  4. zigbee Adapter
    5.9k
zigbee Adapter
38 Beiträge 5 Kommentatoren 3.3k Aufrufe 7 Beobachtet
  • M michihorn
    Hallo ich nutze eine Iobroker Windows Installation.
    Leider habe ich echte Probleme mit dem Zigbee Adapter. Habe gerade mal ein Downgrade versucht von der aktuellen Version 1.6.16 au 1.6.10 gemacht, aber der Adapter bleibt gelb und die Fehlermeldung ähnlich. Vielleicht hat jemand einen Tip
    zigbee.0	2022-04-04 22:55:02.631	info	(5480) Installed Version: iobroker.zigbee@1.6.10
    zigbee.0	2022-04-04 22:55:02.610	error	(5480) Error herdsman start
    zigbee.0	2022-04-04 22:55:02.610	error	(5480) Failed to start Zigbee
    zigbee.0	2022-04-04 22:55:02.608	error	(5480) Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
    zigbee.0	2022-04-04 22:55:02.600	info	(5480) Starting Zigbee npm ...
    zigbee.0	2022-04-04 22:55:02.597	info	(5480) Try to reconnect. 1 attempts left
    zigbee.0	2022-04-04 22:54:52.910	info	(5480) Installed Version: iobroker.zigbee@1.6.10
    zigbee.0	2022-04-04 22:54:52.585	error	(5480) Error herdsman start
    zigbee.0	2022-04-04 22:54:52.584	error	(5480) Failed to start Zigbee
    zigbee.0	2022-04-04 22:54:52.583	error	(5480) Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
    zigbee.0	2022-04-04 22:54:52.377	info	(5480) Starting Zigbee npm ...
    zigbee.0	2022-04-04 22:54:52.137	info	(5480) starting. Version 1.6.16 in C:/iobroker/SmartHome/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 4.0.21
    zigbee.0	2022-04-04 22:54:41.056	info	(8660) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2022-04-04 22:54:41.054	info	(8660) terminating
    zigbee.0	2022-04-04 22:54:41.052	warn	(8660) Failed to stop zigbee during startup
    zigbee.0	2022-04-04 22:54:40.929	info	(8660) cleaned everything up...
    zigbee.0	2022-04-04 22:54:40.927	info	(8660) Got terminate signal TERMINATE_YOURSELF
    zigbee.0	2022-04-04 22:54:24.864	error	(8660) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
    zigbee.0	2022-04-04 22:53:49.424	info	(8660) Installed Version: iobroker.zigbee@1.6.10
    zigbee.0	2022-04-04 22:53:49.388	error	(8660) Error herdsman start
    zigbee.0	2022-04-04 22:53:49.387	error	(8660) Failed to start Zigbee
    zigbee.0	2022-04-04 22:53:49.386	error	(8660) Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
    zigbee.0	2022-04-04 22:53:49.377	info	(8660) Starting Zigbee npm ...
    zigbee.0	2022-04-04 22:53:49.375	info	(8660) Try to reconnect. 1 attempts left
    zigbee.0	2022-04-04 22:53:39.779	info	(8660) Installed Version: iobroker.zigbee@1.6.10
    zigbee.0	2022-04-04 22:53:39.357	error	(8660) Error herdsman start
    zigbee.0	2022-04-04 22:53:39.356	error	(8660) Failed to start Zigbee
    zigbee.0	2022-04-04 22:53:39.354	error	(8660) Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
    zigbee.0	2022-04-04 22:53:39.168	info	(8660) Starting Zigbee npm ...
    zigbee.0	2022-04-04 22:53:38.960	info	(8660) starting. Version 1.6.16 in C:/iobroker/SmartHome/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 4.0.21
    zigbee.0	2022-04-04 22:52:46.855	info	(9024) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2022-04-04 22:52:46.852	info	(9024) terminating
    zigbee.0	2022-04-04 22:52:46.851	warn	(9024) Failed to stop zigbee during startup
    zigbee.0	2022-04-04 22:52:46.717	info	(9024) cleaned everything up...
