<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Alle Adapter starten jede Stunden um :17 neu.]]></title><description><![CDATA[<p dir="auto">Hallo Zusammen,<br />
ich habe auf einem Iobroker das Problem daß alle Adapter jede Stunden einen Neustart machen.<br />
Installiert ist die Version 5.3.4<br />
node -v  v12.22.11<br />
Hier das log, hab nur eine Startsequenz rauskopiert aber das wiederholt sich jede Stunde um 17 nach.<br />
Ich kann keine Startzeitpunkte in den Instanzen finden.</p>
<pre><code>2022-04-04 14:17:02.039 - info: backitup.0 (1270455) cleaned everything up...
2022-04-04 14:17:02.039 - info: sourceanalytix.0 (1270517) SourceAnalytix stopped, now you have to calculate by yourself :'( ...
2022-04-04 14:17:02.039 - info: admin.0 (1270346) terminating http server on port 8081
2022-04-04 14:17:02.043 - info: vis-inventwo.0 (1270538) cleaned everything up...
2022-04-04 14:17:02.043 - info: javascript.0 (1270379) Stop script script.js.InBetrieb.Wäschetrockner
2022-04-04 14:17:02.044 - info: javascript.0 (1270379) Stop script script.js.InBetrieb.Waschmaschine
2022-04-04 14:17:02.049 - info: host.am-000c29d8c32a.intern received SIGTERM
2022-04-04 14:17:02.054 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.admin.0 (force=false, process=true)
2022-04-04 14:17:02.054 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.javascript.0 (force=false, process=true)
2022-04-04 14:17:02.055 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.sql.0 (force=false, process=true)
2022-04-04 14:17:02.055 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.telegram.0 (force=false, process=true)
2022-04-04 14:17:02.056 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.ping.0 (force=false, process=false)
2022-04-04 14:17:02.056 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.sonoff.0 (force=false, process=true)
2022-04-04 14:17:02.057 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.discovery.0 (force=false, process=true)
2022-04-04 14:17:02.057 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.backitup.0 (force=false, process=true)
2022-04-04 14:17:02.057 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.web.0 (force=false, process=true)
2022-04-04 14:17:02.057 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.vis.0 (force=false, process=false)
2022-04-04 14:17:02.057 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.sourceanalytix.0 (force=false, process=true)
2022-04-04 14:17:02.058 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.vis-inventwo.0 (force=false, process=true)
2022-04-04 14:17:02.058 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
2022-04-04 14:17:02.066 - info: backitup.0 (1270455) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-04-04 14:17:02.068 - info: sourceanalytix.0 (1270517) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-04-04 14:17:02.070 - info: admin.0 (1270346) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-04-04 14:17:02.071 - info: javascript.0 (1270379) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-04-04 14:17:02.071 - info: vis-inventwo.0 (1270538) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-04-04 14:17:02.072 - info: admin.0 (1270346) Got terminate signal TERMINATE_YOURSELF
2022-04-04 14:17:02.073 - info: javascript.0 (1270379) Got terminate signal TERMINATE_YOURSELF
2022-04-04 14:17:02.074 - info: sonoff.0 (1270425) Got terminate signal TERMINATE_YOURSELF
2022-04-04 14:17:02.075 - info: discovery.0 (1270440) Got terminate signal TERMINATE_YOURSELF
2022-04-04 14:17:02.076 - info: backitup.0 (1270455) Got terminate signal TERMINATE_YOURSELF
2022-04-04 14:17:02.076 - info: telegram.0 (1270410) Got terminate signal TERMINATE_YOURSELF
2022-04-04 14:17:02.077 - info: vis-inventwo.0 (1270538) Got terminate signal TERMINATE_YOURSELF
2022-04-04 14:17:02.076 - info: web.0 (1270484) Got terminate signal TERMINATE_YOURSELF
2022-04-04 14:17:02.078 - info: sourceanalytix.0 (1270517) Got terminate signal TERMINATE_YOURSELF
2022-04-04 14:17:02.079 - info: discovery.0 (1270440) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-04-04 14:17:02.080 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.admin.0 send kill signal
2022-04-04 14:17:02.079 - info: web.0 (1270484) terminated http server on port 8082
