  4. js-controller 4.0 jetzt im BETA/LATEST!
747 Beiträge 70 Kommentatoren 289.4k Aufrufe 60 Beobachtet
  • DolomitiD Dolomiti
    Habe jetzt auch mal 4.0.10 installiert. System war uptodate
    Node.js ist auch richtig
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v14.19.0
    v14.19.0
    6.14.16
    Bekomme aber folgende Meldungen am Anfang
    schlippe@ioBroker-Test:~$ iobroker upgrade self
    Update js-controller from @3.3.22 to @4.0.10
    NPM version: 6.14.16
    npm install iobroker.js-controller@4.0.10 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../src/binding.cc:1:
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
          (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro 'NODE_MODULE_X'
      NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/binding.cc:153:1: note: in expansion of macro 'NODE_MODULE'
    NODE_MODULE(cpufeatures, init)
    In file included from ../src/unix_dgram.cc:5:
    ../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
        , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:54,
    ../src/unix_dgram.cc: At global scope:
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
    ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
    NODE_MODULE(unix_dgram, Initialize)
    Server Objects 127.0.0.1:32802 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
    Server States 127.0.0.1:38042 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
    Server Objects 127.0.0.1:32802 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
    Server States 127.0.0.1:38044 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
    Server Objects 127.0.0.1:32802 Error from InMemDB: Error: Unknown LUA script load
    (node:14970) Warning: Accessing non-existent property 'count' of module exports inside circular dependency
    (Use `node --trace-warnings ...` to show where the warning was created)
    (node:14970) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency
    (node:14970) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency
    (node:14970) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
    Server Objects 127.0.0.1:32802 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
    Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
    schlippe@ioBroker-Test:~$ iobroker start
    System startet dann auch und bei beim status kommt folgende Warnung. Kann ich das ignorieren?
    schlippe@ioBroker-Test:~$ iobroker status
    (node:15326) Warning: Accessing non-existent property 'count' of module exports inside circular dependency
    (node:15326) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency
    (node:15326) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency
    (node:15326) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
    Objects type: jsonl
    States  type: jsonl
    crunchipC Abwesend
    crunchipC Abwesend
    #388
    @dolomiti bei mir war es mongodb,, die zur gleichen Ausgabe führte
    • FeuersturmF Feuersturm
      @apollon77
      Edit: Sehe gerade im ersten Beitrag, dass die Errors gewollt / ok sind.
      Ich hab gerade einmal mein Produktivsystem von js-controller 3.3.22 auf 4.0.10 aktualisiert und folgende Ausgabe erhalten:
      proxmox@ioBroker:~$ iob stop
      proxmox@ioBroker:~$ iob upgrade self
      NPM version: 6.14.15
      npm install iobroker.js-controller@4.0.10 --loglevel error --unsafe-perm --prefi        x "/opt/iobroker" (System call)
      ../../nan/nan.h:2294:62: warning: cast between incompatible function types from        'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka '        void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       2294 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
      In file included from ../../nan/nan.h:56,
      /home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:43: warning: cast        between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to '        node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::V        alue>, void*)'} [-Wcast-function-type]
        787 |       (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expan        sion of macro 'NODE_MODULE_X'
        821 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_        usage)
        404 | NODE_MODULE(unix_dgram, Initialize)
      Server Objects 127.0.0.1:59728 Error from InMemDB: Error: GET-UNSUPPORTED for na        mespace cfg.: Data=["meta.objects.features.useSets"]
      Server States 127.0.0.1:34856 Error from InMemDB: Error: GET-UNSUPPORTED for nam        espace meta.: Data=["meta.states.protocolVersion"]
      Server Objects 127.0.0.1:59728 Error from InMemDB: Error: GET-UNSUPPORTED for na        mespace cfg.: Data=["meta.objects.protocolVersion"]
      Server States 127.0.0.1:34858 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED        for namespace meta.: Data=["meta.*"]
      Server Objects 127.0.0.1:59728 Error from InMemDB: Error: Unknown LUA script loa        d
      Server Objects 127.0.0.1:59728 Error from InMemDB: Error: SET-UNSUPPORTED for na        mespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]        }]
      Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for names        pace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
      proxmox@ioBroker:~$
      Nach dem Update ergibt iob status folgendes:
      proxmox@ioBroker:~$ iob status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      proxmox@ioBroker:~$ node -v && nodejs -v && npm -v
      v14.18.2
      v14.18.2
      6.14.15
      crunchipC Abwesend
      crunchipC Abwesend
      #389
      @feuersturm sagte in js-controller 4.0 jetzt im BETA/LATEST!:
      Wäre da nicht nach dem iob stop ein iob update angebracht gewesen?
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.0
        v14.19.0
        6.14.16
        Objects type: jsonl
        States  type: jsonl
        #390
        @dolomiti Das hat nichts mit dem Controller zu tun. Das liegt an Nodejs 14 und scheinbar einer "alten" version von node-red der eine buggy mongodb version enthalten hat und diese verursacht diese Fejhler. ALso bitte node-red aktualisieren
        DolomitiD 1 Antwort Letzte Antwort
        • JB_SullivanJ JB_Sullivan
          Ich habe eben nochmal ein Win10 Update gemacht und dann den Broker automatisch neu starten lassen. Dabei poppte die folgende Meldung auf - hatte ich in der Form noch nie und auch die Einstellung 60 Sekunden ließ sich nicht einstellen. Dabei kam die Meldung am unteren Bildrand.
