  3. Entwicklung
  4. [Neuer Adapter] Senec Home Adapter
photovoltaiksenecadapter
485 Beiträge 73 Kommentatoren 147.5k Aufrufe 69 Beobachtet
  • O Offline
    O Offline
    oxident
    Hallo!
    Danke für den Adapter. Klingt wirklich gut, aber:
    Habe heute zum ersten Mal den Adapter installiert (1.3.5-beta) und leider springt er kurz nach dem Start direkt auf Fehler. Objekte sind wohl angelegt worden und auch mit richtigen Daten befüllt.
    Im Log steht jedoch:
    senec.0
    2022-03-03 18:56:23.613	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    senec.0
    2022-03-03 18:56:23.612	error	this.log.warning is not a function
    senec.0
    2022-03-03 18:56:23.611	error	TypeError: this.log.warning is not a function at Senec.updateSelfStatHelper (/opt/iobroker/node_modules/iobroker.senec/main.js:395:14) at async Senec.updateSelfStat (/opt/iobroker/node_modules/iobroker.senec/main.js:358:3) at async Senec.checkUpdateSelfStat (/opt/iobroker/node_modules/iobroker.senec/main.js:324:4) at async Senec.doState (/opt/iobroker/node_modules/iobroker.senec/main.js:283:5)
    senec.0
    2022-03-03 18:56:23.611	error	unhandled promise rejection: this.log.warning is not a function
    senec.0
    2022-03-03 18:56:23.611	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    senec.0
    2022-03-03 18:56:23.606	error	this.log.warning is not a function
    senec.0
    2022-03-03 18:56:23.606	error	TypeError: this.log.warning is not a function at Senec.updateSelfStatHelper (/opt/iobroker/node_modules/iobroker.senec/main.js:395:14) at runMicrotasks (<anonymous>) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9) at async Senec.updateSelfStat (/opt/iobroker/node_modules/iobroker.senec/main.js:358:3) at async Senec.checkUpdateSelfStat (/opt/iobroker/node_modules/iobroker.senec/main.js:324:4) at async Senec.doState (/opt/iobroker/node_modules/iobroker.senec/main.js:283:5)
    senec.0
    2022-03-03 18:56:23.605	error	unhandled promise rejection: this.log.warning is not a function
    senec.0
    2022-03-03 18:56:23.604	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Es handelt sich um einen v3-Speicher.
    Mache ich etwas falsch? ;-)
    N 1 Antwort Letzte Antwort
    • O oxident
      Hallo!
      senec.0
      senec.0
      senec.0
      senec.0
      senec.0
      senec.0
      senec.0
      senec.0
      senec.0
      N Offline
      N Offline
      nobl
      @oxident Nein - Du machst nichts falsch :-)
      Da hab ich mich einfach verschrieben. Neue Version ist unterwegs.
      In Deinem Fall würde mich aber im Nachgang dann interessieren, was genau das Problem jetzt ist.
      Sollte also ein Warning im log auftauchen (mit der neuen Version), dann bitte Ticket auf Github, da ansonsten die Berechnung der Werte für Autarkie, etc. bei Dir falsch sein wird.
      O 1 Antwort Letzte Antwort
      • N nobl
        O Offline
        O Offline
        oxident
        @nobl Mein Problem ist, dass der Adapter direkt nach dem Start wieder auf "Rot" gesprungen ist und sich nach obigen Fehlermeldungen dann auch nicht mehr aktualisiert hat. Ich habe daraufhin erstmal die letzte "Stable" installiert und alles ist gut.
        Werde schnellstmöglich die neue Version probieren.
        Danke für Deine Bemühungen. Ist wirklich eine enorme Erleichterung mit dem Adapter!
        • O oxident
          N Offline
          N Offline
          nobl
          @oxident Konntest Du zwischenzeitlich die aktuelle Version testen?
          Da das Problem scheinbar bisher nur bei Dir aufgetreten ist, interessiert es mich natürlich umso mehr, ob damit wieder alles geht.
          (Wobei dann zumindest ein paar Warnings fliegen sollten - denn scheinbar wurde ein Referenzwert gespeichert, der höher ist, als der aktuell von der Senec gelieferte Wert ... das irritiert mich schon etwas.)
