    6.8k
5.8k Beiträge 156 Kommentatoren 4.7m Aufrufe 137 Beobachtet
  • NegaleinN Negalein
    @SBorg
    seit 26.3., 16:47 kommen keine Daten an.
    dietpi@DietPi:~$ sudo systemctl status wetterstation
    ● wetterstation.service - Service für ioBroker Wetterstation
       Loaded: loaded (/etc/systemd/system/wetterstation.service; enabled; vendor preset: enabled)
       Active: active (running) since Mon 2022-03-28 10:48:31 CEST; 7min ago
     Main PID: 277 (wetterstation.s)
        Tasks: 5 (limit: 264)
       Memory: 4.8M
       CGroup: /system.slice/wetterstation.service
               ├─ 277 /bin/bash /home/iobroker/wetterstation.sh
               ├─2977 /bin/bash /home/iobroker/wetterstation.sh
               ├─2978 timeout 38 nc -nlvw 1 -p 1080
               ├─2979 sed -n 1 p
               └─2980 nc -nlvw 1 -p 1080
    Mär 28 10:50:46 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:51:17 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:51:49 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:52:19 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:52:51 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:53:23 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:53:56 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:54:24 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:55:27 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:55:50 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    im ioBroker-Log seh ich haufenweise influxdb.0 Fehler 😕
     / "{\"error\":\"timeout\"}\n""
    2022-03-28 02:00:35.030  - info: influxdb.0 (520) Add point that had error for javascript.0.Wetterstation.Info.Temp_Aussen_24h_max to buffer again, error-count=1
    SBorgS Offline
    SBorgS Offline
    SBorg
    #3652
    @negalein sagte in [Linux Shell-Skript] WLAN-Wetterstation:
    -5572.77
    Das passiert eigentlich nur wenn das Display keinen Wert für die Außentemperatur schickt.
    Je nachdem was du per WS-View+ App ggf. nutzt, Daten auf WU/Ecowitt sind Ok? Display zeigt auch aktuelle Temperatur an?
    Ev. sind einfach deine Batterien vom Mast alle?
    Vor kurzem hat sich mein Display nach knapp 2 Jahren im 24/7-Betrieb verabschiedet. Genauen Fehler weiß ich jetzt nicht mehr, aber Batterien raus, Strom ab, eine Minute warten, Strom und Batterien an/rein, Service restarten und alles lief wieder :)
    LG SBorg ( SBorg auf GitHub)
    • SBorgS SBorg
      -5572.77
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      #3653
      @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
      gerade gesehn, dass der Display keine Aussentemp anzeigt. Manchmal gehts, manchmal nicht.
      Batterien haben wir vor ein paar Tagen getauscht.
      2 Jahre?? Ich muss alle 8-9 Monate tauschen.
      ° Fixer ---> iob fix
      • SBorgS SBorg
        Kleines Zwischenrelease. Einige Displays scheinen bei der Temperatur "--" zu übertragen wenn die Funkverbindung zum Mast gestört ist. Daraus resultieren dann bei der Umrechnung °F --> °C Phantasiewerte von -5.xxx°C. Nicht gerade schön, gerade wenn es auch noch in der InfluxDB landet...
        Mit dem neuen Release lässt sich dafür nun ein Fix in der "conf" aktivieren (FIX_AUSSENTEMP=true per Default [false], also nicht aktiviert). Sollte die Temperatur unter dem "absoluten Nullpunkt" (-273°C) liegen, wird das Datenpaket verworfen und nichts an den ioB gesendet:
        Neues Release des Wetterstation WLAN-Skriptes auf GitHub V2.12.0
        • + bei fehlerhafter Außentemperatur erfolgt keine Datenübertragung des Paketes an den ioB
        Wie immer zu finden im GitHub
        Update-Routine von Vorgängerversion:
        • wetterstation.sh, wetterstation.sub und ws_updater.sh ersetzen
        • ./ws_updater.sh --patch im Installationsverzeichnis ausführen
        • nun mittels sudo systemctl restart wetterstation den Service neu starten
        Mutige können auch mal direkt den Updater probieren ;) 👍
        Im Installationsverzeichnis ausführen: bash <(curl -s https://raw.githubusercontent.com/SBorg2014/WLAN-Wetterstation/master/ws_updater.sh)
        Dies wird zukünftig die bevorzugte Methode werden. Aktuell funktioniert er bei mir problemlos :)
        Ein Update ist nicht zwingend erforderlich, sofern ihr kein Problem mit "Ausreißern" bei der Temperatur habt.
