  4. Adapter RADAR2 restart-loop
    6.1k
14 Beiträge 3 Kommentatoren 1.2k Aufrufe 3 Beobachtet
  • E eubecker
    Moin,
    RADAR2 funktioniert seit einigen Tagen nicht mehr (ich meine nach Systemupdate.
    Auf einem RASPI. Ich habe NODE auf V14 upgedatet, RADAR2 de- und neuinstalliert. Bring nichts.
    Aus dem Log werde ich nicht schlau, hat jemand einen Tipp?
    2021-12-21 22:21:25.111  - info: host.erbse "system.adapter.radar2.0" enabled
    2021-12-21 22:21:25.241  - info: host.erbse instance system.adapter.radar2.0 started with pid 6684
    2021-12-21 22:21:28.751  - info: radar2.0 (6684) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v14
    .18.2, js-controller: 3.3.21
    2021-12-21 22:21:28.897  - info: radar2.0 (6684) radar2 initialization started...
    2021-12-21 22:21:28.918  - info: radar2.0 (6684) Will use l2Ping for BT scans.
    2021-12-21 22:21:29.032  - info: radar2.0 (6684) Will run hcitool-mode and not noble on device [ [Object] ]!
    2021-12-21 22:21:29.301  - info: radar2.0 (6684) net-ping not available! Will try to use normal ping!
    2021-12-21 22:21:29.344  - info: radar2.0 (6684) arp-scan will use the following interfaces: [ 'eth0' ]
    2021-12-21 22:21:29.367  - error: radar2.0 (6684) uncaught exception: bind EACCES 0.0.0.0:67
    2021-12-21 22:21:29.369  - error: radar2.0 (6684) Error: bind EACCES 0.0.0.0:67
        at dgram.js:357:20
        at processTicksAndRejections (internal/process/task_queues.js:83:21)
    2021-12-21 22:21:29.370  - error: radar2.0 (6684) Exception-Code: EACCES: bind EACCES 0.0.0.0:67
    2021-12-21 22:21:29.373  - warn: radar2.0 (6684) Uncaught Exception: bind EACCES 0.0.0.0:67
    2021-12-21 22:21:29.388  - info: radar2.0 (6684) Unload adapter now with null
    2021-12-21 22:21:29.390  - info: radar2.0 (6684) Adapter disconnected and stopped with dostop(null) and callback(true)
    2021-12-21 22:21:29.392  - info: radar2.0 (6684) terminating
    2021-12-21 22:21:29.394  - warn: radar2.0 (6684) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2021-12-21 22:21:30.073  - error: host.erbse instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2021-12-21 22:21:30.075  - info: host.erbse Restart adapter system.adapter.radar2.0 because enabled
    crunchipC Offline
    crunchipC Offline
    @eubecker sagte in Adapter RADAR2 restart-loop:
    schon mal die readme gelesen
    and below need to be run whenever you or the system updates nodejs, or any of the apps installed above!
    kurzgesagt ein
    iob fix
    sollte es auch tun
    Thomas BraunT E 2 Antworten Letzte Antwort
      kurzgesagt ein
      iob fix
      sollte es auch tun
      @crunchip
      Sag ich doch... 😀
        @crunchip
        Sag ich doch... 😀
        crunchipC Offline
        crunchipC Offline
        @thomas-braun wollt es nur ein bisschen ausführlicher😝
          kurzgesagt ein
          iob fix
          sollte es auch tun
          eubecker
          schrieb am zuletzt editiert von eubecker
          @crunchip said in Adapter RADAR2 restart-loop:
          Ja.
          kurzgesagt ein
          iob fix
          Und nochmal ja.
          Da passiert aber nicht viel, weder bei iobroker fix noch iob fix mit oder ohne sudo:
          iobroker fix
          Execute the installation fixer script, this updates your ioBroker installation
          Options:
                --help     Show help  [boolean]
            -v, --version  Show version  [boolean]
          Fehlt da ein Parameter/script/...?
          • E eubecker
            Ja.
            kurzgesagt ein
            iob fix
            Und nochmal ja.
            iobroker fix
            Options:
            @eubecker
            Nein. Aber die vollständige Shell, inkl. login prompt.
            iobroker status
            iobroker version
            Liefert?
            Und wie oft noch... In einer sauberen Installation wird iobroker nie mit sudo aufgerufen.
            E 1 Antwort Letzte Antwort
            • crunchipC Offline
              crunchipC Offline
              Und nochmal ja.
              dann probier mal die lange Version
              curl -sL https://iobroker.net/fix.sh | bash -
                @eubecker
                iobroker status
                iobroker version
                Liefert?
                eubecker
                iobroker status
                pi@erbse:~ $ iobroker status
                Objects type: file
                States  type: file
                iobroker version
                3.3.21
                Das war auch nur meine Verzweiflung, weil halt augenscheinlich nix passierte.
                  Und nochmal ja.
                  eubecker
                  Danke, das hat geholfen, Radar ist wieder grün :-)
                  • E eubecker
                    eubecker
                    @eubecker said in Adapter RADAR2 restart-loop:
                    Hallo, ich muss das Thema leider wieder aufwärmen:
                    Nachdem Radar "plötzlich" wieder mit der gleichen Meldung in den Streik ging habe ich Update und den Fix wieder laufen lassen müssen.
                    Irgendwelche Ideen, warum der nach ca. 6 Wochen klagloser Arbeit wieder in Streik gegangen ist? Ein einfacher Restart von ioBroker und Raspi hatte nichts gebracht.
                    • E eubecker
                      @eubecker
                      Meldungen?
                      iobroker fix
                      ausgeführt? Meldungen?
                      • E eubecker
                        crunchipC Offline
                        crunchipC Offline
                        war das plötzlich vielleicht ein sudo apt update && sudo apt upgrade??
