  4. Alle Adapter starten jede Stunden um :17 neu.
    6.0k
18 Beiträge 4 Kommentatoren 2.5k Aufrufe 5 Beobachtet
  • F Offline
    femi
    Hallo Zusammen,
    ich habe auf einem Iobroker das Problem daß alle Adapter jede Stunden einen Neustart machen.
    Installiert ist die Version 5.3.4
    node -v v12.22.11
    Hier das log, hab nur eine Startsequenz rauskopiert aber das wiederholt sich jede Stunde um 17 nach.
    Ich kann keine Startzeitpunkte in den Instanzen finden.
    2022-04-04 14:17:02.039 - info: backitup.0 (1270455) cleaned everything up...
    2022-04-04 14:17:02.039 - info: sourceanalytix.0 (1270517) SourceAnalytix stopped, now you have to calculate by yourself :'( ...
    2022-04-04 14:17:02.039 - info: admin.0 (1270346) terminating http server on port 8081
    2022-04-04 14:17:02.043 - info: vis-inventwo.0 (1270538) cleaned everything up...
    2022-04-04 14:17:02.043 - info: javascript.0 (1270379) Stop script script.js.InBetrieb.Wäschetrockner
    2022-04-04 14:17:02.044 - info: javascript.0 (1270379) Stop script script.js.InBetrieb.Waschmaschine
    2022-04-04 14:17:02.049 - info: host.am-000c29d8c32a.intern received SIGTERM
    2022-04-04 14:17:02.054 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-04-04 14:17:02.054 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.javascript.0 (force=false, process=true)
    2022-04-04 14:17:02.055 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.sql.0 (force=false, process=true)
    2022-04-04 14:17:02.055 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.telegram.0 (force=false, process=true)
    2022-04-04 14:17:02.056 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.ping.0 (force=false, process=false)
    2022-04-04 14:17:02.056 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.sonoff.0 (force=false, process=true)
    2022-04-04 14:17:02.057 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.discovery.0 (force=false, process=true)
    2022-04-04 14:17:02.057 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-04-04 14:17:02.057 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.web.0 (force=false, process=true)
    2022-04-04 14:17:02.057 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.vis.0 (force=false, process=false)
    2022-04-04 14:17:02.057 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.sourceanalytix.0 (force=false, process=true)
    2022-04-04 14:17:02.058 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.vis-inventwo.0 (force=false, process=true)
    2022-04-04 14:17:02.058 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
    2022-04-04 14:17:02.066 - info: backitup.0 (1270455) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-04-04 14:17:02.068 - info: sourceanalytix.0 (1270517) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-04-04 14:17:02.070 - info: admin.0 (1270346) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-04-04 14:17:02.071 - info: javascript.0 (1270379) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-04-04 14:17:02.071 - info: vis-inventwo.0 (1270538) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-04-04 14:17:02.072 - info: admin.0 (1270346) Got terminate signal TERMINATE_YOURSELF
    2022-04-04 14:17:02.073 - info: javascript.0 (1270379) Got terminate signal TERMINATE_YOURSELF
    2022-04-04 14:17:02.074 - info: sonoff.0 (1270425) Got terminate signal TERMINATE_YOURSELF
    2022-04-04 14:17:02.075 - info: discovery.0 (1270440) Got terminate signal TERMINATE_YOURSELF
    2022-04-04 14:17:02.076 - info: backitup.0 (1270455) Got terminate signal TERMINATE_YOURSELF
    2022-04-04 14:17:02.076 - info: telegram.0 (1270410) Got terminate signal TERMINATE_YOURSELF
    2022-04-04 14:17:02.077 - info: vis-inventwo.0 (1270538) Got terminate signal TERMINATE_YOURSELF
    2022-04-04 14:17:02.076 - info: web.0 (1270484) Got terminate signal TERMINATE_YOURSELF
    2022-04-04 14:17:02.078 - info: sourceanalytix.0 (1270517) Got terminate signal TERMINATE_YOURSELF
    2022-04-04 14:17:02.079 - info: discovery.0 (1270440) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-04-04 14:17:02.080 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.admin.0 send kill signal
    2022-04-04 14:17:02.079 - info: web.0 (1270484) terminated http server on port 8082