2022-04-04 14:17:02.083 - info: web.0 (1270484) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-04-04 14:17:02.122 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.javascript.0 send kill signal
2022-04-04 14:17:02.123 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.telegram.0 send kill signal
2022-04-04 14:17:02.123 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.sonoff.0 send kill signal
2022-04-04 14:17:02.123 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.discovery.0 send kill signal
2022-04-04 14:17:02.123 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.backitup.0 send kill signal
2022-04-04 14:17:02.123 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.web.0 send kill signal
2022-04-04 14:17:02.124 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.sourceanalytix.0 send kill signal
2022-04-04 14:17:02.124 - info: host.am-000c29d8c32a.intern stopInstance system.adapter.vis-inventwo.0 send kill signal
2022-04-04 14:17:02.546 - info: sonoff.0 (1270425) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-04-04 14:17:02.548 - info: telegram.0 (1270410) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-04-04 14:17:02.654 - info: host.am-000c29d8c32a.intern instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-04-04 14:17:02.655 - info: host.am-000c29d8c32a.intern instance system.adapter.sourceanalytix.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-04-04 14:17:02.671 - info: host.am-000c29d8c32a.intern instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-04-04 14:17:02.671 - info: host.am-000c29d8c32a.intern instance system.adapter.vis-inventwo.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-04-04 14:17:02.685 - info: host.am-000c29d8c32a.intern instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-04-04 14:17:02.686 - info: host.am-000c29d8c32a.intern instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-04-04 14:17:02.692 - info: host.am-000c29d8c32a.intern instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-04-04 14:17:03.073 - info: host.am-000c29d8c32a.intern instance system.adapter.sonoff.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-04-04 14:17:03.079 - info: host.am-000c29d8c32a.intern instance system.adapter.telegram.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-04-04 14:17:05.047 - info: sql.0 (1270394) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-04-04 14:17:05.055 - info: host.am-000c29d8c32a.intern stopInstance timeout 3000 system.adapter.sql.0 killing pid 1270394
2022-04-04 14:17:05.568 - info: host.am-000c29d8c32a.intern instance system.adapter.sql.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-04-04 14:17:05.568 - info: host.am-000c29d8c32a.intern All instances are stopped.
2022-04-04 14:17:05.698 - info: host.am-000c29d8c32a.intern terminated
2022-04-04 14:17:10.359 - info: host.am-000c29d8c32a.intern iobroker.js-controller version 4.0.21 js-controller starting
2022-04-04 14:17:10.362 - info: host.am-000c29d8c32a.intern Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
2022-04-04 14:17:10.363 - info: host.am-000c29d8c32a.intern hostname: am-000c29d8c32a.intern, node: v12.22.11
2022-04-04 14:17:10.363 - info: host.am-000c29d8c32a.intern ip addresses: 192.168.40.20 fe80::20c:29ff:fed8:c32a
2022-04-04 14:17:10.857 - info: host.am-000c29d8c32a.intern connected to Objects and States
2022-04-04 14:17:10.873 - info: host.am-000c29d8c32a.intern added notifications configuration of host
2022-04-04 14:17:11.078 - info: host.am-000c29d8c32a.intern 15 instances found
2022-04-04 14:17:11.095 - info: host.am-000c29d8c32a.intern starting 12 instances
2022-04-04 14:17:11.132 - info: host.am-000c29d8c32a.intern instance system.adapter.admin.0 started with pid 1271004
2022-04-04 14:17:12.022 - info: admin.0 (1271004) starting. Version 5.3.4 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:12.057 - info: admin.0 (1271004) requesting all states
2022-04-04 14:17:12.057 - info: admin.0 (1271004) requesting all objects
2022-04-04 14:17:12.573 - info: admin.0 (1271004) received all objects
2022-04-04 14:17:12.729 - info: admin.0 (1271004) Request actual repository...
2022-04-04 14:17:12.753 - info: admin.0 (1271004) http server listening on port 8081
2022-04-04 14:17:12.754 - info: admin.0 (1271004) Use link "http://localhost:8081" to configure.
