required by aggregate-error@3.1.0
                            npm ERR! missing: array-union@2.1.0, required by globby@11.1.0
                            npm ERR! missing: dir-glob@3.0.1, required by globby@11.1.0
                            npm ERR! missing: fast-glob@3.2.11, required by globby@11.1.0
                            npm ERR! missing: ignore@5.2.0, required by globby@11.1.0
                            npm ERR! missing: merge2@1.4.1, required by globby@11.1.0
                            npm ERR! missing: slash@3.0.0, required by globby@11.1.0
                            npm ERR! missing: path-type@4.0.0, required by dir-glob@3.0.1
                            npm ERR! missing: @nodelib/fs.stat@2.0.5, required by fast-glob@3.2.11
                            npm ERR! missing: @nodelib/fs.walk@1.2.8, required by fast-glob@3.2.11
                            npm ERR! missing: glob-parent@5.1.2, required by fast-glob@3.2.11
                            npm ERR! missing: merge2@1.4.1, required by fast-glob@3.2.11
                            npm ERR! missing: micromatch@4.0.4, required by fast-glob@3.2.11
                            npm ERR! missing: @nodelib/fs.scandir@2.1.5, required by @nodelib/fs.walk@1.2.8
                            npm ERR! missing: fastq@1.13.0, required by @nodelib/fs.walk@1.2.8
                            npm ERR! missing: @nodelib/fs.stat@2.0.5, required by @nodelib/fs.scandir@2.1.5
                            npm ERR! missing: run-parallel@1.2.0, required by @nodelib/fs.scandir@2.1.5
                            npm ERR! missing: queue-microtask@1.2.3, required by run-parallel@1.2.0
                            npm ERR! missing: reusify@1.0.4, required by fastq@1.13.0
                            npm ERR! missing: braces@3.0.2, required by micromatch@4.0.4
                            npm ERR! missing: picomatch@2.3.1, required by micromatch@4.0.4
                            npm ERR! missing: cross-spawn@7.0.3, required by execa@5.1.1
                            npm ERR! missing: get-stream@6.0.1, required by execa@5.1.1
                            npm ERR! missing: human-signals@2.1.0, required by execa@5.1.1
                            npm ERR! missing: is-stream@2.0.1, required by execa@5.1.1
                            npm ERR! missing: merge-stream@2.0.0, required by execa@5.1.1
                            npm ERR! missing: npm-run-path@4.0.1, required by execa@5.1.1
                            npm ERR! missing: onetime@5.1.2, required by execa@5.1.1
                            npm ERR! missing: signal-exit@3.0.7, required by execa@5.1.1
                            npm ERR! missing: strip-final-newline@2.0.0, required by execa@5.1.1
                            npm ERR! missing: path-key@3.1.1, required by cross-spawn@7.0.3
                            npm ERR! missing: shebang-command@2.0.0, required by cross-spawn@7.0.3
                            npm ERR! missing: which@2.0.2, required by cross-spawn@7.0.3
                            npm ERR! missing: shebang-regex@3.0.0, required by shebang-command@2.0.0
                            npm ERR! missing: isexe@2.0.0, required by which@2.0.2
                            npm ERR! missing: path-key@3.1.1, required by npm-run-path@4.0.1
                            npm ERR! missing: lru-cache@6.0.0, required by hosted-git-info@3.0.8
                            npm ERR! missing: minimatch@3.1.2, required by ignore-walk@3.0.4
                            npm ERR! missing: pkg-dir@4.2.0, required by import-local@3.1.0
                            npm ERR! missing: resolve-cwd@3.0.0, required by import-local@3.1.0
                            npm ERR! missing: find-up@4.1.0, required by pkg-dir@4.2.0
                            npm ERR! missing: locate-path@5.0.0, required by find-up@4.1.0
                            npm ERR! missing: path-exists@4.0.0, required by find-up@4.1.0
                            npm ERR! missing: p-locate@4.1.0, required by locate-path@5.0.0
                            npm ERR! missing: p-limit@2.3.0, required by p-locate@4.1.0
                            npm ERR! missing: resolve-from@5.0.0, required by resolve-cwd@3.0.0
                            npm ERR! missing: ansi-escapes@4.3.2, required by inquirer@7.3.3
                            npm ERR! missing: chalk@4.1.2, required by inquirer@7.3.3
                            npm ERR! missing: cli-cursor@3.1.0, required by inquirer@7.3.3
                            npm ERR! missing: cli-width@3.0.0, required by inquirer@7.3.3
                            npm ERR! missing: external-editor@3.1.0, required by inquirer@7.3.3
                            npm ERR! missing: figures@3.2.0, required by inquirer@7.3.3
                            npm ERR! missing: lodash@4.17.21, required by inquirer@7.3.3
                            npm ERR! missing: mute-stream@0.0.8, required by inquirer@7.3.3
                            npm ERR! missing: run-async@2.4.1, required by inquirer@7.3.3
                            npm ERR! missing: rxjs@6.6.7, required by inquirer@7.3.3
                            npm ERR! missing: string-width@4.2.3, required by inquirer@7.3.3
                            npm ERR! missing: strip-ansi@6.0.1, required by inquirer@7.3.3
                            npm ERR! missing: through@2.3.8, required by inquirer@7.3.3
                            npm ERR! missing: type-fest@0.21.3, required by ansi-escapes@4.3.2
                            npm ERR! missing: restore-cursor@3.1.0, required by cli-cursor@3.1.0
                            npm ERR! missing: onetime@5.1.2, required by restore-cursor@3.1.0
                            npm ERR! missing: signal-exit@3.0.7, required by restore-cursor@3.1.0
                            npm ERR! missing: chardet@0.7.0, required by external-editor@3.1.0
                            npm ERR! missing: iconv-lite@0.4.24, required by external-editor@3.1.0
                            npm ERR! missing: tmp@0.0.33, required by external-editor@3.1.0
                            npm ERR! missing: os-tmpdir@1.0.2, required by tmp@0.0.33
                            npm ERR! missing: escape-string-regexp@1.0.5, required by figures@3.2.0
                            npm ERR! missing: global-dirs@2.1.0, required by is-installed-globally@0.3.2
                            npm ERR! missing: is-path-inside@3.0.3, required by is-installed-globally@0.3.2
