  3. Einsteigerfragen
  4. Installation
  5. Welchen Adapter zur Visualisierung nehmen ?
    6.3k
36 Beiträge 6 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • W Wolf-B
    So, nun habe ich eine ganz neue Installation ohne Pihole und ohne "Entdecken" gemacht - hier noch ohne Adapter für Homematic, Vis und Blockly. 2 Warnungen sind drin
    Hier ist das Protokoll:
    v5.3.4
    02
    Log-Größe: 2.8 KB
    Zeit
    Nachricht
    host.raspberrypi
    	2022-04-08 15:44:12.798	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    backitup.0
    	2022-04-08 15:37:27.651	info	[iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.0
    	2022-04-08 15:37:27.588	info	starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.1, js-controller: 4.0.21
    host.raspberrypi
    	2022-04-08 15:37:25.934	info	instance system.adapter.backitup.0 started with pid 6908
    discovery.0
    	2022-04-08 15:37:23.493	info	starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.1, js-controller: 4.0.21
    host.raspberrypi
    	2022-04-08 15:37:21.940	info	instance system.adapter.discovery.0 started with pid 6893
    admin.0
    	2022-04-08 15:37:20.023	warn	Active repository "stable cannot be read
    admin.0
    	2022-04-08 15:37:20.022	warn	Repository cannot be read: Active repo - stable
    admin.0
    	2022-04-08 15:37:19.914	info	Use link "http://localhost:8081" to configure.
    admin.0
    	2022-04-08 15:37:19.913	info	http server listening on port 8081
    admin.0
    	2022-04-08 15:37:19.811	info	received all objects
    admin.0
    	2022-04-08 15:37:19.721	info	requesting all objects
    admin.0
    	2022-04-08 15:37:19.720	info	requesting all states
    admin.0
    	2022-04-08 15:37:19.672	info	starting. Version 5.3.4 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.21
    host.raspberrypi
    	2022-04-08 15:37:17.942	info	instance system.adapter.admin.0 started with pid 6878
    host.raspberrypi
    	2022-04-08 15:37:17.882	info	starting 3 instances
    host.raspberrypi
    	2022-04-08 15:37:17.874	info	3 instances found
    host.raspberrypi
    	2022-04-08 15:37:17.590	info	added notifications configuration of host
    host.raspberrypi
    	2022-04-08 15:37:17.570	info	Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    host.raspberrypi
    	2022-04-08 15:37:17.512	info	Node.js version has changed from unknown to 14.19.1
    host.raspberrypi
    	2022-04-08 15:37:17.480	info	connected to Objects and States
    host.raspberrypi
    	2022-04-08 15:37:17.213	info	ip addresses: 192.168.115.5 fe80::435a:9576:55e9:b750
    host.raspberrypi
    	2022-04-08 15:37:17.212	info	hostname: raspberrypi, node: v14.19.1
    host.raspberrypi
    	2022-04-08 15:37:17.212	info	Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    MOD-EDIT Code in code-tags gesetzt!
    @wolf-b sagte in Welchen Adapter zur Visualisierung nehmen ?:
    ist eigentlich nur eine un passt zu dem früheren Problem
    wie sieht deine Repo Einstellung in den Systemeinstellungen aus?
    W 1 Antwort Letzte Antwort
      W Offline
      W Offline
      Wolf-B
      @homoran Ich wage es ja kaum zu sagen, aber in meiner ersten Installation (mit den 3 Zeilen) kam nichts Derartiges im Protokoll. Aber das hatte ich ja aus einem Internet-Post vom letzten Jahr oder so - also etwas älter.
      • W Wolf-B
        ooops, dann hab ich das mit jemandem anders verwechselt.
        da war ein EAI_AGAIN Fehler
        bleibt die Frage zu den Einstellungen
        W 2 Antworten Letzte Antwort
          W Offline
          W Offline
          Wolf-B
          schrieb am zuletzt editiert von Wolf-B
          @homoran Hm, wenn ich nun wüßte, woher ich die nehmen soll. Kannst Du mir bitte sagen, wo ich die finde ?
          Nachtrag:
          Jetzt habe ich auch noch in der Ansicht der Objekte das Problem, dass die Namensspalte zu klein ist.
          • W Wolf-B
            Nachtrag:
            GlasfaserG Offline
            GlasfaserG Offline
            @wolf-b
            Klick mal da drauf :
            und den Standart einstellen :
            • GlasfaserG Glasfaser
              @wolf-b
              W Offline
              W Offline
              Wolf-B
              @glasfaser Sorry, aber genauso ist das bei mir auch eingestellt.
                W Offline
                W Offline
                Wolf-B
                @homoran Ich habe hier in den Systemeinstellungen unter Repositories das gefunden - sind das die Einstellungen, die Du meintest ?
                • W Wolf-B
                  ja!
                  der dort angegebene Pfad ist korrekt und wird auf den jeweils aktuellen Server umgeleitet.
                  Das klappt nicht immer.
                  Geh mal auf die Seite Adapter und klick dort auf das Reload-Icon oben links.
                  Im log sollte dann etwas zu sehen sein.
                  wenn das wieder negativ ist könnte man den aktuellen Pfad angeben
                    ja!
                    W Offline
                    W Offline
                    Wolf-B
                    @homoran Habe ich gemacht - und das steht im Log:
                    • W Wolf-B
                      als text wäre schöner.
                      aber jetzt ist alles gut!
                        W Offline
                        W Offline
                        Wolf-B
                        @homoran Danke !
