    6.8k
5.8k Beiträge 156 Kommentatoren 4.7m Aufrufe 137 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    #3651
    @SBorg
    seit 26.3., 16:47 kommen keine Daten an.
    dietpi@DietPi:~$ sudo systemctl status wetterstation
    ● wetterstation.service - Service für ioBroker Wetterstation
       Loaded: loaded (/etc/systemd/system/wetterstation.service; enabled; vendor preset: enabled)
       Active: active (running) since Mon 2022-03-28 10:48:31 CEST; 7min ago
     Main PID: 277 (wetterstation.s)
        Tasks: 5 (limit: 264)
       Memory: 4.8M
       CGroup: /system.slice/wetterstation.service
               ├─ 277 /bin/bash /home/iobroker/wetterstation.sh
               ├─2977 /bin/bash /home/iobroker/wetterstation.sh
               ├─2978 timeout 38 nc -nlvw 1 -p 1080
               ├─2979 sed -n 1 p
               └─2980 nc -nlvw 1 -p 1080
    Mär 28 10:50:46 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:51:17 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:51:49 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:52:19 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:52:51 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:53:23 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:53:56 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:54:24 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:55:27 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    Mär 28 10:55:50 DietPi wetterstation.sh[277]: /home/iobroker/wetterstation.sh: line 266: [: -5572.77: integer expression expected
    im ioBroker-Log seh ich haufenweise influxdb.0 Fehler 😕
     / "{\"error\":\"timeout\"}\n""
    2022-03-28 02:00:35.030  - info: influxdb.0 (520) Add point that had error for javascript.0.Wetterstation.Info.Temp_Aussen_24h_max to buffer again, error-count=1
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      @SBorg
         Memory: 4.8M
                 ├─2979 sed -n 1 p
      SBorgS Offline
      SBorgS Offline
      SBorg
      #3652
      @negalein sagte in [Linux Shell-Skript] WLAN-Wetterstation:
      -5572.77
      Das passiert eigentlich nur wenn das Display keinen Wert für die Außentemperatur schickt.
      Je nachdem was du per WS-View+ App ggf. nutzt, Daten auf WU/Ecowitt sind Ok? Display zeigt auch aktuelle Temperatur an?
      Ev. sind einfach deine Batterien vom Mast alle?
      Vor kurzem hat sich mein Display nach knapp 2 Jahren im 24/7-Betrieb verabschiedet. Genauen Fehler weiß ich jetzt nicht mehr, aber Batterien raus, Strom ab, eine Minute warten, Strom und Batterien an/rein, Service restarten und alles lief wieder :)
      LG SBorg ( SBorg auf GitHub)
      • SBorgS SBorg
        -5572.77
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #3653
        @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
        gerade gesehn, dass der Display keine Aussentemp anzeigt. Manchmal gehts, manchmal nicht.
        Batterien haben wir vor ein paar Tagen getauscht.
        2 Jahre?? Ich muss alle 8-9 Monate tauschen.
        • SBorgS SBorg
          Kleines Zwischenrelease. Einige Displays scheinen bei der Temperatur "--" zu übertragen wenn die Funkverbindung zum Mast gestört ist. Daraus resultieren dann bei der Umrechnung °F --> °C Phantasiewerte von -5.xxx°C. Nicht gerade schön, gerade wenn es auch noch in der InfluxDB landet...
          Mit dem neuen Release lässt sich dafür nun ein Fix in der "conf" aktivieren (FIX_AUSSENTEMP=true per Default [false], also nicht aktiviert). Sollte die Temperatur unter dem "absoluten Nullpunkt" (-273°C) liegen, wird das Datenpaket verworfen und nichts an den ioB gesendet:
          Neues Release des Wetterstation WLAN-Skriptes auf GitHub V2.12.0
          • + bei fehlerhafter Außentemperatur erfolgt keine Datenübertragung des Paketes an den ioB
          Wie immer zu finden im GitHub
          Update-Routine von Vorgängerversion:
          • wetterstation.sh, wetterstation.sub und ws_updater.sh ersetzen
          • ./ws_updater.sh --patch im Installationsverzeichnis ausführen
          • nun mittels sudo systemctl restart wetterstation den Service neu starten
          Mutige können auch mal direkt den Updater probieren ;) 👍
          Im Installationsverzeichnis ausführen: bash <(curl -s https://raw.githubusercontent.com/SBorg2014/WLAN-Wetterstation/master/ws_updater.sh)
          Dies wird zukünftig die bevorzugte Methode werden. Aktuell funktioniert er bei mir problemlos :)
          Ein Update ist nicht zwingend erforderlich, sofern ihr kein Problem mit "Ausreißern" bei der Temperatur habt.
