  4. Wasserzähler - Version 2 - all-in-device
wasserzählerversion 2ai on the edgecnnwater meterwater gaugeesp32ov2640neuronale netzehausautomatisierung
3.4k Beiträge 240 Kommentatoren 2.4m Aufrufe 231 Beobachtet
  • XsevX Xsev
    @knallochse Vielen Dank für den Tip!!!!
    @jomjol
    das Log sieht jetzt so aus
    ets Jul 29 2019 12:21:46
    rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    mode:DIO, clock div:2
    load:0x3fff0030,len:4
    load:0x3fff0034,len:7248
    ho 0 tail 12 room 4
    load:0x40078000,len:13856
    load:0x40080400,len:4052
    entry 0x40080688
    I (31) boot: ESP-IDF 3.40100.200827 2nd stage bootloader
    I (31) boot: compile time 18:56:57
    I (31) boot: chip revision: 3
    I (35) boot_comm: chip revision: 3, min. bootloader chip revision: 0
    I (42) boot.esp32: SPI Speed      : 40MHz
    I (46) boot.esp32: SPI Mode       : DIO
    I (51) boot.esp32: SPI Flash Size : 4MB
    I (55) boot: Enabling RNG early entropy source...
    I (61) boot: Partition Table:
    I (64) boot: ## Label            Usage          Type ST Offset   Length
    I (72) boot:  0 nvs              WiFi data        01 02 00009000 00004000
    I (79) boot:  1 otadata          OTA data         01 00 0000d000 00002000
    I (87) boot:  2 phy_init         RF data          01 01 0000f000 00001000
    I (94) boot:  3 ota_0            OTA app          00 10 00010000 001db000
    I (102) boot:  4 ota_1            OTA app          00 11 001f0000 001db000
    I (109) boot: End of partition table
    I (113) boot_comm: chip revision: 3, min. application chip revision: 0
    I (121) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x51048 (331848) map
    I (273) esp_image: segment 1: paddr=0x00061070 vaddr=0x3ffb0000 size=0x0504c ( 20556) load
    I (283) esp_image: segment 2: paddr=0x000660c4 vaddr=0x40080000 size=0x00404 (  1028) load
    I (284) esp_image: segment 3: paddr=0x000664d0 vaddr=0x40080404 size=0x09b48 ( 39752) load
    I (310) esp_image: segment 4: paddr=0x00070020 vaddr=0x400d0020 size=0x122ec8 (1191624) map
    I (826) esp_image: segment 5: paddr=0x00192ef0 vaddr=0x40089f4c size=0x12c68 ( 76904) load
    I (881) boot: Loaded app from partition at offset 0x10000
    I (881) boot: Disabling RNG early entropy source...
    I (881) psram: This chip is ESP32-D0WD
    I (886) spiram: Found 16MBit SPI RAM device
    I (890) spiram: SPI RAM mode: flash 40m sram 40m
    I (896) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
    I (903) cpu_start: Pro cpu up.
    I (907) cpu_start: Application information:
    I (911) cpu_start: Project name:     esp32cam-server-only
    I (917) cpu_start: App version:      0.0.9.3
    I (922) cpu_start: Compile time:     Sep 25 2021 18:55:36
    I (928) cpu_start: ELF file SHA256:  49d2944a34ee25eb...
    I (934) cpu_start: ESP-IDF:          3.40100.200827
    I (940) cpu_start: Starting app cpu, entry point is 0x40081cf0
    I (0) cpu_start: App cpu up.
    I (1397) spiram: SPI SRAM memory test OK
    I (1397) heap_init: Initializing. RAM available for dynamic allocation:
    I (1398) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
    I (1404) heap_init: At 3FFC2A08 len 0001D5F8 (117 KiB): DRAM
    I (1410) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
    I (1416) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
    I (1423) heap_init: At 4009CBB4 len 0000344C (13 KiB): IRAM
    I (1429) cpu_start: Pro cpu start user code
    I (1434) spiram: Adding pool of 2048K of external SPI memory to heap allocator
    I (1459) spi_flash: detected chip: generic
    I (1460) spi_flash: flash io: dio
    I (1460) cpu_start: Starting scheduler on PRO CPU.
    I (0) cpu_start: Starting scheduler on APP CPU.
    I (1468) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations
    Do Reset Camera
    I (1478) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
    Init Camera
    I (3488) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (3488) gpio: GPIO[18]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (3488) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (3498) gpio: GPIO[21]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (3508) gpio: GPIO[22]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (3518) gpio: GPIO[23]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (3528) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (3538) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (3548) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (3558) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (3568) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (3578) sccb: pin_sda 26 pin_scl 27
    I (3578) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
    I (3728) camera: Detected OV2640 camera
    I (3738) camera: Allocating 1 frame buffers (150 KB total)
    I (3748) camera: Allocating 150 KB frame buffer in OnBoard RAM
    I (4348) main: Using SDMMC peripheral
    Type: SDHC/SDXC
    Speed: 20 MHz
    I (4408) server_ota: Start CheckOTAUpdateCheck ...
    I (4418) server_ota: SHA-256 for the partition table: : 9d4a2809ae90fb20709a8ca3dd3ac3462e1e73286bcd31b689060c91de06fa3a
    I (4478) server_ota: SHA-256 for bootloader: : ee8b22523ca2a6f08e0e01e2e6dd2ae40f0a13f93d5c02794b19cfca199b3e9e
    I (5118) server_ota: SHA-256 for current firmware: : dc1319e0f2d427d7bc8d303fa98e0456e09c555804634127bb0960ca1cb42b6a
    CheckOTAUpdate Partition: ESP_OK
    open config file /sdcard/wlan.ini in mode r
    file loaded
    WLan: XXXXXXX, XXXXXXXXXXXXXXX
    Hostename: Watermeter13
    I (5168) wifi:wifi driver task: 3ffd9cc4, prio:23, stack:6656, core=0
    I (5168) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
    I (5198) wifi:wifi firmware version: 3ea4c76
    I (5198) wifi:config NVS flash: enabled
    I (5198) wifi:config nano formating: disabled
    I (5198) wifi:Init dynamic tx buffer num: 32
    I (5208) wifi:Init data frame dynamic rx buffer num: 32
    I (5208) wifi:Init management frame dynamic rx buffer num: 32
    I (5218) wifi:Init management short buffer num: 32
    I (5218) wifi:Init static tx buffer num: 16
    I (5228) wifi:Init static rx buffer size: 1600
    I (5228) wifi:Init static rx buffer num: 10
    I (5228) wifi:Init dynamic rx buffer num: 32
    I (5328) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
    I (5328) wifi:mode : sta (94:b9:7e:ce:50:20)
    I (5338) BLINK: Blinken - start
    I (5338) wifi station: wifi_init_sta finished.