        qqolliQ Offline
        qqolliQ Offline
        qqolli
        #3654
        @sborg
        habe gerade den Updater "ausprobiert", hab aber eine Fehlermeldung bzgl. der Rechte für das Anlegen der tmp.zip Datei (s. unten):
         │   WS-Updater V2.12.0   │
         Service läuft nicht im User-Kontext sondern unter User root...
         Soll nun auf User (empfohlen) umgestellt werden? [J/N]: J
         Done... Restarte Service...
         'bc' installiert: [✓]
         'jq' installiert: [✓]
         'unzip' installiert: [✓]
         'patch' installiert: [✓]
         Aktuelle Version (latest) auf GitHub: V2.12.0 vom 26.03.2022
         Version im aktuellen Verzeichnis    : V2.11.0
         Informationen zum Release V2.12.0:
         Neu/Änderungen im Release:
         Soll ein Update von WLAN-Wetterstation durchgeführt werden? [J/N]: J
         Führe Update aus...
          % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                         Dload  Upload   Total   Spent    Left  Speed
        100   661  100   661    0     0   2777      0 --:--:-- --:--:-- --:--:--  2777
        Warning: Failed to create the file tmp.zip: Keine Berechtigung
          4 30415    4  1369    0     0   2799      0  0:00:10 --:--:--  0:00:10  2799
        curl: (23) Failed writing body (0 != 1369)
        unzip:  cannot find or open tmp.zip, tmp.zip.zip or tmp.zip.ZIP.
        rm: das Entfernen von 'tmp.zip' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
         │   WS-Updater V2.11.0   │
         Soll die wetterstation.conf nun auf eine neue Version gepatcht werden? [J/N]: J
         Version ist bereits aktuell...
         Update ausgeführt. Soll der Service nun neu gestartet werden? [J/N]: J
        • SBorgS Offline
          SBorgS Offline
          SBorg
          #3655
          Auf GitHub (https://github.com/SBorg2014/WLAN-Wetterstation) steht nun die aktuelle Online-Version des ws_updater.sh bereit.
          Dieser muss einmalig herunter geladen werden, oder man wartet auf das Rollout der nächsten Version, dann ist er darin auch enthalten. Nicht verwirren lassen, die Versionsnummer ist noch immer die V2.12.0 (eigentlich hat der Updater keine eigene, er zeigt nur an für welche Version des Skriptes er ist).
          Danach genügt ein einfaches ./ws_updater.sh im Installationsverzeichnis. Bei bestehender Inet-Verbindung nutzt er nun die aktuelle Version von GitHub und zeigt ein Auswahlmenü an.
          Ohne Inet führt er die aktuelle Version im Verzeichnis aus.
          Parameter (Übersicht mittels ./ws_updater.sh --help funktionieren weiterhin, allerdings dann "Offline".
          Kein spezieller @Nashra -Patch:
          Meister Röhrich: das tut nicht Not als root...
          Wenn also alles klapp bedeutet das zukünftig für ein Update einfach:
          • ./ws_updater.sh im Installationsverzeichnis aufrufen
          • Punkt "4" wählen
          • paar Abfragen mit "j" beantworten
          • freuen ;)
          • NegaleinN Offline
            NegaleinN Offline
            Negalein
            #3656
            @SBorg
            Aber warum kommen dann überhaupt keine Daten an?
            Keine Sonne, kein Wind, ...
            Display zeigt alles, bis auf Temperatur an.
              @SBorg
              SBorgS Offline
              SBorgS Offline
              SBorg
              #3657
              @negalein Ich habe noch die ersten Batterien drin, wobei ich meine Station dank euch so gegen März/April 2020 (?) bekam. Habe aber auch "gute" Duracel Alkaline genommen und mein Solarpanel bekommt durchgängig volles Tageslicht.
