  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. einbinden von fhem funktioniert nicht
    5.2k
docker
43 Beiträge 3 Kommentatoren 5.7k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    @foly12 Ist das alles?
    Ich sehe da keinen connect versuch, keinen Abbruch oder sonst was.
    foly12
    schrieb am zuletzt editiert von foly12
    @wendy2702
    fhem.0
    	2022-02-16 21:34:04.001	debug	[main] start
    fhem.0
    	2022-02-16 21:34:03.955	info	starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.fhem, node: v14.19.0, js-controller: 3.3.22
    fhem.0
    	2022-02-16 21:34:03.494	debug	Plugin sentry Initialize Plugin (enabled=true)
    fhem.0
    fhem.0
    	2022-02-16 21:34:03.237	debug	statesDB connected
    fhem.0
    	2022-02-16 21:34:03.235	debug	States connected to redis: 127.0.0.1:9000
    fhem.0
    	2022-02-16 21:34:03.220	debug	States create User PubSub Client
    fhem.0
    	2022-02-16 21:34:03.218	debug	States create System PubSub Client
    fhem.0
    	2022-02-16 21:34:03.203	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    fhem.0
    	2022-02-16 21:34:03.198	debug	objectDB connected
    fhem.0
    	2022-02-16 21:34:03.179	debug	Objects connected to redis: 127.0.0.1:9001
    fhem.0
    	2022-02-16 21:34:03.154	debug	Objects client initialize lua scripts
    fhem.0
    	2022-02-16 21:34:03.152	debug	Objects create User PubSub Client
    fhem.0
    	2022-02-16 21:34:03.149	debug	Objects create System PubSub Client
    fhem.0
    	2022-02-16 21:34:03.144	debug	Objects client ready ... initialize now
    fhem.0
    	2022-02-16 21:34:03.080	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.8a30d25fbb3a
    	2022-02-16 21:34:00.787	info	instance system.adapter.fhem.0 started with pid 26901
    host.8a30d25fbb3a
    	2022-02-16 21:34:00.715	info	"system.adapter.fhem.0" enabled
    host.8a30d25fbb3a
    	2022-02-16 21:33:56.520	info	instance system.adapter.fhem.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    fhem.0
    	2022-02-16 21:33:55.959	warn	State "fhem.0.info.Info.alive" has no existing object, this might lead to an error in future versions
    fhem.0
    	2022-02-16 21:33:55.948	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fhem.0
    	2022-02-16 21:33:55.947	debug	Plugin sentry destroyed
    fhem.0
    	2022-02-16 21:33:55.944	info	terminating
    fhem.0
    	2022-02-16 21:33:55.930	info	Got terminate signal TERMINATE_YOURSELF
    host.8a30d25fbb3a
    	2022-02-16 21:33:55.928	info	stopInstance system.adapter.fhem.0 send kill signal
    host.8a30d25fbb3a
    	2022-02-16 21:33:55.907	info	stopInstance system.adapter.fhem.0 (force=false, process=true)
    host.8a30d25fbb3a
    	2022-02-16 21:33:55.903	info	"system.adapter.fhem.0" disabled
    das ist alles was ich bekomme
    • F foly12
      @wendy2702
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      host.8a30d25fbb3a
      host.8a30d25fbb3a
      host.8a30d25fbb3a
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      fhem.0
      host.8a30d25fbb3a
      host.8a30d25fbb3a
      host.8a30d25fbb3a
      wendy2702W Online
      wendy2702W Online
      @foly12 kommt hinter dem "start" nichts mehr?
      Bis dahin sehe ich jetzt keinen Fehler.
      Ich nutze den Adapter nicht selber, was kann man denn konfigurieren?