          qqolliQ Offline
          qqolliQ Offline
          qqolli
          #3654
          @sborg
          habe gerade den Updater "ausprobiert", hab aber eine Fehlermeldung bzgl. der Rechte für das Anlegen der tmp.zip Datei (s. unten):
           │   WS-Updater V2.12.0   │
           Service läuft nicht im User-Kontext sondern unter User root...
           Soll nun auf User (empfohlen) umgestellt werden? [J/N]: J
           Done... Restarte Service...
           'bc' installiert: [✓]
           'jq' installiert: [✓]
           'unzip' installiert: [✓]
           'patch' installiert: [✓]
           Aktuelle Version (latest) auf GitHub: V2.12.0 vom 26.03.2022
           Version im aktuellen Verzeichnis    : V2.11.0
           Informationen zum Release V2.12.0:
           Neu/Änderungen im Release:
           Soll ein Update von WLAN-Wetterstation durchgeführt werden? [J/N]: J
           Führe Update aus...
            % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                           Dload  Upload   Total   Spent    Left  Speed
          100   661  100   661    0     0   2777      0 --:--:-- --:--:-- --:--:--  2777
          Warning: Failed to create the file tmp.zip: Keine Berechtigung
            4 30415    4  1369    0     0   2799      0  0:00:10 --:--:--  0:00:10  2799
          curl: (23) Failed writing body (0 != 1369)
          unzip:  cannot find or open tmp.zip, tmp.zip.zip or tmp.zip.ZIP.
          rm: das Entfernen von 'tmp.zip' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
           │   WS-Updater V2.11.0   │
           Soll die wetterstation.conf nun auf eine neue Version gepatcht werden? [J/N]: J
           Version ist bereits aktuell...
           Update ausgeführt. Soll der Service nun neu gestartet werden? [J/N]: J
          • SBorgS Offline
            SBorgS Offline
            SBorg
            #3655
            Auf GitHub (https://github.com/SBorg2014/WLAN-Wetterstation) steht nun die aktuelle Online-Version des ws_updater.sh bereit.
            Dieser muss einmalig herunter geladen werden, oder man wartet auf das Rollout der nächsten Version, dann ist er darin auch enthalten. Nicht verwirren lassen, die Versionsnummer ist noch immer die V2.12.0 (eigentlich hat der Updater keine eigene, er zeigt nur an für welche Version des Skriptes er ist).
            Danach genügt ein einfaches ./ws_updater.sh im Installationsverzeichnis. Bei bestehender Inet-Verbindung nutzt er nun die aktuelle Version von GitHub und zeigt ein Auswahlmenü an.
            Ohne Inet führt er die aktuelle Version im Verzeichnis aus.
            Parameter (Übersicht mittels ./ws_updater.sh --help funktionieren weiterhin, allerdings dann "Offline".
            Kein spezieller @Nashra -Patch:
            Meister Röhrich: das tut nicht Not als root...
            Wenn also alles klapp bedeutet das zukünftig für ein Update einfach:
            • ./ws_updater.sh im Installationsverzeichnis aufrufen
            • Punkt "4" wählen
            • paar Abfragen mit "j" beantworten
            • freuen ;)
            • NegaleinN Offline
              NegaleinN Offline
              Negalein
              #3656
              @SBorg
              Aber warum kommen dann überhaupt keine Daten an?
              Keine Sonne, kein Wind, ...
              Display zeigt alles, bis auf Temperatur an.