    zigbee.0	2022-04-04 22:52:46.715	info	(9024) Got terminate signal TERMINATE_YOURSELF
    zigbee.0	2022-04-04 22:51:38.712	info	(9024) Installed Version: ioBroker/ioBroker.zigbee#master
    zigbee.0	2022-04-04 22:51:38.697	error	(9024) Error herdsman start
    zigbee.0	2022-04-04 22:51:38.696	error	(9024) Failed to start Zigbee
    zigbee.0	2022-04-04 22:51:38.695	error	(9024) Starting zigbee-herdsman problem : "Unexpected token \u0000 in JSON at position 0"
    Michael
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @michihorn Bitte verifiziere ob deine shepherd.db Datei sauber ist. Wo sie unter Windows liegt weiss ich nicht. Unter Linux liegt sie auf /opt/iobroker/iobroker-data/zigbee.0.
    Als Versuch: Datei umbenennen, adapter versuchen zu starten.
    A.
    • AsgothianA Asgothian
      A.
      M Online
      M Online
      michihorn
      @asgothian Moin, wie überprüfe ich denn ob die shepherd.db sauber ist?
      Was sind die Kriterien für eine saubere shepherd.db?
      Michael
      • M michihorn
        Michael
        arteckA Offline
        arteckA Offline
        arteck
        @michihorn poste die mal ..
        sollte hier sein
        C:/iobroker/SmartHome/iobroker-data/zigbee.0
        da steht nix Sicherheitsrelevantes..
        wobei da ist was schiefgelaufen bei deiner installation
        ist das ein multihost ?
        • arteckA arteck
          sollte hier sein
          M Online
          M Online
          michihorn
          @arteck Eigentlich lief die Installation bis Sonntag. In der Nacht zum Montag gab es wohl einen Stromausfall. Seit dem läufts nach meiner Wahrnehmung nicht mehr. Ich habe nun auch mal ein Backup vom Sonntag eingespielt, ohne Erfolg
          Anbei die Backupdatei:
          backup_2022_04_02-21_31_21.tar.gz
          Michael
          • M michihorn
            Michael
            arteckA Offline
            arteckA Offline
            arteck
            im backup ist alles ok
            @michihorn sagte in zigbee Adapter:
            verstehe ich nicht.. entweder läuft oder nicht.. wie nach Wahrnehmung.. das kann man doch sehen..
            • arteckA arteck
              M Online
              M Online
              michihorn
              schrieb am zuletzt editiert von michihorn
              @arteck die Installation steht in meinem Ferienhaus 300 km von zu Hause, ich habe zwar per mqtt eine Übertragung nach Hause, schaue aber nicht regelmäßig auf mein Tablet, erst am Montag ist es mir aufgefallen. Sonntag bei Abreise alles noch OK.
              Aktuell ist der Adapter GELB
              Michael
              • M michihorn
                Michael
                arteckA Offline
                arteckA Offline
                arteck
                das kann alles sein...
                solltest erst die installation sauber ziehen.. und den adapter wieder auf die 1.6.16 bringen ..am besten von GIT installieren
                dann die dateien aus dem backup manuell rein kopieren.. so dass du sicher bist dass dir nix dazwischen funkt..
                da es unter windows läuft .. sehe ich da dein problem.. windows ist nicht stabiel genug u mein smarthome unbeaufsichtigt zu betreiben..
                M 2 Antworten Letzte Antwort
                • arteckA arteck
                  M Online
                  M Online
                  michihorn
                  @arteck Smarthome beaufsichtigen ist vielleicht zuviel, ich sehe Temperaturen in den Räumen, offene Fenster und Türen, kann per IFTTT die Heizung einschalten und Beleuchtungen bei Präsenz schalten. Ich werde heute Mittag nochmal berichten wie es nach Update aussieht.
                  Michael
                  • arteckA arteck
                    M Online
                    M Online
                    michihorn
                    @arteck Ich habe nun mal die Instanz inklusive des Verzeichnisse Zigbee_0 gelöscht und den aktuellen Adapter aus dem GIT installiert. Den Ordner zigbee_0 habe ich aus einem Backup aus fehlerfreien Installation vom Sonntag in den Verzeichnisbaum kopiert.