              Keine Daten: ist die neue Funktion des Fixes von V2.12.0 (falls aktiviert)
              Wenn die Außentemperatur -5572°C beträgt klappt auch die Kommunikation mit dem Mast nicht korrekt, also sind andere Werte ebenfalls fragwürdig. Deswegen wird der kpl. Datensatz weggeschmissen und nicht an den ioB geschickt ;)
              • SBorgS SBorg
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #3658
                Ah, ich dachte er schickt nur die fehlerhaften Daten nicht weiter.
                • qqolliQ qqolli
                  @sborg
                   Führe Update aus...
                  SBorgS Offline
                  SBorgS Offline
                  SBorg
                  #3659
                  @qqolli Da hat dein aktueller User keine Schreibrechte in dem Verzeichnis.
                  Ich bin User "sborg" und gehöre der Gruppe "sborg" an. Nur der User "sborg" hat im aktuellen Verzeichnis "." bei mir auch Schreibrechte "w". Du müsstest also deinen aktuellen User einer Gruppe hinzufügen die Schreibrechte im Verzeichnis hat, die Schreibrechte anpassen, ... usw.
                  qqolliQ 1 Antwort Letzte Antwort
                    SBorgS Offline
                    SBorgS Offline
                    SBorg
                    #3660
                    Ah, ich dachte er...
                    Wie sagte mein Alter Lehrer immer nicht denken, lesen, und wer lesen kann ist klar im Vorteil... 😊
                    Aus dem Release-Text:
                    ...und bevor jemand was falsch versteht: das ist nur Spaß, der wird wohl noch erlaubt sein, alles Gut :)
                    • SBorgS SBorg
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #3661
                      mit "nichts" meinte ich nur den 1 Wert! 😬
                      .und bevor jemand was falsch versteht: das ist nur Spaß, der wird wohl noch erlaubt sein, alles Gut 🙂
                      Logo, wir ATler sind da eh nicht so. 😀 😂
                      Gell @da_Woody! Wir aus dem Alpenland sind sehr handzahm.
                        da_WoodyD Offline
                        da_WoodyD Offline
                        #3662
                        schüchtern, fast scheu... 🤠
                        • SBorgS SBorg
                          qqolliQ Offline
                          qqolliQ Offline
                          qqolli
                          #3663
                          @sborg
                          Mein user ist iobroker:
                          pi@ioBroker:/home/iobroker/wetterstation $ ls -al
                          insgesamt 140
                          drwxr-xr-x 2 iobroker iobroker  4096 Mär 28 13:50 .
                          drwxr-xr-x 6 iobroker iobroker  4096 Dez 16 20:53 ..
                          -rwxr--r-- 1 iobroker iobroker  6087 Jan 19 13:02 wetterstation.conf
                          -rwxr--r-- 1 iobroker iobroker 20079 Jan  3 11:21 wetterstation.js
                          -rwxr-xr-x 1 iobroker iobroker 15932 Jan  3 11:21 wetterstation.sh
                          -rwxr--r-- 1 iobroker iobroker 66047 Jan  3 11:21 wetterstation.sub
                          -rwxr-xr-x 1 iobroker iobroker 16932 Jan  3 11:21 ws_updater.sh
                          Müssten alle Dateien in diesem Verzeichnis dann diese Rechte haben?:
                          insgesamt 140
                          • qqolliQ qqolli
                            @sborg
                            insgesamt 140
                            insgesamt 140
                            SBorgS Offline
                            SBorgS Offline
                            SBorg
                            #3664
                            @qqolli sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                            Ne, eben nicht
                            pi@ioBroker
                            Aktuell bist du als User "pi" eingeloggt und unter dessen Kontext (also Rechte) arbeitest du dann auch. Der hat da aber keinerlei Rechte ;)
                            Am einfachsten wäre den User "pi" der Gruppe "iobroker" hinzuzufügen und der Gruppe "iobroker" dann Schreibrechte im Verzeichnis zu geben.
                            Gib einfach mal groups ein. Steht da schon "iobroker" drin (IMO default bei der ioB-Installation)?
