  4. Iobroker findet Tasmota nicht...
    6.0k
66 Beiträge 9 Kommentatoren 9.0k Aufrufe 6 Beobachtet
    @gerdnutzinger sagte in Iobroker findet Tasmota nicht...:
    Sonoff habe ich neu gestartet und auch die Instanz (mehrmals)
    Negativ
    was steht jetzt im log?
    GerdNutzinger
    2022-04-03 21:40:12.674 - error: sonoff.1 (15088) Can not start Server Error: listen EADDRINUSE: address already in use 0.0.0.0:1883
    2022-04-03 21:43:07.928 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.1 (force=false, process=true)
    2022-04-03 21:43:07.929 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.1 send kill signal
    2022-04-03 21:43:07.929 - info: sonoff.1 (15088) Got terminate signal TERMINATE_YOURSELF
    2022-04-03 21:43:07.934 - info: sonoff.1 (15088) terminating
    2022-04-03 21:43:07.935 - info: sonoff.1 (15088) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-04-03 21:43:08.474 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-04-03 21:43:10.317 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.0 (force=false, process=true)
    2022-04-03 21:43:10.320 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.0 send kill signal
    2022-04-03 21:43:10.319 - info: sonoff.0 (22364) Got terminate signal TERMINATE_YOURSELF
    2022-04-03 21:43:10.321 - info: sonoff.0 (22364) terminating
    2022-04-03 21:43:10.321 - info: sonoff.0 (22364) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-04-03 21:43:10.858 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-04-03 21:43:11.133 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.1 started with pid 4800
    2022-04-03 21:43:12.024 - info: sonoff.1 (4800) starting. Version 2.4.7 in C:/iobroker/Zuhause/node_modules/iobroker.sonoff, node: v14.19.0, js-controller: 4.0.18
    2022-04-03 21:43:12.055 - info: sonoff.1 (4800) Starting MQTT authenticated server on port 1883
    2022-04-03 21:43:13.528 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.0 started with pid 12396
    2022-04-03 21:43:14.436 - info: sonoff.0 (12396) starting. Version 2.4.7 in C:/iobroker/Zuhause/node_modules/iobroker.sonoff, node: v14.19.0, js-controller: 4.0.18
    2022-04-03 21:43:14.457 - error: sonoff.0 (12396) Can not start Server Error: listen EADDRINUSE: address already in use 0.0.0.0:1883
    2022-04-03 21:43:17.211 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.0 (force=false, process=true)
    2022-04-03 21:43:17.212 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.0 send kill signal
    2022-04-03 21:43:17.208 - info: sonoff.0 (12396) Got terminate signal TERMINATE_YOURSELF
    2022-04-03 21:43:17.212 - info: sonoff.0 (12396) terminating
    2022-04-03 21:43:17.213 - info: sonoff.0 (12396) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-04-03 21:43:17.739 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-04-03 21:43:20.419 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.0 started with pid 6728
    2022-04-03 21:43:21.242 - info: sonoff.0 (6728) starting. Version 2.4.7 in C:/iobroker/Zuhause/node_modules/iobroker.sonoff, node: v14.19.0, js-controller: 4.0.18
    2022-04-03 21:43:21.261 - error: sonoff.0 (6728) Can not start Server Error: listen EADDRINUSE: address already in use 0.0.0.0:1883
    2022-04-03 21:43:21.809 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.1 (force=false, process=true)
    2022-04-03 21:43:21.811 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.1 send kill signal
    2022-04-03 21:43:21.810 - info: sonoff.1 (4800) Got terminate signal TERMINATE_YOURSELF
    2022-04-03 21:43:21.811 - info: sonoff.1 (4800) terminating
    2022-04-03 21:43:21.812 - info: sonoff.1 (4800) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-04-03 21:43:22.338 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-04-03 21:43:25.015 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.1 started with pid 9660
    2022-04-03 21:43:25.936 - info: sonoff.1 (9660) starting. Version 2.4.7 in C:/iobroker/Zuhause/node_modules/iobroker.sonoff, node: v14.19.0, js-controller: 4.0.18
    2022-04-03 21:43:25.966 - info: sonoff.1 (9660) Starting MQTT authenticated server on port 1883
    2022-04-03 21:45:50.582 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.0 (force=false, process=true)
    2022-04-03 21:45:50.595 - info: sonoff.0 (6728) Got terminate signal TERMINATE_YOURSELF
    2022-04-03 21:45:50.599 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.0 send kill signal
    2022-04-03 21:45:50.601 - info: sonoff.0 (6728) terminating
    2022-04-03 21:45:50.602 - info: sonoff.0 (6728) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-04-03 21:45:51.136 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-04-03 21:45:53.860 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.0 started with pid 25176
    2022-04-03 21:45:54.342 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.1 (force=false, process=true)
    2022-04-03 21:45:54.347 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.1 send kill signal
    2022-04-03 21:45:54.346 - info: sonoff.1 (9660) Got terminate signal TERMINATE_YOURSELF
    2022-04-03 21:45:54.349 - info: sonoff.1 (9660) terminating
    2022-04-03 21:45:54.351 - info: sonoff.1 (9660) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-04-03 21:45:54.883 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-04-03 21:45:54.889 - info: sonoff.0 (25176) starting. Version 2.4.7 in C:/iobroker/Zuhause/node_modules/iobroker.sonoff, node: v14.19.0, js-controller: 4.0.18