    2022-04-04 14:17:02.083 - info: web.0 (1270484) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-04-04 14:17:02.122 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.javascript.0 send kill signal
    2022-04-04 14:17:02.123 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.telegram.0 send kill signal
    2022-04-04 14:17:02.123 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.sonoff.0 send kill signal
    2022-04-04 14:17:02.123 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.discovery.0 send kill signal
    2022-04-04 14:17:02.123 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.backitup.0 send kill signal
    2022-04-04 14:17:02.123 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.web.0 send kill signal
    2022-04-04 14:17:02.124 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.sourceanalytix.0 send kill signal
    2022-04-04 14:17:02.124 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.vis-inventwo.0 send kill signal
    2022-04-04 14:17:02.546 - info: sonoff.0 (1270425) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-04-04 14:17:02.548 - info: telegram.0 (1270410) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-04-04 14:17:02.654 - info: host.am-000c29d8c32a.intern instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-04-04 14:17:02.655 - info: host.am-000c29d8c32a.intern instance system.adapter.sourceanalytix.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-04-04 14:17:02.671 - info: host.am-000c29d8c32a.intern instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-04-04 14:17:02.671 - info: host.am-000c29d8c32a.intern instance system.adapter.vis-inventwo.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-04-04 14:17:02.685 - info: host.am-000c29d8c32a.intern instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-04-04 14:17:02.686 - info: host.am-000c29d8c32a.intern instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-04-04 14:17:02.692 - info: host.am-000c29d8c32a.intern instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-04-04 14:17:03.073 - info: host.am-000c29d8c32a.intern instance system.adapter.sonoff.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-04-04 14:17:03.079 - info: host.am-000c29d8c32a.intern instance system.adapter.telegram.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-04-04 14:17:05.047 - info: sql.0 (1270394) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-04-04 14:17:05.055 - info: host.am-000c29d8c32a.intern stopInstance timeout 3000 system.adapter.sql.0 killing pid 1270394
    2022-04-04 14:17:05.568 - info: host.am-000c29d8c32a.intern instance system.adapter.sql.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-04-04 14:17:05.568 - info: host.am-000c29d8c32a.intern All instances are stopped.
    2022-04-04 14:17:05.698 - info: host.am-000c29d8c32a.intern terminated
    2022-04-04 14:17:10.359 - info: host.am-000c29d8c32a.intern iobroker.js-controller version 4.0.21 js-controller starting
    2022-04-04 14:17:10.362 - info: host.am-000c29d8c32a.intern Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-04-04 14:17:10.363 - info: host.am-000c29d8c32a.intern hostname: am-000c29d8c32a.intern, node: v12.22.11
    2022-04-04 14:17:10.363 - info: host.am-000c29d8c32a.intern ip addresses: 192.168.40.20 fe80::20c:29ff:fed8:c32a
    2022-04-04 14:17:10.857 - info: host.am-000c29d8c32a.intern connected to Objects and States
    2022-04-04 14:17:10.873 - info: host.am-000c29d8c32a.intern added notifications configuration of host
    2022-04-04 14:17:11.078 - info: host.am-000c29d8c32a.intern 15 instances found
    2022-04-04 14:17:11.095 - info: host.am-000c29d8c32a.intern starting 12 instances
    2022-04-04 14:17:11.132 - info: host.am-000c29d8c32a.intern instance system.adapter.admin.0 started with pid 1271004
    2022-04-04 14:17:12.022 - info: admin.0 (1271004) starting. Version 5.3.4 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:12.057 - info: admin.0 (1271004) requesting all states
    2022-04-04 14:17:12.057 - info: admin.0 (1271004) requesting all objects
    2022-04-04 14:17:12.573 - info: admin.0 (1271004) received all objects
    2022-04-04 14:17:12.729 - info: admin.0 (1271004) Request actual repository...
