  4. [erledigt] Backup Fehler
    6.3k
59 Beiträge 8 Kommentatoren 5.7k Aufrufe 6 Beobachtet
  • H hm_krause
    ..nein, hatte im Adapter den Speicherort testweise rausgenommen und Sicherung "nur" Iobroker
    hm_krause
    gerade nochmals alles neu aufgesetzt, nur Iobroker restore vom 18.03, keine Datenbanken usw..
    Fehler kommt weiterhin:
    Started iobroker ...
    [DEBUG] [iobroker] - host.iobroker 176758 states saved
    [DEBUG] [iobroker] - host.iobroker 218049 objects saved
    [ERROR] [iobroker] -
    <--- Last few GCs --->
    [14743:0x35bb3ad0]   269837 ms: Mark-sweep (reduce) 2049.2 (2050.5) -> 2049.2 (2052.5) MB, 929.5 / 0.1 ms  (average mu = 0.362, current mu = 0.017) allocation failure scavenge might not succeed
    <--- JS stacktrace --->
    FATAL ERROR: MarkCompactCollector: young object promotion failed Allocation failed - JavaScript heap out of memory
    [ERROR] [iobroker] -  1: 0xa2f1a8 node::Abort() [/usr/bin/node]
    [ERROR] [iobroker] -  2: 0x975a58 node::FatalError(char const*, char const*) [/usr/bin/node]
    [ERROR] [iobroker] -  3: 0xb947e0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
    [ERROR] [iobroker] -  4: 0xb9496c v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
    [ERROR] [iobroker] -  5: 0xd3d088 v8::internal::Heap::EnsureFromSpaceIsCommitted() [/usr/bin/node]
     6: 0xd6aae0 v8::internal::EvacuateNewSpaceVisitor::Visit(v8::internal::HeapObject, int) [/usr/bin/node]
    [ERROR] [iobroker] -  7: 0xd758fc v8::internal::FullEvacuator::RawEvacuatePage(v8::internal::MemoryChunk*, long*) [/usr/bin/node]
    [ERROR] [iobroker] -  8: 0xd63688 v8::internal::Evacuator::EvacuatePage(v8::internal::MemoryChunk*) [/usr/bin/node]
     9: 0xd63920 v8::internal::PageEvacuationTask::RunInParallel(v8::internal::ItemParallelJob::Task::Runner) [/usr/bin/node]
    10: 0xd56fc0 v8::internal::ItemParallelJob::Run() [/usr/bin/node]
    [ERROR] [iobroker] - 11: 0xd773a8 void v8::internal::MarkCompactCollectorBase::CreateAndExecuteEvacuationTasks<v8::internal::FullEvacuator, v8::internal::MarkCompactCollector>(v8::internal::MarkCompactCollector*, v8::internal::ItemParallelJob*, v8::internal::MigrationObserver*, long) [/usr/bin/node]
    12: 0xd77b20 v8::internal::MarkCompactCollector::EvacuatePagesInParallel() [/usr/bin/node]
    [ERROR] [iobroker] - 13: 0xd77cb4 v8::internal::MarkCompactCollector::Evacuate() [/usr/bin/node]
    14: 0xd88a28 v8::internal::MarkCompactCollector::CollectGarbage() [/usr/bin/node]
    [ERROR] [iobroker] - 15: 0xd4a80c v8::internal::Heap::MarkCompact() [/usr/bin/node]
    16: 0xd4bd88 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
    [ERROR] [iobroker] - 17: 0xd4ec84 v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [/usr/bin/node]
    [ERROR] [iobroker] - 18: 0xd22098 v8::internal::Factory::AllocateRawWithAllocationSite(v8::internal::Handle<v8::internal::Map>, v8::internal::AllocationType, v8::internal::Handle<v8::internal::AllocationSite>) [/usr/bin/node]
    19: 0xd22154 v8::internal::Factory::NewJSObjectFromMap(v8::internal::Handle<v8::internal::Map>, v8::internal::AllocationType, v8::internal::Handle<v8::internal::AllocationSite>) [/usr/bin/node]
    [ERROR] [iobroker] - 20: 0xe2522c v8::internal::JsonParser<unsigned short>::BuildJsonObject(v8::internal::JsonParser<unsigned short>::JsonContinuation const&, std::vector<v8::internal::JsonProperty, std::allocator<v8::internal::JsonProperty> > const&, v8::internal::Handle<v8::internal::Map>) [/usr/bin/node]
    21: 0xe26428 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [/usr/bin/node]
    [ERROR] [iobroker] - 22: 0xe26a8c v8::internal::JsonParser<unsigned short>::ParseJson() [/usr/bin/node]
    23: 0xc38c64  [/usr/bin/node]
    24: 0xc392b8 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
    [ERROR] [iobroker] - 25: 0x139eacc  [/usr/bin/node]
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2022_03_20-16_40_08_backupiobroker.tar.gz
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [DEBUG] [influxDB] - InfluxDB-Backup for is finish
    [DEBUG] [influxDB] - done
    [DEBUG] [historyDB] - compress from historyDB started ...
    [DEBUG] [historyDB] - Packed 12MB so far...
    [DEBUG] [historyDB] - Packed 35MB so far...
    [DEBUG] [historyDB] - Packed 60MB so far...
    [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2022_03_20-16_40_15_backupiobroker.tar.gz
    [DEBUG] [historyDB] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0
    [DEBUG] [zigbee] - done
    [DEBUG] [grafana] - Start Grafana Backup ...
    [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Created dashboard directory
    [DEBUG] [grafana] - Created dashboards_manually_restore directory
    [DEBUG] [grafana] - Created datasource directory
    [DEBUG] [grafana] - start Grafana request ...
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [DEBUG] [grafana] - found Dashboard: verbraucher
    [DEBUG] [grafana] - found Dashboard: energie-1
    [DEBUG] [grafana] - start Grafana backup compress ...
    [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2022_03_20-16_40_50_backupiobroker.tar.gz
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    [DEBUG] [grafana] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: Strom_Steckdosen
    [DEBUG] [javascripts] - found Script: Stromverbrauch
    [DEBUG] [javascripts] - found Script: Uptime
    [DEBUG] [javascripts] - found Script: Wohnzimmer_Stehlampe
    [DEBUG] [javascripts] - found Script: Batterie
    [DEBUG] [javascripts] - found Script: Energie_Bezug
    [DEBUG] [javascripts] - found Script: Energie_Einspeisung
    [DEBUG] [javascripts] - found Script: IP_Device
    [DEBUG] [javascripts] - found Script: Lampe_Flur
    [DEBUG] [javascripts] - found Script: Onlinestatus
    [DEBUG] [javascripts] - found Script: Opnewb_temp
    [DEBUG] [javascripts] - found Script: PV_Anlage
    [DEBUG] [javascripts] - found Script: Raspi_2_VZ_Temp
    [DEBUG] [javascripts] - found Script: Raspi_4_allg__Temp
    [DEBUG] [javascripts] - found Script: SolarWebTabelle
    [DEBUG] [javascripts] - found Script: Steckdose_Lampe_WZ
    [DEBUG] [javascripts] - found Script: Stromverbrauch_gesamt
    [DEBUG] [javascripts] - found Script: Test_für_IPDevices
    [DEBUG] [javascripts] - found Script: Wasser
    [DEBUG] [javascripts] - found Script: Wasser_History
    [DEBUG] [javascripts] - found Script: FB_Abfrage
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_03_20-16_40_56_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [cifs] - Copy iobroker_2022_03_20-16_35_37_backupiobroker.tar.gz...
    [ERROR] [cifs] - Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/iobroker_2022_03_20-16_35_37_backupiobroker.tar.gz'
    [DEBUG] [cifs] - Copy influxDB_2022_03_20-16_40_08_backupiobroker.tar.gz...
    [DEBUG] [cifs] - Copy historyDB_2022_03_20-16_40_15_backupiobroker.tar.gz...
    [DEBUG] [cifs] - Copy zigbee.0_2022_03_20-16_40_47_backupiobroker.tar.gz...
    [DEBUG] [cifs] - Copy grafana_2022_03_20-16_40_50_backupiobroker.tar.gz...
    [DEBUG] [cifs] - Copy javascripts_2022_03_20-16_40_56_backupiobroker.tar.gz...
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [EXIT] 0
    • H hm_krause
      [EXIT] 0
      HomoranH Offline
      HomoranH Offline
      @hm_krause sagte in Backitup Fehler:
      du hast ein Speicherproblem
      wie, genau?
      wie groß ist das?
      Vor dem restore-versuch keine Probleme?
      wie passt das zu
      Thomas BraunT H 2 Antworten Letzte Antwort
        wie, genau?
        wie groß ist das?
        wie passt das zu
        @homoran sagte in Backitup Fehler:
        Genauer ein Problem mit dem Heap. Der ist soweit ich weiß für nodejs auf 2GB gedeckelt.
        190162 Status und 234950 Objekte ist wohl etwas viel...
        [DEBUG] [iobroker] - host.iobroker 190162 states saved
        [DEBUG] [iobroker] - host.iobroker 234950 objects saved
        @hm_krause Wo kommt der ganze Kram her?
        H 1 Antwort Letzte Antwort
          wie, genau?
          wie groß ist das?
          wie passt das zu
          hm_krause
          --wie, genau?
          Iobroker mit "curl -sLf https://iobroker.net/install.sh | bash -" installiert
          dann Backup vom Iobroker vom 18.03 eingespielt (Größe 23095 kb)
          Backup von Grafana, Influxdb, History, Javascipt und Zigbee nicht eingespielt.
          Versuch Backup zu erstellen :-( gescheitert
            hm_krause
            ...das ist installiert:
            pi@iobroker:~ $ iob list instances
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run                                      as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
            + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
            + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
            + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
            + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run                                      as: admin
              system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
              system.adapter.smartmeter.1             : smartmeter            : iobroker                                 - disabled
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
              system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
              system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run                                      as: admin
            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
            + instance is alive
            • apollon77A Offline
              Haaalloooo :-)
              Also ja zwei Themen sehe ich hier:
              1.) backup geht nicht weil nicht genug RAM frei ist ... Was sagt denn "free -m" so? Und wie sieht die Ausgabe von "top" aus?
              Mal versucht ob Backup tut wenn du ioBroker stoppst? Also manuelles "iob backup" kommando ohne Backitup?
              2.)
              Ist ne menge ... Wo kommen die denn her? Der übliche verdächtige "Ble" ist bei Dir ja nicht an Board.
              • apollon77A apollon77
                Haaalloooo :-)
                2.)
                hm_krause
                @apollon77
                pi@iobroker:~ $ free -m
                              gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
                Speicher:       7812        3082         647           0        4082        4693
                Swap:             99           1          98
                pi@iobroker:~ $ top
                top - 17:08:56 up  2:44,  1 user,  load average: 1,45, 1,16, 1,16
                Tasks: 173 total,   3 running, 170 sleeping,   0 stopped,   0 zombie
                %CPU(s): 26,2 us,  3,6 sy,  0,0 ni, 69,9 id,  0,0 wa,  0,0 hi,  0,3 si,  0,0 st
                MiB Spch:   7812,0 total,    451,4 free,   3275,7 used,   4084,9 buff/cache
                MiB Swap:    100,0 total,     98,7 free,      1,3 used.   4500,5 avail Spch
                    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                   7065 iobroker  20   0 1858920   1,0g  35412 R  87,7  13,2 114:52.91 iobroker.js-con
                  16670 iobroker  20   0  662596  69940  29424 R  11,9   0,9   0:02.09 node
                   8035 iobroker  20   0  934068  79012  35420 S   3,6   1,0   1:29.85 io.tr-064.0
                  10538 iobroker  20   0  957780 108868  31660 S   3,0   1,4   5:03.46 io.zigbee.0
                   7093 iobroker  20   0 1233196 372344  35684 S   2,6   4,7   3:33.51 io.admin.0
                   8528 iobroker  20   0 1377640 536396  35668 S   2,6   6,7  16:37.12 io.javascript.0
                  12193 iobroker  20   0 1102200 254640  30656 S   1,3   3,2   4:32.46 io.web.0
                  15321 iobroker  20   0 1008648 149564  30180 S   1,3   1,9   0:56.23 io.influxdb.0
                   8546 iobroker  20   0  942320  83736  30036 S   1,0   1,0   1:16.32 io.mqtt.1
                  12575 root      20   0       0      0      0 I   0,7   0,0   0:03.18 kworker/u8:1-ext4-rsv-conversion
                     12 root      20   0       0      0      0 S   0,3   0,0   0:02.76 ksoftirqd/0
                     90 root     -51   0       0      0      0 S   0,3   0,0   0:20.79 irq/51-mmc0
                   8539 iobroker  20   0  664520  67952  30052 S   0,3   0,8   0:17.42 io.mqtt.0
                  10147 iobroker  20   0  675720  83352  34888 S   0,3   1,0   1:19.42 io.upnp.0
                  10181 iobroker  20   0  742020  87568  30040 S   0,3   1,1   3:02.73 io.sourceanalyt
                  11595 iobroker  20   0  661816  66412  34744 S   0,3   0,8   0:11.96 io.shuttercontr
                  15780 root      20   0       0      0      0 I   0,3   0,0   0:03.53 kworker/1:1-events_power_efficient
                  16607 iobroker  20   0  733696  67384  30548 S   0,3   0,8   0:02.69 io.vis.0
                  16681 pi        20   0   10080   3560   2816 R   0,3   0,0   0:00.03 top
                      1 root      20   0  166100  10164   7184 S   0,0   0,1   0:05.64 systemd
                      2 root      20   0       0      0      0 S   0,0   0,0   0:00.03 kthreadd
                      3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                      4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                      6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/0:0H-events_highpri
                      8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
                      9 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_kthre
                     10 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_rude_
                     11 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_trace
                     13 root      20   0       0      0      0 I   0,0   0,0   0:09.92 rcu_preempt
                     14 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/0
                     15 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
                     16 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
                     17 root      rt   0       0      0      0 S   0,0   0,0   0:00.00 migration/1
                     18 root      20   0       0      0      0 S   0,0   0,0   0:00.40 ksoftirqd/1
                     20 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/1:0H-kblockd
                     21 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
                     22 root      rt   0       0      0      0 S   0,0   0,0   0:00.01 migration/2
                ....werde ich machen..
                  Haaalloooo :-)
                  2.)
                  hm_krause
                  @apollon77
                  ...wird nix
                  pi@iobroker:/ $ sudo systemctl stop iobroker
                  pi@iobroker:/ $ iobroker backup
                  No connection to databases possible ...
                  pi@iobroker:/ $ cd /opt/iobroker
                  pi@iobroker:/opt/iobroker $ iobroker backup
                  • H Offline
                    hm_krause
                    ....und jetzt ????
                    pi@iobroker:/ $ sudo systemctl start iobroker
                    pi@iobroker:/ $ sudo systemctl status iobroker
                    ● iobroker.service - ioBroker Server
                         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                         Active: active (running) since Sun 2022-03-20 17:47:32 CET; 10s ago
                           Docs: http://iobroker.net
                       Main PID: 18644 (iobroker.js-con)
                          Tasks: 11 (limit: 8986)
                            CPU: 14.866s
                         CGroup: /system.slice/iobroker.service
                                 └─18644 iobroker.js-controller
                    Mär 20 17:47:32 iobroker systemd[1]: Started ioBroker Server.
                    pi@iobroker:/ $ iob list instances
                     Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                    pi@iobroker:/ $
                    • H Offline
                      hm_krause
                      ...wird schlimmer:
                       Cannot read system.config: undefined (OK when migrating or restoring)
                      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                              throw e;
                      Error: Connection is closed.
                          at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                          at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                          at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
                          at ScanStream.Readable.read (internal/streams/readable.js:465:10)
                          at resume_ (internal/streams/readable.js:963:12)
                          at processTicksAndRejections (internal/process/task_queues.js:82:21)
                      Emitted 'error' event on ScanStream instance at:
                          at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                          at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                          at processTicksAndRejections (internal/process/task_queues.js:95:5)
                      • H hm_krause
                        ...wird schlimmer:
                                throw e;
                        simatecS Online
                        simatecS Online
                        simatec
                        @hm_krause
                        Warum hantierst du da mit sudo?
                        Hier mal die Standard Befehle, um iobroker zu steuern
                        iob stop
                        iob start
                        iob restart
                        • Besuche meine Github Seite
                        • HowTo Restore ioBroker
                        • H hm_krause
                          @apollon77
                          ...wird nix
                          @hm_krause naja mal langsam ... alles gut. Dein System hat sehr viele Daten ... wo auchimmer die herkommen (das hattest Du noch nicht gesagt).
                          Also tweaken wir mal bissl:
                          In /opt/iobroker/iobroker-data liegen eine states.jsonl und eine objects.jsonl ... WIe groß sind die?
                          in /opt/iobroker/iobroker-data/iobroker.json in den Abschnitten zu "states" und "object" gibts jeweils ein "connectTimeout" ... schreib da mal 60000 als Wert rein.
                          Gehts dann wieder?
                            Gehts dann wieder?
                            crunchipC Offline
                            crunchipC Offline
                            @apollon77 sagte in Backitup Fehler:
                            aber gezeigt
                            https://forum.iobroker.net/post/780181
                            zumindest sind die Adapter überschaubar und schon mal kein ble dabei, (OT: das war mit der alten Adminoberfläche sehr hilfreich, sofort seine Werte zu sehen)
                            • H hm_krause
                              ...hilft Euch das weiter?
                              @hm_krause nee ... weil da sieht man nicht wo diese massen an objekten und states herkommen :-(
                              Mirr fällt aber ausser Admin auf die Admin4 "alte ui" umzuschalten gerade keine idee ein weil da wurde das im Admin angezeigt
                              Wobei an sich wäre mqtt mit den zwei Instanzen ein Kandidat, je nachdem wie "gross" die Struktur ist ... Also wenn ioBroker noch startet mal da reinschauen. Auch bitte schauen ob da was komisch ist. Die neuesten mqtt Versionen (weis snicht ob Du Beta oder Stable nutzt) legen Folder strukturen an... das könnte ggf paar Objekte adden - aber du hattest ja auch sehr viele States
                              • H Offline
                                hm_krause
                                Habe ein altes Backup eingespielt, alles aktualisiert und jetzt hier nur noch
                                "Objekte: 67196, Zustände: 56335", passt so.
                                Danke für Eure Hilfe 👍
                                • H hm_krause
                                  @hm_krause Naja Aber ich sag mal so: Ohne zu wissen wo die Objektmassen herkommen ist das für mich keine Echhte Lösung weil es dir morgen wieder passieren kann.
                                  Eine frage: Welche mqtt Version nutzt du? Beta oder Stable?
                                  Kannst Du jetzt wo alles wieder an ist ggf mal schauen ob es wieder mehr Objekte werden/geworden sind? Zeigt dir Admin oben rechts an unter "Objekte"
                                    hm_krause
                                    @apollon77
                                    mqtt und alles andere ist "Stable"
                                    Objekte: 67668, Zustände: 56711
                                    crunchipC apollon77A 2 Antworten Letzte Antwort
                                    • H hm_krause
                                      @apollon77
                                      crunchipC Offline
                                      crunchipC Offline
                                      @hm_krause also Tendenz steigend.
                                      Vllt werden auch durch den radar2 neu gefundene Geräte angelegt,(wechselnte mac adressen), seh mal den durch
                                      Wobei das auch nicht so viele sein dürften.
                                      Am einfachsten ist es wirklich die alte Admin Oberfläche zu aktivieren, so das man im Verzeichnis die einzelne Anzahl erkennt, woher es kommt.
                                      • H hm_krause
                                        @apollon77
                                        @hm_krause Finde raus was da dazukommt, sonst endest Du bald wieder dort.
                                          hm_krause
                                          @crunchip
                                          "Am einfachsten ist es wirklich die alte Admin Oberfläche zu aktivieren"
                                          Wie mache ich das richtig?