                            npm ERR! missing: ini@1.3.7, required by global-dirs@2.1.0
                            npm ERR! missing: scoped-regex@2.1.0, required by is-scoped@2.1.0
                            npm ERR! missing: @samverschueren/stream-to-observable@0.3.1, required by listr@0.14.3
                            npm ERR! missing: is-observable@1.1.0, required by listr@0.14.3
                            npm ERR! missing: is-promise@2.2.2, required by listr@0.14.3
                            npm ERR! missing: listr-silent-renderer@1.1.1, required by listr@0.14.3
                            npm ERR! missing: listr-update-renderer@0.5.0, required by listr@0.14.3
                            npm ERR! missing: listr-verbose-renderer@0.5.0, required by listr@0.14.3
                            npm ERR! missing: is-stream@1.1.0, required by listr@0.14.3
                            npm ERR! missing: p-map@2.1.0, required by listr@0.14.3
                            npm ERR! missing: rxjs@6.6.7, required by listr@0.14.3
                            npm ERR! missing: symbol-observable@1.2.0, required by is-observable@1.1.0
                            npm ERR! missing: cli-truncate@0.2.1, required by listr-update-renderer@0.5.0
                            npm ERR! missing: elegant-spinner@1.0.1, required by listr-update-renderer@0.5.0
                            npm ERR! missing: indent-string@3.2.0, required by listr-update-renderer@0.5.0
                            npm ERR! missing: chalk@1.1.3, required by listr-update-renderer@0.5.0
                            npm ERR! missing: figures@1.7.0, required by listr-update-renderer@0.5.0
                            npm ERR! missing: log-symbols@1.0.2, required by listr-update-renderer@0.5.0
                            npm ERR! missing: strip-ansi@3.0.1, required by listr-update-renderer@0.5.0
                            npm ERR! missing: log-update@2.3.0, required by listr-update-renderer@0.5.0
                            npm ERR! missing: string-width@1.0.2, required by cli-truncate@0.2.1
                            npm ERR! missing: slice-ansi@0.0.4, required by cli-truncate@0.2.1
                            npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2
                            npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2
                            npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2
                            npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0
                            npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1
                            npm ERR! missing: has-ansi@2.0.0, required by chalk@1.1.3
                            npm ERR! missing: ansi-styles@2.2.1, required by chalk@1.1.3
                            npm ERR! missing: escape-string-regexp@1.0.5, required by chalk@1.1.3
                            npm ERR! missing: strip-ansi@3.0.1, required by chalk@1.1.3
                            npm ERR! missing: supports-color@2.0.0, required by chalk@1.1.3
                            npm ERR! missing: ansi-regex@2.1.1, required by has-ansi@2.0.0
                            npm ERR! missing: escape-string-regexp@1.0.5, required by figures@1.7.0
                            npm ERR! missing: object-assign@4.1.1, required by figures@1.7.0
                            npm ERR! missing: chalk@1.1.3, required by log-symbols@1.0.2
                            npm ERR! missing: ansi-escapes@3.2.0, required by log-update@2.3.0
                            npm ERR! missing: cli-cursor@2.1.0, required by log-update@2.3.0
                            npm ERR! missing: wrap-ansi@3.0.1, required by log-update@2.3.0
                            npm ERR! missing: restore-cursor@2.0.0, required by cli-cursor@2.1.0
                            npm ERR! missing: onetime@2.0.1, required by restore-cursor@2.0.0
                            npm ERR! missing: signal-exit@3.0.7, required by restore-cursor@2.0.0
                            npm ERR! missing: mimic-fn@1.2.0, required by onetime@2.0.1
                            npm ERR! missing: string-width@2.1.1, required by wrap-ansi@3.0.1
                            npm ERR! missing: strip-ansi@4.0.0, required by wrap-ansi@3.0.1
                            npm ERR! missing: is-fullwidth-code-point@2.0.0, required by string-width@2.1.1
                            npm ERR! missing: strip-ansi@4.0.0, required by string-width@2.1.1
                            npm ERR! missing: ansi-regex@3.0.0, required by strip-ansi@4.0.0
                            npm ERR! missing: date-fns@1.30.1, required by listr-verbose-renderer@0.5.0
                            npm ERR! missing: chalk@2.4.2, required by listr-verbose-renderer@0.5.0
                            npm ERR! missing: cli-cursor@2.1.0, required by listr-verbose-renderer@0.5.0
                            npm ERR! missing: figures@2.0.0, required by listr-verbose-renderer@0.5.0
                            npm ERR! missing: escape-string-regexp@1.0.5, required by figures@2.0.0
                            npm ERR! missing: inquirer@7.3.3, required by listr-input@0.2.1
                            npm ERR! missing: inquirer-autosubmit-prompt@0.2.0, required by listr-input@0.2.1
                            npm ERR! missing: rxjs@6.6.7, required by listr-input@0.2.1
                            npm ERR! missing: through@2.3.8, required by listr-input@0.2.1
                            npm ERR! missing: chalk@2.4.2, required by inquirer-autosubmit-prompt@0.2.0
                            npm ERR! missing: inquirer@6.5.2, required by inquirer-autosubmit-prompt@0.2.0
                            npm ERR! missing: rxjs@6.6.7, required by inquirer-autosubmit-prompt@0.2.0
                            npm ERR! missing: external-editor@3.1.0, required by inquirer@6.5.2
                            npm ERR! missing: ansi-escapes@3.2.0, required by inquirer@6.5.2
                            npm ERR! missing: chalk@2.4.2, required by inquirer@6.5.2
                            npm ERR! missing: cli-cursor@2.1.0, required by inquirer@6.5.2
                            npm ERR! missing: cli-width@2.2.1, required by inquirer@6.5.2
                            npm ERR! missing: figures@2.0.0, required by inquirer@6.5.2
                            npm ERR! missing: mute-stream@0.0.7, required by inquirer@6.5.2
                            npm ERR! missing: string-width@2.1.1, required by inquirer@6.5.2