2022-04-04 14:17:13.042 - info: host.am-000c29d8c32a.intern Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
2022-04-04 14:17:13.934 - info: admin.0 (1271004) Repository received successfully.
2022-04-04 14:17:15.118 - info: host.am-000c29d8c32a.intern instance system.adapter.javascript.0 started with pid 1271019
2022-04-04 14:17:16.532 - info: javascript.0 (1271019) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:16.589 - info: javascript.0 (1271019) requesting all states
2022-04-04 14:17:16.590 - info: javascript.0 (1271019) requesting all objects
2022-04-04 14:17:17.028 - info: javascript.0 (1271019) received all objects
2022-04-04 14:17:17.031 - info: javascript.0 (1271019) received all states
2022-04-04 14:17:17.099 - info: javascript.0 (1271019) Start javascript script.js.InBetrieb.Wäschetrockner
2022-04-04 14:17:17.126 - info: javascript.0 (1271019) script.js.InBetrieb.Wäschetrockner: registered 1 subscription and 0 schedules
2022-04-04 14:17:17.126 - info: javascript.0 (1271019) Start javascript script.js.InBetrieb.Waschmaschine
2022-04-04 14:17:17.129 - info: javascript.0 (1271019) script.js.InBetrieb.Waschmaschine: registered 1 subscription and 0 schedules
2022-04-04 14:17:19.126 - info: host.am-000c29d8c32a.intern instance system.adapter.sql.0 started with pid 1271034
2022-04-04 14:17:20.033 - info: sql.0 (1271034) starting. Version 1.16.2 in /opt/iobroker/node_modules/iobroker.sql, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:20.179 - info: sql.0 (1271034) Connected to mysql
2022-04-04 14:17:23.118 - info: host.am-000c29d8c32a.intern instance system.adapter.telegram.0 started with pid 1271051
2022-04-04 14:17:24.213 - info: telegram.0 (1271051) starting. Version 1.11.1 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:27.115 - info: host.am-000c29d8c32a.intern instance system.adapter.sonoff.0 started with pid 1271066
2022-04-04 14:17:27.975 - info: sonoff.0 (1271066) starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:28.015 - info: sonoff.0 (1271066) Starting MQTT authenticated server on port 1883
2022-04-04 14:17:31.114 - info: host.am-000c29d8c32a.intern instance system.adapter.discovery.0 started with pid 1271081
2022-04-04 14:17:31.917 - info: discovery.0 (1271081) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:35.115 - info: host.am-000c29d8c32a.intern instance system.adapter.backitup.0 started with pid 1271096
2022-04-04 14:17:35.194 - info: sonoff.0 (1271066) Client [Waschmaschine] connected with secret 1649074655189_7442
2022-04-04 14:17:35.434 - info: sonoff.0 (1271066) Client [BueroRalle] connected with secret 1649074655433_3750
2022-04-04 14:17:35.547 - info: sonoff.0 (1271066) Client [Wohnzimmer] connected with secret 1649074655546_7726
2022-04-04 14:17:35.865 - info: sonoff.0 (1271066) Client [Trockner] connected with secret 1649074655864_9988
2022-04-04 14:17:36.049 - info: backitup.0 (1271096) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:36.106 - info: backitup.0 (1271096) [iobroker] backup was activated at 02:40 every 1 day(s)
2022-04-04 14:17:40.843 - info: host.am-000c29d8c32a.intern iobroker.js-controller version 4.0.21 js-controller starting
2022-04-04 14:17:40.847 - info: host.am-000c29d8c32a.intern Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
2022-04-04 14:17:40.847 - info: host.am-000c29d8c32a.intern hostname: am-000c29d8c32a.intern, node: v12.22.11
2022-04-04 14:17:40.847 - info: host.am-000c29d8c32a.intern ip addresses: 192.168.40.20 fe80::20c:29ff:fed8:c32a
2022-04-04 14:17:41.341 - info: host.am-000c29d8c32a.intern connected to Objects and States
2022-04-04 14:17:41.357 - info: host.am-000c29d8c32a.intern added notifications configuration of host
2022-04-04 14:17:41.554 - info: host.am-000c29d8c32a.intern 15 instances found
2022-04-04 14:17:41.569 - info: host.am-000c29d8c32a.intern starting 12 instances
2022-04-04 14:17:41.604 - info: host.am-000c29d8c32a.intern instance system.adapter.admin.0 started with pid 1271145
2022-04-04 14:17:42.506 - info: admin.0 (1271145) starting. Version 5.3.4 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:42.534 - info: admin.0 (1271145) requesting all states
2022-04-04 14:17:42.535 - info: admin.0 (1271145) requesting all objects
2022-04-04 14:17:43.020 - info: admin.0 (1271145) received all objects
2022-04-04 14:17:43.185 - info: admin.0 (1271145) Request actual repository...
