  4. [Problem] HM-RPC-Adapter 1.4.5 läuft nicht richtig (on/off)
18 Beiträge 11 Kommentatoren 4.1k Aufrufe
  • R Offline
    rascal
    gleiches Problem, bei mir schmiert deswegen sogar die occu ab :(
    • L Offline
      leo013
      Bei mir ebenfalls, aber nur für die CUXD Einstellungen mit Bin-RPC
      host.raspberrypi 2017-04-22 08:06:08.431 info instance system.adapter.hm-rpc.0 terminated with code null ()
      host.raspberrypi 2017-04-22 08:06:08.429 warn instance system.adapter.hm-rpc.0 terminated due to SIGTERM
      host.raspberrypi 2017-04-22 08:06:08.389 info stopInstance system.adapter.hm-rpc.0 killing pid 24934
      host.raspberrypi 2017-04-22 08:06:08.388 info stopInstance system.adapter.hm-rpc.0
      host.raspberrypi 2017-04-22 08:06:08.387 info object change system.adapter.hm-rpc.0
      host.raspberrypi 2017-04-22 08:06:07.096 info instance system.adapter.hm-rpc.0 started with pid 24934
      hm-rpc.0 2017-04-22 08:06:04.599 info binrpc -> 192.168.123.170:2001 init ["xmlrpc_bin://192.168.123.37:2001",""]
      host.raspberrypi 2017-04-22 08:06:04.553 info stopInstance system.adapter.hm-rpc.0 killing pid 32296
      host.raspberrypi 2017-04-22 08:06:04.552 info stopInstance system.adapter.hm-rpc.0
      host.raspberrypi 2017-04-22 08:06:04.550 info object change system.adapter.hm-rpc.0
      host.raspberrypi 2017-04-22 08:05:22.355 info instance system.adapter.hm-rpc.1 terminated with code 7 (Adapter already running)
      host.raspberrypi 2017-04-22 08:05:18.147 info instance system.adapter.hm-rpc.1 started with pid 24887
      host.raspberrypi 2017-04-22 08:05:15.545 info stopInstance system.adapter.hm-rpc.1 killing pid 23286
      host.raspberrypi 2017-04-22 08:05:15.542 info stopInstance system.adapter.hm-rpc.1
      hm-rpc.1 2017-04-22 08:05:15.564 info binrpc -> 192.168.123.170:8701 init ["xmlrpc_bin://192.168.123.37:8706",""]
      host.raspberrypi 2017-04-22 08:05:15.488 info object change system.adapter.hm-rpc.1
      hm-rpc.1 2017-04-22 08:02:33.468 error Socket error: Error: connect ECONNREFUSED 192.168.123.170:8701
      host.raspberrypi 2017-04-22 08:00:11.780 info instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
      • apollon77A Offline
        schaut mal die 1.4.6/Github-Version , Bluefox hat gerade nochmal an den Dependecies gedreht
        • F Offline
          foxi
          ich kann die Probleme hier auch bestätigen. Nach 4 Monaten uptime habe ich iobroker(update) und die CCU2(Firmware) auf Aktuellen Stand gebracht. Im Ergebnis ist die CCU nicht Bedienbar gewesen - quasi abgewürgt. :D Hat lange gedauert bis ich auf iobroker und dem cuxd mit bin-rpc gekommen bin das da die Probleme her kommen. Also der hm-rpc0 läuft hier mit dem rfd (CCU) über bin-rpc und bekommt die Verbindungen - wenn auch mitunter etwas widerwillig.
          Der hm-rpc1 (cuxd) bekommt hier mit bin-rpc keine komplette Verbindung (Verbunden mit hm-rpc = falsch) Ich habe jetzt erstmal den hm-rpc mit cuxd komplett aus iobroker verband damit die ccu wenigstens läuft.
          Edit: Mit aus Github installieren habe ich mich noch nicht beschäftigt wie das funktioniert - ist das eine größere Baustelle ;)
          Beste Grüße vom Volker
            Github simpel!
            Unter Adapter ist das dritte Icon oben von Links so ein Katzenkopf. Tooltip drüber ist "Custom Install" oder so. Da drauf. Dort beim Tab "Von Github" einfach den Adapter wählen und los gehts.