                            npm ERR! missing: strip-ansi@5.2.0, required by inquirer@6.5.2
                            npm ERR! missing: lodash@4.17.21, required by inquirer@6.5.2
                            npm ERR! missing: run-async@2.4.1, required by inquirer@6.5.2
                            npm ERR! missing: rxjs@6.6.7, required by inquirer@6.5.2
                            npm ERR! missing: through@2.3.8, required by inquirer@6.5.2
                            npm ERR! missing: ansi-regex@4.1.0, required by strip-ansi@5.2.0
                            npm ERR! missing: chalk@4.1.2, required by log-symbols@4.1.0
                            npm ERR! missing: is-unicode-supported@0.1.0, required by log-symbols@4.1.0
                            npm ERR! missing: @types/minimist@1.2.2, required by meow@8.1.2
                            npm ERR! missing: camelcase-keys@6.2.2, required by meow@8.1.2
                            npm ERR! missing: decamelize-keys@1.1.0, required by meow@8.1.2
                            npm ERR! missing: hard-rejection@2.1.0, required by meow@8.1.2
                            npm ERR! missing: type-fest@0.18.1, required by meow@8.1.2
                            npm ERR! missing: yargs-parser@20.2.9, required by meow@8.1.2
                            npm ERR! missing: minimist-options@4.1.0, required by meow@8.1.2
                            npm ERR! missing: normalize-package-data@3.0.3, required by meow@8.1.2
                            npm ERR! missing: read-pkg-up@7.0.1, required by meow@8.1.2
                            npm ERR! missing: redent@3.0.0, required by meow@8.1.2
                            npm ERR! missing: trim-newlines@3.0.1, required by meow@8.1.2
                            npm ERR! missing: camelcase@5.3.1, required by camelcase-keys@6.2.2
                            npm ERR! missing: map-obj@4.3.0, required by camelcase-keys@6.2.2
                            npm ERR! missing: quick-lru@4.0.1, required by camelcase-keys@6.2.2
                            npm ERR! missing: decamelize@1.2.0, required by decamelize-keys@1.1.0
                            npm ERR! missing: map-obj@1.0.1, required by decamelize-keys@1.1.0
                            npm ERR! missing: is-plain-obj@1.1.0, required by minimist-options@4.1.0
                            npm ERR! missing: kind-of@6.0.3, required by minimist-options@4.1.0
                            npm ERR! missing: arrify@1.0.1, required by minimist-options@4.1.0
                            npm ERR! missing: is-core-module@2.8.1, required by normalize-package-data@3.0.3
                            npm ERR! missing: hosted-git-info@4.1.0, required by normalize-package-data@3.0.3
                            npm ERR! missing: semver@7.3.5, required by normalize-package-data@3.0.3
                            npm ERR! missing: validate-npm-package-license@3.0.4, required by normalize-package-data@3.0.3
                            npm ERR! missing: lru-cache@6.0.0, required by hosted-git-info@4.1.0
                            npm ERR! missing: spdx-correct@3.1.1, required by validate-npm-package-license@3.0.4
                            npm ERR! missing: spdx-expression-parse@3.0.1, required by validate-npm-package-license@3.0.4
                            npm ERR! missing: spdx-expression-parse@3.0.1, required by spdx-correct@3.1.1
                            npm ERR! missing: spdx-license-ids@3.0.11, required by spdx-correct@3.1.1
                            npm ERR! missing: spdx-exceptions@2.3.0, required by spdx-expression-parse@3.0.1
                            npm ERR! missing: spdx-license-ids@3.0.11, required by spdx-expression-parse@3.0.1
                            npm ERR! missing: indent-string@4.0.0, required by redent@3.0.0
                            npm ERR! missing: strip-indent@3.0.0, required by redent@3.0.0
                            npm ERR! missing: min-indent@1.0.1, required by strip-indent@3.0.0
                            npm ERR! missing: type-fest@0.4.1, required by new-github-release-url@1.0.0
                            npm ERR! missing: got@10.7.0, required by npm-name@6.0.1
                            npm ERR! missing: is-scoped@2.1.0, required by npm-name@6.0.1
                            npm ERR! missing: is-url-superb@4.0.0, required by npm-name@6.0.1
                            npm ERR! missing: lodash.zip@4.2.0, required by npm-name@6.0.1
                            npm ERR! missing: p-map@3.0.0, required by npm-name@6.0.1
                            npm ERR! missing: org-regex@1.0.0, required by npm-name@6.0.1
                            npm ERR! missing: registry-auth-token@4.2.1, required by npm-name@6.0.1
                            npm ERR! missing: registry-url@5.1.0, required by npm-name@6.0.1
                            npm ERR! missing: validate-npm-package-name@3.0.0, required by npm-name@6.0.1
                            npm ERR! missing: @sindresorhus/is@2.1.1, required by got@10.7.0
                            npm ERR! missing: @szmarczak/http-timer@4.0.6, required by got@10.7.0
                            npm ERR! missing: @types/cacheable-request@6.0.2, required by got@10.7.0
                            npm ERR! missing: cacheable-lookup@2.0.1, required by got@10.7.0
                            npm ERR! missing: cacheable-request@7.0.2, required by got@10.7.0
                            npm ERR! missing: decompress-response@5.0.0, required by got@10.7.0
                            npm ERR! missing: duplexer3@0.1.4, required by got@10.7.0
                            npm ERR! missing: get-stream@5.2.0, required by got@10.7.0
                            npm ERR! missing: type-fest@0.10.0, required by got@10.7.0
                            npm ERR! missing: lowercase-keys@2.0.0, required by got@10.7.0
                            npm ERR! missing: mimic-response@2.1.0, required by got@10.7.0
                            npm ERR! missing: p-cancelable@2.1.1, required by got@10.7.0
                            npm ERR! missing: p-event@4.2.0, required by got@10.7.0
                            npm ERR! missing: responselike@2.0.0, required by got@10.7.0
                            npm ERR! missing: to-readable-stream@2.1.0, required by got@10.7.0
                            npm ERR! missing: @types/keyv@3.1.3, required by cacheable-lookup@2.0.1