    I (5458) wifi:new:<3,0>, old:<1,0>, ap:<255,255>, sta:<3,0>, prof:1
    I (5458) wifi:state: init -> auth (b0)
    I (5468) wifi:state: auth -> assoc (0)
    I (5478) wifi:state: assoc -> run (10)
    I (5518) wifi:connected with Rocket, aid = 3, channel 3, BW20, bssid = e0:63:da:74:3e:f2
    I (5518) wifi:security: WPA2-PSK, phy: bgn, rssi: -78
    I (5528) wifi:pm start, type: 1
    I (5538) BLINK: Blinken - done
    I (5588) wifi:AP's beacon interval = 102400 us, DTIM period = 1
    I (6158) esp_netif_handlers: sta ip: 192.168.13.202, mask: 255.255.255.0, gw: 192.168.13.1
    I (6158) wifi station: got ip:192.168.13.202
    I (6158) BLINK: Blinken - start
    I (6158) wifi station: connected to ap SSID:Rocket password:XXXXXXXXXXX
    main: sleep for : 200ms
    I (8178) sntp: Time is not set yet. Connecting to WiFi and getting time over NTP.
    I (8178) sntp: Initializing SNTP
    I (8178) sntp: Waiting for system time to be set... (1/10)
    I (10178) sntp: Waiting for system time to be set... (2/10)
    I (12178) sntp: Waiting for system time to be set... (3/10)
    TimeZone set to CET-1CEST,M3.5.0,M10.5.0/3
    Logfile opened: /sdcard/log/message/log_2022-03-20.txt
    I (14188) sntp: The current date/time in Berlin is: Sun Mar 20 11:39:34 2022
    I (14188) sntp: The current date/time in Berlin is: 2022-03-20_11:39
    timeist 20220320-113934
    time 20220320-113934
    I (16168) BLINK: Blinken - done
    I (16218) server-main: Starting server on port: '80'
    I (16218) server-main: Registering URI handlers
    I (16218) server_tflite: server_part_camera - Registering URI handlers
    I (16218) server_ota: server_ota - Registering URI handlers
    I (16228) server_GPIO: start GpioHandler
    I (16228) server_GPIO: register GPIO Uri
    I (16238) server_GPIO: server_GPIO - Registering URI handlers
    vor reg server main
    vor dotautostart
    task_autodoFlow: start
    open config file /sdcard/config/config.ini in mode r
    [MakeImage]
    Start ReadParameter ([MakeImage]
    ;LogImageLocation = /log/source
    WaitBeforeTakingPicture = 5
    ;LogfileRetentionInDays = 15
    Brightness = -2
    ;Contrast = 0
    ;Saturation = 0
    ImageQuality = 5
    ImageSize = VGA
    FixedExposure = false
    [Alignment]
    Start ReadParameter ([Alignment])
    InitialRotate = 179
    InitialMirror = false
    SearchFieldX = 20
    SearchFieldY = 20
    AlignmentAlgo = Default
    FlipImageSize = false
    /config/ref0.jpg 103 271
    /config/ref1.jpg 442 142
    [Digits]
    Start ReadParameter ([Digits])
    Model = /config/dig1210s2q.tflite
    ;LogImageLocation = /log/digit
    ;LogfileRetentionInDays = 3
    ModelInputSize = 20 32
    main.dig1 294 126 30 54
    GetGENERAL - GENERAL main - roi dig1
    main.dig2 343 126 30 54
    GetGENERAL - GENERAL main - roi dig2
    main.dig3 391 126 30 54
    GetGENERAL - GENERAL main - roi dig3
    [Analog]
    Start ReadParameter ([Analog])
    Model = /config/ana0700s1lq.tflite
    ;LogImageLocation = /log/analog
    ModelInputSize = 32 32
    ExtendedResolution = true
    main.ana1 432 230 92 92
    GetGENERAL - GENERAL main - roi ana1
    main.ana2 379 332 92 92
    GetGENERAL - GENERAL main - roi ana2
    main.ana3 283 374 92 92
    GetGENERAL - GENERAL main - roi ana3
    main.ana4 155 328 92 92
    GetGENERAL - GENERAL main - roi ana4
    [PostProcessing]
    Start ReadParameter ([PostProcessing])
    Anzahl NUMBERS: 1 - DIGITS: 1, ANALOG: 1
    Number main, Anz DIG: 3, Anz ANA 4
    main.DecimalShift = 0
    PreValueUse = true
    PreValueAgeStartup = 720
    AllowNegativeRates = false
    main.MaxRateValue = 0.1
    ErrorMessage = true
    CheckDigitIncreaseConsistency = true
    ;[MQTT]
    Read Zeile Prevalue.ini: 2020-11-30_12-02-22
    42.013401
    TIME: 120, 10, 0, 1, 1073497820, 5
    Read: ;Uri = mqtt://IP-ADRESS:1883
    Read: ;MainTopic = wasserzaehler
    Read: ;ClientID = wasser
    Read: ;user = USERNAME
    Read: ;password = PASSWORD
    Read:
    Read: ;[GPIO]
    Read: ;MainTopicMQTT = wasserzaehler/GPIO
    Read: ;IO0 = input disabled 10 false false
    Read: ;IO1 = input disabled 10 false false
    Read: ;IO3 = input disabled 10 false false
    Read: ;IO4 = built-in-led disabled 10 false false
    Read: ;IO12 = input-pullup disabled 10 false false
    Read: ;IO13 = input-pullup disabled 10 false false
    Read:
    Read: [AutoTimer]
    Start ReadParameter ([AutoTimer]
    AutoStart = true
    Intervall = 4.85
    [Debug]
    Start ReadParameter ([Debug])
    Logfile = false
    [System]
    Start ReadParameter ([System])
    TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
    ;TimeServer = undefined
    ;AutoAdjustSummertime = false
    ;Hostname = undefined