    2022-04-04 14:17:12.753 - info: admin.0 (1271004) http server listening on port 8081
    2022-04-04 14:17:12.754 - info: admin.0 (1271004) Use link "http://localhost:8081" to configure.
    2022-04-04 14:17:13.042 - info: host.am-000c29d8c32a.intern Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-04-04 14:17:13.934 - info: admin.0 (1271004) Repository received successfully.
    2022-04-04 14:17:15.118 - info: host.am-000c29d8c32a.intern instance system.adapter.javascript.0 started with pid 1271019
    2022-04-04 14:17:16.532 - info: javascript.0 (1271019) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:16.589 - info: javascript.0 (1271019) requesting all states
    2022-04-04 14:17:16.590 - info: javascript.0 (1271019) requesting all objects
    2022-04-04 14:17:17.028 - info: javascript.0 (1271019) received all objects
    2022-04-04 14:17:17.031 - info: javascript.0 (1271019) received all states
    2022-04-04 14:17:17.099 - info: javascript.0 (1271019) Start javascript script.js.InBetrieb.Wäschetrockner
    2022-04-04 14:17:17.126 - info: javascript.0 (1271019) script.js.InBetrieb.Wäschetrockner: registered 1 subscription and 0 schedules
    2022-04-04 14:17:17.126 - info: javascript.0 (1271019) Start javascript script.js.InBetrieb.Waschmaschine
    2022-04-04 14:17:17.129 - info: javascript.0 (1271019) script.js.InBetrieb.Waschmaschine: registered 1 subscription and 0 schedules
    2022-04-04 14:17:19.126 - info: host.am-000c29d8c32a.intern instance system.adapter.sql.0 started with pid 1271034
    2022-04-04 14:17:20.033 - info: sql.0 (1271034) starting. Version 1.16.2 in /opt/iobroker/node_modules/iobroker.sql, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:20.179 - info: sql.0 (1271034) Connected to mysql
    2022-04-04 14:17:23.118 - info: host.am-000c29d8c32a.intern instance system.adapter.telegram.0 started with pid 1271051
    2022-04-04 14:17:24.213 - info: telegram.0 (1271051) starting. Version 1.11.1 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:27.115 - info: host.am-000c29d8c32a.intern instance system.adapter.sonoff.0 started with pid 1271066
    2022-04-04 14:17:27.975 - info: sonoff.0 (1271066) starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:28.015 - info: sonoff.0 (1271066) Starting MQTT authenticated server on port 1883
    2022-04-04 14:17:31.114 - info: host.am-000c29d8c32a.intern instance system.adapter.discovery.0 started with pid 1271081
    2022-04-04 14:17:31.917 - info: discovery.0 (1271081) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:35.115 - info: host.am-000c29d8c32a.intern instance system.adapter.backitup.0 started with pid 1271096
    2022-04-04 14:17:35.194 - info: sonoff.0 (1271066) Client [Waschmaschine] connected with secret 1649074655189_7442
    2022-04-04 14:17:35.434 - info: sonoff.0 (1271066) Client [BueroRalle] connected with secret 1649074655433_3750
    2022-04-04 14:17:35.547 - info: sonoff.0 (1271066) Client [Wohnzimmer] connected with secret 1649074655546_7726
    2022-04-04 14:17:35.865 - info: sonoff.0 (1271066) Client [Trockner] connected with secret 1649074655864_9988
    2022-04-04 14:17:36.049 - info: backitup.0 (1271096) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:36.106 - info: backitup.0 (1271096) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-04-04 14:17:40.843 - info: host.am-000c29d8c32a.intern iobroker.js-controller version 4.0.21 js-controller starting
    2022-04-04 14:17:40.847 - info: host.am-000c29d8c32a.intern Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-04-04 14:17:40.847 - info: host.am-000c29d8c32a.intern hostname: am-000c29d8c32a.intern, node: v12.22.11