                            npm ERR! missing: keyv@4.1.1, required by cacheable-lookup@2.0.1
                            npm ERR! missing: mimic-response@2.1.0, required by decompress-response@5.0.0
                            npm ERR! missing: pump@3.0.0, required by get-stream@5.2.0
                            npm ERR! missing: p-timeout@3.2.0, required by p-event@4.2.0
                            npm ERR! missing: p-finally@1.0.0, required by p-timeout@3.2.0
                            npm ERR! missing: aggregate-error@3.1.0, required by p-map@3.0.0
                            npm ERR! missing: rc@1.2.8, required by registry-auth-token@4.2.1
                            npm ERR! missing: rc@1.2.8, required by registry-url@5.1.0
                            npm ERR! missing: builtins@1.0.3, required by validate-npm-package-name@3.0.0
                            npm ERR! missing: mimic-fn@2.1.0, required by onetime@5.1.2
                            npm ERR! missing: is-docker@2.2.1, required by open@7.4.2
                            npm ERR! missing: is-wsl@2.2.0, required by open@7.4.2
                            npm ERR! missing: is-docker@2.2.1, required by is-wsl@2.2.0
                            npm ERR! missing: callsites@3.1.0, required by ow@0.21.0
                            npm ERR! missing: dot-prop@6.0.1, required by ow@0.21.0
                            npm ERR! missing: lodash.isequal@4.5.0, required by ow@0.21.0
                            npm ERR! missing: @sindresorhus/is@4.6.0, required by ow@0.21.0
                            npm ERR! missing: type-fest@0.20.2, required by ow@0.21.0
                            npm ERR! missing: vali-date@1.0.0, required by ow@0.21.0
                            npm ERR! missing: is-obj@2.0.0, required by dot-prop@6.0.1
                            npm ERR! missing: map-age-cleaner@0.1.3, required by p-memoize@4.0.4
                            npm ERR! missing: mimic-fn@3.1.0, required by p-memoize@4.0.4
                            npm ERR! missing: p-settle@4.1.1, required by p-memoize@4.0.4
                            npm ERR! missing: p-defer@1.0.0, required by map-age-cleaner@0.1.3
                            npm ERR! missing: p-limit@2.3.0, required by p-settle@4.1.1
                            npm ERR! missing: p-reflect@2.1.0, required by p-settle@4.1.1
                            npm ERR! missing: p-try@2.2.0, required by p-limit@2.3.0
                            npm ERR! missing: find-up@5.0.0, required by pkg-dir@5.0.0
                            npm ERR! missing: locate-path@6.0.0, required by find-up@5.0.0
                            npm ERR! missing: path-exists@4.0.0, required by find-up@5.0.0
                            npm ERR! missing: p-locate@5.0.0, required by locate-path@6.0.0
                            npm ERR! missing: p-limit@3.1.0, required by p-locate@5.0.0
                            npm ERR! missing: yocto-queue@0.1.0, required by p-limit@3.1.0
                            npm ERR! missing: read-pkg@5.2.0, required by read-pkg-up@7.0.1
                            npm ERR! missing: find-up@4.1.0, required by read-pkg-up@7.0.1
                            npm ERR! missing: type-fest@0.8.1, required by read-pkg-up@7.0.1
                            npm ERR! missing: @types/normalize-package-data@2.4.1, required by read-pkg@5.2.0
                            npm ERR! missing: parse-json@5.2.0, required by read-pkg@5.2.0
                            npm ERR! missing: normalize-package-data@2.5.0, required by read-pkg@5.2.0
                            npm ERR! missing: type-fest@0.6.0, required by read-pkg@5.2.0
                            npm ERR! missing: hosted-git-info@2.8.9, required by normalize-package-data@2.5.0
                            npm ERR! missing: semver@5.7.1, required by normalize-package-data@2.5.0
                            npm ERR! missing: resolve@1.22.0, required by normalize-package-data@2.5.0
                            npm ERR! missing: validate-npm-package-license@3.0.4, required by normalize-package-data@2.5.0
                            npm ERR! missing: tslib@1.14.1, required by rxjs@6.6.7
                            npm ERR! missing: through@2.3.8, required by split@1.0.1
                            npm ERR! missing: ansi-escapes@4.3.2, required by terminal-link@2.1.1
                            npm ERR! missing: supports-hyperlinks@2.2.0, required by terminal-link@2.1.1
                            npm ERR! missing: has-flag@4.0.0, required by supports-hyperlinks@2.2.0
                            npm ERR! missing: supports-color@7.2.0, required by supports-hyperlinks@2.2.0
                            npm ERR! missing: boxen@5.1.2, required by update-notifier@5.1.0
                            npm ERR! missing: chalk@4.1.2, required by update-notifier@5.1.0
                            npm ERR! missing: configstore@5.0.1, required by update-notifier@5.1.0
                            npm ERR! missing: has-yarn@2.1.0, required by update-notifier@5.1.0
                            npm ERR! missing: import-lazy@2.1.0, required by update-notifier@5.1.0
                            npm ERR! missing: is-ci@2.0.0, required by update-notifier@5.1.0
                            npm ERR! missing: is-npm@5.0.0, required by update-notifier@5.1.0
                            npm ERR! missing: is-yarn-global@0.3.0, required by update-notifier@5.1.0
                            npm ERR! missing: latest-version@5.1.0, required by update-notifier@5.1.0
                            npm ERR! missing: pupa@2.1.1, required by update-notifier@5.1.0
                            npm ERR! missing: semver@7.3.5, required by update-notifier@5.1.0
                            npm ERR! missing: semver-diff@3.1.1, required by update-notifier@5.1.0
                            npm ERR! missing: is-installed-globally@0.4.0, required by update-notifier@5.1.0
                            npm ERR! missing: xdg-basedir@4.0.0, required by update-notifier@5.1.0
                            npm ERR! missing: ansi-align@3.0.1, required by boxen@5.1.2
                            npm ERR! missing: camelcase@6.3.0, required by boxen@5.1.2
                            npm ERR! missing: type-fest@0.20.2, required by boxen@5.1.2
                            npm ERR! missing: chalk@4.1.2, required by boxen@5.1.2
                            npm ERR! missing: cli-boxes@2.2.1, required by boxen@5.1.2
