  4. Iobroker backitup error.. Wo liegt das problem
    6.3k
283 Beiträge 14 Kommentatoren 39.3k Aufrufe 8 Beobachtet
    @elmos04
    Das sehe ich im Log.
    Das ist aber zu 100% falsch eingestellt.
    Stell 'noserverino' aus und die smb Version auf die, die auch dein NAS spricht.
    elmos04
    #68
    code_text
    Started iobroker ...
    [DEBUG] [iobroker] - host.raspberrypi 8762 states saved
    [DEBUG] [iobroker] - host.raspberrypi 10657 objects saved
    [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json is not a valid json file
    [DEBUG] [iobroker] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0
    [DEBUG] [zigbee] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: Garagentor_Status
    [DEBUG] [javascripts] - found Script: Taster_6Fach
    [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
    [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
    [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
    [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
    [DEBUG] [javascripts] - found Script: Gast_Wlan
    [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
    [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
    [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
    [DEBUG] [javascripts] - found Script: Überwachung_Temp
    [DEBUG] [javascripts] - found Script: Rauchmelder
    [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
    [DEBUG] [javascripts] - found Script: Xiaomi_Taster
    [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
    [DEBUG] [javascripts] - found Script: Ikea_Taster_
    [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
    [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
    [DEBUG] [javascripts] - found Script: Duty_Cycle
    [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
    [DEBUG] [javascripts] - found Script: Einbruch_erkannt
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-12_18_53_ioBroker_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [EXIT] 26
    Jetzt habe ich auf nas aus und speichere es Lokal.
    • E elmos04
      code_text
      [EXIT] 26
      #69
      @elmos04
      Lokales speichern ist kein Backup.
      E 1 Antwort Letzte Antwort
        @elmos04
        elmos04
        #70
        Ja ich wollte nur sehen bo die Einstellungen für mein Nas falsch sind. dann sollte es ja lokal gehen.
        • E elmos04
          #71
          @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
          JA, die sind FALSCH.
          Hab ich doch eben schon geschrieben.
          Lösch alles Dateien aus /opt/iobroker/backups wieder raus, das Verzeichnis muss leer sein beim mounten
            elmos04
            #72
            aber trotzdem bekomme ich kein lokales backup hin.
            wenn das geht schau ich mir die nas Einstellungen an. java und zigbee werden auf dem nas gesichert
            • E elmos04
              #73
              @elmos04
              mal anschauen. Das ist offenbar krumm.
              • E Offline
                elmos04
                #74
                Ja wurde mir beim einspielen vom alten backup installiert. den 6fachtaster gab es da noch nicht. der wurde erst später im Zigbee installiert
                • E elmos04
                  #75
                  @elmos04
                  Wurscht wo das herkommt, es ist offenbar kaputt.
                    @elmos04
                    elmos04
                    #76
                    Okay das dachte ich mir ja schon
                    Nur wie bekomme ich den weg?👍
                    • E elmos04
                      #77
                      @elmos04
                      Wie ist es denn hingekommen?
                      Vielleicht mal löschen:
                      sudo rm /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                      • E elmos04
                        #78
                        @elmos04 liest du auch ab und zu mal was im log steht?
                        Demnach ist das ein defekter View
                        EDIT:
                        oder ein defektes (abgebrochenes ???) backup
                        E Thomas BraunT 2 Antworten Letzte Antwort
                          @elmos04
                          elmos04
                          #79
                          Ich habe den IOBroker neu erstellt. als erstes nach dem Start versucht mit dem BackitUp adapter das Backup vor einer Woche eingespielt. danach war nur Zigbee JavaScript und vis da. Aber seit dem geht das Backup nicht mehr.
                            EDIT:
                            elmos04
                            #80
                            ich habe den VIS gelöscht und neu gemacht. den Vis Tech wurde durch den DemoView überschrieben. hat alles nicht geklappt.
                              EDIT:
                              #81
                              @homoran sagte in Iobroker backitup error.. Wo liegt das problem:
                              EDIT:
                              Eher das. Das file liegt ja in tmp.
                                EDIT:
                                #82
                                @thomas-braun sagte in Iobroker backitup error.. Wo liegt das problem:
                                oder es liegt da, weil es gerade(??) die Views packen will??
                                • E Offline
                                  elmos04
                                  #83
                                  da ich wie gesagt keine Ahnung habe dachte ich mir das es am view liegt. habe versucht alles weg machen zu können. hat nichts gebracht. ich hatte Gehöft das es ein Befehl gibt ein Verzeichnis zu löschen welchen dann neu erstellt werden kann ohne die Reste vom Alten Backup.
                                  aber ist wohl doch ein grösseres problem.
                                  • E elmos04
                                    #84
                                    @elmos04
                                    Hast du denn das krumme file gelöscht?
                                    ls -la /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                                      @elmos04
                                      elmos04
                                      #85
                                      bestimmt nicht
                                      ich habe nur den View überschrieben
                                      im terminal hab ich nicht gelöscht. das kann ich ja halt nicht.
                                      ich brauchen den ganzen view tech nicht. hab ein neuen main erstellt.
                                      • E elmos04
                                        bestimmt nicht
                                        #86
                                        Warum nicht? Die Befehle hab ich doch schon c&p-fertig serviert?
                                          elmos04
                                          #87
                                          Ich meinte das ich das nochnicjt gemacht hatte. habe es jetzt versucht.
                                          code_text
                                          pi@raspberrypi:~ $ cd /opt/iobroker/
                                          pi@raspberrypi:/opt/iobroker $ ls -la /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                                          ls: Zugriff auf '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                          Kommt das