                @SBorg
                SBorgS Offline
                SBorgS Offline
                SBorg
                #3657
                @negalein Ich habe noch die ersten Batterien drin, wobei ich meine Station dank euch so gegen März/April 2020 (?) bekam. Habe aber auch "gute" Duracel Alkaline genommen und mein Solarpanel bekommt durchgängig volles Tageslicht.
                Keine Daten: ist die neue Funktion des Fixes von V2.12.0 (falls aktiviert)
                Wenn die Außentemperatur -5572°C beträgt klappt auch die Kommunikation mit dem Mast nicht korrekt, also sind andere Werte ebenfalls fragwürdig. Deswegen wird der kpl. Datensatz weggeschmissen und nicht an den ioB geschickt ;)
                • SBorgS SBorg
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #3658
                  Ah, ich dachte er schickt nur die fehlerhaften Daten nicht weiter.
                  • qqolliQ qqolli
                    @sborg
                     Führe Update aus...
                    SBorgS Offline
                    SBorgS Offline
                    SBorg
                    #3659
                    @qqolli Da hat dein aktueller User keine Schreibrechte in dem Verzeichnis.
                    Ich bin User "sborg" und gehöre der Gruppe "sborg" an. Nur der User "sborg" hat im aktuellen Verzeichnis "." bei mir auch Schreibrechte "w". Du müsstest also deinen aktuellen User einer Gruppe hinzufügen die Schreibrechte im Verzeichnis hat, die Schreibrechte anpassen, ... usw.
                    qqolliQ 1 Antwort Letzte Antwort
                      SBorgS Offline
                      SBorgS Offline
                      SBorg
                      #3660
                      Ah, ich dachte er...
                      Wie sagte mein Alter Lehrer immer nicht denken, lesen, und wer lesen kann ist klar im Vorteil... 😊
                      Aus dem Release-Text:
                      ...und bevor jemand was falsch versteht: das ist nur Spaß, der wird wohl noch erlaubt sein, alles Gut :)
                      • SBorgS SBorg
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #3661
                        mit "nichts" meinte ich nur den 1 Wert! 😬
                        .und bevor jemand was falsch versteht: das ist nur Spaß, der wird wohl noch erlaubt sein, alles Gut 🙂
                        Logo, wir ATler sind da eh nicht so. 😀 😂
                        Gell @da_Woody! Wir aus dem Alpenland sind sehr handzahm.
                          da_WoodyD Offline
                          da_WoodyD Offline
                          #3662
                          schüchtern, fast scheu... 🤠
                          • SBorgS SBorg
                            qqolliQ Offline
                            qqolliQ Offline
                            qqolli
                            #3663
                            @sborg
                            Mein user ist iobroker:
                            pi@ioBroker:/home/iobroker/wetterstation $ ls -al
                            insgesamt 140
                            drwxr-xr-x 2 iobroker iobroker  4096 Mär 28 13:50 .
                            drwxr-xr-x 6 iobroker iobroker  4096 Dez 16 20:53 ..
                            -rwxr--r-- 1 iobroker iobroker  6087 Jan 19 13:02 wetterstation.conf
                            -rwxr--r-- 1 iobroker iobroker 20079 Jan  3 11:21 wetterstation.js
                            -rwxr-xr-x 1 iobroker iobroker 15932 Jan  3 11:21 wetterstation.sh
                            -rwxr--r-- 1 iobroker iobroker 66047 Jan  3 11:21 wetterstation.sub
                            -rwxr-xr-x 1 iobroker iobroker 16932 Jan  3 11:21 ws_updater.sh
                            Müssten alle Dateien in diesem Verzeichnis dann diese Rechte haben?:
                            insgesamt 140
                            • qqolliQ qqolli
                              @sborg
                              insgesamt 140
                              insgesamt 140
                              SBorgS Offline
                              SBorgS Offline
                              SBorg
                              #3664
                              @qqolli sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                              Ne, eben nicht
                              pi@ioBroker
                              Aktuell bist du als User "pi" eingeloggt und unter dessen Kontext (also Rechte) arbeitest du dann auch. Der hat da aber keinerlei Rechte ;)
                              Am einfachsten wäre den User "pi" der Gruppe "iobroker" hinzuzufügen und der Gruppe "iobroker" dann Schreibrechte im Verzeichnis zu geben.