                            npm ERR! missing: string-width@4.2.3, required by boxen@5.1.2
                            npm ERR! missing: widest-line@3.1.0, required by boxen@5.1.2
                            npm ERR! missing: wrap-ansi@7.0.0, required by boxen@5.1.2
                            npm ERR! missing: string-width@4.2.3, required by ansi-align@3.0.1
                            npm ERR! missing: string-width@4.2.3, required by widest-line@3.1.0
                            npm ERR! missing: dot-prop@5.3.0, required by configstore@5.0.1
                            npm ERR! missing: graceful-fs@4.2.9, required by configstore@5.0.1
                            npm ERR! missing: make-dir@3.1.0, required by configstore@5.0.1
                            npm ERR! missing: unique-string@2.0.0, required by configstore@5.0.1
                            npm ERR! missing: write-file-atomic@3.0.3, required by configstore@5.0.1
                            npm ERR! missing: xdg-basedir@4.0.0, required by configstore@5.0.1
                            npm ERR! missing: is-obj@2.0.0, required by dot-prop@5.3.0
                            npm ERR! missing: crypto-random-string@2.0.0, required by unique-string@2.0.0
                            npm ERR! missing: imurmurhash@0.1.4, required by write-file-atomic@3.0.3
                            npm ERR! missing: is-typedarray@1.0.0, required by write-file-atomic@3.0.3
                            npm ERR! missing: signal-exit@3.0.7, required by write-file-atomic@3.0.3
                            npm ERR! missing: typedarray-to-buffer@3.1.5, required by write-file-atomic@3.0.3
                            npm ERR! missing: ci-info@2.0.0, required by is-ci@2.0.0
                            npm ERR! missing: package-json@6.5.0, required by latest-version@5.1.0
                            npm ERR! missing: got@9.6.0, required by package-json@6.5.0
                            npm ERR! missing: semver@6.3.0, required by package-json@6.5.0
                            npm ERR! missing: registry-auth-token@4.2.1, required by package-json@6.5.0
                            npm ERR! missing: registry-url@5.1.0, required by package-json@6.5.0
                            npm ERR! missing: duplexer3@0.1.4, required by got@9.6.0
                            npm ERR! missing: @sindresorhus/is@0.14.0, required by got@9.6.0
                            npm ERR! missing: @szmarczak/http-timer@1.1.2, required by got@9.6.0
                            npm ERR! missing: cacheable-request@6.1.0, required by got@9.6.0
                            npm ERR! missing: decompress-response@3.3.0, required by got@9.6.0
                            npm ERR! missing: get-stream@4.1.0, required by got@9.6.0
                            npm ERR! missing: lowercase-keys@1.0.1, required by got@9.6.0
                            npm ERR! missing: mimic-response@1.0.1, required by got@9.6.0
                            npm ERR! missing: p-cancelable@1.1.0, required by got@9.6.0
                            npm ERR! missing: to-readable-stream@1.0.0, required by got@9.6.0
                            npm ERR! missing: url-parse-lax@3.0.0, required by got@9.6.0
                            npm ERR! missing: defer-to-connect@1.1.3, required by @szmarczak/http-timer@1.1.2
                            npm ERR! missing: clone-response@1.0.2, required by cacheable-request@6.1.0
                            npm ERR! missing: http-cache-semantics@4.1.0, required by cacheable-request@6.1.0
                            npm ERR! missing: lowercase-keys@2.0.0, required by cacheable-request@6.1.0
                            npm ERR! missing: get-stream@5.2.0, required by cacheable-request@6.1.0
                            npm ERR! missing: keyv@3.1.0, required by cacheable-request@6.1.0
                            npm ERR! missing: normalize-url@4.5.1, required by cacheable-request@6.1.0
                            npm ERR! missing: responselike@1.0.2, required by cacheable-request@6.1.0
                            npm ERR! missing: json-buffer@3.0.0, required by keyv@3.1.0
                            npm ERR! missing: lowercase-keys@1.0.1, required by responselike@1.0.2
                            npm ERR! missing: mimic-response@1.0.1, required by decompress-response@3.3.0
                            npm ERR! missing: pump@3.0.0, required by get-stream@4.1.0
                            npm ERR! missing: prepend-http@2.0.0, required by url-parse-lax@3.0.0
                            npm ERR! missing: escape-goat@2.1.1, required by pupa@2.1.1
                            npm ERR! missing: semver@6.3.0, required by semver-diff@3.1.1
                            npm ERR! missing: is-path-inside@3.0.3, required by is-installed-globally@0.4.0
                            npm ERR! missing: global-dirs@3.0.0, required by is-installed-globally@0.4.0
                            npm ERR! missing: ini@2.0.0, required by global-dirs@3.0.0
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.vis-inventwo@3.3.1
                            npm ERR! missing: minimist@1.2.5, required by iobroker.vis-inventwo@3.3.1
                            npm ERR! missing: np@7.6.0, required by iobroker.vis-inventwo@3.3.1
                            npm ERR! missing: @iobroker/adapter-core@1.0.3, required by iobroker.vis-metro@1.2.0
                            npm ERR! missing: @types/iobroker@1.4.13, required by @iobroker/adapter-core@1.0.3
                            npm ERR! missing: @types/node@17.0.21, required by @types/iobroker@1.4.13
                            npm ERR! missing: @iobroker/adapter-core@1.0.3, required by iobroker.vis-players@0.1.6
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.web@4.2.0
                            npm ERR! missing: body-parser@1.19.2, required by iobroker.web@4.2.0
                            npm ERR! missing: compression@1.7.4, required by iobroker.web@4.2.0
                            npm ERR! missing: connect-flash@0.1.1, required by iobroker.web@4.2.0
                            npm ERR! missing: cookie-parser@1.4.6, required by iobroker.web@4.2.0
                            npm ERR! missing: express@4.17.3, required by iobroker.web@4.2.0
                            npm ERR! missing: express-session@1.17.2, required by iobroker.web@4.2.0
                            npm ERR! missing: iobroker.simple-api@2.6.3, required by iobroker.web@4.2.0