          Habe dann Abrechen gedrückt, da ich in der Form eigentlich noch nie Probleme hatte. Waren wohl noch ein paar andere Windows Prozesse im Hintergrund am starten, oder so.....
          Das nur mal am Rande.
          #391
          @jb_sullivan Diese Meldung kommt vom Admin wenn nicht innerhalb einer definierten Wartezeit Daten kommen. Ja das passiert ggf wenn gerade viele Adapter starten und somit das System unter Last steht.
            FeuersturmF Offline
            FeuersturmF Offline
            Feuersturm
            #392
            @crunchip sagte in js-controller 4.0 jetzt im BETA/LATEST!:
            iob update wurde vor dem iob stop ausgeführt.
              @apollon77
              proxmox@ioBroker:~$
              Objects type: jsonl
              States  type: jsonl
              v14.18.2
              v14.18.2
              6.14.15
              #393
              @feuersturm Sieht alles korrekt aus. Sind die üblichen Compile Warnungen und die oben beschriebenen "einmaligen Not supported "Meldungen. Alles so wie es soll :-)
              • DiginixD Offline
                DiginixD Offline
                Diginix
                #394
                @apollon77 Habe eben unter 4.0.10 5 Adapter aktualisiert (shelly von 5.1.3 auf 5.2.0, text2command von 2.1.2 auf 2.1.6, socketio von 4.1.2 auf 4.1.4, ws von 1.1.4 auf 1.1.6, web von 4.1.4 auf 4.1.5). Als letztes den web und dann kam mal wieder der OOM Killer obwohl die VM nun 6GB hat und nicht über 5 GB belegt hatte:
                Feb 17 11:17:27 iobroker kernel: [185572.752465] CPU: 1 PID: 707 Comm: gmain Not tainted 5.4.0-99-generic #112-Ubuntu
                Feb 17 11:17:27 iobroker kernel: [185572.752466] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org 04/01/2014
                Feb 17 11:17:27 iobroker kernel: [185572.752469] Call Trace:
                Feb 17 11:17:27 iobroker kernel: [185572.752486]  dump_stack+0x6d/0x8b
                Feb 17 11:17:27 iobroker kernel: [185572.752489]  dump_header+0x4f/0x1eb
                Feb 17 11:17:27 iobroker kernel: [185572.752491]  oom_kill_process.cold+0xb/0x10
                Feb 17 11:17:27 iobroker kernel: [185572.752494]  out_of_memory+0x1cf/0x4d0
                Feb 17 11:17:27 iobroker kernel: [185572.752497]  __alloc_pages_slowpath+0xd5e/0xe50
                Feb 17 11:17:27 iobroker kernel: [185572.752502]  __alloc_pages_nodemask+0x2d0/0x320
                Feb 17 11:17:27 iobroker kernel: [185572.752504]  alloc_pages_current+0x87/0xe0
                Feb 17 11:17:27 iobroker kernel: [185572.752511]  __page_cache_alloc+0x72/0x90
                Feb 17 11:17:27 iobroker kernel: [185572.752514]  pagecache_get_page+0xbf/0x300
                Feb 17 11:17:27 iobroker kernel: [185572.752516]  filemap_fault+0x6b2/0xa50
                Feb 17 11:17:27 iobroker kernel: [185572.752519]  ? unlock_page_memcg+0x12/0x20
                Feb 17 11:17:27 iobroker kernel: [185572.752521]  ? page_add_file_rmap+0xff/0x1a0
                Feb 17 11:17:27 iobroker kernel: [185572.752524]  ? xas_load+0xd/0x80
                Feb 17 11:17:27 iobroker kernel: [185572.752526]  ? xas_find+0x17f/0x1c0
                Feb 17 11:17:27 iobroker kernel: [185572.752532]  ? filemap_map_pages+0x24c/0x380
                Feb 17 11:17:27 iobroker kernel: [185572.752535]  ext4_filemap_fault+0x32/0x50
                Feb 17 11:17:27 iobroker kernel: [185572.752538]  __do_fault+0x3c/0x130
                Feb 17 11:17:27 iobroker kernel: [185572.752540]  do_fault+0x24b/0x640
                Feb 17 11:17:27 iobroker kernel: [185572.752542]  __handle_mm_fault+0x4c5/0x7a0
                Feb 17 11:17:27 iobroker kernel: [185572.752545]  handle_mm_fault+0xca/0x200
                Feb 17 11:17:27 iobroker kernel: [185572.752548]  do_user_addr_fault+0x1f9/0x450
                Feb 17 11:17:27 iobroker kernel: [185572.752551]  __do_page_fault+0x58/0x90
                Feb 17 11:17:27 iobroker kernel: [185572.752553]  do_page_fault+0x2c/0xe0
                Feb 17 11:17:27 iobroker kernel: [185572.752556]  do_async_page_fault+0x39/0x70
                Feb 17 11:17:27 iobroker kernel: [185572.752558]  async_page_fault+0x34/0x40
                Feb 17 11:17:27 iobroker kernel: [185572.752569] RIP: 0033:0x7fdd6c4e54d0
                Feb 17 11:17:27 iobroker kernel: [185572.752575] Code: Bad RIP value.