                            • SBorgS SBorg
                              Ne, eben nicht
                              pi@ioBroker
                              qqolliQ Offline
                              qqolliQ Offline
                              qqolli
                              #3665
                              @sborg
                              Ja, der iobroker steht drin:
                              pi@ioBroker:/home/iobroker/wetterstation $ groups
                              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                              Aber leider reichen meine Linux-Kenntnisse noch nicht ganz aus, die Rechte und Gruppen einzurichten. Wie kann man das am "einfachsten" machen?
                              • qqolliQ qqolli
                                @sborg
                                SBorgS Offline
                                SBorgS Offline
                                SBorg
                                schrieb am zuletzt editiert von SBorg
                                #3666
                                @qqolli Wenn man es mal verstanden hat ist es, wie eigentlich bei allem ;) , recht leicht.
                                Kleiner Exkurs:
                                ganz vorne das "d" steht für Directory (Verzeichnis)
                                Dann folgen drei Dreiergruppen für User-, Gruppen- und Andere-Rechte
                                • r = read (lesen)
                                • w = write (schreiben, anlegen)
                                • x = executable (ausführbar)
                                Nehmen wir mal deine "wetterstation.conf" (-rwxr--r--):
                                • kein Verzeichnis
                                • User "iobroker" (1. Bezeichnung) darf lesen, schreiben und ausführen [1. Dreiergruppe]
                                • Gruppe "iobroker" (2. Bezeichnung) darf nur lesen [2. Dreiergruppe]
                                • "Andere" darf nur lesen [3. Dreiergruppe]
                                Dein User "pi" ist schon in der Gruppe "iobroker", der fehlt aber aktuell das "w" beim aktuellen Verzeichnis "."
                                • cd .. ein Verzeichnis hoch
                                • sudo chmod g+w wetterstation "g" steht für Gruppenrechte, "+" für hinzufügen, "w" für die Schreibrechte und "wetterstation" für das Verzeichnis. "chmod" ist der passende Befehl (change modifikation) und "sudo" muss, da die Rechte nur von einem admin vergeben werden dürfen
                                Wenn du nun wieder in das Verzeichnis wechselst ergibt ein ls -al
                                drwxrwxr-x 2 iobroker iobroker  4096 Mär 28 13:50 .
                                und die Gruppe "iobroker" (der natürlich auch dein User "pi" angehört) darf in diesem Verzeichnis nun schreiben und auch Dateien neu anlegen, löschen...
                                qqolliQ da_WoodyD 2 Antworten Letzte Antwort
                                • SBorgS SBorg
                                  Kleiner Exkurs:
                                  • r = read (lesen)
                                  • kein Verzeichnis
                                  qqolliQ Offline
                                  qqolliQ Offline
                                  qqolli
                                  #3667
                                  @sborg
                                  Super! Hat genauso funktioniert und etwas gelernt habe ich auch noch. Vielen Dank für deine Zeit und Mühe.
                                  • SBorgS SBorg
                                    Kleiner Exkurs:
                                    • r = read (lesen)
                                    • kein Verzeichnis
                                    da_WoodyD Offline
                                    da_WoodyD Offline
                                    #3668
                                    Wenn man es mal verstanden hat ist es, wie eigentlich bei allem , recht leicht.
                                    welch wahre aussage! nur manchmal ists halt nicht so einfach... ;)
                                    vor allem als winuser, der mit dem pinguin recht wenig zu tun hatte... :)
                                    • SBorgS SBorg
                                      • Punkt "4" wählen
                                      • freuen ;)
                                      NashraN Offline
                                      NashraN Offline
                                      Nashra
                                      Most Active Forum Testing
                                      #3669
                                      Gruß Ralf
                                      • NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #3670
                                        @SBorg
                                        Irgendwas passt nicht!
                                        Daten am Display passen!
                                        Aber seit 26.3., 16:47 kommen im ioBroker keine Daten an.
                                        Kannst du weiterhelfen?
                                          @SBorg
                                          SBorgS Offline
                                          SBorgS Offline
                                          SBorg
                                          #3671
                                          @negalein Hast du den "FIX_AUSSENTEMP" mittels true aktiviert? Dann stelle mal auf false zurück (Service-Restart nicht vergessen).
                                          Falls es dann funktioniert, hast du wieder -5k°C seit dem Zeitpunkt in der Influx stehen?