    SetupMode = true
    END OF FILE
    *************** Start GPIOHandler_Init *****************
    I (18088) server_GPIO: read GPIO config and init GPIO
    [MakeImage]
    Brightness = -2
    ;Contrast = 0
    ;Saturation = 0
    ImageQuality = 5
    ImageSize = VGA
    [Alignment]
    InitialRotate = 179
    SearchFieldX = 20
    SearchFieldY = 20
    [Digits]
    [Analog]
    [PostProcessing]
    PreValueUse = true
    ErrorMessage = true
    ;[MQTT]
    ;ClientID = wasser
    ;user = USERNAME
    ;[GPIO]
    [AutoTimer]
    AutoStart = true
    Intervall = 4.85
    [Debug]
    Logfile = false
    [System]
    SetupMode = true
    I (18248) server_GPIO: GPIO init comleted, handler is disabled
    Flashdauer: 5000
    Image loaded from memory: 0, 0, 0
    Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
    Core 0 register dump:
    PC      : 0x400ef308  PS      : 0x00060030  A0      : 0x8018c5ca  A1      : 0x3fff9fd0
    A2      : 0x00000780  A3      : 0x3ffc3c68  A4      : 0x00000280  A5      : 0x00000780
    A6      : 0x00000001  A7      : 0x000001e0  A8      : 0x00000000  A9      : 0x3f82c168
    A10     : 0x00000000  A11     : 0x3fffa388  A12     : 0x00003826  A13     : 0x00000001
    A14     : 0x3ffc35ac  A15     : 0x3fff9ef0  SAR     : 0x0000001e  EXCCAUSE: 0x0000001c
    EXCVADDR: 0x00000000  LBEG    : 0x4008bed5  LEND    : 0x4008bee5  LCOUNT  : 0xffffffff
    Backtrace: 0x400ef305:0x3fff9fd0 0x4018c5c7:0x3fffa040 0x4018c64e:0x3fffa080 0x40189d89:0x3fffa110 0x400f13a2:0x3fffa1c0
    Rebooting...
    jomjol
    #2113
    @xsev sagte in Wasserzähler - Version 2 - all-in-device:
    das Problem ist das PSRAM - da bist du wohl übers Ohr gehauen worden:
    [0;32mI (881) psram: This chip is ESP32-D0WD
    [0;32mI (886) spiram: Found 16MBit SPI RAM device
    Du hast nur einen 16MBit (=2 MByte) verbaut - da sollte eigentlich 64MBit stehen (=8 MByte, davon aber nur 4 MByte nutzbar.
    Reklamieren und neu bestellen - kommt wohl gerade häufig vor!
    XsevX 2 Antworten Letzte Antwort
    • J jomjol
      XsevX Offline
      XsevX Offline
      Xsev
      #2114
      @jomjol Ach schande ok, danke für die Info.
      • J jomjol
        XsevX Offline
        XsevX Offline
        Xsev
        #2115
        @jomjol Ich hatte noch einen alten ESP mit defekter Cam rumliegen, ich hab jetzt mal das alte Board genommen mit neuer Cam. Laut Log hat dieser ESP die 64Mbit aber der Fehler bleibt der selbe. Kurz vor Logende meldet er folgendes:
        14:04:37.130 -> 14:04:37.130 -> Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
        14:04:37.130 -> Core 0 register dump:
        14:04:37.130 -> PC      : 0x400ef308  PS      : 0x00060530  A0      : 0x8018c5ca  A1      : 0x3fff9fd0
        14:04:37.130 -> A2      : 0x00000780  A3      : 0x3ffc3c68  A4      : 0x00000280  A5      : 0x00000780
        14:04:37.130 -> A6      : 0x00000001  A7      : 0x000001e0  A8      : 0x00000000  A9      : 0x3f82c168
        14:04:37.130 -> A10     : 0x00000000  A11     : 0x3f92ddd8  A12     : 0x00004d80  A13     : 0x00000001
        14:04:37.130 -> A14     : 0x3ffc35ac  A15     : 0x3fff9ef0  SAR     : 0x0000001a  EXCCAUSE: 0x0000001c
        14:04:37.130 -> EXCVADDR: 0x00000000  LBEG    : 0x4008bed5  LEND    : 0x4008bee5  LCOUNT  : 0xffffffff
        14:04:37.130 ->
        14:04:37.130 -> ELF file SHA256: 49d2944a34ee25eb
        14:04:37.130 -> Backtrace: 0x400ef305:0x3fff9fd0 0x4018c5c7:0x3fffa040 0x4018c64e:0x3fffa080 0x40189d89:0x3fffa110 0x400f13a2:0x3fffa1c0
        Das ganze Log:
        14:04:15.068 -> Rebooting...
        14:04:15.068 -> ets Jun  8 2016 00:22:57
        14:04:15.068 ->
        14:04:15.068 -> rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
        14:04:15.068 -> configsip: 0, SPIWP:0xee
        14:04:15.068 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
        14:04:15.068 -> mode:DIO, clock div:2
        14:04:15.068 -> load:0x3fff0030,len:4
        14:04:15.068 -> load:0x3fff0034,len:7248
        14:04:15.068 -> ho 0 tail 12 room 4
        14:04:15.068 -> load:0x40078000,len:13856
        14:04:15.068 -> load:0x40080400,len:4052
        14:04:15.068 -> entry 0x40080688
        14:04:15.068 -> I (31) boot: ESP-IDF 3.40100.200827 2nd stage bootloader
        14:04:15.068 -> I (31) boot: compile time 18:56:57
        14:04:15.068 -> I (31) boot: chip revision: 1
        14:04:15.068 -> I (34) boot_comm: chip revision: 1, min. bootloader chip revision: 0
        14:04:15.068 -> I (41) boot.esp32: SPI Speed      : 40MHz
        14:04:15.068 -> I (46) boot.esp32: SPI Mode       : DIO
        14:04:15.068 -> I (51) boot.esp32: SPI Flash Size : 4MB
        14:04:15.068 -> I (55) boot: Enabling RNG early entropy source...