2022-04-04 14:17:43.196 - info: admin.0 (1271145) http server listening on port 8081
2022-04-04 14:17:43.196 - info: admin.0 (1271145) Use link "http://localhost:8081" to configure.
2022-04-04 14:17:43.496 - info: host.am-000c29d8c32a.intern Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
2022-04-04 14:17:44.028 - info: admin.0 (1271145) Repository received successfully.
2022-04-04 14:17:45.594 - info: host.am-000c29d8c32a.intern instance system.adapter.javascript.0 started with pid 1271178
2022-04-04 14:17:47.005 - info: javascript.0 (1271178) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:47.060 - info: javascript.0 (1271178) requesting all states
2022-04-04 14:17:47.061 - info: javascript.0 (1271178) requesting all objects
2022-04-04 14:17:47.473 - info: javascript.0 (1271178) received all objects
2022-04-04 14:17:47.484 - info: javascript.0 (1271178) received all states
2022-04-04 14:17:47.549 - info: javascript.0 (1271178) Start javascript script.js.InBetrieb.Wäschetrockner
2022-04-04 14:17:47.576 - info: javascript.0 (1271178) script.js.InBetrieb.Wäschetrockner: registered 1 subscription and 0 schedules
2022-04-04 14:17:47.578 - info: javascript.0 (1271178) Start javascript script.js.InBetrieb.Waschmaschine
2022-04-04 14:17:47.581 - info: javascript.0 (1271178) script.js.InBetrieb.Waschmaschine: registered 1 subscription and 0 schedules
2022-04-04 14:17:49.592 - info: host.am-000c29d8c32a.intern instance system.adapter.sql.0 started with pid 1271193
2022-04-04 14:17:50.475 - info: sql.0 (1271193) starting. Version 1.16.2 in /opt/iobroker/node_modules/iobroker.sql, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:50.619 - info: sql.0 (1271193) Connected to mysql
2022-04-04 14:17:53.592 - info: host.am-000c29d8c32a.intern instance system.adapter.telegram.0 started with pid 1271209
2022-04-04 14:17:54.697 - info: telegram.0 (1271209) starting. Version 1.11.1 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:57.592 - info: host.am-000c29d8c32a.intern instance system.adapter.sonoff.0 started with pid 1271225
2022-04-04 14:17:58.435 - info: sonoff.0 (1271225) starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:17:58.469 - info: sonoff.0 (1271225) Starting MQTT authenticated server on port 1883
2022-04-04 14:18:01.589 - info: host.am-000c29d8c32a.intern instance system.adapter.discovery.0 started with pid 1271240
2022-04-04 14:18:02.429 - info: discovery.0 (1271240) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:18:05.594 - info: host.am-000c29d8c32a.intern instance system.adapter.backitup.0 started with pid 1271255
2022-04-04 14:18:06.464 - info: backitup.0 (1271255) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:18:06.502 - info: backitup.0 (1271255) [iobroker] backup was activated at 02:40 every 1 day(s)
2022-04-04 14:18:09.427 - info: sonoff.0 (1271225) Client [BueroRalle] connected with secret 1649074689422_4962
2022-04-04 14:18:09.553 - info: sonoff.0 (1271225) Client [Wohnzimmer] connected with secret 1649074689553_256
2022-04-04 14:18:09.590 - info: host.am-000c29d8c32a.intern instance system.adapter.web.0 started with pid 1271285
2022-04-04 14:18:09.828 - info: sonoff.0 (1271225) Client [Trockner] connected with secret 1649074689828_5206
2022-04-04 14:18:10.168 - info: sonoff.0 (1271225) Client [Waschmaschine] connected with secret 1649074690167_2520
2022-04-04 14:18:10.551 - info: web.0 (1271285) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:18:10.648 - info: web.0 (1271285) socket.io server listening on port 8082
2022-04-04 14:18:10.651 - info: web.0 (1271285) http server listening on port 8082
2022-04-04 14:18:14.213 - info: vis.0 (1271300) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:18:14.388 - info: vis.0 (1271300) vis license is OK.