    2022-04-03 21:45:54.917 - info: sonoff.0 (25176) Starting MQTT authenticated server on port 1883
    2022-04-03 21:45:57.572 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.1 started with pid 24384
    2022-04-03 21:45:58.428 - info: sonoff.1 (24384) starting. Version 2.4.7 in C:/iobroker/Zuhause/node_modules/iobroker.sonoff, node: v14.19.0, js-controller: 4.0.18
    2022-04-03 21:45:58.454 - error: sonoff.1 (24384) Can not start Server Error: listen EADDRINUSE: address already in use 0.0.0.0:1883
    2022-04-03 21:46:14.666 - info: discovery.0 (15140) Discovering devices with a HF-LPB100 chipset...
    2022-04-03 21:46:14.670 - info: discovery.0 (15140) Discovering mDNS devices...
    2022-04-03 21:46:14.678 - info: discovery.0 (15140) Discovering ping devices...
    2022-04-03 21:46:14.720 - info: discovery.0 (15140) Discovering UPnP devices...
    2022-04-03 21:46:14.730 - info: discovery.0 (15140) Discovering wifi-mi-light devices...
    2022-04-03 21:46:14.744 - info: discovery.0 (15140) Done discovering serial devices. 5 packages received
    2022-04-03 21:46:14.781 - info: discovery.0 (15140) Done discovering tr064 devices. 27 packages received
    2022-04-03 21:46:15.430 - warn: discovery.0 (15140) halt
    2022-04-03 21:46:15.430 - info: discovery.0 (15140) Done discovering ping devices. 2 packages received
    2022-04-03 21:46:16.741 - info: discovery.0 (15140) Done discovering wifi-mi-light devices. 0 packages received
    2022-04-03 21:46:19.714 - info: discovery.0 (15140) Done discovering udp devices. 1 packages received
    2022-04-03 21:46:24.682 - info: discovery.0 (15140) Done discovering HF-LPB100 devices. 0 packages received
    2022-04-03 21:46:29.684 - info: discovery.0 (15140) Done discovering mdns devices. 0 packages received
    2022-04-03 21:46:29.725 - info: discovery.0 (15140) Done discovering upnp devices. 107 packages received
    2022-04-03 21:46:29.774 - info: discovery.0 (15140) Found 40 addresses
    2022-04-03 21:46:29.892 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:29.893 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:29.897 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:29.898 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:31.929 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:31.930 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:31.933 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:31.934 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:33.965 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:33.966 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:33.969 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:33.970 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:36.493 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:36.494 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:36.497 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:36.498 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:39.006 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:39.006 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:39.009 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:39.010 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:41.542 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:41.542 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:41.545 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:41.545 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:44.082 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:44.083 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:44.085 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:44.086 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:46.635 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:46.637 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:46.643 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:46.648 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:49.176 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:49.179 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:49.182 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:49.182 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:51.738 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:51.739 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:51.745 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:51.747 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:54.280 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:54.281 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:54.283 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:54.284 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:56.818 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:56.819 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:56.821 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:56.822 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:59.347 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:59.348 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:59.355 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:46:59.356 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:01.876 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:01.878 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:01.880 