        14:04:15.068 -> I (61) boot: Partition Table:
        14:04:15.068 -> I (64) boot: ## Label            Usage          Type ST Offset   Length
        14:04:15.068 -> I (71) boot:  0 nvs              WiFi data        01 02 00009000 00004000
        14:04:15.068 -> I (79) boot:  1 otadata          OTA data         01 00 0000d000 00002000
        14:04:15.068 -> I (86) boot:  2 phy_init         RF data          01 01 0000f000 00001000
        14:04:15.068 -> I (94) boot:  3 ota_0            OTA app          00 10 00010000 001db000
        14:04:15.068 -> I (101) boot:  4 ota_1            OTA app          00 11 001f0000 001db000
        14:04:15.068 -> I (109) boot: End of partition table
        14:04:15.068 -> I (113) boot_comm: chip revision: 1, min. application chip revision: 0
        14:04:15.068 -> I (120) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x51048 (331848) map
        14:04:15.224 -> I (273) esp_image: segment 1: paddr=0x00061070 vaddr=0x3ffb0000 size=0x0504c ( 20556) load
        14:04:15.224 -> I (283) esp_image: segment 2: paddr=0x000660c4 vaddr=0x40080000 size=0x00404 (  1028) load
        14:04:15.224 -> I (284) esp_image: segment 3: paddr=0x000664d0 vaddr=0x40080404 size=0x09b48 ( 39752) load
        14:04:15.224 -> I (310) esp_image: segment 4: paddr=0x00070020 vaddr=0x400d0020 size=0x122ec8 (1191624) map
        14:04:15.718 -> I (826) esp_image: segment 5: paddr=0x00192ef0 vaddr=0x40089f4c size=0x12c68 ( 76904) load
        14:04:16.357 -> I (880) boot: Loaded app from partition at offset 0x10000
        14:04:16.357 -> I (880) boot: Disabling RNG early entropy source...
        14:04:16.357 -> I (881) psram: This chip is ESP32-D0WD
        14:04:16.357 -> I (885) spiram: Found 64MBit SPI RAM device
        14:04:16.357 -> I (890) spiram: SPI RAM mode: flash 40m sram 40m
        14:04:16.357 -> I (895) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
        14:04:16.357 -> I (903) cpu_start: Pro cpu up.
        14:04:16.357 -> I (906) cpu_start: Application information:
        14:04:16.357 -> I (911) cpu_start: Project name:     esp32cam-server-only
        14:04:16.357 -> I (917) cpu_start: App version:      0.0.9.3
        14:04:16.357 -> I (922) cpu_start: Compile time:     Sep 25 2021 18:55:36
        14:04:16.357 -> I (928) cpu_start: ELF file SHA256:  49d2944a34ee25eb...
        14:04:16.357 -> I (934) cpu_start: ESP-IDF:          3.40100.200827
        14:04:16.357 -> I (940) cpu_start: Starting app cpu, entry point is 0x40081cf0
        14:04:16.357 -> I (931) cpu_start: App cpu up.
        14:04:16.841 -> I (1837) spiram: SPI SRAM memory test OK
        14:04:16.841 -> I (1838) heap_init: Initializing. RAM available for dynamic allocation:
        14:04:16.841 -> I (1838) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
        14:04:16.841 -> I (1844) heap_init: At 3FFC2A08 len 0001D5F8 (117 KiB): DRAM
        14:04:16.841 -> I (1851) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
        14:04:16.841 -> I (1857) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
        14:04:16.841 -> I (1864) heap_init: At 4009CBB4 len 0000344C (13 KiB): IRAM
        14:04:16.841 -> I (1870) cpu_start: Pro cpu start user code
        14:04:16.841 -> I (1875) spiram: Adding pool of 4096K of external SPI memory to heap allocator
        14:04:16.841 -> I (1900) spi_flash: detected chip: generic
        14:04:16.841 -> I (1901) spi_flash: flash io: dio
        14:04:16.841 -> I (1901) cpu_start: Starting scheduler on PRO CPU.
        14:04:16.841 -> I (0) cpu_start: Starting scheduler on APP CPU.
        14:04:16.841 -> I (1909) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations
        14:04:16.841 -> Do Reset Camera
        14:04:16.841 -> I (1919) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
        14:04:18.823 -> Init Camera
        14:04:18.823 -> I (3929) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        14:04:18.958 -> I (3929) gpio: GPIO[18]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        14:04:18.958 -> I (3929) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        14:04:18.958 -> I (3939) gpio: GPIO[21]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        14:04:18.958 -> I (3949) gpio: GPIO[22]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        14:04:18.958 -> I (3959) gpio: GPIO[23]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        14:04:18.958 -> I (3969) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        14:04:18.958 -> I (3979) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        14:04:18.958 -> I (3989) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        14:04:18.958 -> I (3999) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        14:04:18.958 -> I (4009) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
        14:04:18.958 -> I (4019) sccb: pin_sda 26 pin_scl 27
        14:04:18.958 ->
        14:04:18.958 -> I (4019) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
        14:04:19.098 -> I (4169) camera: Detected OV2640 camera
        14:04:19.098 -> I (4179) camera: Allocating 1 frame buffers (150 KB total)
        14:04:19.098 -> I (4189) camera: Allocating 150 KB frame buffer in OnBoard RAM
        14:04:19.694 -> I (4789) main: Using SDMMC peripheral
        14:04:19.788 -> Name: SN64G
        14:04:19.788 -> Type: SDHC/SDXC
        14:04:19.788 -> Speed: 20 MHz
        14:04:19.788 -> Size: 60906MB
        14:04:19.788 -> I (4849) server_ota: Start CheckOTAUpdateCheck ...
        14:04:19.788 -> Start CheckOTAUpdateCheck ...