2022-04-04 14:18:15.035 - info: vis.0 (1271300) Terminated (NO_ERROR): Without reason
2022-04-04 14:18:15.564 - info: host.am-000c29d8c32a.intern instance system.adapter.vis.0 terminated while should be started once
2022-04-04 14:18:17.589 - info: host.am-000c29d8c32a.intern instance system.adapter.sourceanalytix.0 started with pid 1271318
2022-04-04 14:18:18.416 - info: sourceanalytix.0 (1271318) starting. Version 0.4.14 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:18:18.442 - info: sourceanalytix.0 (1271318) Welcome to SourceAnalytix, making things ready ...
2022-04-04 14:18:18.463 - info: sourceanalytix.0 (1271318) Found 4 SourceAnalytix enabled states
2022-04-04 14:18:18.463 - info: sourceanalytix.0 (1271318) Initialising (1 of 4) "sonoff.0.Waschmaschine.ENERGY_Total"
2022-04-04 14:18:19.822 - info: sourceanalytix.0 (1271318) Initialization of sonoff.0.Waschmaschine.ENERGY_Total successfully
2022-04-04 14:18:19.823 - info: sourceanalytix.0 (1271318) Initialising (2 of 4) "sonoff.0.Wohnzimmer.ENERGY_Total"
2022-04-04 14:18:20.982 - info: sourceanalytix.0 (1271318) Initialization of sonoff.0.Wohnzimmer.ENERGY_Total successfully
2022-04-04 14:18:20.982 - info: sourceanalytix.0 (1271318) Initialising (3 of 4) "sonoff.0.BueroRalle.ENERGY_Total"
2022-04-04 14:18:21.595 - info: host.am-000c29d8c32a.intern instance system.adapter.vis-inventwo.0 started with pid 1271339
2022-04-04 14:18:22.205 - info: sourceanalytix.0 (1271318) Initialization of sonoff.0.BueroRalle.ENERGY_Total successfully
2022-04-04 14:18:22.206 - info: sourceanalytix.0 (1271318) Initialising (4 of 4) "sonoff.0.Trockner.ENERGY_Total"
2022-04-04 14:18:22.551 - info: vis-inventwo.0 (1271339) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v12.22.11, js-controller: 4.0.21
2022-04-04 14:18:23.397 - info: sourceanalytix.0 (1271318) Initialization of sonoff.0.Trockner.ENERGY_Total successfully
2022-04-04 14:18:23.403 - info: sourceanalytix.0 (1271318) Successfully activated SourceAnalytix for 4 of 4 states, will do my Job until you stop me!
