  4. VIS 1.4.13 startet nicht mehr
    6.0k
50 Beiträge 8 Kommentatoren 6.8k Aufrufe 5 Beobachtet
  • K knopers1
    iobroker update -i
    pi@raspberrypi:/opt/iobroker $ iobroker update -i
    Used repository: beta
    hash changed or no sources cached => force download of new sources
    update done
    Adapter    "admin"         : 5.3.3    , installed 5.3.3
    Adapter    "alexa2"        : 3.12.0   , installed 3.12.0
    Adapter    "cloud"         : 4.1.1    , installed 4.1.1
    Adapter    "discovery"     : 3.0.2    , installed 3.0.2
    Adapter    "email"         : 1.0.10   , installed 1.0.10
    Adapter    "flot"          : 1.10.7   , installed 1.10.7
    Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
    Adapter    "history"       : 1.11.0   , installed 1.11.0
    Adapter    "hm-rega"       : 3.0.37   , installed 3.0.37
    Adapter    "hm-rpc"        : 1.15.12  , installed 1.15.12
    Adapter    "ical"          : 1.12.1   , installed 1.12.1
    Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
    Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
    Adapter    "info"          : 1.9.19   , installed 1.9.19
    Adapter    "javascript"    : 5.5.2    , installed 5.5.2
    Controller "js-controller" : 4.0.21   , installed 3.3.22 [Updateable]
    Adapter    "km200"         : 2.0.3    , installed 2.0.3
    Adapter    "mqtt"          : 2.7.4    , installed 2.7.4
    Adapter    "node-red"      : 3.1.0    , installed 3.1.0
    Adapter    "ping"          : 1.5.3    , installed 1.5.3
    Adapter    "rflink"        : 2.1.6    , installed 2.1.6
    Adapter    "samsung"       : 0.2.9    , installed 0.2.9
    Adapter    "simple-api"    : 2.6.4    , installed 2.6.4
    Adapter    "socketio"      : 4.1.5    , installed 4.1.5
    Adapter    "sonoff"        : 2.5.0    , installed 2.5.0
    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
    Adapter    "terminal"      : 0.2.1    , installed 0.2.1
    Adapter    "tr-064"        : 4.2.16   , installed 4.2.16
    Adapter    "vis"           : 1.4.13   , installed 1.4.12 [Updateable]
    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
    Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-hqwidgets" : 1.1.9    , installed 1.1.9
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
    Adapter    "vis-metro"     : 1.2.0    , installed 1.2.0
    Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
    Adapter    "vis-weather"   : 2.5.5    , installed 2.5.5
    Adapter    "web"           : 4.2.1    , installed 4.2.1
    Adapter    "ws"            : 1.2.0    , installed 1.2.0
    Adapter    "yr"            : 5.1.3    , installed 5.1.3
    ein Upload
    iobroker upload  all
    bringt keine Besserung. Ist es bei euch auch so? Bin jetzt wieder auf die V 1.4.12 und es läuft wieder.
    arteckA Offline
    arteckA Offline
    arteck
    @knopers1 welches Gerät ? nicht zufällig Firehd
    • haselchenH haselchen
      @knopers1
      Läuft mit der neuen Version bei mir . Muss woanders bei dir haken.
      Dein JSController ist noch „ veraltet“
      Dein Update hat vermutlich deswegen nicht geklappt weil v4 glaube ich Voraussetzung ist.
      knopers1
      @haselchen said in VIS 1.4.13 startet nicht mehr:
      @knopers1
      JSController ist noch alt, da der Buderus km200 Adapter damit nicht funktioniert!
      @arteck
      am Gerät scheint es nicht zu liegen, die VIS-Seite wird weder am Laptop noch an einem Tablet aufgebaut.
      Ist hierzu wirklich ein JSController v4 notwendig?
      Ich habe das Update des VIS 1.4.13 mehrmals versucht, ständig aber mit dem gleichen Ergebniss!
      VIS 1.4.12 läuft, und V1.4.13 bleibt beim Laden hängen.....
      • K knopers1
        @knopers1
        @arteck
        arteckA Offline
        arteckA Offline
        arteck
        @knopers1 ich gerade bei mir geschaut... FireHd und alte Fire laufen
        jo js-controller sollte 4.x sein
        • arteckA arteck
          BlueEssi
          schrieb am zuletzt editiert von BlueEssi
          @arteck Gleiches Problem bei mir. js-controller auf 4.0.21. Bleibt beim "Lade Werte" hängen. Bin zurück auf 1.4.12. Das geht wieder.
          • B BlueEssi
            haselchenH Offline
            haselchenH Offline
            haselchen
            @blueessi
            Wie lange wartest du denn bei dem Bildschirm?