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:01.881 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:04.429 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:04.430 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:04.433 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:04.435 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:06.959 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:06.960 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:06.965 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:06.966 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:09.510 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:09.512 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:09.520 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:09.522 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:12.032 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:12.033 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:12.036 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:12.037 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:14.562 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:14.564 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:14.571 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:14.571 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:17.085 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:17.086 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:17.089 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:17.090 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:19.643 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:19.645 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:19.652 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:19.654 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:22.196 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:22.197 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:22.199 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:22.201 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:24.728 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:24.729 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:24.732 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:24.733 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:27.280 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:27.282 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:27.287 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:27.288 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:29.827 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:29.828 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:29.833 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:29.833 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:30.605 - info: ham.0 (14104) stateChange ham.0.BASICR2.BASICR2-History.S2R1 {"val":"U80XAAAAAAAAZOInAQ4BewTADwAAAAAAAAAAAQE=","ack":true,"ts":1649015250603,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1649015250603}
    2022-04-03 21:47:30.605 - info: ham.0 (14104) stateChange ham.0.Warmwasser.Warmwasser-History.S2R1 {"val":"QHMjAAAAAAATvtYnAQ4BCQbADwAAAAAAAAAAAQE=","ack":true,"ts":1649015250604,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1649015250604}
    2022-04-03 21:47:30.606 - info: ham.0 (14104) stateChange ham.0.Heizung-.Heizung--History.S2R1 {"val":"QHMjAAAAAAATvtYnAgECDgEDBsAPAAAAAAAAAAABAQ==","ack":true,"ts":1649015250604,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1649015250604}
    2022-04-03 21:47:30.606 - info: ham.0 (14104) stateChange ham.0.Garagentoreantrieb-.Garagentoreantrieb--History.S2R1 {"val":"QHMjAAAAAAATvtYnAQ4BAwbADwAAAAAAAAAAAQE=","ack":true,"ts":1649015250604,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1649015250604}
    2022-04-03 21:47:30.606 - info: ham.0 (14104) stateChange ham.0.Hinterhof-Strahler.Hinterhof-Strahler-History.S2R1 {"val":"QHMjAAAAAAATvtYnAQ4BAwbADwAAAAAAAAAAAQE=","ack":true,"ts":1649015250604,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1649015250604}
    2022-04-03 21:47:30.607 - info: ham.0 (14104) stateChange ham.0.Kamera-Fitness-.Kamera-Fitness--History.S2R1 {"val":"QHMjAAAAAAATvtYnAQ4BBwbADwAAAAAAAAAAAQE=","ack":true,"ts":1649015250604,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1649015250604}
    2022-04-03 21:47:31.716 - debug: onvif.0 (9816) startCameras
    2022-04-03 21:47:31.718 - debug: onvif.0 (9816) getDevices: []
    2022-04-03 21:47:31.719 - debug: onvif.0 (9816) setCameras: []
    2022-04-03 21:47:31.719 - debug: onvif.0 (9816) startCameras. cameras: {}
    2022-04-03 21:47:31.719 - warn: onvif.0 (9816) startCameras: Cameras/NVT unavailables
    2022-04-03 21:47:32.373 - error: discovery.0 (15140) eky error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:32.374 - error: discovery.0 (15140) emby error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:32.377 - warn: discovery.0 (15140) Onkyo AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:32.377 - warn: discovery.0 (15140) Pioneer AVR discovery error Error: addMembership EHOSTUNREACH
    2022-04-03 21:47:38.992 - warn: discovery.0 (15140) write: 10;VERSION;
    2022-04-03 21:47:54.343 - warn: discovery.0 (15140) write: 10;VERSION;
    2022-04-03 21:47:59.122 - warn: discovery.0 (15140) write: 10;VERSION;
    2022-04-03 21:48:05.402 - info: discovery.0 (15140) Discovery finished. Found new or modified 16 instances