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/53973/alle-adapter-starten-jede-stunden-um-17-neu</link><generator>RSS for Node</generator><lastBuildDate>Fri, 22 May 2026 09:39:01 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/53973.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Apr 2022 19:44:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 15:48:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/femi" aria-label="Profile: femi">@<bdi>femi</bdi></a></p>
<p dir="auto">Besser ist das. ;-)</p>
]]></description><link>https://forum.iobroker.net/post/787436</link><guid isPermaLink="true">https://forum.iobroker.net/post/787436</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 05 Apr 2022 15:48:22 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 15:19:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
es soll Leute geben die auch noch was anderes machen als sich mit Linux zu beschäftigen.<br />
Es ist 11.2</p>
]]></description><link>https://forum.iobroker.net/post/787427</link><guid isPermaLink="true">https://forum.iobroker.net/post/787427</guid><dc:creator><![CDATA[femi]]></dc:creator><pubDate>Tue, 05 Apr 2022 15:19:03 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 10:27:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/femi" aria-label="Profile: femi">@<bdi>femi</bdi></a></p>
<p dir="auto">Warum man irgendwas anderes als ein Debian 'Lite' installiert versteh ich eh nicht.</p>
<p dir="auto">Was ist denn das da nun für ein Release?</p>
<pre><code>cat /etc/debian_version
</code></pre>
]]></description><link>https://forum.iobroker.net/post/787263</link><guid isPermaLink="true">https://forum.iobroker.net/post/787263</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 05 Apr 2022 10:27:16 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 10:24:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
ich dachte edu wäre die Bezeichnung der Version, so wie Buster usw.<br />
Daß das eine Education Version ist wußte ich nicht, aber jetzt bin ich wieder schlauer.</p>
<p dir="auto">Killer hab ich deinstalliert.</p>
]]></description><link>https://forum.iobroker.net/post/787257</link><guid isPermaLink="true">https://forum.iobroker.net/post/787257</guid><dc:creator><![CDATA[femi]]></dc:creator><pubDate>Tue, 05 Apr 2022 10:24:19 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 10:22:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/femi" aria-label="Profile: femi">@<bdi>femi</bdi></a> sagte in <a href="/post/787245">Alle Adapter starten jede Stunden um :17 neu.</a>:</p>
<blockquote>
<p dir="auto">Ich lösche das Script, dann sollte der Fehler weg sein.</p>
</blockquote>
<p dir="auto">Nein, du deinstallierst das Paket, in dem das Skript drin ist!<br />
Wird sich vermutlich 'killer' schimpfen.</p>
<blockquote>
<p dir="auto">ist mir wahrscheinlich grade von die Maus gelaufen</p>
</blockquote>
<p dir="auto">Einfach mal irgendwas irgendwie installieren? Gute Taktik. Macht alles viel einfacher.</p>
]]></description><link>https://forum.iobroker.net/post/787254</link><guid isPermaLink="true">https://forum.iobroker.net/post/787254</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 05 Apr 2022 10:22:17 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 10:19:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oliverio" aria-label="Profile: oliverio">@<bdi>oliverio</bdi></a><br />
warum ich das edu runtergeladen habe weiß ich auch nicht mehr, ist mir wahrscheinlich grade von die Maus gelaufen :-)<br />
Ich lösche das Script, dann sollte der Fehler weg sein.<br />
Und schon ist Ruhe!!<br />
Vielen Dank für die Hilfe!!<br />
Da wäre ich nicht drauf gekommen.</p>
]]></description><link>https://forum.iobroker.net/post/787245</link><guid isPermaLink="true">https://forum.iobroker.net/post/787245</guid><dc:creator><![CDATA[femi]]></dc:creator><pubDate>Tue, 05 Apr 2022 10:19:38 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 10:00:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/femi" aria-label="Profile: femi">@<bdi>femi</bdi></a></p>
<p dir="auto">das oben genannte Packet ist es ziemlich sicher.<br />
die syslog message entspricht dieser anweisung.<br />
<a href="https://salsa.debian.org/debian-edu-pkg-team/killer/-/blob/master/killer#L810" rel="nofollow ugc">https://salsa.debian.org/debian-edu-pkg-team/killer/-/blob/master/killer#L810</a></p>
<p dir="auto">das skript ist über 20 jahre alt (was nix schlechtes sein muss)</p>
<p dir="auto">killer entfernt alle hintergrundprozesse zu benutzern die nicht mehr eingeloggt sind.<br />
bei edu kann ich mir das als lern-linux vorstellen. wenn der benutzer nicht mehr da ist, dann werden auch alle seine gestarteten prozesse beendet.</p>
<p dir="auto">in diesem fall ist halt der benutzer iobroker nicht mehr angemeldet.</p>
