  4. js-controller Update schlägt immer fehl
    6.0k
24 Beiträge 5 Kommentatoren 2.0k Aufrufe 4 Beobachtet
  • P pjo123456
    @apollon77
    Also nach dem Updateversuch ist admin nicht mehr erreichbar. Die state.jjson finde ich in: /opt/iobroker/iobroker-data und dort auch eine state.json.bak.
    Wenn ich in der /opt/iobroekr/iobroker-data/iobroker.json nachsehe, dann finde ich dataDir mehrmals. Hier mal der Inhalt:
      "system": {
        "memoryLimitMB": 0,
        "hostname": "",
        "statisticsInterval": 15000,
        "checkDiskInterval": 300000
      "multihostService": {
        "enabled": false,
        "secure": true,
        "password": "$/aes-192-cbc:28a379506c10d56d6f67db5c2290f15d:37ee00d646c76cc95210975ac782ff1d",
        "persist": false
      "network": {
        "IPv4": true,
        "IPv6": true,
        "bindAddress": null,
        "useSystemNpm": true
      "objects": {
        "type": "jsonl",
        "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984>
        "host": "0.0.0.0",
        "port": 9001,
        "user": "",
        "pass": "",
        "noFileCache": false,
        "connectTimeout": 2000,
        "dataDir": "f",
        "options": {
          "auth_pass": null,
          "enableReadyCheck": true,
          "host": "0.0.0.0",
          "port": 9001,
          "db": 0,
          "family": 0,
          "password": null,
          "autoResubscribe": false,
          "connectionName": "host.iobroker-master",
          "retry_max_delay": 5000
        "maxQueue": 1000
      "states": {
        "type": "jsonl",
        "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
        "host": "0.0.0.0",
        "port": 9000,
        "maxQueue": 1000,
        "options": {
          "auth_pass": null,
          "host": "0.0.0.0",
          "port": 9000,
          "db": 0,
          "family": 0,
          "password": null,
        "dataDir": "f"
      "log": {
        "level": "info",
        "maxDays": 7,
        "noStdout": true,
        "transport": {
          "file1": {
            "type": "file",
            "enabled": true,
            "filename": "log/iobroker",
            "fileext": ".log",
            "maxsize": null,
            "maxFiles": null
          "syslog1": {
            "type": "syslog",
            "enabled": false,
            "host": "localhost",
            "host_comment": "The host running syslogd, defaults to localhost.",
            "port_comment": "The port on the host that syslog is running on, defaults to syslogd's def>
            "protocol": "udp4",
            "protocol_comment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect>
            "path_comment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for>
            "facility_comment": "Syslog facility to use (Default: local0).",
      "states": {
        "type": "jsonl",
        "host": "0.0.0.0",
        "port": 9000,
        "maxQueue": 1000,
        "options": {
          "auth_pass": null,
          "host": "0.0.0.0",
          "port": 9000,
          "db": 0,
          "family": 0,
          "password": null,
        "dataDir": "f"
      "log": {
        "level": "info",
        "maxDays": 7,
        "noStdout": true,
        "transport": {
          "file1": {
            "type": "file",
            "enabled": true,
            "fileext": ".log",
            "maxsize": null,
            "maxFiles": null
          "syslog1": {
            "type": "syslog",
            "enabled": false,
            "protocol": "udp4",
            "localhost": "iobroker",
            "localhost_comment": "Host to indicate that log messages are coming from (Default: localho>
            "sysLogType_comment": "The type of the syslog protocol to use (Default: BSD).",
            "app_name_comment": "The name of the application (Default: process.title).",
            "eol_comment": "The end of line character to be added to the end of the message (Default: >
      "dataDirComment": "Always relative to iobroker.js-controller/",
      "dataDir": "../../iobroker-data/"
    @pjo123456 sagte in js-controller Update schlägt immer fehl:
    "dataDir": "f"
    Das ist dein Fehler. Wie auch immer das da rein kommt. machs mal raus. Ist im "states" Sektion
    Dr. BakteriusD 1 Antwort Letzte Antwort
    • apollon77A apollon77
      "dataDir": "f"
      Dr. BakteriusD Online
      Dr. Bakterius
      @pjo123456 - @apollon77 sagte in js-controller Update schlägt immer fehl:
      Nicht nur dort!