            Bei mir dauert das ca. 1,5min bis die VIS kommt.
            B K 2 Antworten Letzte Antwort
              @blueessi
              BlueEssi
              @haselchen Habe deutlich länger gewartet. Ich habe es auf dem Pad und am PC probiert. Es lädt bei mir sonst nur ein paar Sekunden.
                @blueessi
                knopers1
                schrieb am zuletzt editiert von knopers1
                @blueessi
                puhh, das Laden dauert sonst 3 sek und nicht länger....
                1.5min auf VIS zu warten, wieso auf einmal so lange?
                Da kann doch grundsätzlich etwas nicht in Ordnung sein.
                bahnuhrB haselchenH 3 Antworten Letzte Antwort
                • K knopers1
                  @blueessi
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  @knopers1 sagte in VIS 1.4.13 startet nicht mehr:
                  Das sehe ich auch so.
                  Das muss geändert werden.
                  Es wartet keiner so lange.
                  Danke.
                  • K knopers1
                    @blueessi
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @knopers1
                    Ich benutze die App von Iobroker .
                    Da es tatsächlich schon immer so lange dauerte stört mich das nicht . Solange es immer funktioniert könnte es auch 5min dauern 😬
                      @knopers1
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @haselchen
                      die nutze ich am Handy.
                      Aber selbst da dauert das Laden ca. 5-10 Sekunden.
                      Danke.
                      • bahnuhrB bahnuhr
                        @haselchen
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @bahnuhr
                        Ich will nicht ausschliessen, dass es an den Komponenten liegt (Lenovo Tablet) oder WLAN oder den App Einstellungen.
                        Ich kann mit der Zeit leben, aber nur , weil es seit Jahr und Tag funktioniert.
                        • K knopers1
                          @blueessi
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @knopers1
                          @BlueEssi
                          Bei euch müssen das dann Einstellungen sein, die wir, bei denen es geht, anders haben.
                          Ich gucke gerade mal , was wir vergleichen könnten.
                            @knopers1
                            @BlueEssi
                            knopers1
                            @knopers1
                            @BlueEssi
                            welche Einstellungen meist Du?
                            ich betreibe IObroker und VIS seit Anfang des Projekts und musste nie etwas anpassen.
                            Anschauen müsste man sich die V1.14.13 an, alle anderen ältere Versionen laufen Problemlos. Dort ist der Hund begraben.
                            • arteckA Offline
                              arteckA Offline
                              arteck
                              LEUTE
                              postet die Geräte wo es nicht geht
                              und welcher Browser oder App
                              ... ein einfaches "es geht nicht" ist keine Fehlerbeschreibung..
                              mit dem laden der Vis über 1 min ist auch schwachsinn.. @haselchen wo hast du das her ... never...
                              nein tun sie nicht... die 1.4.12 ging bei alten FireHd's nicht.. also nur weil es bei dir läuft heisst es nicht das es überall geht..
                              K B haselchenH 3 Antworten Letzte Antwort
                              • arteckA arteck
                                LEUTE
                                knopers1
                                @arteck said in VIS 1.4.13 startet nicht mehr:
                                LEUTE postet die Geräte wo es nicht geht... ein einfaches "es geht nicht" ist keine Fehlerbeschreibung..
                                RPI4 - nichts besonderes halt... dort läuft meine VIS.
                                Die Vis habe ich auf einem HP Laptop anzeigen wollen. Browser - Firefox.
                                • arteckA arteck
                                  LEUTE
                                  BlueEssi
                                  @arteck Bei mir war es der Firefox auf PC und die iobroker-App auf dem iPad.
                                  arteckA 2 Antworten Letzte Antwort
                                  • K knopers1
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @knopers1 was RPI4 ..das ist hardware... wo wird es Visualisiert nicht auf welcher Maschiene der iobroker läuft
                                    • B BlueEssi
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @blueessi da kommen wir der sache näher.. check mali m chrome ? nicht dass wir ein issue im FF haben
                                      • arteckA arteck
                                        knopers1
                                        • arteckA arteck
                                          LEUTE
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @arteck sagte in VIS 1.4.13 startet nicht mehr:
                                          LEUTE
                                          Wie kannst Du meine Erfahrung als Schwachsinn abtun?
                                          Soll ich Dir nen Video drehen?
                                          Komm mal von Deinem hohen Roß runter.
                                          Wenn ich der Einzige bin mit so einer Ladezeit, dann ist das so und liegt an meinem System/Einstellungen.
                                          Aber überleg vorher mal im Kopf , was Deine Finger dann schreiben.