                    Anbei mein aktueller LOG:
                    zigbee.0	2022-04-05 15:34:15.091	info	(8688) Installed Version: iobroker.zigbee@1.6.16
                    zigbee.0	2022-04-05 15:34:15.077	error	(8688) Error herdsman start
                    zigbee.0	2022-04-05 15:34:15.076	error	(8688) Failed to start Zigbee
                    zigbee.0	2022-04-05 15:34:15.075	error	(8688) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Opening COM4: Access denied'"
                    zigbee.0	2022-04-05 15:34:14.993	info	(8688) Starting Zigbee npm ...
                    zigbee.0	2022-04-05 15:34:14.991	info	(8688) Try to reconnect. 1 attempts left
                    zigbee.0	2022-04-05 15:34:04.981	error	(8688) Error herdsman start
                    zigbee.0	2022-04-05 15:34:04.980	error	(8688) Failed to start Zigbee
                    zigbee.0	2022-04-05 15:34:04.978	error	(8688) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                    zigbee.0	2022-04-05 15:33:44.903	info	(8688) Installed Version: iobroker.zigbee@1.6.16
                    zigbee.0	2022-04-05 15:33:43.945	info	(8688) Starting Zigbee npm ...
                    zigbee.0	2022-04-05 15:33:43.688	info	(8688) starting. Version 1.6.16 in C:/iobroker/SmartHome/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 4.0.21
                    zigbee.0	2022-04-05 15:32:54.154	info	(12484) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0	2022-04-05 15:32:54.151	info	(12484) terminating
                    zigbee.0	2022-04-05 15:32:54.149	warn	(12484) Failed to stop zigbee during startup
                    zigbee.0	2022-04-05 15:32:54.124	info	(12484) Zigbee: disabling joining new devices.
                    zigbee.0	2022-04-05 15:32:53.797	info	(12484) cleaned everything up...
                    zigbee.0	2022-04-05 15:32:53.794	info	(12484) Got terminate signal TERMINATE_YOURSELF
                    zigbee.0	2022-04-05 15:32:09.574	info	(12484) Installed Version: iobroker.zigbee@1.6.16
                    zigbee.0	2022-04-05 15:32:09.505	error	(12484) Error herdsman start
                    zigbee.0	2022-04-05 15:32:09.504	error	(12484) Failed to start Zigbee
                    zigbee.0	2022-04-05 15:32:09.502	error	(12484) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Opening COM4: Access denied'"
                    zigbee.0	2022-04-05 15:32:09.407	info	(12484) Starting Zigbee npm ...
                    zigbee.0	2022-04-05 15:32:09.403	info	(12484) Try to reconnect. 1 attempts left
                    Nun habe ich offenbar ein neues Problem mit dem COM4.
                    Nun bin ich Ratlos
                    Michael
                    • M michihorn
                      Nun bin ich Ratlos
                      Michael
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @michihorn sachte..
                      jetzt schau mal in den Systemeinstellungen nach.. oder der COM Port immer noch derselbe ist
                      ich sag ja Windows ist kacke
                      • arteckA arteck
                        @michihorn sachte..
                        M Online
                        M Online
                        michihorn
                        @arteck Ja habe ich schon, COM4 ist ausgewählt. Jetzt habe ich nochmal alles gelöscht, Adapter, und Verezeichnis, den Adapter nochmal von GIT installiert aber ohne das Backup zu kopieren, also Blanko:
                        zigbee.0	2022-04-05 15:51:48.141	info	(9316) Installed Version: ioBroker/ioBroker.zigbee#ffe1892c1134a7f4b39a5e364b32090296e5eef6
                        zigbee.0	2022-04-05 15:51:48.127	error	(9316) Error herdsman start
                        zigbee.0	2022-04-05 15:51:48.126	error	(9316) Failed to start Zigbee
                        zigbee.0	2022-04-05 15:51:48.125	error	(9316) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Opening COM4: Access denied'"
                        zigbee.0	2022-04-05 15:51:48.060	info	(9316) Starting Zigbee npm ...