          • N nobl
            O Offline
            O Offline
            oxident
            @nobl said in [Neuer Adapter] Senec Home Adapter:
            Alles perfekt ... kein einziger Fehler und keine Warnung mehr!
            SokomotoS N 2 Antworten Letzte Antwort
            • O oxident
              SokomotoS Offline
              SokomotoS Offline
              Sokomoto
              @oxident sagte in [Neuer Adapter] Senec Home Adapter:
              ...ja doch es gibt Warnungen
              https://forum.iobroker.net/topic/53228/sicherheitswarnung-senec-speicher?_=1646857587108
              • SokomotoS Sokomoto
                O Offline
                O Offline
                oxident
                schrieb am zuletzt editiert von oxident
                @sokomoto Naja, den Zustand haben wir ja alle derzeit :-(
                Aber der Adapter läuft ohne Warnungen. BMS_READY_FLAG ist halt false.
                • O oxident
                  N Offline
                  N Offline
                  nobl
                  @oxident so möchte ich das haben :-) Danke für die Rückmeldung.
                  Und ja - für den Rest ... da kann der Adapter nur wenig helfen :(
                  L 1 Antwort Letzte Antwort
                  • N nobl
                    Loely
                    @nobl
                    Eine blöde Anfänger Frage, wie bekomme ich den Adapter geupdated, normalerweise gibt es ja auf der Iobroker-Oberfläche bei jedem Adapter einen Aktualisieren-Button, den gibt es bei mir beim Senec-Adapter aber leider nicht?
                    Danke und viele Grüsse
                    Loely
                    • L Loely
                      @nobl
                      Loely
                      N Offline
                      N Offline
                      nobl
                      @loely wenns kein update gibt, dann gibts keinen button :)
                      Ansonsten ist der Adapter nur im latest Repository - nicht im stable.
                      frankthegreatF 1 Antwort Letzte Antwort
                      • J juergenkir
                        ich habe seit 7 Monaten einen V3hybrid und nutze seit 4 Wochen den IoBroker.
                        Wollte mich zuerst herzlich bedanken, dass es diesen Adapter gibt. Dadurch habe ich die Informationen zu meiner PV-Anlage, die ich mir erhofft hatte.
                        Eine Frage habe ich zu low und high prio Datenpunkten:
                        Der Datenpunkt senec.0.WALLBOX.APPARENT_CHARGING_POWER.0 wird als low priority klassifiziert und daher nur alle 60 Minuten übertragen.
                        Das ist aus meiner Sicht nicht praktikabel. Ich würde diesen Wert gerne öfter abgreifen.
                        Weiter oben im Forum hatte ich gelesen, dass das in der source geändert werden muss.
                        Ist das noch aktuell oder gibt es da etwas Neueres?
                        Was muss ich da genau tun? (sorry, bin Anfänger)
                        Hier mal meine Visualisierung mit Grafana:
                        lustig29
                        @juergenkir Wow, die View sieht ja klasse aus. Würdest du sie mit mir teilen?
                        • O Offline
                          O Offline
                          oxident
                          Hat einer von Euch schon mal erlebt, dass ein zu häufiges Abfragen des Speichers dazu führt, dass dieser die Verbindung zum Enfluri verliert?
                          Bei mir ist es jetzt spontan dazu gekommeb, dass er mehrmals täglich im Log "Lost connection to powermeter" schreibt und die Werte des Enfluri dann alle auf 0 stehen.
                          Hoffe, es hat nichts mit der Verkabelung zu tun :-(
                          Update: Es lag an der Verkabelung.
                          • L Loely
                            hallo Aerix,
                            Ging mir genau so, Senec unter der Suche eingegeben und nix ging.
                            Da hat mir die Anleitung auf github geholfen:
                            Das heisst, Du gehts via FTP auf den z.B. Raspberry, auf dem der iobroker läuft, navigierst in den iobroker Ordner (bei mir /opt/iobroker) und startest die Installation mit:
                            npm i iobroker.senec
                            Anschliessend noch eine Instanz installieren und konfigurieren, und dann sollte es laufen.
                            Viele Grüsse
                            Loely
                            squashmichi
                            @loely
                            Ich könnte etwas Hilfe bei der Installation der Instanz benötigen.
                            Direkt über den Iobroker über die Suche bei den Instanzen habe ich bzgl. Senec nichts gefunden.