            • W Offline
              W Offline
              WolleGee
              Hallo
              bei mir hat das Update auf die 1.4.6 auch keine Verbesserung gebracht. Der hm.rpc.0 (rfd) springt von grün auf Gelb, der hm.rpc.1 (hmip) ist auf grün. Im Log steht folgendes:
              hm-rpc.0	2017-04-22 11:39:28.695	info	binrpc -> 150 devices
              hm-rpc.0	2017-04-22 11:39:28.684	info	binrpc <- listDevices ["hm-rpc.0"]
              hm-rpc.0	2017-04-22 11:39:28.669	info	binrpc <- system.listMethods ["hm-rpc.0"]
              hm-rpc.0	2017-04-22 11:39:28.370	info	binrpc -> 150 devices
              hm-rpc.0	2017-04-22 11:39:28.359	info	binrpc <- listDevices ["hm-rpc.0"]
              hm-rpc.0	2017-04-22 11:39:28.345	info	binrpc <- system.listMethods ["hm-rpc.0"]
              und das fortlaufend… Die CCU reagiert seitdem auch sehr träge
              Wolle
              • F Offline
                foxi
                hier läuft es jetzt mit der 1.4.6 - Fettes Danke an Bluefox
                ! hm-rpc.1 2017-04-22 11:53:10.704 info Connected
                ! hm-rpc.1 2017-04-22 11:53:10.698 info new CUxD devices/channels after filter: 0
                ! hm-rpc.1 2017-04-22 11:53:10.683 info binrpc -> listDevices 18
                ! hm-rpc.1 2017-04-22 11:53:10.029 info binrpc client is trying to connect to 192.168.178.28:8701 with ["xmlrpc_bin://192.168.178.23:8701","hm-rpc.1"]
                ! hm-rpc.1 2017-04-22 11:53:10.026 info binrpc server is trying to listen on 192.168.178.23:8701
                ! hm-rpc.1 2017-04-22 11:53:09.780 info starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v4.2.6
                Gruß vom Volker
                • BBTownB Offline
                  BBTownB Offline
                  BBTown
                  Auch von meiner Seite die Bestätigung, dass sowohl mit der hm.rpc Version 1.4.5 als auch mit der 1.4.6 der Adapter Schwierigkeiten macht.
                  Ich nutze 2 Instanzen vom hm.rpc (einmal wireless, einmal wired).
                  Mit der 1.4.5 konnte nur der wireless (hm.rpc.0) gestartet werden, der wired (hm.rpc.1) blieb rot.
                  Mit der Version 1.4.6 gehen beide Instanzen auf grün, wechseln dann jedoch rhytmisch wieder auf rot.
                  Anbei mein Log hierzu:
                    Dieses Verhalten kann ich bestätigen.
                    Das Problem:
                    Beim Update (genau gesagt davor) wurde der laufende Prozess nicht gekillt)
                    Nach dem Update sollte er wieder gestartet werden, statt dessen wurde er zum zweiten mal gestartet
                    Die Lösung:
                    Die Instanz stoppen und die dann noch laufende zusätzliche Instanz über die Konsole killen und anschließend die hm-rpc (im admin) wieder starten.
                    Das Vorgehen:
                    über die Konsole mit
                    cd /opt/iobroker
                    sudo iobroker stop hm-rpc.0
                    ggf. auch weitere Instanzen
                    dann die PID des noch laufenden Prozesses herausbekommen mit:
                    ps -A | grep io
                    irgendwo steht dann noch z.B. ein
                    20234 ? 00:05:30 io.hm-rpc.0
                    Anschließend diesen Prozess killen
                    sudo kill -9 20243
                    Dies ggf. mit weiteren Instanzen ebenfalls durchführen.
                    Dann wieder mit
                    sudo iobroker start hm-rpc.0
                    die Instanz starten, alternativ über den Reiter Instanzen im Admin
                    Viel Erfolg
                    • BBTownB Offline
                      BBTownB Offline
                      BBTown
                      Moin Rainer,
                      Deine Anleitung war Perfekt!! :D
                      Bei mir waren es insgesamt 6 hm-rpc Prozesse die noch liefen :shock:
                      Nun macht es einen guten Eindruck und die v.1.4.6 scheint wieder zu machen was sie soll
                      Vielen Dank für deine superschnelle Hilfe und ein erholsames Wochenende.
                      • L Offline
                        leo013
                        Auch von mir ein Danke!
                        Alles wieder in Ordnung!
                        Bei mir liefen 8 Prozesse! Jetzt muss ich nur noch meine Wemos updaten.
                        Wolfgang
                          Semenchkare
                          auch bei mir wieder alles im grünen Bereich!
                          Herzlichen Dank!
                          Viele Grüße
                          Semenchkare
                          raspberry 5 8GB mit iobroker,
                          raspberry 5 8GB mit Raspberrymatic
                            Marcolotti
                            bei mir läuft seit den Updates die 2. Instanz (CUXD) nicht mehr richtig.