                        zigbee.0	2022-04-05 15:51:48.057	info	(9316) Try to reconnect. 1 attempts left
                        zigbee.0	2022-04-05 15:51:38.052	error	(9316) Error herdsman start
                        zigbee.0	2022-04-05 15:51:38.052	error	(9316) Failed to start Zigbee
                        zigbee.0	2022-04-05 15:51:38.051	error	(9316) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                        zigbee.0	2022-04-05 15:51:18.083	info	(9316) Installed Version: ioBroker/ioBroker.zigbee#ffe1892c1134a7f4b39a5e364b32090296e5eef6
                        zigbee.0	2022-04-05 15:51:17.095	info	(9316) Starting Zigbee npm ...
                        zigbee.0	2022-04-05 15:51:16.833	info	(9316) starting. Version 1.6.16 (non-npm: ioBroker/ioBroker.zigbee#ffe1892c1134a7f4b39a5e364b32090296e5eef6) in C:/iobroker/SmartHome/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 4.0.
                        zigbee.0	2022-04-05 15:51:06.545	info	(15764) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        zigbee.0	2022-04-05 15:51:06.542	info	(15764) terminating
                        zigbee.0	2022-04-05 15:51:06.541	warn	(15764) Failed to stop zigbee during startup
                        zigbee.0	2022-04-05 15:51:06.511	info	(15764) Zigbee: disabling joining new devices.
                        zigbee.0	2022-04-05 15:51:06.507	info	(15764) cleaned everything up...
                        zigbee.0	2022-04-05 15:51:06.504	info	(15764) Got terminate signal TERMINATE_YOURSELF
                        • M michihorn
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @michihorn das hab ic hnicht gesagt... war doch alles ok bis dahin .. das einzige war der COM4 war belegt..eineinfaches neu starten der Kiste hätte auch gereicht.
                          • arteckA arteck
                            M Online
                            M Online
                            michihorn
                            @arteck Die Maschine habe ich auch schon gestartet, aber ohne Veränderung, der Adapter bleibt GELB
                            • M michihorn
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @michihorn
                              der COM4 wird von irgendeinem anderen Programm in beschlag genommen..
                              deshlab kann der iobroker da nicht dran kommen.. ewtl. zieh den mal ab und steck den wieder rein
                              • arteckA arteck
                                @michihorn
                                M Online
                                M Online
                                michihorn
                                @arteck Das wir schwierig, da der Rechner 300 KM entfernt steht 🙄
                                Kann ich evtl am Wochenende mal machen
                                • arteckA arteck
                                  @michihorn
                                  M Online
                                  M Online
                                  michihorn
                                  @arteck Hallöchen, ein freundlicher Nachbar hat den Rechner einmal per Ausschaltknopf augeschaltet, ist offensichtlich was anderes als wenn ich den Rechner nur aus der Ferne per Remote neustarte. Der Adapter ist jetzt grün, die Geräte mit dem Backup vom 2.4.22 sind zu sehen, zeigen aber keinen Status an, aussderm sind viele Namen verloren gegangen.
                                  Was kann ich tun?
                                  Michael
                                  • M michihorn
                                    Was kann ich tun?
                                    Michael
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @michihorn zumindest läuft die instanz.. die wirst du wohl neu anlernen müssen..
                                    und für die zukunft.. wenn was nicht läuft ist ein zurückspielen des Backups eher kontraproduktiv.. vor allem wenn man nicht weiss was man macht.
                                    der cc2531 ist ne zicke .. tausche den mal aus.. vor allem da du keinen Router im Netz hast..der wird dir immer wieder aussteigen..
                                    • arteckA arteck
                                      M Online
                                      M Online
                                      michihorn
                                      @arteck Welchen Stick würdest Du empfehlen?
                                      • M michihorn
                                        @michihorn
                                        Schau hier:
                                        https://www.zigbee2mqtt.io/guide/adapters/#recommended
                                          @michihorn
                                          Schau hier:
                                          M Online
                                          M Online
                                          michihorn
                                          @thomas-braun Danke , was machst du mit Zigbee über mehrere Etagen, die Osram Steckdose als Repeater funktioniert nur suboptimal