        14:04:19.788 -> I (4859) server_ota: SHA-256 for the partition table: : 9d4a2809ae90fb20709a8ca3dd3ac3462e1e73286bcd31b689060c91de06fa3a
        14:04:19.835 -> I (4919) server_ota: SHA-256 for bootloader: : ee8b22523ca2a6f08e0e01e2e6dd2ae40f0a13f93d5c02794b19cfca199b3e9e
        14:04:20.491 -> I (5559) server_ota: SHA-256 for current firmware: : dc1319e0f2d427d7bc8d303fa98e0456e09c555804634127bb0960ca1cb42b6a
        14:04:20.491 -> CheckOTAUpdate Partition: ESP_OK
        14:04:20.538 -> open config file /sdcard/wlan.ini in mode r
        14:04:20.538 -> file loaded
        14:04:20.538 ->
        14:04:20.538 -> WLan: Rocket, XXXXXXXXXXXXX
        14:04:20.538 -> Hostename: Watermeter13
        14:04:20.538 -> I (5609) wifi:wifi driver task: 3ffd9cc4, prio:23, stack:6656, core=0
        14:04:20.538 -> I (5609) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
        14:04:20.538 -> I (5639) wifi:wifi firmware version: 3ea4c76
        14:04:20.585 -> I (5639) wifi:config NVS flash: enabled
        14:04:20.585 -> I (5639) wifi:config nano formating: disabled
        14:04:20.585 -> I (5639) wifi:Init dynamic tx buffer num: 32
        14:04:20.585 -> I (5649) wifi:Init data frame dynamic rx buffer num: 32
        14:04:20.585 -> I (5649) wifi:Init management frame dynamic rx buffer num: 32
        14:04:20.585 -> I (5659) wifi:Init management short buffer num: 32
        14:04:20.585 -> I (5659) wifi:Init static tx buffer num: 16
        14:04:20.585 -> I (5669) wifi:Init static rx buffer size: 1600
        14:04:20.585 -> I (5669) wifi:Init static rx buffer num: 10
        14:04:20.585 -> I (5669) wifi:Init dynamic rx buffer num: 32
        14:04:20.721 -> I (5769) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
        14:04:20.721 -> I (5769) wifi:mode : sta (9c:9c:1f:c9:24:34)
        14:04:20.721 -> I (5769) BLINK: Blinken - start
        14:04:20.721 -> I (5779) wifi station: wifi_init_sta finished.
        14:04:20.815 -> I (5899) wifi:new:<3,0>, old:<1,0>, ap:<255,255>, sta:<3,0>, prof:1
        14:04:20.815 -> I (5899) wifi:state: init -> auth (b0)
        14:04:20.815 -> I (5919) wifi:state: auth -> assoc (0)
        14:04:20.862 -> I (5929) wifi:state: assoc -> run (10)
        14:04:20.862 -> I (5959) wifi:connected with Rocket, aid = 2, channel 3, BW20, bssid = e0:63:da:74:3e:f2
        14:04:20.909 -> I (5959) wifi:security: WPA2-PSK, phy: bgn, rssi: -72
        14:04:20.909 -> I (5969) wifi:pm start, type: 1
        14:04:20.909 ->
        14:04:20.909 -> I (5979) BLINK: Blinken - done
        14:04:20.956 -> I (6019) wifi:AP's beacon interval = 102400 us, DTIM period = 1
        14:04:21.518 -> I (6599) esp_netif_handlers: sta ip: 192.168.13.206, mask: 255.255.255.0, gw: 192.168.13.1
        14:04:21.518 -> I (6599) wifi station: got ip:192.168.13.206
        14:04:21.518 -> I (6599) BLINK: Blinken - start
        14:04:21.518 -> I (6609) wifi station: connected to ap SSID:Rocket password:XXXXXXXXXXXXX
        14:04:21.518 -> main: sleep for : 200ms
        14:04:23.514 -> I (8619) sntp: Time is not set yet. Connecting to WiFi and getting time over NTP.
        14:04:23.561 -> I (8619) sntp: Initializing SNTP
        14:04:23.561 -> I (8619) sntp: Waiting for system time to be set... (1/10)
        14:04:25.525 -> I (10619) sntp: Waiting for system time to be set... (2/10)
        14:04:27.593 -> TimeZone set to CET-1CEST,M3.5.0,M10.5.0/3
        14:04:27.593 -> Logfile opened: /sdcard/log/message/log_2022-03-20.txt
        14:04:27.593 -> I (12629) sntp: The current date/time in Berlin is: Sun Mar 20 14:04:29 2022
        14:04:27.593 -> I (12629) sntp: The current date/time in Berlin is: 2022-03-20_14:04
        14:04:27.593 -> timeist 20220320-140429
        14:04:27.593 -> time 20220320-140429
        14:04:27.593 -> main: sleep for : 200ms
        14:04:29.619 -> I (14659) server-main: Starting server on port: '80'
        14:04:29.619 -> I (14659) server-main: Registering URI handlers
        14:04:29.619 -> I (14659) server_tflite: server_part_camera - Registering URI handlers
        14:04:29.619 -> I (14659) server_ota: server_ota - Registering URI handlers
        14:04:29.619 -> I (14669) server_GPIO: start GpioHandler
        14:04:29.619 -> I (14669) server_GPIO: register GPIO Uri
        14:04:29.619 -> I (14679) server_GPIO: server_GPIO - Registering URI handlers
        14:04:29.619 -> vor reg server main
        14:04:29.619 -> vor dotautostart
        14:04:29.619 -> task_autodoFlow: start
        14:04:29.619 -> open config file /sdcard/config/config.ini in mode r
        14:04:29.619 -> [MakeImage]
        14:04:29.619 -> Start ReadParameter ([MakeImage]
        14:04:29.619 -> )
        14:04:29.619 -> ;LogImageLocation = /log/source
        14:04:29.619 -> WaitBeforeTakingPicture = 5
        14:04:29.619 -> ;LogfileRetentionInDays = 15
        14:04:29.619 -> Brightness = -2