    2022-04-03 21:48:05.442 - info: discovery.0 (15140) Discovery finished
    2022-04-03 21:48:20.528 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.0 (force=false, process=true)
    2022-04-03 21:48:20.530 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.0 send kill signal
    2022-04-03 21:48:20.530 - info: sonoff.0 (25176) Got terminate signal TERMINATE_YOURSELF
    2022-04-03 21:48:20.532 - info: sonoff.0 (25176) terminating
    2022-04-03 21:48:20.532 - info: sonoff.0 (25176) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-04-03 21:48:21.059 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-04-03 21:48:21.403 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.1 (force=false, process=true)
    2022-04-03 21:48:21.405 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.1 send kill signal
    2022-04-03 21:48:21.405 - info: sonoff.1 (24384) Got terminate signal TERMINATE_YOURSELF
    2022-04-03 21:48:21.411 - info: sonoff.1 (24384) terminating
    2022-04-03 21:48:21.412 - info: sonoff.1 (24384) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-04-03 21:48:21.948 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-04-03 21:48:23.738 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.0 started with pid 21332
    2022-04-03 21:48:24.665 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.1 started with pid 5224
    2022-04-03 21:48:24.919 - info: sonoff.0 (21332) starting. Version 2.4.7 in C:/iobroker/Zuhause/node_modules/iobroker.sonoff, node: v14.19.0, js-controller: 4.0.18
    2022-04-03 21:48:24.944 - info: sonoff.0 (21332) Starting MQTT authenticated server on port 1883
    2022-04-03 21:48:25.635 - info: sonoff.1 (5224) starting. Version 2.4.7 in C:/iobroker/Zuhause/node_modules/iobroker.sonoff, node: v14.19.0, js-controller: 4.0.18
    2022-04-03 21:48:25.663 - error: sonoff.1 (5224) Can not start Server Error: listen EADDRINUSE: address already in use 0.0.0.0:1883
    2022-04-03 21:48:26.847 - error: host.Gerdprivat(Zuhause) cannot check file: C:\iobroker\Zuhause\log\iobroker.2022-03-17.log - EPERM: operation not permitted, lstat 'C:\iobroker\Zuhause\log\iobroker.2022-03-17.log'
    MOD-EDIT: Code in code-tags gesetzt
    • G GerdNutzinger
      crunchipC Abwesend
      crunchipC Abwesend
      schalte mal deine mqtt Instanz aus
      und dann die Frage, brauchst du mqtt, wenn ja, dann musst du den Port ändern
      standard verwendet mqtt Port 1883/1884, somt kannst du bei sonoff auf Port 1885 gehen
      das heisst in deiner sonoff Instanz, sowie auf deinen sonoff Geräten den Port 1885 eintragen, dann sollte es funktionieren
      HomoranH G 3 Antworten Letzte Antwort
        @crunchip sagte in Iobroker findet Tasmota nicht...:
        wie ganz zu Beginn schon befürchtet
          @crunchip
          ich bin am Anfang und war heilfroh das ich IOBroker auf meinen Laptop gebracht habe 🥵
          Und jetzt bekomme ich die Basic nicht rein.
          ich werde später das System auf einen raspberry setzen.... Wenn alles so geht wie ich mir das vorgestelle
          hättest mal mit Raspi angefangen.
          die Installation geht da viel einfacher.
          kannst du mal iobroker list instances machen und das Ergebnis posten?
          GerdNutzinger
          @homoran said in Iobroker findet Tasmota nicht...:
          HomoranH crunchipC 2 Antworten Letzte Antwort
            GerdNutzinger
            @crunchip
            gemacht
            • G GerdNutzinger
              @gerdnutzinger da bin ich dann leider mangels Kenntnisse unter WIN raus.
              G 1 Antwort Letzte Antwort
              • G GerdNutzinger
                @crunchip
                gemacht
                crunchipC Abwesend
                crunchipC Abwesend
                gemacht
                falscher screen
                  ich klink mich aus, mein Akku ist auf 3%
                    GerdNutzinger
                    Ich probier mal morgen noch etwas rum.
                    Trotzdem ganz herzlichen DANK und einen schönen Abend noch!
                    • G GerdNutzinger
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @gerdnutzinger windows kenn ich auch nicht, aber dafür muss man denk ich in den Ordner iobroker wechseln
                      • G GerdNutzinger
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @gerdnutzinger hast du das gemacht, was ich geschrieben hab?
                          GerdNutzinger
                          @crunchip said in Iobroker findet Tasmota nicht...:
                          MQTT braucht man doch um es in IOBroker zubringen (habe ich gelesen in Netz)
                          Habe bei Sonoff - MQTT-Einstellungen und bei Instanzeinstellungen: sonoff.0 auch 1885 eingetragen.
                          Ergebnis: negativ
                          • G GerdNutzinger
                            Ergebnis: negativ
                            crunchipC Abwesend
                            crunchipC Abwesend
                            was?
                            nein, es gibt den mqtt Adapter, dieser verwendet den Port 1883.
                            es gibt aber auch den sonoff Adapter, der funktioniert "ähnlich" und nimmt dir eine Menge Arbeit ab.
                            mit dem mqtt Adapter kannst du dir alle Geräte , die diese "Sprache sprechen" in den iobroker holen.
