<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adapter RADAR2 restart-loop]]></title><description><![CDATA[<p dir="auto">Moin,</p>
<p dir="auto">RADAR2 funktioniert seit einigen Tagen nicht mehr (ich meine nach Systemupdate.</p>
<p dir="auto">Auf einem RASPI. Ich habe NODE auf V14 upgedatet, RADAR2 de- und neuinstalliert. Bring nichts.</p>
<p dir="auto">Aus dem Log werde ich nicht schlau, hat jemand einen Tipp?</p>
<pre><code>2021-12-21 22:21:25.111  - info: host.erbse "system.adapter.radar2.0" enabled
2021-12-21 22:21:25.241  - info: host.erbse instance system.adapter.radar2.0 started with pid 6684
2021-12-21 22:21:28.751  - info: radar2.0 (6684) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v14
.18.2, js-controller: 3.3.21
2021-12-21 22:21:28.897  - info: radar2.0 (6684) radar2 initialization started...
2021-12-21 22:21:28.918  - info: radar2.0 (6684) Will use l2Ping for BT scans.
2021-12-21 22:21:29.032  - info: radar2.0 (6684) Will run hcitool-mode and not noble on device [ [Object] ]!
2021-12-21 22:21:29.301  - info: radar2.0 (6684) net-ping not available! Will try to use normal ping!
2021-12-21 22:21:29.344  - info: radar2.0 (6684) arp-scan will use the following interfaces: [ 'eth0' ]
2021-12-21 22:21:29.367  - error: radar2.0 (6684) uncaught exception: bind EACCES 0.0.0.0:67
2021-12-21 22:21:29.369  - error: radar2.0 (6684) Error: bind EACCES 0.0.0.0:67
    at dgram.js:357:20
    at processTicksAndRejections (internal/process/task_queues.js:83:21)
2021-12-21 22:21:29.370  - error: radar2.0 (6684) Exception-Code: EACCES: bind EACCES 0.0.0.0:67
2021-12-21 22:21:29.373  - warn: radar2.0 (6684) Uncaught Exception: bind EACCES 0.0.0.0:67
2021-12-21 22:21:29.388  - info: radar2.0 (6684) Unload adapter now with null
2021-12-21 22:21:29.390  - info: radar2.0 (6684) Adapter disconnected and stopped with dostop(null) and callback(true)
2021-12-21 22:21:29.392  - info: radar2.0 (6684) terminating
2021-12-21 22:21:29.394  - warn: radar2.0 (6684) Terminated (UNCAUGHT_EXCEPTION): Without reason
2021-12-21 22:21:30.073  - error: host.erbse instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
2021-12-21 22:21:30.075  - info: host.erbse Restart adapter system.adapter.radar2.0 because enabled
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/50529/adapter-radar2-restart-loop</link><generator>RSS for Node</generator><lastBuildDate>Sat, 23 May 2026 15:37:18 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/50529.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Dec 2021 21:24:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Sun, 13 Feb 2022 14:18:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eubecker" aria-label="Profile: eubecker">@<bdi>eubecker</bdi></a> sagte in <a href="/post/761632">Adapter RADAR2 restart-loop</a>:</p>
<blockquote>
<p dir="auto">Nachdem Radar <strong>"plötzlich</strong>" wieder mit der gleichen Meldung in den Streik ging habe ich Update und den Fix wieder laufen lassen müssen.</p>
</blockquote>
<p dir="auto">war das <strong>plötzlich</strong> vielleicht ein <code>sudo apt update &amp;&amp;  sudo apt upgrade</code>??</p>
]]></description><link>https://forum.iobroker.net/post/761674</link><guid isPermaLink="true">https://forum.iobroker.net/post/761674</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Sun, 13 Feb 2022 14:18:14 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Sun, 13 Feb 2022 13:09:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eubecker" aria-label="Profile: eubecker">@<bdi>eubecker</bdi></a></p>
<p dir="auto">Meldungen?</p>
<pre><code>iobroker fix
</code></pre>
<p dir="auto">ausgeführt? Meldungen?</p>