        14:04:29.619 -> ;Contrast = 0
        14:04:29.619 -> ;Saturation = 0
        14:04:29.619 -> ImageQuality = 5
        14:04:29.619 -> ImageSize = VGA
        14:04:29.619 -> FixedExposure = false
        14:04:29.619 ->
        14:04:29.619 -> [Alignment]
        14:04:31.563 -> Start ReadParameter ([Alignment])
        14:04:31.563 -> InitialRotate = 179
        14:04:31.563 -> InitialMirror = false
        14:04:31.563 -> SearchFieldX = 20
        14:04:31.563 -> SearchFieldY = 20
        14:04:31.563 -> AlignmentAlgo = Default
        14:04:31.563 -> FlipImageSize = false
        14:04:31.563 -> /config/ref0.jpg 103 271
        14:04:31.563 -> /config/ref1.jpg 442 142
        14:04:31.563 ->
        14:04:31.563 -> [Digits]
        14:04:31.563 -> Start ReadParameter ([Digits])
        14:04:31.563 -> Model = /config/dig1210s2q.tflite
        14:04:31.563 -> ;LogImageLocation = /log/digit
        14:04:31.563 -> ;LogfileRetentionInDays = 3
        14:04:31.563 -> ModelInputSize = 20 32
        14:04:31.563 -> main.dig1 294 126 30 54
        14:04:31.563 -> GetGENERAL - GENERAL main - roi dig1
        14:04:31.563 -> main.dig2 343 126 30 54
        14:04:31.563 -> GetGENERAL - GENERAL main - roi dig2
        14:04:31.563 -> main.dig3 391 126 30 54
        14:04:31.563 -> GetGENERAL - GENERAL main - roi dig3
        14:04:31.563 ->
        14:04:31.563 -> [Analog]
        14:04:31.563 -> Start ReadParameter ([Analog])
        14:04:31.563 -> Model = /config/ana0700s1lq.tflite
        14:04:31.563 -> ;LogImageLocation = /log/analog
        14:04:31.563 -> ModelInputSize = 32 32
        14:04:31.563 -> ExtendedResolution = true
        14:04:31.563 -> main.ana1 432 230 92 92
        14:04:31.563 -> GetGENERAL - GENERAL main - roi ana1
        14:04:31.563 -> main.ana2 379 332 92 92
        14:04:31.563 -> GetGENERAL - GENERAL main - roi ana2
        14:04:31.563 -> main.ana3 283 374 92 92
        14:04:31.563 -> GetGENERAL - GENERAL main - roi ana3
        14:04:31.563 -> main.ana4 155 328 92 92
        14:04:31.563 -> GetGENERAL - GENERAL main - roi ana4
        14:04:31.563 ->
        14:04:31.563 -> [PostProcessing]
        14:04:31.563 -> Start ReadParameter ([PostProcessing])
        14:04:31.563 -> Anzahl NUMBERS: 1 - DIGITS: 1, ANALOG: 1
        14:04:31.563 -> Number main, Anz DIG: 3, Anz ANA 4
        14:04:31.563 -> main.DecimalShift = 0
        14:04:31.563 -> PreValueUse = true
        14:04:31.563 -> PreValueAgeStartup = 720
        14:04:31.563 -> AllowNegativeRates = false
        14:04:31.563 -> main.MaxRateValue = 0.1
        14:04:31.563 -> ErrorMessage = true
        14:04:31.563 -> CheckDigitIncreaseConsistency = true
        14:04:31.563 ->
        14:04:31.563 -> ;[MQTT]
        14:04:31.563 -> Read Zeile Prevalue.ini: 2020-11-30_12-02-22
        14:04:31.563 -> 42.013401
        14:04:31.563 -> TIME: 120, 10, 0, 1, 1, 5
        14:04:31.563 -> Read: ;Uri = mqtt://IP-ADRESS:1883
        14:04:31.563 -> Read: ;MainTopic = wasserzaehler
        14:04:31.563 -> Read: ;ClientID = wasser
        14:04:31.563 -> Read: ;user = USERNAME
        14:04:31.563 -> Read: ;password = PASSWORD
        14:04:31.563 -> Read: ;[GPIO]
        14:04:31.563 -> Read: ;MainTopicMQTT = wasserzaehler/GPIO
        14:04:31.563 -> Read: ;IO0 = input disabled 10 false false
        14:04:31.563 -> Read: ;IO1 = input disabled 10 false false
        14:04:31.563 -> Read: ;IO3 = input disabled 10 false false
        14:04:31.563 -> Read: ;IO4 = built-in-led disabled 10 false false
        14:04:31.563 -> Read: ;IO12 = input-pullup disabled 10 false false
        14:04:31.563 -> Read: ;IO13 = input-pullup disabled 10 false false
        14:04:31.563 -> Read: [AutoTimer]
        14:04:31.563 -> Start ReadParameter ([AutoTimer]
        14:04:31.563 -> )
        14:04:31.563 -> AutoStart = true
        14:04:31.563 -> Intervall = 4.85
        14:04:31.563 ->
        14:04:31.563 -> [Debug]
        14:04:31.563 -> Start ReadParameter ([Debug])
        14:04:31.563 -> Logfile = false
        14:04:31.563 -> LogfileRetentionInDays = 3
        14:04:31.563 ->
        14:04:31.563 -> [System]
        14:04:31.563 -> Start ReadParameter ([System])
        14:04:31.563 -> TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
        14:04:31.563 -> TimeZone set to CET-1CEST,M3.5.0,M10.5.0/3
        14:04:31.563 -> ;TimeServer = undefined
        14:04:31.563 -> ;AutoAdjustSummertime = false
        14:04:31.563 -> ;Hostname = undefined
        14:04:31.563 -> SetupMode = true
        14:04:31.563 -> END OF FILE
        14:04:31.563 -> *************** Start GPIOHandler_Init *****************
        14:04:31.563 -> I (16519) server_GPIO: read GPIO config and init GPIO
        14:04:31.563 -> open config file /sdcard/config/config.ini in mode r
        14:04:31.563 -> [MakeImage]
        14:04:31.563 -> ;LogImageLocation = /log/source
        14:04:31.563 -> WaitBeforeTakingPicture = 5
