  4. Influx arbeitet nicht mehr stabil
    6.0k
influx grafana vis
214 Beiträge 9 Kommentatoren 29.2k Aufrufe 7 Beobachtet
    @altersrentner
    systemctl status influxd influxdb
    anschauen.
    Altersrentner
    #110
    @thomas-braun Bitte
    pi@raspberrypi:~ $ systemctl status influxd influxdb
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
       Active: active (running) since Sat 2022-03-12 14:40:27 CET; 1h 10min ago
         Docs: man:influxd(1)
     Main PID: 478 (influxd)
        Tasks: 14 (limit: 4915)
       CGroup: /system.slice/influxdb.service
               └─478 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
    Mar 12 15:50:37 raspberrypi influxd[478]: ts=2022-03-12T14:50:37.353213Z lvl=info msg="Aborted compaction" log_id=0_BaaK70000
    Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.345574Z lvl=info msg="TSM compaction (end)" log_id=0_BaaK700
    Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346336Z lvl=info msg="TSM compaction (start)" log_id=0_BaaK7
    Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346381Z lvl=info msg="Beginning compaction" log_id=0_BaaK700
    Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346403Z lvl=info msg="Compacting file" log_id=0_BaaK70000 en
    Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346425Z lvl=info msg="Compacting file" log_id=0_BaaK70000 en
    Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346445Z lvl=info msg="Compacting file" log_id=0_BaaK70000 en
    Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346465Z lvl=info msg="Compacting file" log_id=0_BaaK70000 en
    Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.346824Z lvl=info msg="Aborted compaction" log_id=0_BaaK70000
    Mar 12 15:50:38 raspberrypi influxd[478]: ts=2022-03-12T14:50:38.353357Z lvl=info msg="TSM compaction (end)" log_id=0_BaaK700
    lines 1-23
    • A Altersrentner
      @altersrentner
      Seit heute Mittag ist wieder der Wurm bei Influx am Nagen.
      Erst laufende Abbrüche und jetzt nach Update steht die Ansicht in Vis
      aber wird nicht aktualisiert.
      In der conf steht.
      [ File '/etc/influxdb/influxdb.conf' is unwritable ]
      Sonst scheint dort alles OK zu sein.
      Es kann doch nicht sein, das der Adapter aus heiterem Himmel anfängt auszusetzen.
      Seit dem letzten Problem bis heute gab es keine Ausfälle.
      Hat jemand eine Idee?
      Mit freundlichen Grüßen
      Michael
      W Online
      W Online
      Wildbill
      #111
      @altersrentner Hast Du den influx-Adapter im iobroker geupdated? Dann musst Du dort einmal das Passwort neu eintragen.
      Also das Passwort der Influx-DB.
      Gruss, Jürgen
      • W Wildbill
        Gruss, Jürgen
        Altersrentner
        #112
        @wildbill Hallo Jürgen,
        Da steht doch ein Passwort drin.?
        MfG Michael
        • A Altersrentner
          MfG Michael
          #113
          @altersrentner
          Das nochmal neueintragen. Evtl. zuvor mal bewusst ein falsches angeben.
          A 2 Antworten Letzte Antwort
            @altersrentner
            Altersrentner
            #114
            @thomas-braun sagte in Influx arbeitet nicht mehr stabil:
            Kann ich das irgendwo auslesen?
            Habs vergessen😧
              @altersrentner
              Altersrentner
              #115
              @thomas-braun gefunden😊
              Habe das Passwort eingegeben und Verbindung Prüfen aktiviert.
              Antwort OK.
              Jetzt ist der Adapter grün.
              Wie kann es sein, das sich das Passwort verstellt?
              MfG Michael
              A W 2 Antworten Letzte Antwort
              • A Altersrentner
                Antwort OK.
                MfG Michael
                Altersrentner
                #116
                @altersrentner
                Ich bedanke mich für Eure schnelle Hilfe
                und Unterstützung👍 👍 👍
                Michael
                • A Altersrentner
                  Antwort OK.
                  MfG Michael
                  W Online
                  W Online
                  Wildbill
                  #117
                  @altersrentner Das Passwort hat sich nicht verstellt, sondern der Adapter hat es beim Update schlicht „vergessen“. Warum, weiss ich auch nicht, hatte das aber gestern hier irgendwo gelesen.
                  Gruss, Jürgen
                  • W Wildbill
                    Gruss, Jürgen
                    Altersrentner
                    #118
                    Danke für die Info.
                    Das kann doch aber nicht richtig sein.
                    MfG Michael
                    • A Altersrentner
                      Danke für die Info.
                      MfG Michael
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #119
                      @altersrentner
                      dann mach ein issue beim adapter auf
                      https://github.com/ioBroker/ioBroker.influxdb/issues
                      Meine Adapter und Widgets
                      Links im Profil
                        Altersrentner
                        #120
                        Guten Morgen,
                        Wieder dieselbe Situation,
                        Influx.0 Adapter geht wie gehabt seit ca. 60 min kurzzeitig auf Unterbrechung.
