  4. Iobroker backitup error.. Wo liegt das problem
    6.3k
283 Beiträge 14 Kommentatoren 39.3k Aufrufe 8 Beobachtet
    @elmos04
    Dann ist es auch weg.
    Ein Backup-Versuch sieht jetzt wie aus?
    Tip am Rande: Umlaute in Dateinamen sind zu vermeiden.
    elmos04
    #89
    code_textStarted iobroker ...
    [DEBUG] [iobroker] - host.raspberrypi 8762 states saved
    [DEBUG] [iobroker] - host.raspberrypi 10657 objects saved
    [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json is not a valid json file
    [DEBUG] [iobroker] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0
    [DEBUG] [zigbee] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: Garagentor_Status
    [DEBUG] [javascripts] - found Script: Taster_6Fach
    [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
    [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
    [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
    [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
    [DEBUG] [javascripts] - found Script: Gast_Wlan
    [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
    [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
    [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
    [DEBUG] [javascripts] - found Script: Überwachung_Temp
    [DEBUG] [javascripts] - found Script: Rauchmelder
    [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
    [DEBUG] [javascripts] - found Script: Xiaomi_Taster
    [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
    [DEBUG] [javascripts] - found Script: Ikea_Taster_
    [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
    [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
    [DEBUG] [javascripts] - found Script: Duty_Cycle
    [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
    [DEBUG] [javascripts] - found Script: Einbruch_erkannt
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-13_06_24_ioBroker_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [EXIT] 26
    • E elmos04
      [EXIT] 26
      #90
      @elmos04
      Dann ist die Quell-Datei schon krumm. Ich weiß aber nicht wo die liegt und wie die da hingekommen ist.
      E 1 Antwort Letzte Antwort
        @elmos04
        elmos04
        #91
        das werde ich wohl nie sagen können wie es dahin gekommen ist.
        Denke das ich auch ohne Backup erst mal leben kann. Ich speichere meine Vis und skripte gelegentlich selber ab. wenn der Broker mal defekt ist mache ich alles nochmal und dann wird der Back-up adapter wieder gehen. Mein altes system wurde darüber gesichert und lief auch über 4 jähre durch. bei einer Neuinstallation hat er mir diesmal auch nicht weiter geholfen. Aber viele vielen dank für eure Hilfe. Dann weis ich nun das ich es versucht habe und es ein großes Problem ist.
        • E elmos04
          simatecS Offline
          simatecS Offline
          simatec
          #92
          @elmos04
          Schaue mal, ob die Datei hier liegt
          /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
          Lösche diese bzw. lege sie woanders ab.
          Die hat einen Fehler und bricht beim parsen das Backup ab
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
            @elmos04
            #93
            @thomas-braun sagte in Iobroker backitup error.. Wo liegt das problem:
            oder er hat keine Rechte
            • E Offline
              elmos04
              #94
              code_text
              pi@raspberrypi:/opt/iobroker $ /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
              -bash: /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json: Keine Berechtigung
              • E elmos04
                code_text
                #95
                @elmos04
                ls -la /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                  @elmos04
                  elmos04
                  #96
                  code_text
                  pi@raspberrypi:/opt/iobroker $ ls
                  backups             iob       iobroker-data  node_modules  package-lock.json
                  INSTALLER_INFO.txt  iobroker  log            package.json  reinstall.js
                  pi@raspberrypi:/opt/iobroker $ ls -la /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                  -rw-rw-r--+ 1 iobroker iobroker 2405  4. Feb 17:57 /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                  simatecS HomoranH 2 Antworten Letzte Antwort
                  • E Offline
                    elmos04
                    #97
                    code_text
                    [DEBUG] [mount] - noserverino option: true
                    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ElmoS04,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.2.31/home/ioBrokerVis /opt/iobroker/backups"
                    [DEBUG] [mount] - mount successfully completed
                    [DEBUG] [mount] - done
                    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-15_58_06_ioBroker_backupiobroker.tar.gz
                    [DEBUG] [cifs] - done
                    [DEBUG] [umount] - mount activ, umount is started ...
                    [DEBUG] [umount] - umount successfully completed
                    [DEBUG] [umount] - done
                    [EXIT] 26
                    • E elmos04
                      code_text
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #98
                      @elmos04 Das json Format ist nicht in Ordnung.
                      Speiche doch die Datei erstmal weg und lösche sie im Vis Pfad
                      • simatecS simatec
                        elmos04
                        #99
                        @simatec
                        Ja super. 😊
                        Würde ich gerne machen. Ich kann nur copy und Paste.
                        • E elmos04
                          @simatec
                          Ja super. 😊
                          wendy2702W Online
                          wendy2702W Online
                          #100
                          @elmos04 weg kopieren:
                          sudo cp /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json /opt/iobroker/6_Fach_Taster_1_Büro_licht.json.defekt
                          Die Kopie sollte dann erstmal bei /opt/iobroker/ landen. Kannst du dir dann in Ruhe ansehen oder komplett löschen wenn du die nicht mehr benötigst.
                          Löschen:
                          sudo rm /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                          • E Offline
                            elmos04
                            #101
                            @wendy2702 sagte in Iobroker backitup error.. Wo liegt das problem:
                            code_text
                            pi@raspberrypi:/opt/iobroker $ sudo cp /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json /opt/iobroker/6_Fach_Taster_1_Büro_licht.json.defekt
                            cp: der Aufruf von stat für '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                            pi@raspberrypi:/opt/iobroker $ cd //
                            pi@raspberrypi:// $ sudo cp /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json /opt/iobroker/6_Fach_Taster_1_Büro_licht.json.defekt
                            pi@raspberrypi:// $
                            • E elmos04
                              code_text
                              #102
                              Es geht um diese Datei!
                              @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
                              pi@raspberrypi:/opt/iobroker $ ls -la /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json -rw-rw-r--+ 1 iobroker iobroker 2405 4. Feb 17:57 /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                              nicht um das tmp Verzeichnis
                                elmos04
                                #103
                                @homoran 😢 Wenn ich das nur wüsste.
                                • E elmos04
                                  #104
                                  deswegen sag ich's ja.
                                  das tmp Verzeichnis (oder sein Inhalt) existiert wahrscheinlich nicht mehr
                                    elmos04
                                    #105
                                    deshalb glaub ich da ich damit leben muss.
                                    HomoranH simatecS 2 Antworten Letzte Antwort
                                    • E elmos04
                                      #106
                                      Liest du eigentlich was wir dir schreiben?
                                      und verstehst du was du da tust?
                                      Du hast doch extra nach der Datei gesucht (und sie gefunden)
                                      Diese Datei wird im Rahmen des Backups gepackt und vorher geprüft.
                                      Dafür liegt die (Kopie der) Datei kurzzeitig in diesem tmp-Verzeichnis.
                                      Der Fehler (das defekte json) ist aber in der Originaldatei, die jedesmal wieder das backup killen wird, wenn du sie nicht löschst oder verschiebst in ein Verzeichnis, das nicht gesichert wird
                                      Da gibt es kein mit leben müssen !!
                                      • E elmos04
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #107
                                        @elmos04
                                        sudo cp /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json /home/pi/6_Fach_Taster_1_Büro_licht.json
                                        sudo rm /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                                        Danach geht dein Backup
                                          elmos04
                                          #108
                                          Lesen -Ja
                                          Verstehen - nein