]]></description><link>https://forum.iobroker.net/post/761637</link><guid isPermaLink="true">https://forum.iobroker.net/post/761637</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 13 Feb 2022 13:09:46 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Sun, 13 Feb 2022 13:07:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eubecker" aria-label="Profile: eubecker">@<bdi>eubecker</bdi></a> said in <a href="/post/726003">Adapter RADAR2 restart-loop</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> said in <a href="/post/725332">Adapter RADAR2 restart-loop</a>:</p>
<blockquote>
<p dir="auto">dann probier mal die lange Version</p>
<pre><code>curl -sL https://iobroker.net/fix.sh | bash -
</code></pre>
</blockquote>
<p dir="auto">Danke, das hat geholfen, Radar ist wieder grün :-)</p>
</blockquote>
<p dir="auto">Hallo, ich muss das Thema leider wieder aufwärmen:<br />
Nachdem Radar "plötzlich" wieder mit der gleichen Meldung in den Streik ging habe ich Update und den Fix wieder laufen lassen müssen.<br />
Irgendwelche Ideen, warum der nach ca. 6 Wochen klagloser Arbeit wieder in Streik gegangen ist? Ein einfacher Restart von ioBroker und Raspi hatte nichts gebracht.</p>
]]></description><link>https://forum.iobroker.net/post/761632</link><guid isPermaLink="true">https://forum.iobroker.net/post/761632</guid><dc:creator><![CDATA[eubecker]]></dc:creator><pubDate>Sun, 13 Feb 2022 13:07:28 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Fri, 24 Dec 2021 11:49:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> said in <a href="/post/725332">Adapter RADAR2 restart-loop</a>:</p>
<blockquote>
</code></pre>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/726003</link><guid isPermaLink="true">https://forum.iobroker.net/post/726003</guid><dc:creator><![CDATA[eubecker]]></dc:creator><pubDate>Fri, 24 Dec 2021 11:49:44 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Fri, 24 Dec 2021 11:43:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">iobroker status</p>
</blockquote>
<pre><code>pi@erbse:~ $ iobroker status
Objects type: file
States  type: file
</code></pre>
<blockquote>
<p dir="auto">iobroker version</p>
</blockquote>
<pre><code>3.3.21
</code></pre>
<blockquote>
<p dir="auto">Und wie oft noch... In einer sauberen Installation wird iobroker nie mit sudo aufgerufen.</p>
</blockquote>
<p dir="auto">Das war auch nur meine Verzweiflung, weil halt augenscheinlich nix passierte.</p>
]]></description><link>https://forum.iobroker.net/post/725998</link><guid isPermaLink="true">https://forum.iobroker.net/post/725998</guid><dc:creator><![CDATA[eubecker]]></dc:creator><pubDate>Fri, 24 Dec 2021 11:43:02 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Thu, 23 Dec 2021 07:02:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eubecker" aria-label="Profile: eubecker">@<bdi>eubecker</bdi></a> sagte in <a href="/post/725255">Adapter RADAR2 restart-loop</a>:</p>
<blockquote>
<p dir="auto">Und nochmal ja.<br />
Da passiert aber nicht viel, weder bei iobroker fix</p>
</blockquote>
</code></pre>
]]></description><link>https://forum.iobroker.net/post/725332</link><guid isPermaLink="true">https://forum.iobroker.net/post/725332</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Thu, 23 Dec 2021 07:02:40 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Wed, 22 Dec 2021 22:10:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eubecker" aria-label="Profile: eubecker">@<bdi>eubecker</bdi></a></p>
<p dir="auto">Nein. Aber die vollständige Shell, inkl. login prompt.</p>
<pre><code>iobroker status
iobroker version
</code></pre>
<p dir="auto">Liefert?</p>
]]></description><link>https://forum.iobroker.net/post/725258</link><guid isPermaLink="true">https://forum.iobroker.net/post/725258</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 22 Dec 2021 22:10:32 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Wed, 22 Dec 2021 22:09:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> said in <a href="/post/724594">Adapter RADAR2 restart-loop</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eubecker" aria-label="Profile: eubecker">@<bdi>eubecker</bdi></a> sagte in <a href="/post/724550">Adapter RADAR2 restart-loop</a>:</p>