        Nicht nur dort!
        @dr-bakterius Ooohh stimmt ... hatte es in objects glatt übersehen
        P 1 Antwort Letzte Antwort
          pjo123456
          Im Moment komme ich gar nicht weiter. Da die Installation vom ioBroker ja nicht mehr funktionierte, habe ich den ioBroker per Installscript neu installiert. Ein Rückspielen des Backups funktioniert aber nicht. Das war aber auch schon immer so. Irgendwann irgendwie habe ich es dann hinbekommen. Aber im Moment geht gar nichts.
          Wenn ich Restore übersTerminal mache, dann meckert ioBroker über die neue js-controller Version. Das Backup wurde mit einer älteren js-controller Version gemacht. Ich soll eine ältere Version installieren. Wenn ich das mache komme ich danach auch nicht mehr auf die Admin-Weboberfläche.
          Ich bin mit meinem Latein am Ende. Vorschläge?
          mfg pjo123456
          Moin aus dem Norden…
          • P pjo123456
            mfg pjo123456
            crunchipC Abwesend
            crunchipC Abwesend
            Weil und warum, mit welchen Fehlermeldungen?
            Vorschläge?
            wie ist denn der aktuell ist Stand?
              Vorschläge?
              pjo123456
              @crunchip Der aktuelle Stand ist, das gar nichts mehr funktioniert. Nach der Neuinstallation möchte ich das Backup zurückspielen. Dazu installiere ich den History und Javascript Adapter und konfiguriere den Backitup Adapter. Danach starte ich das Restore. Es startet und danach sehe ich nur einen drehenden bunten Kreis für Stunden. Admin ist nicht erreichbar.
              Gibt es überhaupt eine Möglichkeit, nach einer Neuinstallation mit neuer js-controller und admin-version eine Backup zurückzuspielen mit einer niedrigeren admin und js-controller version?
              apollon77A crunchipC 2 Antworten Letzte Antwort
              • P pjo123456
                @pjo123456 also wenn Backup sagt das die Controller Version nicht passt dann bitte wie an sich in der Fehlermeldung gesagt das restore mit --force aufrufen dann wird das ignoriert.
                Steht oben im ersten post und der faq im
                Zweiten post beschrieben. Da steht auch wie du eine ältere Version direkt per npm installieren kannst.
                Am besten bitte wirklich Screenshots Bzw bei console die Text Infos hier posten. Dann sieht man viel besser was wirklich los ist anstelle von Beschreibungen.
                  pjo123456
                  schrieb am zuletzt editiert von pjo123456
                  @apollon77 Moin!
                  Mit --force hatte ich es auch probiert. Nach ca. 20 Versuchen habe ich nun zumindest das System wieder am Laufen. Mit aktuellem js-controller. Keine Ahnung was jetzt genau anders gelaufen ist.
                  • P pjo123456
                    @apollon77 Moin!
                    @pjo123456 Naja ohne Logs oder andere Details der fehlgeschlagenen Versuche schwierig was dazu zu sagen
                    • P pjo123456
                      crunchipC Abwesend
                      crunchipC Abwesend
                      Es wird nur der backup Adapter eingerichtet, nichts anderes.
                      Wie schon geschrieben, wenn denn Versionen nicht passen. Mach es schritt für schritt und poste die Meldungen, sonst kann man nicht helfen
                      • apollon77A Offline
                        Und dazu: Der Restore Prozess hat sich mit js-controller 4.0 geändert und kann nun VIEEL LÄÄNGER dauern. Zuerst werden alle adapter deinstalliert und richtet der erste Start das alles wieder ein wie es sein muss... Aber sind alles nur annahmen weil Unklar ist wo und bei was es hier genau hängt
                          pjo123456
                          OK, beim nächsten Update werde ich alle logs speichern.
                          Da ja nun alles wieder hergestellt ist, taucht natürlich das Problem vom Anfang wieder auf. Diese komischen Einträge ("dataDir": "f"). Kann ich die iobroker.json mit dem nano Editor bearbeiten? Die Zeilen einfach löschen?