                            npm ERR! missing: iobroker.socketio@4.1.4, required by iobroker.web@4.2.0
                            npm ERR! missing: iobroker.ws@1.2.0, required by iobroker.web@4.2.0
                            npm ERR! missing: mime-types@2.1.34, required by iobroker.web@4.2.0
                            npm ERR! missing: passport@0.5.2, required by iobroker.web@4.2.0
                            npm ERR! missing: passport-local@1.0.0, required by iobroker.web@4.2.0
                            npm ERR! missing: xtend@4.0.2, required by iobroker.web@4.2.0
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.simple-api@2.6.3
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.ws@1.2.0
                            npm ERR! missing: cookie-parser@1.4.6, required by iobroker.ws@1.2.0
                            npm ERR! missing: express-session@1.17.2, required by iobroker.ws@1.2.0
                            npm ERR! missing: iobroker.ws.server@1.0.1, required by iobroker.ws@1.2.0
                            npm ERR! missing: axios@0.26.1, required by iobroker.ws@1.2.0
                            npm ERR! missing: passport@0.5.2, required by iobroker.ws@1.2.0
                            npm ERR! missing: ws@8.5.0, required by iobroker.ws.server@1.0.1
                            npm ERR! missing: mime-db@1.51.0, required by mime-types@2.1.34
                            npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.zigbee@1.6.16
                            npm ERR! missing: tar@6.1.11, required by iobroker.zigbee@1.6.16
                            npm ERR! missing: typescript@4.6.2, required by iobroker.zigbee@1.6.16
                            npm ERR! missing: zigbee-herdsman@0.14.16, required by iobroker.zigbee@1.6.16
                            npm ERR! missing: zigbee-herdsman-converters@14.0.422, required by iobroker.zigbee@1.6.16
                            npm ERR! missing: debounce@1.2.1, required by zigbee-herdsman@0.14.16
                            npm ERR! missing: debug@4.3.3, required by zigbee-herdsman@0.14.16
                            npm ERR! missing: fast-deep-equal@3.1.3, required by zigbee-herdsman@0.14.16
                            npm ERR! missing: mixin-deep@2.0.1, required by zigbee-herdsman@0.14.16
                            npm ERR! missing: mz@2.7.0, required by zigbee-herdsman@0.14.16
                            npm ERR! missing: serialport@9.2.8, required by zigbee-herdsman@0.14.16
                            npm ERR! missing: slip@1.0.2, required by zigbee-herdsman@0.14.16
                            npm ERR! missing: any-promise@1.3.0, required by mz@2.7.0
                            npm ERR! missing: object-assign@4.1.1, required by mz@2.7.0
                            npm ERR! missing: thenify-all@1.6.0, required by mz@2.7.0
                            npm ERR! missing: thenify@3.3.1, required by thenify-all@1.6.0
                            npm ERR! missing: any-promise@1.3.0, required by thenify@3.3.1
                            npm ERR! missing: @serialport/binding-mock@9.2.4, required by serialport@9.2.8
                            npm ERR! missing: @serialport/bindings@9.2.8, required by serialport@9.2.8
                            npm ERR! missing: @serialport/parser-byte-length@9.2.4, required by serialport@9.2.8
                            npm ERR! missing: @serialport/parser-cctalk@9.2.4, required by serialport@9.2.8
                            npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by serialport@9.2.8
                            npm ERR! missing: @serialport/parser-inter-byte-timeout@9.2.4, required by serialport@9.2.8
                            npm ERR! missing: @serialport/parser-readline@9.2.4, required by serialport@9.2.8
                            npm ERR! missing: @serialport/parser-ready@9.2.4, required by serialport@9.2.8
                            npm ERR! missing: @serialport/parser-regex@9.2.4, required by serialport@9.2.8
                            npm ERR! missing: @serialport/stream@9.2.4, required by serialport@9.2.8
                            npm ERR! missing: debug@4.3.3, required by serialport@9.2.8
                            npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/binding-mock@9.2.4
                            npm ERR! missing: debug@4.3.3, required by @serialport/binding-mock@9.2.4
                            npm ERR! missing: debug@4.3.3, required by @serialport/binding-abstract@9.2.3
                            npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/bindings@9.2.8
                            npm ERR! missing: @serialport/parser-readline@9.2.4, required by @serialport/bindings@9.2.8
                            npm ERR! missing: bindings@1.5.0, required by @serialport/bindings@9.2.8
                            npm ERR! missing: debug@4.3.3, required by @serialport/bindings@9.2.8
                            npm ERR! missing: nan@2.15.0, required by @serialport/bindings@9.2.8
                            npm ERR! missing: prebuild-install@7.0.1, required by @serialport/bindings@9.2.8
                            npm ERR! missing: file-uri-to-path@1.0.0, required by bindings@1.5.0
                            npm ERR! missing: detect-libc@2.0.0, required by prebuild-install@7.0.1
                            npm ERR! missing: expand-template@2.0.3, required by prebuild-install@7.0.1
                            npm ERR! missing: github-from-package@0.0.0, required by prebuild-install@7.0.1
                            npm ERR! missing: minimist@1.2.5, required by prebuild-install@7.0.1
                            npm ERR! missing: mkdirp-classic@0.5.3, required by prebuild-install@7.0.1
                            npm ERR! missing: napi-build-utils@1.0.2, required by prebuild-install@7.0.1
                            npm ERR! missing: node-abi@3.8.0, required by prebuild-install@7.0.1
                            npm ERR! missing: npmlog@4.1.2, required by prebuild-install@7.0.1
                            npm ERR! missing: pump@3.0.0, required by prebuild-install@7.0.1
                            npm ERR! missing: rc@1.2.8, required by prebuild-install@7.0.1
                            npm ERR! missing: simple-get@4.0.1, required by prebuild-install@7.0.1
                            npm ERR! missing: tar-fs@2.1.1, required by prebuild-install@7.0.1