                            Apr 23 11:12:07 homematic-ccu2 daemon.info cuxd[307]: INIT 'xmlrpc_bin://192.168.178.23:8701' ''
                            Apr 23 11:12:12 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(init) request
                            Apr 23 11:12:12 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(listDevices) request
                            Apr 23 11:12:19 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(init) request
                            Apr 23 11:12:19 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(listDevices) request
                            Apr 23 11:13:49 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(ping) request
                            Apr 23 11:14:23 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(init) request
                            Apr 23 11:15:09 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(init) request
                            Apr 23 11:15:09 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(listDevices) request
                            Ich habe den Tip von Rainer schon ausprobiert. Nichts.
                            Gruß Marco
                            CCU2-CuxD&Cul868MHz, 44xHM Geräte, 20xMAX Fenstersensoren.Acer Revo mit IoBroker, Tablet Captiva 9,7 SFHD. SMA SB2.5,STP7000TL20,SMA Energy Meter, Echo, Harmony, JeeLink868, Arduino 433MHz, MaxtoxCUL868,MilightEasyLED,Hue
                              Das ist auch kein Wunder, da cuxd nur bin-rpc versteht.
                              Mit dem letzten fix des Adapters sollte das dann wieder gehen.
                              • R Offline
                                robsdobs
                                Ich hab auch Probleme mit CUXD.
                                Meine Version ist die 1.4.6.
                                Ich wollte die Kanäle neu einlesen, weil ich einige Datenpunkt umbenannt hatte (hieß mal LIGHT, jetzt GAS).
                                Im WebUI soeht es folgendermaßen aus:
                                Also unter Objekte hab ich das gelöscht und Geräte neu einlesen den haken rein:
                                Wenn ich jetzt Speichere und den haken bei neu einlesen setze und speichere springt das erstmal ständig zwischen Connected und Disconnected hin und her:
                                hm-rpc.2	2017-04-26 22:35:30.088	info	Disconnected
                                hm-rpc.2	2017-0 4-26 22:35:30.088	info	Connected
                                hm-rpc.2	2017-04-26 22:35:30.087	info	Connected
                                hm-rpc.2	2017-04-26 22:35:14.878	info	Connected
                                hm-rpc.2	2017-04-26 22:35:14.877	info	new CUxD devices/channels after filter: 0
                                hm-rpc.2	2017-04-26 22:35:14.854	info	binrpc -> listDevices 125
                                hm-rpc.2	2017-04-26 22:35:14.360	info	binrpc client is trying to connect to 192.168.178.205:8701 with ["xmlrpc_bin://192.168.178.220:8711","hm-rpc.2"]
                                hm-rpc.2	2017-04-26 22:35:14.357	info	binrpc server is trying to listen on 192.168.178.220:8711
                                hm-rpc.2	2017-04-26 22:35:13.249	info	starting. Version 1.4.6 in /media/1c31537f-0f75-428d-9228-7b54b469086c/programms/iobroker/node_modules/iobroker.hm-rpc, node: v4.8.2
                                hm-rpc.2	2017-04-26 22:35:10.137	info	Disconnected
                                hm-rpc.2	2017-04-26 22:35:10.133	info	binrpc -> 192.168.178.205:8701 init ["xmlrpc_bin://192.168.178.220:8711",""]
                                hm-rpc.2	2017-04-26 22:35:06.628	info	Connected
                                hm-rpc.2	2017-04-26 22:35:05.702	info	binrpc -> listDevices 125
                                hm-rpc.2	2017-04-26 22:35:05.197	info	binrpc client is trying to connect to 192.168.178.205:8701 with ["xmlrpc_bin://192.168.178.220:8711","hm-rpc.2"]
                                hm-rpc.2	2017-04-26 22:35:05.193	info	binrpc server is trying to listen on 192.168.178.220:8711
                                hm-rpc.2	2017-04-26 22:35:04.048	info	starting. Version 1.4.6 in /media/1c31537f-0f75-428d-9228-7b54b469086c/programms/iobroker/node_modules/iobroker.hm-rpc, node: v4.8.2
                                hm-rpc.2	2017-04-26 22:35:01.001	info	terminating
                                hm-rpc.2	2017-04-26 22:35:00.979	info	Disconnected
                                hm-rpc.2	2017-04-26 22:35:00.977	info	binrpc -> 192.168.178.205:8701 init ["xmlrpc_bin://192.168.178.220:8711",""]
                                Die Datenpunte stimmen dann nicht (LIGHT anstelle GAS):
                                Scripte: http://forum.iobroker.net/viewtopic.php?f=23&t=2799&p=119565#p119565,