<blockquote>
<p dir="auto">Ich habe NODE auf V14 upgedatet</p>
</blockquote>
<p dir="auto">schon mal die <a href="https://github.com/frankjoke/ioBroker.radar2" rel="nofollow ugc">readme</a> gelesen</p>
<pre><code></code></pre>
</blockquote>
<p dir="auto">Ja.</p>
<blockquote>
<blockquote>
<p dir="auto">and below need to be run whenever you or the system updates nodejs, or any of the apps installed above!</p>
</blockquote>
<pre><code>kurzgesagt ein
</code></pre>
<p dir="auto">iob fix</p>
</blockquote>
Da passiert aber nicht viel, weder bei iobroker fix noch iob fix mit oder ohne sudo:</p>
Execute the installation fixer script, this updates your ioBroker installation
Options:
      --help     Show help  [boolean]
  -v, --version  Show version  [boolean]
</code></pre>
<p dir="auto">Fehlt da ein Parameter/script/...?</p>
]]></description><link>https://forum.iobroker.net/post/725255</link><guid isPermaLink="true">https://forum.iobroker.net/post/725255</guid><dc:creator><![CDATA[eubecker]]></dc:creator><pubDate>Wed, 22 Dec 2021 22:09:28 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Tue, 21 Dec 2021 23:18:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> wollt es nur ein bisschen ausführlicher<img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61d.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--stuck_out_tongue_closed_eyes" style="height:23px;width:auto;vertical-align:middle" title=":stuck_out_tongue_closed_eyes:" alt="😝" /></p>
]]></description><link>https://forum.iobroker.net/post/724601</link><guid isPermaLink="true">https://forum.iobroker.net/post/724601</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 21 Dec 2021 23:18:09 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Tue, 21 Dec 2021 23:11:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a></p>
<p dir="auto">Sag ich doch... 😀</p>
]]></description><link>https://forum.iobroker.net/post/724599</link><guid isPermaLink="true">https://forum.iobroker.net/post/724599</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 21 Dec 2021 23:11:25 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Tue, 21 Dec 2021 23:03:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eubecker" aria-label="Profile: eubecker">@<bdi>eubecker</bdi></a> sagte in <a href="/post/724550">Adapter RADAR2 restart-loop</a>:</p>
<blockquote>
</blockquote>
<pre><code>and below need to be run whenever you or the system updates nodejs, or any of the apps installed above!
</code></pre>
<p dir="auto">kurzgesagt ein</p>
<pre><code>iob fix
</code></pre>
<p dir="auto">sollte es auch tun</p>
]]></description><link>https://forum.iobroker.net/post/724594</link><guid isPermaLink="true">https://forum.iobroker.net/post/724594</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 21 Dec 2021 23:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Tue, 21 Dec 2021 21:29:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eubecker" aria-label="Profile: eubecker">@<bdi>eubecker</bdi></a></p>
<p dir="auto">Hast du den Fixer auch mal ausgeführt? Scheint mir mit den Rechten zusammenzuhängen.</p>
]]></description><link>https://forum.iobroker.net/post/724553</link><guid isPermaLink="true">https://forum.iobroker.net/post/724553</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 21 Dec 2021 21:29:31 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter RADAR2 restart-loop on Tue, 21 Dec 2021 21:26:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eubecker" aria-label="Profile: eubecker">@<bdi>eubecker</bdi></a></p>
<p dir="auto">Bitte CodeTags für Log-Auszüge verwenden.</p>
]]></description><link>https://forum.iobroker.net/post/724552</link><guid isPermaLink="true">https://forum.iobroker.net/post/724552</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 21 Dec 2021 21:26:02 GMT</pubDate></item></channel></rss>