                            der sonoff Adapter ist speziel, nur für sonoff/tasmota Geräte gedacht, dieser legt dir sämtliche benötigte Datenpunkte an, was dir die Arbeit erspart und ist leichter in der weiter Verarbeitung.
                            Also entweder oder
                            beide Adapter dürfen aber nicht auf dem selben Port laufen.
                            • 1 Ist die mqtt Instanz ausgeschaltet?
                            • 2 sonoff Instanz Port 1885 eingetragen?
                            • 3 im sonoff, Port 1885 eingestellt?
                            • 4 was zeigt das log, wenn du die Instanz startest?
                              was?
                              Also entweder oder
                              GerdNutzinger
                              was?
                              Also entweder oder
                              • 1 Ist die mqtt Instanz ausgeschaltet? erledigt
                              • 2 sonoff Instanz Port 1885 eingetragen? erledigt
                              • 3 im sonoff, Port 1885 eingestellt? erledigt
                              2022-04-04 11:43:21.648 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.0 (force=false, process=true)
                              2022-04-04 11:43:21.650 - info: host.Gerdprivat(Zuhause) stopInstance system.adapter.sonoff.0 send kill signal
                              2022-04-04 11:43:21.650 - info: sonoff.0 (25340) Got terminate signal TERMINATE_YOURSELF
                              2022-04-04 11:43:21.652 - info: sonoff.0 (25340) terminating
                              2022-04-04 11:43:21.653 - info: sonoff.0 (25340) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-04-04 11:43:22.196 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-04-04 11:43:24.855 - info: host.Gerdprivat(Zuhause) instance system.adapter.sonoff.0 started with pid 26452
                              2022-04-04 11:43:25.673 - info: sonoff.0 (26452) starting. Version 2.4.7 in C:/iobroker/Zuhause/node_modules/iobroker.sonoff, node: v14.19.0, js-controller: 4.0.18
                              2022-04-04 11:43:25.695 - info: sonoff.0 (26452) Starting MQTT authenticated server on port 1885
                              2022-04-04 11:43:29.772 - error: host.Gerdprivat(Zuhause) cannot check file: C:\iobroker\Zuhause\log\iobroker.2022-03-17.log - EPERM: operation not permitted, lstat 'C:\iobroker\Zuhause\log\iobroker.2022-03-17.log'
                              • G GerdNutzinger
                                was?
                                Also entweder oder
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @gerdnutzinger
                                ok, das mit dem Port ist nun vom Tisch, jedoch hast du da noch ein anderes Problem, welches ich aber gerade nicht zuordnen kann
                                  @GerdNutzinger
                                  hast du deinen zukünftigen Pi schon?
                                  Dann würde ich mal damit anfangen.
                                    @GerdNutzinger
                                    GerdNutzinger
                                    @GerdNutzinger
                                    Nein, habe jetzt mal geschaut und stelle fest das die Systeme ohne Betriebssyteme sind.
                                    Linux neu aufsetzten hatte ich noch nie gemacht.
                                    Wäre das Angebot unten ok?
                                    https://www.ebay.de/itm/125222936766?epid=7035054216&hash=item1d27de60be%3Ag%3AYJYAAOSwWoBiRzoo&LH_BIN=1&LH_ItemCondition=1000
                                    • G GerdNutzinger
                                      @GerdNutzinger
                                      ist überhaupt kein Problem.
                                      Bei raspberrypi.org runterladen und auf SDKarte schreiben
                                      im Moment leider ja. der 4er wird in Gold aufgewogen.
                                      vielleicht wäre der c4 etwas
                                      https://www.reichelt.de/odroid-c4-4x-2-0-ghz-4-gb-ram-odroid-c4-p283467.html?&trstct=pol_8&nbc=1
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @homoran sagte in Iobroker findet Tasmota nicht...:
                                        Macht Preislich aber keinen Unterschied, wenn Netzteil + Gehäuse noch dazu kommen.
                                        Leider lässt die aktuelle Situation es nicht zu, günstige Hardware zu finden.
                                          GerdNutzinger
                                          schrieb am zuletzt editiert von GerdNutzinger
                                          @crunchip
                                          Habe jetzt mal bei EBay bestellt. SollMittwoch da sein.
                                          Ich würde mich dann melden wenn ich wieder auf Probleme stoße.
                                          Ganz herzliches DANKESCHÖN an alle die bis jetzt geholfen haben.👍 🌟