    2022-04-04 14:17:40.847 - info: host.am-000c29d8c32a.intern ip addresses: 192.168.40.20 fe80::20c:29ff:fed8:c32a
    2022-04-04 14:17:41.341 - info: host.am-000c29d8c32a.intern connected to Objects and States
    2022-04-04 14:17:41.357 - info: host.am-000c29d8c32a.intern added notifications configuration of host
    2022-04-04 14:17:41.554 - info: host.am-000c29d8c32a.intern 15 instances found
    2022-04-04 14:17:41.569 - info: host.am-000c29d8c32a.intern starting 12 instances
    2022-04-04 14:17:41.604 - info: host.am-000c29d8c32a.intern instance system.adapter.admin.0 started with pid 1271145
    2022-04-04 14:17:42.506 - info: admin.0 (1271145) starting. Version 5.3.4 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:42.534 - info: admin.0 (1271145) requesting all states
    2022-04-04 14:17:42.535 - info: admin.0 (1271145) requesting all objects
    2022-04-04 14:17:43.020 - info: admin.0 (1271145) received all objects
    2022-04-04 14:17:43.185 - info: admin.0 (1271145) Request actual repository...
    2022-04-04 14:17:43.196 - info: admin.0 (1271145) http server listening on port 8081
    2022-04-04 14:17:43.196 - info: admin.0 (1271145) Use link "http://localhost:8081" to configure.
    2022-04-04 14:17:43.496 - info: host.am-000c29d8c32a.intern Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-04-04 14:17:44.028 - info: admin.0 (1271145) Repository received successfully.
    2022-04-04 14:17:45.594 - info: host.am-000c29d8c32a.intern instance system.adapter.javascript.0 started with pid 1271178
    2022-04-04 14:17:47.005 - info: javascript.0 (1271178) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:47.060 - info: javascript.0 (1271178) requesting all states
    2022-04-04 14:17:47.061 - info: javascript.0 (1271178) requesting all objects
    2022-04-04 14:17:47.473 - info: javascript.0 (1271178) received all objects
    2022-04-04 14:17:47.484 - info: javascript.0 (1271178) received all states
    2022-04-04 14:17:47.549 - info: javascript.0 (1271178) Start javascript script.js.InBetrieb.Wäschetrockner
    2022-04-04 14:17:47.576 - info: javascript.0 (1271178) script.js.InBetrieb.Wäschetrockner: registered 1 subscription and 0 schedules
    2022-04-04 14:17:47.578 - info: javascript.0 (1271178) Start javascript script.js.InBetrieb.Waschmaschine
    2022-04-04 14:17:47.581 - info: javascript.0 (1271178) script.js.InBetrieb.Waschmaschine: registered 1 subscription and 0 schedules
    2022-04-04 14:17:49.592 - info: host.am-000c29d8c32a.intern instance system.adapter.sql.0 started with pid 1271193
    2022-04-04 14:17:50.475 - info: sql.0 (1271193) starting. Version 1.16.2 in /opt/iobroker/node_modules/iobroker.sql, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:50.619 - info: sql.0 (1271193) Connected to mysql
    2022-04-04 14:17:53.592 - info: host.am-000c29d8c32a.intern instance system.adapter.telegram.0 started with pid 1271209
    2022-04-04 14:17:54.697 - info: telegram.0 (1271209) starting. Version 1.11.1 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:57.592 - info: host.am-000c29d8c32a.intern instance system.adapter.sonoff.0 started with pid 1271225
    2022-04-04 14:17:58.435 - info: sonoff.0 (1271225) starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:17:58.469 - info: sonoff.0 (1271225) Starting MQTT authenticated server on port 1883
    2022-04-04 14:18:01.589 - info: host.am-000c29d8c32a.intern instance system.adapter.discovery.0 started with pid 1271240