                          • P pjo123456
                            @pjo123456 ja einfach editieren mit Texteditor
                              pjo123456
                              Habe die iobroker.json geändert. Der iobroker läuft noch. 😊 Aber irgendwie scheint sich ein Fehler eingeschlichen zu haben, denn jetzt geht Flot und Vis nicht mehr. Es erscheint dann nur eine weiße Seite mit "File edit.html not found: {}". Nehme ich meine gesicherte iobroker.json wieder ist alles ok.
                              Kann sich jemand mal die iobroker.json ansehen? Und eventuell den Fehler finden?
                              die originale Datei ist weiter oben zu sehen. Und so habe ich sie jetzt geändert.
                                "system": {
                                  "memoryLimitMB": 0,
                                  "hostname": "",
                                  "enabled": false,
                                  "secure": true,
                                  "persist": false
                                "network": {
                                  "IPv4": true,
                                  "IPv6": true,
                                "objects": {
                                  "type": "jsonl",
                                  "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
                                  "host": "0.0.0.0",
                                  "port": 9001,
                                  "user": "",
                                  "pass": "",
                                  "options": {
                                    "auth_pass": null,
                                    "host": "0.0.0.0",
                                    "port": 9001,
                                    "db": 0,
                                    "family": 0,
                                    "password": null,
                                  "maxQueue": 1000
                                "states": {
                                  "type": "jsonl",
                                  "host": "0.0.0.0",
                                  "port": 9000,
                                  "maxQueue": 1000,
                                  "options": {
                                    "auth_pass": null,
                                    "host": "0.0.0.0",
                                    "port": 9000,
                                    "db": 0,
                                    "family": 0,
                                    "password": null,
                                "log": {
                                  "level": "info",
                                  "maxDays": 7,
                                  "noStdout": true,
                                  "transport": {
                                    "file1": {
                                      "type": "file",
                                      "enabled": true,
                                      "fileext": ".log",
                                      "maxsize": null,
                                      "maxFiles": null
                                    "syslog1": {
                                      "type": "syslog",
                                      "enabled": false,
                                      "port_comment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
                                      "protocol": "udp4",
                                      "protocol_comment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
                                      "path_comment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
                                      "localhost_comment": "Host to indicate that log messages are coming from (Default: localhost).",
                                      "eol_comment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
                              Aber wie gesagt, es muss noch etwas falsch sein. Ich hoffe, jemand kann das finden oder meine Orginaldatei im dritten Post entsprechend ändern. Danke!
                              mfg pjo123456
                              • P pjo123456
                                  "system": {
                                    "memoryLimitMB": 0,
                                    "hostname": "",
                                    "enabled": false,
                                    "secure": true,
                                    "persist": false
                                  "network": {
                                    "IPv4": true,
                                    "IPv6": true,
                                  "objects": {
                                    "type": "jsonl",
                                    "host": "0.0.0.0",
                                    "port": 9001,
                                    "user": "",
                                    "pass": "",
                                    "options": {
                                      "auth_pass": null,
                                      "host": "0.0.0.0",
                                      "port": 9001,
                                      "db": 0,
                                      "family": 0,
                                      "password": null,
                                    "maxQueue": 1000
                                  "states": {
                                    "type": "jsonl",
                                    "host": "0.0.0.0",
                                    "port": 9000,
                                    "maxQueue": 1000,
                                    "options": {
                                      "auth_pass": null,
                                      "host": "0.0.0.0",
                                      "port": 9000,
                                      "db": 0,
                                      "family": 0,
                                      "password": null,
                                  "log": {
                                    "level": "info",
                                    "maxDays": 7,
                                    "noStdout": true,
                                    "transport": {
                                      "file1": {
                                        "type": "file",
                                        "enabled": true,
                                        "fileext": ".log",
                                        "maxsize": null,
                                        "maxFiles": null
                                      "syslog1": {
                                        "type": "syslog",
                                        "enabled": false,
                                        "protocol": "udp4",
                                mfg pjo123456
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @pjo123456 bin grad nur am handy, aber fehlen da nicht ein paar Zeilen?
                                Eigentlich sind es dich nur 3 Zeilen zum entfernen.