      EDIT: Das hier beachtet:
      Um die Verbindung zu aktivieren, muss das Telnet in FHEM aktiviert sein. Um es zu aktivieren (standardmäßig aktiviert), überprüfen Sie die folgenden Einstellungen in der fhen.cfg:
      define telnetPort telnet 7072 global
      Genau der gleiche Port und die IP-Adresse des FHEM-Hosts (oder localhost, wenn FHEM und ioBroker auf demselben PC laufen) sollten für die Einstellungen des Adapters verwendet werden.
      ioBroker sendet beim Start den Befehl "jsonlist2", um alle "Readings" aus der Liste zu erhalten.
      F 1 Antwort Letzte Antwort
        foly12
        @wendy2702 said in einbinden von fhem funktioniert nicht:
        Ja, das habe ich beachtet. Ich habe auch den telnet zugang geprüft und bekomme mit jsonlist2 remote ein listing ...
        • F foly12
          foly12
          Mein iobroker läuft in einem Docker Container, kann das etwas damit zu tun haben?
          • F foly12
            wendy2702W Online
            wendy2702W Online
            @foly12 Ja,
            wenn die Abfrage über Telnet läuft denke ich du musst den entsprechenden Port freigeben.
              @foly12 Ja,
              foly12
              @wendy2702
              Und da waren wieder meine drei Probleme ... wahrscheinlich hast Du recht, das wäre logisch ... jetzt muss ich nur noch lernen wie ich in Portainer einen Port freigeben kann
              Dann google ich mal weiter
              • wendy2702W Online
                wendy2702W Online
                @foly12 Vielleicht hilft das ein wenig:
                https://forum.iobroker.net/topic/4733/howto-iobroker-unter-docker-auf-synology-diskstation/714
                Sonst Google:
                Portainer POrt Freigeben
                  Sonst Google:
                  foly12
                  @wendy2702 Danke für die Tipps!! Ich habe jetzt den Port 7072 geöffnet und getestet indem ich telnet im container installiert habe und im Terminal eine Verbindung zu FHEM aufgebaut habe. Jsonlist2 bringt eine perfekte Liste ... Leider ist aber im iobroker immer noch kein Gerät verfügbar ... hast Du noch eine Idee? MIr fällt nichts mehr ein :-(
                  • F foly12
                    wendy2702W Online
                    wendy2702W Online
                    @foly12 zeige jetzt nochmal bitte das log vom Adapter nachdem den Port offen ist.
                      foly12
                      @wendy2702 da gibts m.E. keine Fehlermeldung:
                      fhem.0
                      	2022-02-17 21:49:52.012	debug	[main] start
                      fhem.0
                      	2022-02-17 21:49:51.966	info	starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.fhem, node: v14.19.0, js-controller: 3.3.22
                      fhem.0
                      	2022-02-17 21:49:51.531	debug	Plugin sentry Initialize Plugin (enabled=true)
                      fhem.0
                      	2022-02-17 21:49:51.258	debug	statesDB connected
                      fhem.0
                      	2022-02-17 21:49:51.256	debug	States connected to redis: 127.0.0.1:9000
                      fhem.0
                      	2022-02-17 21:49:51.242	debug	States create User PubSub Client
                      fhem.0
                      	2022-02-17 21:49:51.240	debug	States create System PubSub Client
                      fhem.0
                      	2022-02-17 21:49:51.224	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                      fhem.0
                      	2022-02-17 21:49:51.220	debug	objectDB connected
                      fhem.0
                      	2022-02-17 21:49:51.201	debug	Objects connected to redis: 127.0.0.1:9001
                      fhem.0
                      	2022-02-17 21:49:51.178	debug	Objects client initialize lua scripts
                      fhem.0
                      	2022-02-17 21:49:51.176	debug	Objects create User PubSub Client
                      fhem.0
                      	2022-02-17 21:49:51.173	debug	Objects create System PubSub Client
                      fhem.0
                      	2022-02-17 21:49:51.169	debug	Objects client ready ... initialize now
                      fhem.0
                      	2022-02-17 21:49:51.109	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                      host.8a30d25fbb3a
                      	2022-02-17 21:49:49.012	info	instance system.adapter.fhem.0 started with pid 2255
                      host.8a30d25fbb3a
                      	2022-02-17 21:49:48.938	info	"system.adapter.fhem.0" enabled
                      • F foly12
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        fhem.0
                        host.8a30d25fbb3a
                        host.8a30d25fbb3a
                        wendy2702W Online
                        wendy2702W Online
                        @foly12 morgen…. Bin auf dem weg ins Bett
                          foly12
                          @wendy2702 gerne! :-) gute Nacht!
                          • wendy2702W Online
                            wendy2702W Online
                            Ich komme auch nochmal auf die Anleitung zum Adapter zurück:
                            was kommt auf dem FHEM Server bei:
                            list telnetPort
                            LausiDL F 2 Antworten Letzte Antwort
                              list telnetPort
                              LausiDL Offline
                              LausiDL Offline
                              LausiD
                              @foly12
                              Wenn nach Adapter Start die letzte Zeile im Protkoll "fhem.0 2022-02-17 21:49:52.012 debug [main] start" ist wird keine Telnet Verbindung aufgebaut.
                              Hier wurde mal hinter der IP ein Blank eingefügt ?
                              https://forum.iobroker.net/topic/44980/gelöst-fhem-adapter-keine-verbindung-zu-fhem?_=1645196461791
                              Gruß LausiD
                              Doku zum FHEM Adapter
                              Aktuelles zum FHEM Adapter
                              Test FHEM Adapter
                                list telnetPort
                                foly12
                                @wendy2702 da bekomme ich folgendes listing:
                                Internals:
                                   CONNECTS   83
                                   DEF        7072 global
                                   FD         5
                                   FUUID      5c8ff621-f33f-004e-94c1-9ff5a4210910a150
                                   NAME       telnetPort
                                   NR         3
                                   PORT       7072
                                   STATE      Initialized
                                   TYPE       telnet
                                   READINGS:
                                     2022-01-30 08:17:14   state           Initialized
                                Attributes:
                                   room       Infrastructure
                                • LausiDL LausiD
                                  @foly12
                                  Gruß LausiD
                                  foly12
                                  @lausid eine leerstelle habe ich leider nicht in der IP, habe ich eben nochmal geprüft ... schade ...
                                  die telnet Verbindung habe ich geprüft und bekomme eine Antwort (per putty)
                                  • F foly12
                                    Internals:
                                       CONNECTS   83
                                       DEF        7072 global
                                       FD         5
                                       NAME       telnetPort
                                       NR         3
                                       PORT       7072
                                       STATE      Initialized
                                       TYPE       telnet
                                       READINGS:
                                    Attributes:
                                       room       Infrastructure
                                    wendy2702W Online
                                    wendy2702W Online
                                    @foly12 dann solltest du die Hinweise aus dem Link von @LausiD bezüglich Telnet und Passwort mal durcharbeiten und das mit dem Leerzeichen versuchen
                                    https://github.com/iobroker-community-adapters/ioBroker.fhem/blob/master/docs/de/README.md
                                      foly12
                                      @wendy2702 wie gesagt, das habe ich schon geprüft und mehrfach neu eingegeben ... das ändert nichts, leider
                                      LausiDL 1 Antwort Letzte Antwort
                                      • F foly12
                                        LausiDL Offline
                                        LausiDL Offline
                                        LausiD
                                        @foly12
                                        Schon mal ohne Passwort versucht?
                                        Test FHEM Adapter
                                        • LausiDL LausiD
                                          @foly12
                                          foly12
                                          @lausid ja, jetzt, da kommt interessanterweise die gleiche Rückmeldung in iobroker wie mit meinem PW. Das Passwort habe ich übrigens mehrfach eingegeben, das muss passen. Ebenso habe ich es beim telnet test eingegeben und da funktioniert es