                            npm ERR! missing: tunnel-agent@0.6.0, required by prebuild-install@7.0.1
                            npm ERR! missing: semver@7.3.5, required by node-abi@3.8.0
                            npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5
                            npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0
                            npm ERR! missing: are-we-there-yet@1.1.7, required by npmlog@4.1.2
                            npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2
                            npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2
                            npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2
                            npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.7
                            npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.7
                            npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4
                            npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4
                            npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4
                            npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4
                            npm ERR! missing: signal-exit@3.0.7, required by gauge@2.7.4
                            npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4
                            npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4
                            npm ERR! missing: wide-align@1.1.5, required by gauge@2.7.4
                            npm ERR! missing: string-width@1.0.2, required by wide-align@1.1.5
                            npm ERR! missing: end-of-stream@1.4.4, required by pump@3.0.0
                            npm ERR! missing: once@1.4.0, required by pump@3.0.0
                            npm ERR! missing: once@1.4.0, required by end-of-stream@1.4.4
                            npm ERR! missing: wrappy@1.0.2, required by once@1.4.0
                            npm ERR! missing: deep-extend@0.6.0, required by rc@1.2.8
                            npm ERR! missing: ini@1.3.8, required by rc@1.2.8
                            npm ERR! missing: minimist@1.2.5, required by rc@1.2.8
                            npm ERR! missing: strip-json-comments@2.0.1, required by rc@1.2.8
                            npm ERR! missing: decompress-response@6.0.0, required by simple-get@4.0.1
                            npm ERR! missing: once@1.4.0, required by simple-get@4.0.1
                            npm ERR! missing: simple-concat@1.0.1, required by simple-get@4.0.1
                            npm ERR! missing: mimic-response@3.1.0, required by decompress-response@6.0.0
                            npm ERR! missing: chownr@1.1.4, required by tar-fs@2.1.1
                            npm ERR! missing: mkdirp-classic@0.5.3, required by tar-fs@2.1.1
                            npm ERR! missing: pump@3.0.0, required by tar-fs@2.1.1
                            npm ERR! missing: tar-stream@2.2.0, required by tar-fs@2.1.1
                            npm ERR! missing: bl@4.1.0, required by tar-stream@2.2.0
                            npm ERR! missing: end-of-stream@1.4.4, required by tar-stream@2.2.0
                            npm ERR! missing: fs-constants@1.0.0, required by tar-stream@2.2.0
                            npm ERR! missing: inherits@2.0.4, required by tar-stream@2.2.0
                            npm ERR! missing: readable-stream@3.6.0, required by tar-stream@2.2.0
                            npm ERR! missing: readable-stream@3.6.0, required by bl@4.1.0
                            npm ERR! missing: buffer@5.7.1, required by bl@4.1.0
                            npm ERR! missing: inherits@2.0.4, required by bl@4.1.0
                            npm ERR! missing: inherits@2.0.4, required by readable-stream@3.6.0
                            npm ERR! missing: string_decoder@1.1.1, required by readable-stream@3.6.0
                            npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@3.6.0
                            npm ERR! missing: base64-js@1.5.1, required by buffer@5.7.1
                            npm ERR! missing: ieee754@1.2.1, required by buffer@5.7.1
                            npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0
                            npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by @serialport/parser-readline@9.2.4
                            npm ERR! missing: debug@4.3.3, required by @serialport/stream@9.2.4
                            npm ERR! missing: axios@0.25.0, required by zigbee-herdsman-converters@14.0.422
                            npm ERR! missing: buffer-crc32@0.2.13, required by zigbee-herdsman-converters@14.0.422
                            npm ERR! missing: https-proxy-agent@5.0.0, required by zigbee-herdsman-converters@14.0.422
                            npm ERR! missing: tar-stream@2.2.0, required by zigbee-herdsman-converters@14.0.422
                            npm ERR! missing: zigbee-herdsman@0.14.14, required by zigbee-herdsman-converters@14.0.422
                            npm ERR! missing: follow-redirects@1.14.8, required by axios@0.25.0
                            npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0
                            npm ERR! missing: debug@4.3.3, required by https-proxy-agent@5.0.0
                            npm ERR! missing: debug@4.3.3, required by agent-base@6.0.2
                            npm ERR! missing: string_decoder@1.3.0, required by readable-stream@3.6.0
                            npm ERR! missing: safe-buffer@5.2.1, required by string_decoder@1.3.0
                            npm ERR! missing: debounce@1.2.1, required by zigbee-herdsman@0.14.14
                            npm ERR! missing: debug@4.3.3, required by zigbee-herdsman@0.14.14
                            npm ERR! missing: fast-deep-equal@3.1.3, required by zigbee-herdsman@0.14.14
                            npm ERR! missing: mixin-deep@2.0.1, required by zigbee-herdsman@0.14.14
                            npm ERR! missing: mz@2.7.0, required by zigbee-herdsman@0.14.14
                            npm ERR! missing: serialport@9.2.8, required by zigbee-herdsman@0.14.14
                            npm ERR! missing: slip@1.0.2, required by zigbee-herdsman@0.14.14
                            • J joeysch
                              @joeysch