]]></description><link>https://forum.iobroker.net/post/787236</link><guid isPermaLink="true">https://forum.iobroker.net/post/787236</guid><dc:creator><![CDATA[OliverIO]]></dc:creator><pubDate>Tue, 05 Apr 2022 10:00:31 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 09:51:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/femi" aria-label="Profile: femi">@<bdi>femi</bdi></a><br />
Das scheint mir ein Sonderfall bei Debian Edu zu sein.<br />
(Warum setzt man sowas 'exotisches' ein? Und was ist das für ein Release?)</p>
<p dir="auto"><a href="https://linux.debian.bugs.dist.narkive.com/ilpk6QBM/bug-890517-killer-s-cron-logs-out-users-once-per-hour" rel="nofollow ugc">https://linux.debian.bugs.dist.narkive.com/ilpk6QBM/bug-890517-killer-s-cron-logs-out-users-once-per-hour</a></p>
]]></description><link>https://forum.iobroker.net/post/787228</link><guid isPermaLink="true">https://forum.iobroker.net/post/787228</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 05 Apr 2022 09:51:59 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 09:48:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
da ist tatsächlich was drin.<br />
eine Datei namens killer<br />
mit diesem Inhalt:</p>
<pre><code>if [ -x /usr/sbin/killer ] ; then /usr/sbin/killer; fi
</code></pre>
]]></description><link>https://forum.iobroker.net/post/787227</link><guid isPermaLink="true">https://forum.iobroker.net/post/787227</guid><dc:creator><![CDATA[femi]]></dc:creator><pubDate>Tue, 05 Apr 2022 09:48:55 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 09:46:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/femi" aria-label="Profile: femi">@<bdi>femi</bdi></a></p>
<p dir="auto">Schau mal in die /etc/cron.hourly rein.</p>
]]></description><link>https://forum.iobroker.net/post/787221</link><guid isPermaLink="true">https://forum.iobroker.net/post/787221</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 05 Apr 2022 09:46:22 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 09:47:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/femi" aria-label="Profile: femi">@<bdi>femi</bdi></a></p>
<p dir="auto">hast du evtl so etwas installiert?<br />
<a href="https://packages.debian.org/bullseye/killer" rel="nofollow ugc">https://packages.debian.org/bullseye/killer</a></p>
<p dir="auto">sudo apt list --installed</p>
]]></description><link>https://forum.iobroker.net/post/787219</link><guid isPermaLink="true">https://forum.iobroker.net/post/787219</guid><dc:creator><![CDATA[OliverIO]]></dc:creator><pubDate>Tue, 05 Apr 2022 09:47:32 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 09:32:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a><br />
ich bin kein Freund von "neu aufsetzen" weil man dann nie weiß wo der Fehler lag.<br />
Das muß doch zu finden sein.</p>
]]></description><link>https://forum.iobroker.net/post/787210</link><guid isPermaLink="true">https://forum.iobroker.net/post/787210</guid><dc:creator><![CDATA[femi]]></dc:creator><pubDate>Tue, 05 Apr 2022 09:32:44 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 09:24:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/femi" aria-label="Profile: femi">@<bdi>femi</bdi></a> sagte in <a href="/post/787066">Alle Adapter starten jede Stunden um :17 neu.</a>:</p>
<blockquote>
<p dir="auto">VMware ESXI</p>
</blockquote>
<p dir="auto">ich kenn mich leider damit überhaupt nicht aus.</p>
<p dir="auto">irgend ein bash script laufen oder anderweitig ein script?</p>
<p dir="auto">vielleicht wäre es möglich/Sinnvoll, ne neue VM zu erstellen und ein Backup des ioBrokers einzuspielen.<br />
um zu sehen ob es dann immer noch passiert.</p>
]]></description><link>https://forum.iobroker.net/post/787205</link><guid isPermaLink="true">https://forum.iobroker.net/post/787205</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 05 Apr 2022 09:24:56 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 07:49:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a><br />
Das frage ich mich auch, im Crontab ist nichts eingetragen.<br />
Hab die cronjobs von allen Usern ausgelesen.</p>
<pre><code>root
no crontab for root
daemon
no crontab for daemon
bin
no crontab for bin
sys
no crontab for sys
sync
no crontab for sync
games
no crontab for games
man
no crontab for man
lp
no crontab for lp
mail
no crontab for mail
news
no crontab for news
uucp
no crontab for uucp
proxy
no crontab for proxy
www-data
no crontab for www-data
backup
no crontab for backup
list
no crontab for list
irc
no crontab for irc
gnats
no crontab for gnats
nobody
no crontab for nobody
_apt
no crontab for _apt
systemd-timesync
no crontab for systemd-timesync
systemd-network
no crontab for systemd-network
systemd-resolve
no crontab for systemd-resolve
messagebus
no crontab for messagebus
Debian-exim
no crontab for Debian-exim
nslcd
no crontab for nslcd
tcpdump
no crontab for tcpdump
sshd
no crontab for sshd
_rpc
no crontab for _rpc
statd
no crontab for statd
avahi
no crontab for avahi
munin
no crontab for munin
saned
no crontab for saned
colord
no crontab for colord
systemd-coredump
no crontab for systemd-coredump