                        Alle Punkte wie in den vergangenen Posts angeraten überprüft.
                        Auch Passwort neu gesetzt.
                        Es wird nur nachts ein Backup gemacht.
                        Sonst nichts.
                        Das ist doch nicht normal.
                        Michael
                        • A Altersrentner
                          Guten Morgen,
                          Sonst nichts.
                          Michael
                          crunchipC Offline
                          crunchipC Offline
                          #121
                          @altersrentner noch mal zusammenfassend
                          Wo läuft die InfluxDb?
                          Schalte die Instanz mal auf debug um zu sehen was für ein Problem vorliegt
                          F A 2 Antworten Letzte Antwort
                            funky4t
                            schrieb am zuletzt editiert von funky4t
                            #122
                            @crunchip @Altersrentner
                            Ich muss mich hier mal kurz "ranhängen", wenn ich darf ... ;)
                            Ich hab den influx adapter gestern auch upgedatet und dabei hat er scheinbar ebenfalls mein PW für die InfluxDB shell version: 1.8.10 "vergessen".
                            Ich hab dann das alte PW vom User neu eingegeben. Danach hat mir der Broker im Log einen Error von wegen "retention policy" im Log ausgegeben. Nach etwas Googeln hab ich mich dann entschieden, den admin der Influx im Adapter mitsamt PW zu hinterlegen, danach lief er fehlerfrei hoch.
                            Heut sehe ich wieder ein verfügbares Update auf 2.6.3 im Broker und hab upgedatet. Nun kommt IMMER ein "Error: authorization failed", im Test und im Log des Brokers.
                            Ich habe 1. das PW und 2. den User nach dem Update nicht geändert.
                            Interessant ist, wenn ich das erste Passwort Influx PW "admin" eingebe, dann variert es JEDESMAL von der zweiten Abfrage in der Adapter Konfiguration. Sprich ich kann dem Admin beide Passworte gleich eingeben, speichern und wenn ich die Konfiguration dann erneut öffne und das GLEICHE PW wie vorher eingebe, ergibt die PW Prüfung einen Fehler......als wenn durch erneutes Öffnen der Konfiguration ein altes PW wieder eingesetzt wird...
                            Irgendwo ist da meines Erachtens ein Bug und leider krieg ich den Adapter trotz 100% richtigem Passwort jetzt in 2.6.3 überhaupt nicht mehr auf grün!
                            Habt ihr eventuell noch einen Tip? Ich mach als Noobie immer ungern nen Issue auf Git auf... Der Broker liegt in einer VM auf Proxmox, Influx und Grafana im CT. Lief Monate ohne Probleme......
                            LG funky4t
                            • F funky4t
                              LG funky4t
                              wendy2702W Online
                              wendy2702W Online
                              #123
                              @funky4t kannst du dich mit dem User/PW denn noch in Influx einloggen?
                              Sonst möglicherweise User geblockt wegen zu vielen Fehlversuchen
                              F 1 Antwort Letzte Antwort
                              • wendy2702W wendy2702
                                funky4t
                                #124
                                @wendy2702
                                Würd sagen über die Shell geht es definitiv....
                                wendy2702W F 2 Antworten Letzte Antwort
                                • F funky4t
                                  @wendy2702
                                  wendy2702W Online
                                  wendy2702W Online
                                  #125
                                  @funky4t Wenn du auf dem iobroker Rechner mal in einem Fenster User und PW eintippst, passt das dann?
                                  Groß/klein usw.
                                  • F funky4t
                                    @wendy2702
                                    funky4t
                                    #126
                                    !!!UPDATE!!!
                                    Ich hab des Spaßeshalber mal die IP der influx im Adapter "überschrieben", also wirklich exakt die gleiche IP eingegeben und evoila auf einmal wird der Adapter grün!
                                    Wirkt als würde die Konfiguration angezeigt, aber im Hintergrund war gestern nach Update das PW weg und heut die IP.... Jetzt rennt es...
                                    Ich hab aber noch ein Feeling, das nach dem letzen MacOS Update mein Mac sich manchmal seltsam verhält, vielleicht war da noch was im Safari Browser Cache?!? Die Nummer mit den neu einzugebenden Passworten hatte ich gestern aber auf ner Windows Kiste in Firefox.... Also so richtig schlau werd ich daraus nicht....
                                    • F funky4t
                                      !!!UPDATE!!!
                                      Altersrentner
                                      #127
                                      @funky4t Hallo,
                                      Warum auch immer; es funktioniert wieder.
                                      Unerklärlich
                                      Michael
                                        Altersrentner
                                        #128
                                        @crunchip sagte in Influx arbeitet nicht mehr stabil:
                                        Wie muss ich das machen?
                                        Wieder extreme Ausfälle.
                                        Alle Punkte wie hier vorgegeben geprüft.
                                        MfG Michael
                                        • A Altersrentner
                                          MfG Michael
                                          crunchipC Offline
                                          crunchipC Offline
                                          #129
                                          @altersrentner sagte in Influx arbeitet nicht mehr stabil:
                                          und danach im Log nachsehen