                              Gib einfach mal groups ein. Steht da schon "iobroker" drin (IMO default bei der ioB-Installation)?
                              • SBorgS SBorg
                                Ne, eben nicht
                                pi@ioBroker
                                qqolliQ Offline
                                qqolliQ Offline
                                qqolli
                                #3665
                                @sborg
                                Ja, der iobroker steht drin:
                                pi@ioBroker:/home/iobroker/wetterstation $ groups
                                pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                Aber leider reichen meine Linux-Kenntnisse noch nicht ganz aus, die Rechte und Gruppen einzurichten. Wie kann man das am "einfachsten" machen?
                                • qqolliQ qqolli
                                  @sborg
                                  SBorgS Offline
                                  SBorgS Offline
                                  SBorg
                                  schrieb am zuletzt editiert von SBorg
                                  #3666
                                  @qqolli Wenn man es mal verstanden hat ist es, wie eigentlich bei allem ;) , recht leicht.
                                  Kleiner Exkurs:
                                  ganz vorne das "d" steht für Directory (Verzeichnis)
                                  Dann folgen drei Dreiergruppen für User-, Gruppen- und Andere-Rechte
                                  • r = read (lesen)
                                  • w = write (schreiben, anlegen)
                                  • x = executable (ausführbar)
                                  Nehmen wir mal deine "wetterstation.conf" (-rwxr--r--):
                                  • kein Verzeichnis
                                  • User "iobroker" (1. Bezeichnung) darf lesen, schreiben und ausführen [1. Dreiergruppe]
                                  • Gruppe "iobroker" (2. Bezeichnung) darf nur lesen [2. Dreiergruppe]
                                  • "Andere" darf nur lesen [3. Dreiergruppe]
                                  Dein User "pi" ist schon in der Gruppe "iobroker", der fehlt aber aktuell das "w" beim aktuellen Verzeichnis "."
                                  • cd .. ein Verzeichnis hoch
                                  • sudo chmod g+w wetterstation "g" steht für Gruppenrechte, "+" für hinzufügen, "w" für die Schreibrechte und "wetterstation" für das Verzeichnis. "chmod" ist der passende Befehl (change modifikation) und "sudo" muss, da die Rechte nur von einem admin vergeben werden dürfen
                                  Wenn du nun wieder in das Verzeichnis wechselst ergibt ein ls -al
                                  drwxrwxr-x 2 iobroker iobroker  4096 Mär 28 13:50 .
                                  und die Gruppe "iobroker" (der natürlich auch dein User "pi" angehört) darf in diesem Verzeichnis nun schreiben und auch Dateien neu anlegen, löschen...
                                  qqolliQ da_WoodyD 2 Antworten Letzte Antwort
                                  • SBorgS SBorg
                                    Kleiner Exkurs:
                                    • r = read (lesen)
                                    • kein Verzeichnis
                                    qqolliQ Offline
                                    qqolliQ Offline
                                    qqolli
                                    #3667
                                    @sborg
                                    Super! Hat genauso funktioniert und etwas gelernt habe ich auch noch. Vielen Dank für deine Zeit und Mühe.
                                    • SBorgS SBorg
                                      Kleiner Exkurs:
                                      • r = read (lesen)
                                      • kein Verzeichnis
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      #3668
                                      Wenn man es mal verstanden hat ist es, wie eigentlich bei allem , recht leicht.
                                      welch wahre aussage! nur manchmal ists halt nicht so einfach... ;)
                                      vor allem als winuser, der mit dem pinguin recht wenig zu tun hatte... :)
                                      • SBorgS SBorg
                                        • Punkt "4" wählen
                                        • freuen ;)
                                        NashraN Offline
                                        NashraN Offline
                                        Nashra
                                        Most Active Forum Testing
                                        #3669
                                        Gruß Ralf
                                        • NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #3670
                                          @SBorg
                                          Irgendwas passt nicht!
                                          Daten am Display passen!
                                          Aber seit 26.3., 16:47 kommen im ioBroker keine Daten an.
                                          Kannst du weiterhelfen?