                Feb 17 11:17:27 iobroker kernel: [185572.752576] RSP: 002b:00007fdd6bbe0c58 EFLAGS: 00010246
                Feb 17 11:17:27 iobroker kernel: [185572.752578] RAX: 0000000000000000 RBX: 00005653fef41350 RCX: 0000000000000002
                Feb 17 11:17:27 iobroker kernel: [185572.752579] RDX: 00005653fef41350 RSI: 000000007fffffff RDI: 00005653fef43e90
                Feb 17 11:17:27 iobroker kernel: [185572.752580] RBP: 00005653fef43e90 R08: 0000000000000000 R09: 0000000000000000
                Feb 17 11:17:27 iobroker kernel: [185572.752581] R10: 00005653fef5e870 R11: 0000000000000000 R12: 0000000000000002
                Feb 17 11:17:27 iobroker kernel: [185572.752582] R13: 000000007fffffff R14: 0000000000000002 R15: 00005653fef43e90
                Feb 17 11:17:27 iobroker kernel: [185572.752596] Mem-Info:
                Feb 17 11:17:27 iobroker kernel: [185572.752608] active_anon:1417365 inactive_anon:49 isolated_anon:0
                Feb 17 11:17:27 iobroker kernel: [185572.752608]  active_file:105 inactive_file:33 isolated_file:0
                Feb 17 11:17:27 iobroker kernel: [185572.752608]  unevictable:4618 dirty:0 writeback:0 unstable:0
                Feb 17 11:17:27 iobroker kernel: [185572.752608]  slab_reclaimable:10079 slab_unreclaimable:24210
                Feb 17 11:17:27 iobroker kernel: [185572.752608]  mapped:2683 shmem:288 pagetables:14758 bounce:0
                Feb 17 11:17:27 iobroker kernel: [185572.752608]  free:23741 free_pcp:1412 free_cma:0
                Feb 17 11:17:27 iobroker kernel: [185572.752616] Node 0 active_anon:5669460kB inactive_anon:196kB active_file:420kB inactive_file:132kB unevictable:18472kB isolated(anon):0kB isolated(file):0kB mapped:10732kB dirty:0kB writeback:0kB shmem:1152kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 0kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
                Feb 17 11:17:27 iobroker kernel: [185572.752617] Node 0 DMA free:15900kB min:176kB low:220kB high:264kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15992kB managed:15908kB mlocked:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
                Feb 17 11:17:27 iobroker kernel: [185572.752621] lowmem_reserve[]: 0 2875 5837 5837 5837
                Feb 17 11:17:27 iobroker kernel: [185572.752624] Node 0 DMA32 free:45028kB min:33196kB low:41492kB high:49788kB active_anon:2910612kB inactive_anon:64kB active_file:968kB inactive_file:420kB unevictable:0kB writepending:0kB present:3129176kB managed:3034304kB mlocked:0kB kernel_stack:2384kB pagetables:17240kB bounce:0kB free_pcp:3220kB local_pcp:548kB free_cma:0kB
                Feb 17 11:17:27 iobroker kernel: [185572.752634] lowmem_reserve[]: 0 0 2962 2962 2962
                Feb 17 11:17:27 iobroker kernel: [185572.752637] Node 0 Normal free:34036kB min:34204kB low:42752kB high:51300kB active_anon:2758848kB inactive_anon:132kB active_file:240kB inactive_file:276kB unevictable:18472kB writepending:0kB present:3145728kB managed:3033552kB mlocked:18472kB kernel_stack:7696kB pagetables:41792kB bounce:0kB free_pcp:2436kB local_pcp:288kB free_cma:0kB
                Feb 17 11:17:27 iobroker kernel: [185572.752640] lowmem_reserve[]: 0 0 0 0 0
                Feb 17 11:17:27 iobroker kernel: [185572.752643] Node 0 DMA: 1*4kB (U) 1*8kB (U) 1*16kB (U) 0*32kB 2*64kB (U) 1*128kB (U) 1*256kB (U) 0*512kB 1*1024kB (U) 1*2048kB (M) 3*4096kB (M) = 15900kB
                Feb 17 11:17:27 iobroker kernel: [185572.752651] Node 0 DMA32: 1299*4kB (UME) 956*8kB (UME) 540*16kB (UME) 259*32kB (UME) 130*64kB (UME) 41*128kB (UME) 6*256kB (UME) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 44876kB
                Feb 17 11:17:27 iobroker kernel: [185572.752660] Node 0 Normal: 880*4kB (UMH) 1532*8kB (UMEH) 734*16kB (UEH) 227*32kB (UE) 1*64kB (H) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 34848kB
                Feb 17 11:17:27 iobroker kernel: [185572.752679] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
                Feb 17 11:17:27 iobroker kernel: [185572.752679] 2460 total pagecache pages
                Feb 17 11:17:27 iobroker kernel: [185572.752681] 0 pages in swap cache
                Feb 17 11:17:27 iobroker kernel: [185572.752682] Swap cache stats: add 0, delete 0, find 0/0
                Feb 17 11:17:27 iobroker kernel: [185572.752683] Free swap  = 0kB
                Feb 17 11:17:27 iobroker kernel: [185572.752683] Total swap = 0kB
                Feb 17 11:17:27 iobroker kernel: [185572.752684] 1572724 pages RAM
                Feb 17 11:17:27 iobroker kernel: [185572.752685] 0 pages HighMem/MovableOnly
                Feb 17 11:17:27 iobroker kernel: [185572.752686] 51783 pages reserved
                Feb 17 11:17:27 iobroker kernel: [185572.752689] 0 pages cma reserved
                Feb 17 11:17:27 iobroker kernel: [185572.752690] 0 pages hwpoisoned
                Feb 17 11:17:27 iobroker kernel: [185572.752691] Tasks state (memory values in pages):
                Feb 17 11:17:27 iobroker kernel: [185572.752691] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
                Feb 17 11:17:27 iobroker kernel: [185572.752700] [    377]     0   377    35296      683   282624        0          -250 systemd-journal
                Feb 17 11:17:27 iobroker kernel: [185572.752703] [    411]     0   411     5347      827    73728        0         -1000 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752706] [    599]     0   599    70036     4487    98304        0         -1000 multipathd
                Feb 17 11:17:27 iobroker kernel: [185572.752709] [    653]   112   653     1776      733    49152        0             0 rpcbind
                Feb 17 11:17:27 iobroker kernel: [185572.752712] [    657]   102   657    22558      662    81920        0             0 systemd-timesyn
                Feb 17 11:17:27 iobroker kernel: [185572.752714] [    688]   100   688     6653      713    73728        0             0 systemd-network
                Feb 17 11:17:27 iobroker kernel: [185572.752716] [    690]   101   690     6040     1489    90112        0             0 systemd-resolve
                Feb 17 11:17:27 iobroker kernel: [185572.752718] [    702]     0   702    58871     1060    90112        0             0 accounts-daemon
                Feb 17 11:17:27 iobroker kernel: [185572.752720] [    705]     0   705     2357      814    61440        0             0 bluetoothd
                Feb 17 11:17:27 iobroker kernel: [185572.752722] [    710]     0   710     1392      601    49152        0             0 cron
                Feb 17 11:17:27 iobroker kernel: [185572.752724] [    711]   103   711     1949      805    53248        0          -900 dbus-daemon
                Feb 17 11:17:27 iobroker kernel: [185572.752726] [    717]     0   717    20474      689    61440        0             0 irqbalance
                Feb 17 11:17:27 iobroker kernel: [185572.752728] [    718]     0   718     6656     2681    90112        0             0 networkd-dispat
                Feb 17 11:17:27 iobroker kernel: [185572.752731] [    719]     0   719     1637      544    49152        0             0 qemu-ga
                Feb 17 11:17:27 iobroker kernel: [185572.752733] [    720]   104   720    56087      624    81920        0             0 rsyslogd
                Feb 17 11:17:27 iobroker kernel: [185572.752735] [    732]     0   732     4213      941    73728        0             0 systemd-logind
                Feb 17 11:17:27 iobroker kernel: [185572.752737] [    734]     0   734    98140     1267   122880        0             0 udisksd
                Feb 17 11:17:27 iobroker kernel: [185572.752739] [    735]     0   735      948      491    49152        0             0 atd
                Feb 17 11:17:27 iobroker kernel: [185572.752741] [    745]     0   745     3044      929    65536        0         -1000 sshd
                Feb 17 11:17:27 iobroker kernel: [185572.752743] [    758]     0   758      715      388    45056        0             0 agetty
                Feb 17 11:17:27 iobroker kernel: [185572.752745] [    773]     0   773    26287     2668   102400        0             0 unattended-upgr
                Feb 17 11:17:27 iobroker kernel: [185572.752747] [    795]     0   795    58179      794    86016        0             0 polkitd
                Feb 17 11:17:27 iobroker kernel: [185572.752750] [  55466]     0 55466    62066      476    98304        0             0 upowerd
                Feb 17 11:17:27 iobroker kernel: [185572.752753] [ 154992]     0 154992   292215     4229   286720        0          -900 snapd
                Feb 17 11:17:27 iobroker kernel: [185572.752755] [ 179634]  1000 179634  1016283   803799 13590528        0             0 iobroker.js-con
                Feb 17 11:17:27 iobroker kernel: [185572.752758] [ 179664]  1000 179664   274516    62398  4775936        0             0 io.admin.0
                Feb 17 11:17:27 iobroker kernel: [185572.752760] [ 179688]  1000 179688   167893     8967  2334720        0             0 io.email.0
                Feb 17 11:17:27 iobroker kernel: [185572.752762] [ 179705]  1000 179705   170907    14589  2367488        0             0 io.history.0
                Feb 17 11:17:27 iobroker kernel: [185572.752764] [ 179720]  1000 179720   277563    55508  5705728        0             0 io.javascript.0
                Feb 17 11:17:27 iobroker kernel: [185572.752766] [ 179752]  1000 179752   172560    15417  2478080        0             0 io.influxdb.0
                Feb 17 11:17:27 iobroker kernel: [185572.752769] [ 179807]  1000 179807   235550    11930  2543616        0             0 io.alexa2.0
                Feb 17 11:17:27 iobroker kernel: [185572.752771] [ 179830]  1000 179830   260645    21474  2674688        0             0 io.mihome-vacuu
                Feb 17 11:17:27 iobroker kernel: [185572.752773] [ 179843]  1000 179843   234206     9900  2486272        0             0 io.alexa2.1
                Feb 17 11:17:27 iobroker kernel: [185572.752775] [ 179862]  1000 179862   170010    11804  2420736        0             0 io.modbus.0
                Feb 17 11:17:27 iobroker kernel: [185572.752777] [ 179877]  1000 179877   170662    12442  2703360        0             0 io.mqtt.0
                Feb 17 11:17:27 iobroker kernel: [185572.752779] [ 179892]  1000 179892   238326    15902  2600960        0             0 io.telegram.0
                Feb 17 11:17:27 iobroker kernel: [185572.752781] [ 179901]  1000 179901   167782     9130  2396160        0             0 io.onkyo.0
                Feb 17 11:17:27 iobroker kernel: [185572.752783] [ 179926]  1000 179926   168992    10349  2473984        0             0 io.ping.0
                Feb 17 11:17:27 iobroker kernel: [185572.752788] [ 179977]  1000 179977   205085    47412  3014656        0             0 io.sonoff.0
                Feb 17 11:17:27 iobroker kernel: [185572.752791] [ 180033]  1000 180033   236423    12055  2510848        0             0 io.backitup.0
                Feb 17 11:17:27 iobroker kernel: [185572.752793] [ 180097]  1000 180097   229752    12323  1814528        0             0 io.info.0
                Feb 17 11:17:27 iobroker kernel: [185572.752795] [ 180454]  1000 180454   186182    11257  2637824        0             0 io.iot.0
                Feb 17 11:17:27 iobroker kernel: [185572.752798] [ 180574]  1000 180574   218574    11282  2678784        0             0 io.iot.1
                Feb 17 11:17:27 iobroker kernel: [185572.752800] [ 180589]  1000 180589   236003    13396  2514944        0             0 io.jarvis.0
                Feb 17 11:17:27 iobroker kernel: [185572.752802] [ 180610]  1000 180610   173911    23431  2682880        0             0 io.lupusec.0
                Feb 17 11:17:27 iobroker kernel: [185572.752804] [ 180660]  1000 180660   234680    11490  2596864        0             0 io.parser.0
                Feb 17 11:17:27 iobroker kernel: [185572.752807] [ 180701]  1000 180701   235683    13335  2441216        0             0 io.plenticore.0
                Feb 17 11:17:27 iobroker kernel: [185572.752809] [ 180724]  1000 180724   170176    14529  2662400        0             0 io.radar2.0
                Feb 17 11:17:27 iobroker kernel: [185572.752811] [ 180763]  1000 180763   167700     8939  2379776        0             0 io.samsung.0
                Feb 17 11:17:27 iobroker kernel: [185572.752813] [ 180783]  1000 180783   232943     9789  2342912        0             0 io.simple-api.0
                Feb 17 11:17:27 iobroker kernel: [185572.752815] [ 180800]  1000 180800   172168    13773  2330624        0             0 io.statistics.0
                Feb 17 11:17:27 iobroker kernel: [185572.752817] [ 180979]  1000 180979   234641    10296  2514944        0             0 io.tankerkoenig
                Feb 17 11:17:27 iobroker kernel: [185572.752819] [ 180986]  1000 180986   235595    10738  2523136        0             0 io.bring.0
                Feb 17 11:17:27 iobroker kernel: [185572.752821] [ 181009]  1000 181009   169962    12869  2412544        0             0 io.proxmox.0
                Feb 17 11:17:27 iobroker kernel: [185572.752823] [ 181031]  1000 181031   170411    14387  2232320        0             0 io.bydbatt.0
                Feb 17 11:17:27 iobroker kernel: [185572.752832] [ 181042]  1000 181042   232850     8750  2375680        0             0 io.pvforecast.0
                Feb 17 11:17:27 iobroker kernel: [185572.752835] [ 331158]     0 331158     3482     1022    65536        0             0 sshd
                Feb 17 11:17:27 iobroker kernel: [185572.752837] [ 331169]  1000 331169     4591     1119    86016        0             0 systemd
                Feb 17 11:17:27 iobroker kernel: [185572.752839] [ 331182]  1000 331182    42506     1175   102400        0             0 (sd-pam)
                Feb 17 11:17:27 iobroker kernel: [185572.752842] [ 331304]  1000 331304     3516      837    65536        0             0 sshd
                Feb 17 11:17:27 iobroker kernel: [185572.752844] [ 331305]  1000 331305     1465      534    53248        0             0 bash
                Feb 17 11:17:27 iobroker kernel: [185572.752847] [ 336178]  1000 336178   170475    12467  2805760        0             0 io.tr-064.0
                Feb 17 11:17:27 iobroker kernel: [185572.752849] [ 355290]  1000 355290   164702     6762  2220032        0             0 io.frontier_sil
                Feb 17 11:17:27 iobroker kernel: [185572.752851] [ 356236]     0 356236     3482     1021    65536        0             0 sshd
                Feb 17 11:17:27 iobroker kernel: [185572.752854] [ 356241]     0 356241     3482     1004    73728        0             0 sshd
                Feb 17 11:17:27 iobroker kernel: [185572.752856] [ 356376]  1000 356376     3516      759    73728        0             0 sshd
                Feb 17 11:17:27 iobroker kernel: [185572.752859] [ 356387]  1000 356387     1465      505    53248        0             0 bash
                Feb 17 11:17:27 iobroker kernel: [185572.752861] [ 356417]  1000 356417     3516      721    65536        0             0 sshd
                Feb 17 11:17:27 iobroker kernel: [185572.752863] [ 356420]  1000 356420     1465      422    53248        0             0 bash
                Feb 17 11:17:27 iobroker kernel: [185572.752865] [ 356570]  1000 356570   164244     6600  2162688        0             0 io.yeelight-2.0
                Feb 17 11:17:27 iobroker kernel: [185572.752868] [ 356834]  1000 356834   171308    13942  2818048        0             0 io.shelly.0
                Feb 17 11:17:27 iobroker kernel: [185572.752870] [ 357162]  1000 357162   164403     6264  2195456        0             0 io.mihome.0
                Feb 17 11:17:27 iobroker kernel: [185572.752872] [ 357217]     0 357217     3482      988    69632        0             0 sshd
                Feb 17 11:17:27 iobroker kernel: [185572.752875] [ 357316]  1000 357316     3516      812    69632        0             0 sshd
                Feb 17 11:17:27 iobroker kernel: [185572.752877] [ 357317]  1000 357317     1465      528    57344        0             0 bash
                Feb 17 11:17:27 iobroker kernel: [185572.752879] [ 357404]  1000 357404   164225     6370  2170880        0             0 io.text2command
                Feb 17 11:17:27 iobroker kernel: [185572.752882] [ 357964]  1000 357964   237010    13544  2936832        0             0 io.web.0
                Feb 17 11:17:27 iobroker kernel: [185572.752885] [ 357974]  1000 357974   191386    16792  3194880        0             0 io.web.1
                Feb 17 11:17:27 iobroker kernel: [185572.752887] [ 358127]     0 358127     5347      659    65536        0             0 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752889] [ 358128]     0 358128     5347      659    65536        0             0 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752895] [ 358129]     0 358129     5347      659    65536        0             0 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752897] [ 358130]     0 358130     5347      419    65536        0             0 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752899] [ 358131]     0 358131     5347      659    65536        0             0 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752901] [ 358132]     0 358132     5347      659    65536        0             0 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752903] [ 358133]     0 358133     5347      659    65536        0             0 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752905] [ 358134]     0 358134     5347      659    65536        0             0 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752907] [ 358135]     0 358135     5347      659    65536        0             0 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752908] [ 358136]     0 358136     5347      659    65536        0             0 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752910] [ 358137]     0 358137     5347      659    65536        0             0 systemd-udevd
                Feb 17 11:17:27 iobroker kernel: [185572.752912] [ 358142]  1000 358142      652      104    40960        0             0 sh
                Feb 17 11:17:27 iobroker kernel: [185572.752915] [ 358143]  1000 358143     1237      919    49152        0             0 arp-scan
                Feb 17 11:17:27 iobroker kernel: [185572.752916] [ 358144]  1000 358144     1469      520    49152        0             0 ping
                Feb 17 11:17:27 iobroker kernel: [185572.752918] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/iobroker.service,task=iobroker.js-con,pid=179634,uid=1000
                Feb 17 11:17:27 iobroker kernel: [185572.752962] Out of memory: Killed process 179634 (iobroker.js-con) total-vm:4065132kB, anon-rss:3213752kB, file-rss:1444kB, shmem-rss:0kB, UID:1000 pgtables:13272kB oom_score_adj:0
                Feb 17 11:17:27 iobroker kernel: [185572.946819] oom_reaper: reaped process 179634 (iobroker.js-con), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                Feb 17 11:17:27 iobroker kernel: [185573.010658] debugfs: File 'le_min_key_size' in directory 'hci0' already present!
                Feb 17 11:17:27 iobroker kernel: [185573.011690] debugfs: File 'le_max_key_size' in directory 'hci0' already present!
                Feb 17 11:17:27 iobroker systemd[1]: iobroker.service: Main process exited, code=killed, status=9/KILL
                Feb 17 11:17:27 iobroker kernel: [185573.133563] device ens18 left promiscuous mode
                Feb 17 11:17:36 iobroker systemd[1]: Started Session 91 of user iobroker.
                Feb 17 11:17:56 iobroker systemd[1]: iobroker.service: Failed with result 'signal'.
                Feb 17 11:17:56 iobroker systemd[1]: Stopped ioBroker Server.
                Also hab ich ein iob stop gemacht und danach ein iob start. Dann kam es zu dem Fall dass Instanzen loopten:
                2022-02-17 11:19:11.550 - error: admin.0 (358368) admin.0 already running
                2022-02-17 11:19:11.551 - warn: admin.0 (358368) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-02-17 11:19:12.152 - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-02-17 11:19:15.139 - error: email.0 (358380) email.0 already running
                2022-02-17 11:19:15.140 - warn: email.0 (358380) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-02-17 11:19:15.739 - error: host.iobroker instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-02-17 11:19:19.206 - error: history.0 (358393) history.0 already running
                2022-02-17 11:19:19.208 - warn: history.0 (358393) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-02-17 11:19:19.803 - error: host.iobroker instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-02-17 11:19:24.000 - error: javascript.0 (358405) javascript.0 already running
                2022-02-17 11:19:24.002 - warn: javascript.0 (358405) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-02-17 11:19:24.607 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-02-17 11:19:27.671 - error: telegram.0 (358417) telegram.0 already running
                2022-02-17 11:19:27.673 - warn: telegram.0 (358417) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-02-17 11:19:28.277 - error: host.iobroker instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-02-17 11:19:31.374 - error: influxdb.0 (358432) influxdb.0 already running
                2022-02-17 11:19:31.375 - warn: influxdb.0 (358432) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-02-17 11:19:31.974 - error: host.iobroker instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-02-17 11:19:35.248 - error: alexa2.0 (358444) alexa2.0 already running
                2022-02-17 11:19:35.249 - warn: alexa2.0 (358444) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-02-17 11:19:35.848 - error: host.iobroker instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-02-17 11:19:39.215 - error: alexa2.1 (358457) alexa2.1 already running
                2022-02-17 11:19:39.217 - warn: alexa2.1 (358457) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-02-17 11:19:39.810 - error: host.iobroker instance system.adapter.alexa2.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-02-17 11:19:43.691 - info: admin.0 (358468) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.0.10
                2022-02-17 11:19:43.783 - info: admin.0 (358468) requesting all states
                2022-02-17 11:19:43.784 - info: admin.0 (358468) requesting all objects
                2022-02-17 11:19:44.134 - info: admin.0 (358468) Request actual repository...
                2022-02-17 11:19:45.330 - info: admin.0 (358468) received all objects
                2022-02-17 11:19:45.538 - info: admin.0 (358468) https server listening on port 8081
                2022-02-17 11:19:45.539 - info: admin.0 (358468) Use link "https://localhost:8081" to configure.
                2022-02-17 11:19:46.828 - info: admin.0 (358468) Repository received successfully.
                2022-02-17 11:19:47.323 - info: email.0 (358500) starting. Version 1.0.10 in /opt/iobroker/node_modules/iobroker.email, node: v14.19.0, js-controller: 4.0.10
                2022-02-17 11:19:47.838 - error: mihome-vacuum.0 (358511) mihome-vacuum.0 already running
                2022-02-17 11:19:47.839 - warn: mihome-vacuum.0 (358511) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-02-17 11:19:48.428 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-02-17 11:19:48.971 - error: admin.0 (358468) error
                2022-02-17 11:19:51.615 - error: modbus.0 (358539) modbus.0 already running
                2022-02-17 11:19:51.617 - warn: modbus.0 (358539) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-02-17 11:19:52.210 - error: host.iobroker instance system.adapter.modbus.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-02-17 11:19:55.302 - error: mqtt.0 (358555) mqtt.0 already running
                2022-02-17 11:19:55.303 - warn: mqtt.0 (358555) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-02-17 11:19:55.938 - error: host.iobroker instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                Also noch mal iob stop, mit ps auxww | grep io geschaut dass nichts mehr läuft und nochmal iob start.
                Nun läuft er wieder. Aber dass mit dem OOM Killer seit js-controller 4.x ist schon "interessant".
                ..:: So long! Tom ::..
                • DiginixD Diginix
                  #395
                  @diginix Sehr interessant. Also das "Already running" ist einfach (und da haben Sie auch nicht geloopt!) - Der Restart passiert so schnell das die instanzen noch auf "alive" stehen, das erkennt der startende adapter und sagt "neee, da läuft schon einer". Dann stoppen Sie sich mit Fehler 7, der Controller räumt das auf bzw durch die kurze verzögerung bis zum nächsten Restart ist dann alles ok.
                  Also wenn ich jetzt frech sein darf frage ich dich ob DU es nachstellen kannst und wenn du es "verlässlich" hinbekommst dann wäre mal eine Idee zurück auf fileDB zu gehen um auszuschliessen das es was mit jsonl zu tun hat
                  • crunchipC Abwesend
                    crunchipC Abwesend
                    #396
                    @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                    Die Fehler haben mit Viel-CPU-Problemen nichts zu tun!! Das ist ok so, wundert mich
                    ging ja nicht um die CPU, sondern die Frage der HOST ERROR MELDUNGEN, bei einem ìob stop
                    hier nochmal aus dem daemon.log
                    Feb 16 11:36:06 IoBroker systemd[1]: Stopping ioBroker Server...
                    Feb 16 11:36:08 IoBroker bash[14308]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    Feb 16 11:36:08 IoBroker bash[14308]: Error: DB closed
                    Feb 16 11:36:08 IoBroker bash[14308]:     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                    Feb 16 11:36:08 IoBroker bash[14308]:     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                    Feb 16 11:36:08 IoBroker bash[14308]:     at Object.onceWrapper (events.js:520:26)
                    Feb 16 11:36:08 IoBroker bash[14308]:     at Socket.emit (events.js:400:28)
                    Feb 16 11:36:08 IoBroker bash[14308]:     at Socket.emit (domain.js:475:12)
                    Feb 16 11:36:08 IoBroker bash[14308]:     at TCP.<anonymous> (net.js:686:12)
                    Feb 16 11:36:08 IoBroker bash[14308]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                    Feb 16 11:36:08 IoBroker bash[14308]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                    Feb 16 11:36:08 IoBroker bash[14308]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40)
                    Feb 16 11:36:08 IoBroker bash[14308]:     at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:6485:35)
                    Feb 16 11:36:14 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
                    Feb 16 11:36:15 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                    Feb 16 11:36:15 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
                    Feb 16 11:36:15 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
                    Feb 16 11:36:16 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [Process stopped]
                    Feb 16 11:36:16 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.logparser.0 => false [Process stopped]
                    Feb 16 11:36:16 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [system.adapter.iot.0.logging]
                    Feb 16 11:36:16 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.jarvis.0 => false [Process stopped]
                    Feb 16 11:36:17 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.seq.0 => false [Process stopped]
                    Feb 16 11:36:17 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.logparser.0 => false [system.adapter.logparser.0.logging]
                    Feb 16 11:36:17 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.jarvis.0 => false [system.adapter.jarvis.0.logging]
                    Feb 16 11:36:17 IoBroker bash[14308]: ================================== > LOG REDIRECT system.adapter.seq.0 => false [system.adapter.seq.0.logging]
                    Feb 16 11:36:20 IoBroker systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                    Feb 16 11:36:20 IoBroker systemd[1]: iobroker.service: Failed with result 'exit-code'.
                    Feb 16 11:36:20 IoBroker systemd[1]: Stopped ioBroker Server.
                      #397
                      @crunchip Nutzt Du adapter im Compact mode und da in gruppe 0?
                      EDIT: Ok vergiss die Frage: Diese Logzeilen sind die die der Shelly adapter ausgespuckt hatte nur nochmal "wiederholt"
                      • apollon77A apollon77
                        DiginixD Offline
                        DiginixD Offline
                        Diginix
                        #398
                        Wenn ich da nicht manuell eingreife geht das munter so weiter. Zumindest war das meine Beobachtung. Da man schnell wieder ein lauffähiges System möchte, bricht man halt mit iob stop alles ab. Ob sich das von allein beruhig hätte, bekommen wir so nicht raus. Eigentlich interessiert mich das OOM Killer "Problem" mehr. Wenn genug da ist, sollte kein Update diesen triggern. Mit js-controller 3.x und file db hatte ich das nie und da war der RAM sogar 2 GG weniger bei identischer Adapter Anzahl.
                        Verständlich, aber selbst mit Proxmox und VMs ist das keine einfache Aufgabe. Selbst wenn ich die VM klone und darin alles auf file db zurück stelle, kann ich nicht alle Adapter laufen lassen, weil zB mqtt clients nicht an 2 Brokern hängen können. Also liefe im Klon nur ein kleiner Teil der Adapter um auch das Netzwerk nicht zu überlasten. Ob das dann noch repräsentativ wäre, weiß ich nicht. Ich beobachte vorerst mal unverändert weiter.
                        apollon77A AlCalzoneA 3 Antworten Letzte Antwort
                        • DiginixD Diginix
                          #399
                          @diginix Ich habe in meinen testsyteme auch rumexperimentiert und bei mir ist RAM technisch alles stabil ...
                          Die Preisfrage ist ja Wo das RAM verbraucht wird ... (und nur die Grafik darfst nicht ansehen weil Linux sich an sich RAM krallt wenns da ist und freigibt wenn nötig. also "zählt nur" free -m
                          • DiginixD Diginix
                            #400
                            @diginix sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                            sollte maxmial 30s so sein (wenn mehr als einmal)...
                              @knopers1 Interessant. Ist deprecated seit der 3.0 ... hat scheinbar keiner vorher im Log gesehen. Für dich als Quick Fix: Suche die Code stelle /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js Zeile 252 und ändere adapter.objects.getObjectList in adapter.getObjectList.
                              Anpassen muss es frankjoke ... sorry
                              I added to incompatibility List in first post
                              W Offline
                              W Offline
                              Werner303
                              #401
                              @apollon77 Vielen Dank. Die kleine Änderung am Code hat mir sehr geholfen.
                              • DiginixD Diginix
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                #402
                                @diginix Kannst du mal mitschneiden, was die einzelnen ioBroker-Prozesse an RAM verbrauchen? Z.B. durch History-Aufzeichnung von system.adapter.<adaptername>.0.memRss und system.host.<hostname>.memRss
                                Ebenfalls interessant wäre (einmalig) Anzahl Objekte, Anzahl States und input/output count der Adapter.
                                • AlCalzoneA AlCalzone
                                  DiginixD Offline
                                  DiginixD Offline
                                  Diginix
                                  #403
                                  @alcalzone memRss für alle Instanzen+Host ist nun in History aktiviert.
                                  Objekte: 17720, Zustände: 15859
                                  Alle in/out aller 47 Instanzen ging als Screenshot am einfachsten:
                                  https://www.dropbox.com/s/ceafuk51rhv0om2/2022-02-17_in_out_adapter.png?dl=0
                                  Im regulären Betrieb ist da aber auch nichts auffällig mMn. Nur bei den js-controller Updates hatte ich zuletzt einmal ein OOM Problem und heute nach Update von 5 Adaptern.
                                  apollon77A AlCalzoneA 2 Antworten Letzte Antwort
                                  • DiginixD Diginix
                                    #404
                                    Neee, auch das gibts als states in system.adapter/host.NAME.*
                                      DiginixD Offline
                                      DiginixD Offline
                                      Diginix
                                      #405
                                      @apollon77 Davon ist doch der Screenshot super vorgefiltert ;-)
                                      Aber selbst das lies sich nicht als html, text aus Admin raus kopieren und ich copy/paste keine 94 Werte plus Namen...
                                      Wenn ich @AlCalzone richtig verstanden habe, wollte er es doch nur einmalig und das wahrs. menschlich lesbar aber nicht zwingend maschinenlesbar...
                                      • DiginixD Diginix
                                        #406
                                        @diginix Naja, einmalig ist einmalig ... mit Historisierung sieht man wie es sich generell verhält ... kann ja sein das der Blick auf das "JETZT" sehr irreführend ist
                                          DiginixD Offline
                                          DiginixD Offline
                                          Diginix
                                          #407
                                          @apollon77 Ich habe nur gemacht was @AlCalzone geschrieben hat. ;-)
                                          Dachte er will sich erstmal ein Bild von meinem System verschaffen.
                                          RAM wird nun mit Vorhaltezeit von 1 Monat dauerhaft mirgemeiselt. Das kann ich für in/out genau so aktivieren.
                                          Edit:
                                          ab sofort wird für 30 Tage rückwirkend auf der HDD persistiert:
                                          system.adapter/host.*.*.memRss
                                          system.adapter/host.*.*.inputCount
                                          system.adapter/host.*.*.outputCount