                                29, 62 und 106
                                  29, 62 und 106
                                  pjo123456
                                  Ich glaube im Post mit der iobroker.json ist beim Kopieren etwas schiefgelaufen. Da ist ein Teil doppelt. Habe jetzt noch einmal die Sicherungskopie genommen.
                                  Wenn ich einfach nur die Zeilen mit "dataDir": "f", lösche kann ich die Admin Oberfläche nicht mehr erreichen.
                                  Hier noch einmal die Originaldatei:
                                    "system": {
                                      "memoryLimitMB": 0,
                                      "hostname": "",
                                      "enabled": false,
                                      "secure": true,
                                      "persist": false
                                    "network": {
                                      "IPv4": true,
                                      "IPv6": true,
                                    "objects": {
                                      "type": "jsonl",
                                      "host": "0.0.0.0",
                                      "port": 9001,
                                      "user": "",
                                      "pass": "",
                                      "dataDir": "f",
                                      "options": {
                                        "auth_pass": null,
                                        "host": "0.0.0.0",
                                        "port": 9001,
                                        "db": 0,
                                        "family": 0,
                                        "password": null,
                                      "maxQueue": 1000
                                    "states": {
                                      "type": "jsonl",
                                      "host": "0.0.0.0",
                                      "port": 9000,
                                      "maxQueue": 1000,
                                      "options": {
                                        "auth_pass": null,
                                        "host": "0.0.0.0",
                                        "port": 9000,
                                        "db": 0,
                                        "family": 0,
                                        "password": null,
                                      "dataDir": "f"
                                    "log": {
                                      "level": "info",
                                      "maxDays": 7,
                                      "noStdout": true,
                                      "transport": {
                                        "file1": {
                                          "type": "file",
                                          "enabled": true,
                                          "fileext": ".log",
                                          "maxsize": null,
                                          "maxFiles": null
                                        "syslog1": {
                                          "type": "syslog",
                                          "enabled": false,
                                          "protocol": "udp4",
                                  Und hier meine Änderungen:
                                    "system": {
                                      "memoryLimitMB": 0,
                                      "hostname": "",
                                      "enabled": false,
                                      "secure": true,
                                      "persist": false
                                    "network": {
                                      "IPv4": true,
                                      "IPv6": true,
                                    "objects": {
                                      "type": "jsonl",
                                      "host": "0.0.0.0",
                                      "port": 9001,
                                      "user": "",
                                      "pass": "",
                                      "options": {
                                        "auth_pass": null,
                                        "host": "0.0.0.0",
                                        "port": 9001,
                                        "db": 0,
                                        "family": 0,
                                        "password": null,
                                      "maxQueue": 1000
                                    "states": {
                                      "type": "jsonl",
                                      "host": "0.0.0.0",
                                      "port": 9000,
                                      "maxQueue": 1000,
                                      "options": {
                                        "auth_pass": null,
                                        "host": "0.0.0.0",
                                        "port": 9000,
                                        "db": 0,
                                        "family": 0,
                                        "password": null,
                                    "log": {
                                      "level": "info",
                                      "maxDays": 7,
                                      "noStdout": true,
                                      "transport": {
                                        "file1": {
                                          "type": "file",
                                          "enabled": true,
                                          "fileext": ".log",
                                          "maxsize": null,
                                          "maxFiles": null
                                        "syslog1": {
                                          "type": "syslog",
                                          "enabled": false,
                                          "protocol": "udp4",
                                  • P pjo123456
                                      "system": {
                                        "memoryLimitMB": 0,
                                        "hostname": "",
                                        "enabled": false,
                                        "secure": true,
                                        "persist": false
                                      "network": {
                                        "IPv4": true,
                                        "IPv6": true,
                                      "objects": {
                                        "type": "jsonl",
                                        "host": "0.0.0.0",
                                        "port": 9001,
                                        "user": "",
                                        "pass": "",
                                        "dataDir": "f",
                                        "options": {