                            Daraufhin habe ich über ssh am Raspy folgendes eingegeben:
                            Anschließendes suchen des Adapters über Iobroker leider ohne Erfolg.
                            Folgendes hat mir der Raspy nach Eingabe von "npm i iobroker.senec" ausgeworfen:
                            Bin über jede Hilfe dankbar:-)
                            GlasfaserG S 2 Antworten Letzte Antwort
                            • S squashmichi
                              @loely
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #66
                              @squashmichi sagte in [Neuer Adapter] Senec Home Adapter:
                              leider ohne Erfolg.
                              Ich antworte mal hier ... wenn du es noch nicht hinbekommen hast !? :
                              Du stehst auch im falschen Verzeichniss für die Installation :
                              cd /opt/iobroker
                              steht auch in der Readme
                              MichaHiddM 1 Antwort Letzte Antwort
                              • GlasfaserG Glasfaser
                                leider ohne Erfolg.
                                cd /opt/iobroker
                                MichaHiddM Offline
                                MichaHiddM Offline
                                MichaHidd
                                #67
                                Nach vielen Problemen hat endlich das Update von der Version 1.3.2 auf 1.3.6 geklappt (hatte es blöderweise erst über github versucht, aber dort die Lösung von jkoeber erwirtscht).
                                Jetzt läuft eigentlich alles. Neu ist aber dass ich links in der Menüübersicht jetzt einen Punkt Senec (JavaScript) finde. Wenn ich diesen aber aufrufe, kommt nur die Meldung: Filte tab.html not found
                                Liegt der Fehler bei mir?
                                • boerneiB boernei
                                  danke für den Adapter. Läuft auch bei mir super.
                                  Ich habe die Wallbox auch von senec. Das "Solar-optimierte" Laden macht ja minimum 4kw. Ich würde gerne über iobroker einstellen, dass die wallbox erst eingeschaltet wird, wenn die PV anlage mehr als 4kw liefert. In der app gibt es ja diesen on off schalten für die wallbox. Kann ich das auch über iobroker schalten? Wisst ihr das?
                                  danke, und vg, Bernhard
                                  MichaHiddM Offline
                                  MichaHiddM Offline
                                  MichaHidd
                                  schrieb am zuletzt editiert von MichaHidd
                                  #68
                                  @boernei said in [Neuer Adapter] Senec Home Adapter:
                                  Würde mich auch interessieren ...
                                  • MichaHiddM MichaHidd
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #69
                                    @michahidd sagte in [Neuer Adapter] Senec Home Adapter:
                                    Schau mal hier :
                                    https://forum.iobroker.net/topic/30620/neuer-adapter-senec-home-adapter/49
                                    • FreunderNachtF Offline
                                      FreunderNacht
                                      #70
                                      es geht um den Datenpunkt:
                                      STAT_ZUSTAND
                                      Gibt es irgendwo eine Liste mit der Auflistung welche Zahl für welchen Status steht (so wie er im Datenpunkt: STAT_STATE_Text angegeben ist)?
                                      Ich will mir nee kleine Übersicht wann er in welchem Zustand war in Grafana bauen und da wäre es für mich wahrscheinlich einfacher mit den Zahlenwerten zu arbeiten.
                                      Intel NUC mit Proxmox
                                      IO Broker (Homematic IP / CCU3 / Shelly / Tasmota / Zigbee)
                                      Influx DB
                                      Grafana
                                      PiHole
                                      PiVPN
                                      • J juergenkir
                                        fly001
                                        schrieb am zuletzt editiert von fly001
                                        #71
                                        @juergenkir kannst du mir die Visualisierung bitte teilen? Sieht gut aus und ich bin noch neu in iobroker unterwegs.. Danke!
                                        • N nobl
                                          frankthegreatF Offline
                                          frankthegreat
                                          #72
                                          @nobl
                                          Moin, dein Adapter läuft jetzt bei mir schon über ein Jahr ohne zu zicken. Macht also was er soll 👍
                                          Dafür mal zwischendurch ein großes DANKE!!!
                                          Hab auch die wichtigsten Werte visualisiert und will noch etwas tiefer einsteigen.
                                          Jetzt suche ich schon einige Zeit erfolglos nach der STRING Spannung.
                                          Gibt's dafür Datenpunkte bzw. nach was müßte ich schauen???
                                          Hier ein Beispiel vom Fronius Adapter:
