  4. Repository Updates nicht mehr möglich
    6.0k
29 Beiträge 7 Kommentatoren 3.3k Aufrufe 5 Beobachtet
  • M Messknecht
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
    Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
    Adapter    "admin"        : 5.3.1    , installed 5.3.1
    Adapter    "backitup"     : 2.3.3    , installed 2.3.3
    Adapter    "bring"        : 1.7.13   , installed 1.7.13
    Adapter    "cloud"        : 4.1.0    , installed 4.1.0
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.0.9    , installed 3.0.9
    Adapter    "devices"      : 1.0.9    , installed 1.0.9
    Adapter    "discovery"    : 2.7.5    , installed 2.7.5
    Adapter    "dwd"          : 2.7.7    , installed 2.7.7
    Adapter    "echarts"      : 1.0.3    , installed 1.0.3
    Adapter    "flot"         : 1.10.7   , installed 1.10.7
    Adapter    "history"      : 1.10.5   , installed 1.10.5
    Adapter    "ical"         : 1.11.4   , installed 1.11.4
    Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
    Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
    Adapter    "influxdb"     : 1.9.5    , installed 1.9.5
    Adapter    "info"         : 1.9.8    , installed 1.9.8
    Adapter    "iot"          : 1.8.24   , installed 1.8.24
    Adapter    "javascript"   : 5.2.21   , installed 5.2.21
    Controller "js-controller": 4.0.18   , installed 4.0.18
    Adapter    "knx"          : 2.0.5    , installed 2.0.5
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "minuvis"      : 2.2.0    , installed 2.2.0
    Adapter    "modbus"       : 3.4.17   , installed 3.4.17
    Adapter    "mqtt"         : 2.4.1    , installed 2.4.1
    Adapter    "net-tools"    : 0.1.7    , installed 0.1.7
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 2.4.2    , installed 2.4.2
    Adapter    "odl"          : 1.1.4    , installed 1.1.4
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
    Adapter    "rssfeed"      : 1.0.0    , installed 1.0.0
    Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
    Adapter    "smartmeter"   : 3.2.1    , installed 3.2.1
    Adapter    "socketio"     : 3.1.5    , installed 4.1.0
    Adapter    "statistics"   : 1.0.9    , installed 1.0.9
    Adapter    "telegram"     : 1.11.1   , installed 1.11.1
    Adapter    "text2command" : 2.1.1    , installed 2.1.1
    Adapter    "trashschedule": 1.4.1    , installed 1.4.1
    Adapter    "viessmannapi" : 2.0.7    , installed 2.0.7
    Adapter    "vis"          : 1.4.5    , installed 1.4.5
    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
    Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
    Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
    Adapter    "vis-inventwo" : 3.2.8    , installed 3.2.8
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "web"          : 3.4.16   , installed 3.4.16
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Ich erhalte beim Versuch des Updates auch eine ähnliche Meldung.
    Ich bekomme scheinbar zwei Timeouts und dann scheint es doch zu klappen.
    Liegt dies an mir oder ist das ne Sache des Servers?
    @messknecht
    Dürfte am Server liegen. Probier doch mal die Alternativen aus.
      @messknecht
      Messknecht
      live-stable : http://iobroker.live/repo/sources-dist.json
      Mit diesem Repo scheint es zu klappen. Wenn ich es richtig sehe verlinkt mein ursprüngliches Repo auch nur auf dieses.
      Richtig?
      • M Messknecht
        Richtig?
        @messknecht sagte in Repository Updates nicht mehr möglich:
        Richtig?
        Ja, aber da hängt es manchmal
          Richtig?
          Messknecht
          • apollon77A Offline
            Bitte nicht wild die URLs ändern. Der download.iobroker.net ist das offizielle und ist ein CDN, was die Daten weltweit verteilt liefert ... Also wenn das passiert einfach später nochmal neu versuchen und gut ist!
            • apollon77A apollon77
              Messknecht
              @apollon77
              Was meinst Du genau mit wilder Änderung?
              Ich habe dieses Problem seit mehreren Tagen.
              • M Messknecht
                @apollon77
                @messknecht Ich meine das Ändern auf andere URLs.
                Ok, mal frage: lädt das File denn wenn du die URL mal im Browser öffnest? wenn ja, was sagt ein "wget https://download.iobroker.net/sources-dist-hash.json" auf dem ioBroker host ... geht das? Ich würde mal low level anfangen, weil bei mir und sehr vielen anderen besteht das Problem halt nicht, sonst würde sich mehr melden ...
                Ergo: Ich tippe auf eine "Lokale Ursache" ... jetzt gilt es rauszufinden welche dies sein könnte
                  Messknecht
                  schrieb am zuletzt editiert von Messknecht
                  @apollon77
                  Hier die Ausgabe vom wget....
                  --2022-03-16 22:52:45--  https://download.iobroker.net/sources-dist-hash.json
                  Auflösen des Hostnamens download.iobroker.net (download.iobroker.net)… 79.143.182.215, 2a02:c205:0:855::1
                  Verbindungsaufbau zu download.iobroker.net (download.iobroker.net)|79.143.182.215|:443 … verbunden.
                  Der Zertifikat-Eigentümer passt nicht zum Hostname »download.iobroker.net«.
                  Wenn ich http://iobroker.live/repo/sources-dist.json in den Browser eingebe, werde ich weitergeleitet zu http://iobroker.live/repo/sources-dist.json.
                  Deshalb habe ich dieses Repository im iobroker admin hinterlegt. Damit habe ich keine Fehler.
                  • M Messknecht
                    @apollon77
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @messknecht
                    @apollon77
                    hatte bluefox nicht letzt geschrieben, das bei dem link nur http funktionieren soll?
                    der zertifikatsfehler wurde schon an anderer stelle berichtet
                    Meine Adapter und Widgets
                    Links im Profil
                      Ja genau ... die URL ist nur http ... sorry war ein typo von mir ... mach mal das wget von http
                        Messknecht
                        @apollon77
                        Das funktioniert scheinbar
                        wget http://download.iobroker.net/sources-dist-hash.json
                        --2022-03-16 22:58:41--  http://download.iobroker.net/sources-dist-hash.json
                        Verbindungsaufbau zu download.iobroker.net (download.iobroker.net)|79.143.182.215|:80 … verbunden.
                        HTTP-Anforderung gesendet, auf Antwort wird gewartet … 301 Moved Permanently
                        Platz: http://repo.iobroker.live/sources-dist-hash.json [folgend]
                        --2022-03-16 22:58:46--  http://repo.iobroker.live/sources-dist-hash.json
                        Auflösen des Hostnamens repo.iobroker.live (repo.iobroker.live)… 104.21.88.137, 172.67.180.22, 2606:4700:3033::ac43:b416, ...
                        Verbindungsaufbau zu repo.iobroker.live (repo.iobroker.live)|104.21.88.137|:80 … verbunden.
                        HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
                        Länge: 104 [application/json]
                        Wird in »sources-dist-hash.json.1« gespeichert.
                        sources-dist-hash.json.1                     100%[============================================================================================>]     104  --.-KB/s    in 0s
                        2022-03-16 22:58:51 (5,62 MB/s) - »sources-dist-hash.json.1« gespeichert [104/104]
                        Das Auflösen dauert ziemlich lange....
                        • M Messknecht
                          @apollon77
                          @messknecht Heisst er "hängt" bei den "Auflösen" logs oder wie? Dann wäre das ein Namesever Thema (so von mir als absoluter Laie vermutet)
                            Messknecht
                            @apollon77
                            Bei Zeile 3 hängt er.
                            Komisch, dass niemand anderes davon berichtet.....
                            M OliverIOO 2 Antworten Letzte Antwort
                            • M Messknecht
                              @apollon77
                              Messknecht
                              Letztendlich wird permanent zu http://iobroker.live/repo/sources-dist.json weitergeleitet.
                              Wenn ich dieses Repository im iobroker admin eintrage, sind die Probleme verschwunden.
                              Was genau spricht gegen dieses Vorgehen?
                              • M Messknecht
                                @apollon77
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                @messknecht
                                ist auch kein iobroker problem, sondern
                                ein netzwerk-problem zwischen deinem rechner und dem verwendeten DNS-Server (also der der namen zu IP-Adressen auflöst)
                                Wenn du Linux verwendest, kannst du mal folgendes testen:
                                time nslookup download.iobroker.net
                                mit nslookup kann man genau diesen teilschritt testen und zeigt auch welchen dns-server dein system verwendet. das kann evtl für die fehlersuche helfen.
                                Wenn sie nicht installiert sind, kannst du die bind-utils installieren
                                sudo apt install bind-utils
                                setzt du pihole ein?
                                oder dns-sec?
                                evtl kannst auch mal für dein linuxsystem einen alternativen dns server testen
                                8.8.8.8 der von google
                                1.1.1.1 der von einer anderen firma, beide relativ schnell
                                mit dem folgenden Befehl kannst du den dns server testen ohne umzustellen
                                time nslookup download.iobroker.net 8.8.8.8
                                Mein Ergebnis ist mit pihole und google dns
                                real    0m0,028s
                                user    0m0,020s
                                sys     0m0,008s
                                Links im Profil
                                • OliverIOO OliverIO
                                  @messknecht
                                  oder dns-sec?
                                  real    0m0,028s
                                  user    0m0,020s
                                  sys     0m0,008s
                                  @oliverio sagte in Repository Updates nicht mehr möglich:
                                  Mein lokaler (ok denke damit die Fritzbox) noch schneller :-)
                                  ingof@io1:~$ time nslookup download.iobroker.net
                                  Server: 127.0.0.53
                                  Address: 127.0.0.53#53
                                  Non-authoritative answer:
                                  Address: 79.143.182.215
                                  Address: 2a02:c205:0:855::1
                                  real 0m0.013s
                                  user 0m0.000s
                                  sys 0m0.009s
                                  • M Messknecht
                                    Du musst das anders sehen ... Deine Formulierung muss korrekterweise lauten:
                                    AKTUELL wird permanent zu xxx weitergeleitet, aber das kann sich jede Sekunde ändern wenn es in der ioBroker Infrastruktur Änderungen gibt, die dies nötig machen.
                                    Naja ... die offizielle URL und damit die wo das Repo File "immer" erreichbar ist iost das oben genannte. jede andere URL ist "nicht sichergestellt". Also jeder der ein "iobroker.live" oder irgendeine andere URL selbst einträgt muss sich selbst darum kümmern wenn die mal nicht mehr tut :-) Für andere URLs gibt es keinerlei Garantien.
                                      Messknecht
                                      Vielen Dank euch beiden für die Gedankenanstöße. Letztendlich hätte ich auch selbst drauf kommen können.
                                      War ein dummer Layer 8 Fehler. Ich habe vor ein paar Wochen meinen Pi-Hole auf einen neuen Host migriert und dabei auch die IP Adresse des PI-Hole geändert. Die iobroker VM hatte noch die alte IP und eine Fallback-IP auf meinen Router konfiguriert. Der Fallback, so konnte ich es rekonstruieren, sorgte für die Verzögerung.
                                      Vielen Dank und Gute N8 Euch beiden.
                                      • M Messknecht
                                        @messknecht Super und danke für die Infos zur Auflösung :-)