        14:04:31.563 -> ;LogfileRetentionInDays = 15
        14:04:31.563 -> Brightness = -2
        14:04:31.563 -> ;Contrast = 0
        14:04:31.563 -> ;Saturation = 0
        14:04:31.563 -> ImageQuality = 5
        14:04:31.563 -> ImageSize = VGA
        14:04:31.563 -> FixedExposure = false
        14:04:31.563 ->
        14:04:31.563 -> [Alignment]
        14:04:31.563 ->
        14:04:31.563 ->
        14:04:31.563 -> I (16609) BLINK: Blinken - done
        14:04:31.563 ->
        14:04:31.563 ->
        14:04:31.563 -> ;Uri = mqtt://IP-ADRESS:1883
        14:04:31.563 -> ;MainTopic = wasserzaehler
        14:04:31.563 -> ;ClientID = wasser
        14:04:31.563 -> ;user = USERNAME
        14:04:31.563 -> ;password = PASSWORD
        14:04:31.563 ->
        14:04:31.563 -> ;[GPIO]
        14:04:31.563 -> ;MainTopicMQTT = wasserzaehler/GPIO
        14:04:31.563 -> ;IO0 = input disabled 10 false false
        14:04:31.563 -> ;IO1 = input disabled 10 false false
        14:04:31.563 -> ;IO3 = input disabled 10 false false
        14:04:31.563 -> ;IO4 = built-in-led disabled 10 false false
        14:04:31.610 -> ;IO12 = input-pullup disabled 10 false false
        14:04:31.610 -> ;IO13 = input-pullup disabled 10 false false
        14:04:31.610 ->
        14:04:31.610 -> [AutoTimer]
        14:04:31.610 -> AutoStart = true
        14:04:31.610 -> Intervall = 4.85
        14:04:31.610 ->
        14:04:31.610 -> [Debug]
        14:04:31.610 -> Logfile = false
        14:04:31.610 -> LogfileRetentionInDays = 3
        14:04:31.610 ->
        14:04:31.610 -> [System]
        14:04:31.610 -> TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
        14:04:31.610 -> ;TimeServer = undefined
        14:04:31.610 -> ;AutoAdjustSummertime = false
        14:04:31.610 -> ;Hostname = undefined
        14:04:31.610 -> SetupMode = true
        14:04:31.610 -> I (16689) server_GPIO: GPIO init comleted, handler is disabled
        14:04:31.610 -> Flashdauer: 5000
        14:04:37.130 -> Image loaded from memory: 0, 0, 0
        14:04:37.130 ->
        14:04:37.130 ->
        14:04:37.130 -> Rebooting...
        14:04:37.130 -> ets Jun  8 2016 00:22:57
        • XsevX Xsev
          14:04:37.130 ->
          Das ganze Log:
          14:04:15.068 ->
          14:04:18.958 ->
          14:04:20.538 ->
          14:04:20.909 ->
          14:04:29.619 -> )
          14:04:29.619 ->
          14:04:31.563 ->
          14:04:31.563 ->
          14:04:31.563 ->
          14:04:31.563 ->
          14:04:31.563 -> )
          14:04:31.563 ->
          14:04:31.563 ->
          14:04:31.563 ->
          14:04:31.563 ->
          14:04:31.563 ->
          14:04:31.563 ->
          14:04:31.563 ->
          14:04:31.563 ->
          14:04:31.610 ->
          14:04:31.610 ->
          14:04:31.610 ->
          14:04:37.130 ->
          14:04:37.130 ->
          martinschm
          #2116
          ich habe gerade in meinen history Daten gesehen, das bei mir die 4 an der dritten Stelle wohl nicht richtig erkannt wird. Lauter raw Werte die ein N dort anzeigen. Mittlerweile ist der Zähler bei der 5 und dann der 6 angekommen.
          Kann ich irgendwie mit anderen Trainingswerten ein Test laufen lassen ob er damit die 4 richtig erkannt hätte?
          ciao
          Martin
          • M martinschm
            ciao
            Martin
            toki1973
            #2117
            Kann mir das jemand erklären?
            NUC, PROXMOX, Grafana, Influx, Unify
            • T toki1973
              JoergH
              #2118
              @toki1973 Was ist denn unklar? Der Zähler wird korrekt abgelesen, aber zuvor hatte er wohl mal einen höheren falschen Wert und da er nicht rückwärts zählen darf laut Deinen Einstellungen ("allow negative rates - false"), übermittelt er weiter den zuvor fälschlicherweise ermittelten, hohen Wert. Warum der mal so falsch ermittelt wurde? Keine Ahnung. Ich habe von 4 Zählern mit 3 en dauernd Probleme mit der Erkennung. Ich denke ohne eigenes Training mit den Bildern der eigenen Schrift wird es vermutlich nicht besser werden bei mir.
              • J JoergH
                mameier1234
                #2119
                @joergh Ich denke mal die Hauptfrage ist, warum da ein Sprung zwischendurch von 390 auf 411 stattfand, obwohl das MaxRateValue auf 0,9 steht...
                Das passiert bei mir auch leider immer wieder mal.. Bisher ohne Erklärung..
                Grüße,
                Martin
                XsevX 1 Antwort Letzte Antwort
                • M mameier1234
                  XsevX Offline
                  XsevX Offline
                  Xsev
                  #2120
                  @jomjol
                  Kannst du vielleicht bei Gelegenheit bitte nochmal über das Log schauen. Trotz anderem ESP (mit 64Mbit Psram) und jetzt auch neuer 32GB SD Karte, selbes Problem. Ich komm aus dem Dauerreboot einfach nicht raus.