    2022-04-04 14:18:02.429 - info: discovery.0 (1271240) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:18:05.594 - info: host.am-000c29d8c32a.intern instance system.adapter.backitup.0 started with pid 1271255
    2022-04-04 14:18:06.464 - info: backitup.0 (1271255) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:18:06.502 - info: backitup.0 (1271255) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-04-04 14:18:09.427 - info: sonoff.0 (1271225) Client [BueroRalle] connected with secret 1649074689422_4962
    2022-04-04 14:18:09.553 - info: sonoff.0 (1271225) Client [Wohnzimmer] connected with secret 1649074689553_256
    2022-04-04 14:18:09.590 - info: host.am-000c29d8c32a.intern instance system.adapter.web.0 started with pid 1271285
    2022-04-04 14:18:09.828 - info: sonoff.0 (1271225) Client [Trockner] connected with secret 1649074689828_5206
    2022-04-04 14:18:10.168 - info: sonoff.0 (1271225) Client [Waschmaschine] connected with secret 1649074690167_2520
    2022-04-04 14:18:10.551 - info: web.0 (1271285) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:18:10.648 - info: web.0 (1271285) socket.io server listening on port 8082
    2022-04-04 14:18:10.651 - info: web.0 (1271285) http server listening on port 8082
    2022-04-04 14:18:14.213 - info: vis.0 (1271300) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:18:14.388 - info: vis.0 (1271300) vis license is OK.
    2022-04-04 14:18:15.035 - info: vis.0 (1271300) Terminated (NO_ERROR): Without reason
    2022-04-04 14:18:15.564 - info: host.am-000c29d8c32a.intern instance system.adapter.vis.0 terminated while should be started once
    2022-04-04 14:18:17.589 - info: host.am-000c29d8c32a.intern instance system.adapter.sourceanalytix.0 started with pid 1271318
    2022-04-04 14:18:18.416 - info: sourceanalytix.0 (1271318) starting. Version 0.4.14 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:18:18.442 - info: sourceanalytix.0 (1271318) Welcome to SourceAnalytix, making things ready ...
    2022-04-04 14:18:18.463 - info: sourceanalytix.0 (1271318) Found 4 SourceAnalytix enabled states
    2022-04-04 14:18:18.463 - info: sourceanalytix.0 (1271318) Initialising (1 of 4) "sonoff.0.Waschmaschine.ENERGY_Total"
    2022-04-04 14:18:19.822 - info: sourceanalytix.0 (1271318) Initialization of sonoff.0.Waschmaschine.ENERGY_Total successfully
    2022-04-04 14:18:19.823 - info: sourceanalytix.0 (1271318) Initialising (2 of 4) "sonoff.0.Wohnzimmer.ENERGY_Total"
    2022-04-04 14:18:20.982 - info: sourceanalytix.0 (1271318) Initialization of sonoff.0.Wohnzimmer.ENERGY_Total successfully
    2022-04-04 14:18:20.982 - info: sourceanalytix.0 (1271318) Initialising (3 of 4) "sonoff.0.BueroRalle.ENERGY_Total"
    2022-04-04 14:18:21.595 - info: host.am-000c29d8c32a.intern instance system.adapter.vis-inventwo.0 started with pid 1271339
    2022-04-04 14:18:22.205 - info: sourceanalytix.0 (1271318) Initialization of sonoff.0.BueroRalle.ENERGY_Total successfully
    2022-04-04 14:18:22.206 - info: sourceanalytix.0 (1271318) Initialising (4 of 4) "sonoff.0.Trockner.ENERGY_Total"
    2022-04-04 14:18:22.551 - info: vis-inventwo.0 (1271339) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v12.22.11, js-controller: 4.0.21
    2022-04-04 14:18:23.397 - info: sourceanalytix.0 (1271318) Initialization of sonoff.0.Trockner.ENERGY_Total successfully
    2022-04-04 14:18:23.403 - info: sourceanalytix.0 (1271318) Successfully activated SourceAnalytix for 4 of 4 states, will do my Job until you stop me!