iobroker
no crontab for iobroker
mysql
no crontab for mysql
</code></pre>
]]></description><link>https://forum.iobroker.net/post/787101</link><guid isPermaLink="true">https://forum.iobroker.net/post/787101</guid><dc:creator><![CDATA[femi]]></dc:creator><pubDate>Tue, 05 Apr 2022 07:49:30 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 06:48:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/femi" aria-label="Profile: femi">@<bdi>femi</bdi></a> die Frage, woher kommt das Kommando</p>
<pre><code>killer[1284180]: kill(15, 1283728) user=iobroker command=node nice=0
</code></pre>
]]></description><link>https://forum.iobroker.net/post/787092</link><guid isPermaLink="true">https://forum.iobroker.net/post/787092</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 05 Apr 2022 06:48:36 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Tue, 05 Apr 2022 04:53:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a><br />
VMware ESXI<br />
Debian 11</p>
<p dir="auto">hier die Einträge in /var/log/messages:</p>
<pre><code>Apr  5 06:10:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
Apr  5 06:15:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283728) user=iobroker command=node nice=0
Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283674) user=iobroker command=node nice=0
Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283707) user=iobroker command=node nice=0
Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283535) user=iobroker command=node nice=0
Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283583) user=iobroker command=node nice=0
Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283614) user=iobroker command=node nice=0
Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283629) user=iobroker command=node nice=0
Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283517) user=iobroker command=node nice=0
Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283644) user=iobroker command=node nice=0
Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283568) user=iobroker command=node nice=0
Apr  5 06:17:01 am-000c29d8c32a killer[1284180]: kill(15, 1283599) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284286) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284301) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284271) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284190) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284256) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284316) user=iobroker command=sh nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284223) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284208) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(23, 1284238) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284286) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284301) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284271) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284190) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284256) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284316) user=iobroker command=sh nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284223) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284208) user=iobroker command=node nice=0
Apr  5 06:17:36 am-000c29d8c32a killer[1284180]: kill(9, 1284238) user=iobroker command=node nice=0
Apr  5 06:20:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
Apr  5 06:25:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
Apr  5 06:30:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
Apr  5 06:35:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
Apr  5 06:38:19 am-000c29d8c32a sitesummary-client: error: unable to submit to 'http://sitesummary/cgi-bin/sitesummary-collector.cgi'
Apr  5 06:40:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
Apr  5 06:45:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
Apr  5 06:50:01 am-000c29d8c32a debian-edu-update-netblock: making sure netblock is disabled
</code></pre>
]]></description><link>https://forum.iobroker.net/post/787066</link><guid isPermaLink="true">https://forum.iobroker.net/post/787066</guid><dc:creator><![CDATA[femi]]></dc:creator><pubDate>Tue, 05 Apr 2022 04:53:02 GMT</pubDate></item><item><title><![CDATA[Reply to Alle Adapter starten jede Stunden um :17 neu. on Mon, 04 Apr 2022 21:33:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/femi" aria-label="Profile: femi">@<bdi>femi</bdi></a> sagte in <a href="/post/787015">Alle Adapter starten jede Stunden um :17 neu.</a>:</p>
<blockquote>
<p dir="auto">das wiederholt sich jede Stunde um 17 nach</p>
</blockquote>
<p dir="auto">ein cronjob vllt, nur die Frage woher<br />
worauf läuft der iobroker?</p>
]]></description><link>https://forum.iobroker.net/post/787051</link><guid isPermaLink="true">https://forum.iobroker.net/post/787051</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Mon, 04 Apr 2022 21:33:35 GMT</pubDate></item></channel></rss>