                  14:04:37.130 ->
                  Das ganze Log:
                  14:04:15.068 ->
                  14:04:18.958 ->
                  14:04:20.538 ->
                  14:04:20.909 ->
                  14:04:29.619 -> )
                  14:04:29.619 ->
                  14:04:31.563 ->
                  14:04:31.563 ->
                  14:04:31.563 ->
                  14:04:31.563 ->
                  14:04:31.563 -> )
                  14:04:31.563 ->
                  14:04:31.563 ->
                  14:04:31.563 ->
                  14:04:31.563 ->
                  14:04:31.563 ->
                  14:04:31.563 ->
                  14:04:31.563 ->
                  14:04:31.563 ->
                  14:04:31.610 ->
                  14:04:31.610 ->
                  14:04:31.610 ->
                  14:04:37.130 ->
                  14:04:37.130 ->
                  • XsevX Xsev
                    @jomjol
                    14:04:37.130 ->
                    Das ganze Log:
                    14:04:15.068 ->
                    14:04:18.958 ->
                    14:04:20.538 ->
                    14:04:20.909 ->
                    14:04:29.619 -> )
                    14:04:29.619 ->
                    14:04:31.563 ->
                    14:04:31.563 ->
                    14:04:31.563 ->
                    14:04:31.563 ->
                    14:04:31.563 -> )
                    14:04:31.563 ->
                    14:04:31.563 ->
                    14:04:31.563 ->
                    14:04:31.563 ->
                    14:04:31.563 ->
                    14:04:31.563 ->
                    14:04:31.563 ->
                    14:04:31.563 ->
                    14:04:31.610 ->
                    14:04:31.610 ->
                    14:04:31.610 ->
                    14:04:37.130 ->
                    14:04:37.130 ->
                    jomjol
                    #2121
                    The Problem I see is here:
                    This tells, that the image from the camera could not be loaded. Can you check the connection to your camera (flex band).
                    • J jomjol
                      BorderCounter
                      #2122
                      mein Problem: Die vollen Kubikmeter (6) wird nicht erkannt. Raw Value: 0082N.075 (00826.075)- Alter Stand war 0082N.981 (00825.981). Durch den Sprung der vollen Kubikmeter von 825 auf 826 und die Tatsache, dass die 1-Kubikmeterstelle nicht richtig erkannt wird, ist die "neue Menge" kleiner als die "alte Menge". Wie gehe ich am besten damit um?
                      Ich habe Versuchsweise das Feld für die Stelle zu vergrößern, schafft aber keine Abhilfe.
                      • B BorderCounter
                        JoergH
                        #2123
                        @bordercounter Das Fenster um die Ziffer 6 sieht zu groß aus. Das würde ich mal exakt anpassen, dann erkennt er die Ziffer vielleicht besser...
                        • J JoergH
                          BorderCounter
                          #2124
                          @joergh Ich habe das Feld schon größer gemacht. als es exakt gepasst hat, war der fehler der selbe :(
                          • B BorderCounter
                            XsevX Offline
                            XsevX Offline
                            Xsev
                            #2125
                            @bordercounter Du kannst mal mit einem anderen Erkennungsfile testen, ich hab mit den älteren Versionen teilweise bessere Ergebnisse erzielt. Da sollten 2-3 auf der SD Karte sein, evtl. gibt's die auch als Download auf Git...
                              markushi
                              schrieb am zuletzt editiert von markushi
                              #2126
                              bin zufällig auch über dieses absolut geniale Projekt gestoßen und habs mal provisorisch installiert um meinen analogen Stromzähler auszulesen:
                              Funktioniert 1a und was mich echt überrascht hat, ist die hohe Erkennungsqualität der Software! Aktuell logge ich so jede Stunde den Stand in meine Postgres Datenbank:
                              Problem für mich bei dem Ganzen: Ich habe keine 3D-Drucker! Und irgendwie finde ich keinen Shop, wo ich mir ein gedrucktes Gehäuse für das Modul bestellen könnte?!? Habt ihr einen Tipp für mich? Wollte mir deswegen ungern einen 3D-Drucker anschaffen....
                              Danke!
                              Gruß - Markus
                              ERLEDIGT ---> hab jetzt bei einem Online Druckdienst Gehäuse bestellt ✌
                              • M markushi
                                Danke!
                                Gruß - Markus
                                BananaJoeB Offline
                                BananaJoeB Offline
                                BananaJoe
                                #2127
                                @markushi aus Pappe oder Bastelholz / Bastelkunststoffplatten aus dem Baumarkt.
                                Kannst du mit dem Teppichmesser zuschneiden und kleben.
                                Musst nur schauen woran du es hängen oder festklemmen kannst
                                  markushi
                                  #2128
                                  Kann ich eigentlich was machen, um die Erkennung zu verbessern? Mir scheint es so, als ob die "6" Probleme macht:
                                  Das wurde auch in anderen Posts hier erwähnt, dass es mit der Zahl wohl Probleme gibt!? Hat jemand einen Tipp für mich?
                                  • XsevX Xsev
                                    XsevX Offline
                                    XsevX Offline
                                    Xsev
                                    #2129
                                    @markushi Probier mal folgendes:
                                    • XsevX Xsev
                                      markushi
                                      #2130
                                      @xsev Was genau ist das Erkennungsfile? Sind das die dig... Files im config Verzeichnis?
                                        markushi
                                        #2131
                                        Ich zieh die Frage zurück nachdem ich ein wenig zu Tensorflow gegooglet habe 😁
                                        • J Offline
                                          juergi
                                          schrieb am zuletzt editiert von juergi
                                          #2132
                                          auch ich bin begeistert von diesem Tool und habe mir inzwischen auch eines für meinen Wasserzähler gebaut.
                                          Aktuell befinde ich mich im Probebetrieb.
                                          Da ich wegen Reflektionen oft Probleme mit falscher Erkennung habe, bin ich zu der Lösung mit externen LEDs umgestiegen. 2 WS2812B sollen hier helfen. Allerdings gehen diese bei der Erstellung eines neuen Images gar nicht an!? In der Konfiguration, bei der Erstellung eines Referenzimages, allerdings schon. Ich habe nun schon einige Versuche mit geänderten Einstellungen gemacht - die Dinger bleiben aber weiter dunkel :-(
                                          Die GPIO12 Konfiguration sieht so aus:
                                          Habe ich noch etwas übersehen oder mache etwas falsch?
                                          Hat jemand eine Idee?
                                          Jürgen
                                          Nachtrag: Ich habe das Gerät nun mal eine gute Stunde neben mir laufen lassen. Das ist das Ergebnis:
                                          Ab und an gehen die LEDs tatsächlich an (2 mal in der Zeit), sonst blieben sie aus. Nach einer der beiden Beleuchtungen blieb dann die letzte der beiden LEDs einfach an - bis zum nächsten Foto. Also irgendetwas stimmt da ja noch nicht.
                                          Hat denn niemand außer mir die externe Beleuchtung aktiviert?