                              Ja, da ist irgendwas komplett schief.
                              which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              sagt?
                                @joeysch
                                sagt?
                                joeysch
        sudo ln -s /usr/bin/node /usr/bin/nodejs        which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                guido@iobroker:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v14.19.1
                                v14.19.1
                                6.14.16
                                guido
                                /opt/iobroker
                                Hit:1 https://deb.nodesource.com/node_14.x impish InRelease
                                Hit:2 http://archive.ubuntu.com/ubuntu impish InRelease
                                Get:3 http://archive.ubuntu.com/ubuntu impish-updates InRelease [115 kB]
                                Get:4 http://archive.ubuntu.com/ubuntu impish-security InRelease [110 kB]
                                Fetched 225 kB in 1s (279 kB/s)
                                Reading package lists... Done
                                All packages are up to date.
                                nodejs:
                                  Installed: 14.19.1-deb-1nodesource1
                                  Candidate: 14.19.1-deb-1nodesource1
                                  Version table:
                                 *** 14.19.1-deb-1nodesource1 500
                                        500 https://deb.nodesource.com/node_14.x impish/main amd64 Packages
                                     12.22.5~dfsg-5ubuntu1 500
                                        500 http://archive.ubuntu.com/ubuntu impish/universe amd64 Packages
                                • J joeysch
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v14.19.1
                                  v14.19.1
                                  6.14.16
                                  guido
                                  /opt/iobroker
                                  nodejs:
                                    Version table:
                                  @joeysch
                                  cd /opt/iobroker
                                  npm prune
                                    @joeysch
                                    cd /opt/iobroker
                                    npm prune
                                    joeysch
                                    npm prune
                                    Hab einen Teil rausgelöscht sonst kann ich es nicht einstellen.
                                    npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www'
                                    npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs'
                                    npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/echarts-c76558f7/src'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/nothing.png'
                                    npm ERR! Error while executing:
                                    npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                                    npm ERR!
                                    npm ERR! git@github.com: Permission denied (publickey).
                                    npm ERR! fatal: Could not read from remote repository.
                                    npm ERR!
                                    npm ERR! Please make sure you have the correct access rights
                                    npm ERR! and the repository exists.
                                    npm ERR!
                                    npm ERR! exited with error code: 128
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/offline.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/ok.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/on.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/online.png'
                                    npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/admin'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/package.png'
                                    npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react'
                                    npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/padlock_closed.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/padlock_open.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/plus.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload1.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload2.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload3.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/rgb.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/search.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/settings.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/shutdown.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/sleep_no.png'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/sleep_yes.png'
                                    npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/echarts-c76558f7/theme'
                                    npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/lib'
                                    npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/admin/admin.d.ts'
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-04-29T13_39_27_537Z-debug.log
                                    • J joeysch
                                      @thomas-braun sagte in ERROR: Process exited with code 25:
                                      npm prune
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      @joeysch sagte in ERROR: Process exited with code 25:
                                      Wo kommt denn das Verzeichnis her? Hab ich auf meinem System nicht.
                                      Mal irgendwann/irgendwie mit Versionen aus git herumgespielt?
                                        joeysch
                                        Nein, die gesamte Installation ist noch nicht so alt. Der Ärger fing glaube ich nach dem Update des Admin-Adapters an.
                                        • J joeysch
                                          @joeysch
                                          Zeig doch mal
                                          iobroker repo list
                                          iobroker update -i