    • crunchipC Abwesend
      crunchipC Abwesend
      @femi sagte in Alle Adapter starten jede Stunden um :17 neu.:
      ein cronjob vllt, nur die Frage woher
      worauf läuft der iobroker?
      F 1 Antwort Letzte Antwort
        femi
        schrieb am zuletzt editiert von femi
        @crunchip
        VMware ESXI
        Debian 11
        hier die Einträge in /var/log/messages:
        Apr  5 06:10:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
        Apr  5 06:15:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
        Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283728) user=iobroker command=node nice=0
        Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283674) user=iobroker command=node nice=0
        Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283707) user=iobroker command=node nice=0
        Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283535) user=iobroker command=node nice=0
        Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283583) user=iobroker command=node nice=0
        Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283614) user=iobroker command=node nice=0
        Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283629) user=iobroker command=node nice=0
        Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283517) user=iobroker command=node nice=0
        Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283644) user=iobroker command=node nice=0
        Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283568) user=iobroker command=node nice=0
        Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283599) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284286) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284301) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284271) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284190) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284256) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284316) user=iobroker command=sh nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284223) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284208) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284238) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284286) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284301) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284271) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284190) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284256) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284316) user=iobroker command=sh nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284223) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284208) user=iobroker command=node nice=0
        Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284238) user=iobroker command=node nice=0
        Apr  5 06:20:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
        Apr  5 06:25:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
        Apr  5 06:30:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
        Apr  5 06:35:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
        Apr  5 06:38:19 am-000c29d8c32a sitesummary-client: error: unable to submit to 'http://sitesummary/cgi-bin/sitesummary-collector.cgi'
        Apr  5 06:40:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
        Apr  5 06:45:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
        Apr  5 06:50:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
        • F femi
          @crunchip
          VMware ESXI
          Debian 11
          crunchipC Abwesend
          crunchipC Abwesend
          @femi die Frage, woher kommt das Kommando
            femi
            @crunchip
            Das frage ich mich auch, im Crontab ist nichts eingetragen.
            Hab die cronjobs von allen Usern ausgelesen.
            root
            no crontab for root
            daemon
            no crontab for daemon
            bin
            no crontab for bin
            sys
            no crontab for sys
            sync
            no crontab for sync
            games
            no crontab for games
            man
            no crontab for man
            lp
            no crontab for lp
            mail
            no crontab for mail
            news
            no crontab for news
            uucp
            no crontab for uucp
            proxy
            no crontab for proxy
            www-data
            no crontab for www-data
            backup
            no crontab for backup
            list
            no crontab for list
            irc
            no crontab for irc
            gnats
            no crontab for gnats
            nobody
            no crontab for nobody
            _apt
            no crontab for _apt
            systemd-timesync
            no crontab for systemd-timesync
            systemd-network
            no crontab for systemd-network
            systemd-resolve
            no crontab for systemd-resolve
            messagebus
            no crontab for messagebus
            Debian-exim
            no crontab for Debian-exim
            nslcd
            no crontab for nslcd
            tcpdump
            no crontab for tcpdump
            sshd
            no crontab for sshd
            _rpc
            no crontab for _rpc
            statd
            no crontab for statd
            avahi
            no crontab for avahi
            munin
            no crontab for munin
            saned
            no crontab for saned
            colord
            no crontab for colord
            systemd-coredump
            no crontab for systemd-coredump
            iobroker
            no crontab for iobroker
            mysql
            no crontab for mysql
            • F femi
              @crunchip
              VMware ESXI
              Debian 11
              crunchipC Abwesend
              crunchipC Abwesend
              VMware ESXI
              ich kenn mich leider damit überhaupt nicht aus.
              irgend ein bash script laufen oder anderweitig ein script?
              vielleicht wäre es möglich/Sinnvoll, ne neue VM zu erstellen und ein Backup des ioBrokers einzuspielen.
              um zu sehen ob es dann immer noch passiert.