                                          "auth_pass": null,
                                          "host": "0.0.0.0",
                                          "port": 9001,
                                          "db": 0,
                                          "family": 0,
                                          "password": null,
                                        "maxQueue": 1000
                                      "states": {
                                        "type": "jsonl",
                                        "host": "0.0.0.0",
                                        "port": 9000,
                                        "maxQueue": 1000,
                                        "options": {
                                          "auth_pass": null,
                                          "host": "0.0.0.0",
                                          "port": 9000,
                                          "db": 0,
                                          "family": 0,
                                          "password": null,
                                        "dataDir": "f"
                                      "log": {
                                        "level": "info",
                                        "maxDays": 7,
                                        "noStdout": true,
                                        "transport": {
                                          "file1": {
                                            "type": "file",
                                            "enabled": true,
                                            "fileext": ".log",
                                            "maxsize": null,
                                            "maxFiles": null
                                          "syslog1": {
                                            "type": "syslog",
                                            "enabled": false,
                                            "protocol": "udp4",
                                      "system": {
                                        "memoryLimitMB": 0,
                                        "hostname": "",
                                        "enabled": false,
                                        "secure": true,
                                        "persist": false
                                      "network": {
                                        "IPv4": true,
                                        "IPv6": true,
                                      "objects": {
                                        "type": "jsonl",
                                        "host": "0.0.0.0",
                                        "port": 9001,
                                        "user": "",
                                        "pass": "",
                                        "options": {
                                          "auth_pass": null,
                                          "host": "0.0.0.0",
                                          "port": 9001,
                                          "db": 0,
                                          "family": 0,
                                          "password": null,
                                        "maxQueue": 1000
                                      "states": {
                                        "type": "jsonl",
                                        "host": "0.0.0.0",
                                        "port": 9000,
                                        "maxQueue": 1000,
                                        "options": {
                                          "auth_pass": null,
                                          "host": "0.0.0.0",
                                          "port": 9000,
                                          "db": 0,
                                          "family": 0,
                                          "password": null,
                                      "log": {
                                        "level": "info",
                                        "maxDays": 7,
                                        "noStdout": true,
                                        "transport": {
                                          "file1": {
                                            "type": "file",
                                            "enabled": true,
                                            "fileext": ".log",
                                            "maxsize": null,
                                            "maxFiles": null
                                          "syslog1": {
                                            "type": "syslog",
                                            "enabled": false,
                                            "protocol": "udp4",
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @pjo123456 zeile 61 ist ein Komma zu viel
                                      pjo123456
                                      @crunchip OK, das Komma habe ich entfernt. Admin ist wieder erreichbar aber Flot und Vis nicht mehr.
                                      • P pjo123456
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @pjo123456 ich kann bei mir gerade nicht nachsehen wie es aussehen müsste. Bin nur am Handy.
                                        Daher kann ich da nicht weiterhelfen
                                          naja Du hast mit dem modifizierten DataDir dir ggf ein blödes EI gelegt weil DU jetzt Meta Daten an zwei verschiedenen stellen hast
                                          Daher: Schau mal ob unter /opt/iobroker/node_modules/iobroker.js-controller/f/iobroker-data Daten liegen und welche
                                          Schau auch ob in /opt/iobroker/node_modules/iobroker.js-controller/f/iobroker-data/files Daten liegen - da könnten jetzt deine Vis Files liegen. Das musst DU jetzt anschauen und irgendwie zusammenführen.
                                          Kannst versuchen ein backup /opt/iobroker/iobroker-data/* zu machen zur sicherheit und dann kannst du versuchen /opt/iobroker/node_modules/iobroker.js-controller/f/iobrokee-data/files/* mal in /opt/iobroker/iobroker-data/files/ reinzukopieren.
                                          Danach am besten noch ein "iob upload all" ausführen.
                                          Die Frage ist halt wie lange das bei Dir so lief.
                                          Wenn du aber pech hast ist unter /opt/iobroker/node_modules/iobroker.js-controller/f/ nichts mehr weil du durch den js.controller update ein neues npm Paket installiert hast und der das alles was "Zuviel" war weggeräumt hat. Dann kannst Du nur schauen ob Du aus der Zeit wo es falsch war ein Backup hast was du mal wegkopiert hast und was Du ggf nutzen kannst.
                                          Wenn das alles nicht ist dann habe ich leider Bad news: Dann musst Du von vorne anfangen.
                                          EIn "iob upload all" sollte dazu führen das alle Adapter tun. Ein pot angelegtes Vis wäre dann aber weg.