                VMware ESXI
                femi
                @crunchip
                ich bin kein Freund von "neu aufsetzen" weil man dann nie weiß wo der Fehler lag.
                Das muß doch zu finden sein.
                OliverIOO Thomas BraunT 2 Antworten Letzte Antwort
                • F femi
                  @crunchip
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @femi
                  hast du evtl so etwas installiert?
                  https://packages.debian.org/bullseye/killer
                  sudo apt list --installed
                  Meine Adapter und Widgets
                  Links im Profil
                  • F femi
                    @crunchip
                    @femi
                    Schau mal in die /etc/cron.hourly rein.
                      @femi
                      femi
                      da ist tatsächlich was drin.
                      eine Datei namens killer
                      mit diesem Inhalt:
                      if [ -x /usr/sbin/killer ] ; then /usr/sbin/killer; fi
                      Thomas BraunT OliverIOO 2 Antworten Letzte Antwort
                      • F femi
                        mit diesem Inhalt:
                        @femi
                        Das scheint mir ein Sonderfall bei Debian Edu zu sein.
                        (Warum setzt man sowas 'exotisches' ein? Und was ist das für ein Release?)
                        https://linux.debian.bugs.dist.narkive.com/ilpk6QBM/bug-890517-killer-s-cron-logs-out-users-once-per-hour
                        • F femi
                          mit diesem Inhalt:
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          @femi
                          das oben genannte Packet ist es ziemlich sicher.
                          die syslog message entspricht dieser anweisung.
                          https://salsa.debian.org/debian-edu-pkg-team/killer/-/blob/master/killer#L810
                          das skript ist über 20 jahre alt (was nix schlechtes sein muss)
                          killer entfernt alle hintergrundprozesse zu benutzern die nicht mehr eingeloggt sind.
                          bei edu kann ich mir das als lern-linux vorstellen. wenn der benutzer nicht mehr da ist, dann werden auch alle seine gestarteten prozesse beendet.
                          in diesem fall ist halt der benutzer iobroker nicht mehr angemeldet.
                          Links im Profil
                          • OliverIOO OliverIO
                            @femi
                            femi
                            @oliverio
                            warum ich das edu runtergeladen habe weiß ich auch nicht mehr, ist mir wahrscheinlich grade von die Maus gelaufen :-)
                            Ich lösche das Script, dann sollte der Fehler weg sein.
                            Und schon ist Ruhe!!
                            Vielen Dank für die Hilfe!!
                            Da wäre ich nicht drauf gekommen.
                            • F femi
                              @oliverio
                              Nein, du deinstallierst das Paket, in dem das Skript drin ist!
                              Wird sich vermutlich 'killer' schimpfen.
                              Einfach mal irgendwas irgendwie installieren? Gute Taktik. Macht alles viel einfacher.
                                femi
                                ich dachte edu wäre die Bezeichnung der Version, so wie Buster usw.
                                Daß das eine Education Version ist wußte ich nicht, aber jetzt bin ich wieder schlauer.
                                Killer hab ich deinstalliert.
                                • F femi
                                  @femi
                                  Warum man irgendwas anderes als ein Debian 'Lite' installiert versteh ich eh nicht.
                                  Was ist denn das da nun für ein Release?
                                  cat /etc/debian_version
                                    @femi
                                    femi
                                    es soll Leute geben die auch noch was anderes machen als sich mit Linux zu beschäftigen.
                                    Es ist 11.2
                                    • F femi
                                      Es ist 11.2
                                      @femi
                                      Besser ist das. ;-)
