  4. Iobroker backitup error.. Wo liegt das problem
    6.3k
283 Beiträge 14 Kommentatoren 39.3k Aufrufe 8 Beobachtet
  • E elmos04
    @thomas-braun code_text
    code_text
    ```Started iobroker ...
    [DEBUG] [mount] - mount activ... umount is started before mount!!
    [DEBUG] [mount] - umount successfully completed
    [DEBUG] [mount] - noserverino option: true
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ElmoS04,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.31/home/ioBrokerVis /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 8760 states saved
    [DEBUG] [iobroker] - host.raspberrypi 10657 objects saved
    [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json is not a valid json file
    [DEBUG] [iobroker] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0
    [DEBUG] [zigbee] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: Garagentor_Status
    [DEBUG] [javascripts] - found Script: Taster_6Fach
    [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
    [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
    [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
    [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
    [DEBUG] [javascripts] - found Script: Gast_Wlan
    [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
    [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
    [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
    [DEBUG] [javascripts] - found Script: Überwachung_Temp
    [DEBUG] [javascripts] - found Script: Rauchmelder
    [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
    [DEBUG] [javascripts] - found Script: Xiaomi_Taster
    [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
    [DEBUG] [javascripts] - found Script: Ikea_Taster_
    [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
    [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
    [DEBUG] [javascripts] - found Script: Duty_Cycle
    [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
    [DEBUG] [javascripts] - found Script: Einbruch_erkannt
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-11_58_19_ioBroker_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [ERROR] [ftp] - [IGNORED] Error: Login incorrect.
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 26
    elmos04
    @elmos04 😊 😊 😊 😊
    • E elmos04
      code_text
      [EXIT] 26
      @elmos04 iobroker update -i
      E 1 Antwort Letzte Antwort
        elmos04
        @homoran sagte in Iobroker backitup error.. Wo liegt das problem:
        iobroker update -i
        Habe ich so gemacht
        [DEBUG] [iobroker] - host.raspberrypi 8762 states saved
        [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-12_02_46_ioBroker_backupiobroker.tar.gz
        [EXIT] 26
        Kommt noch immer
        • E elmos04
          code_text
          [EXIT] 26
          simatecS Offline
          simatecS Offline
          simatec
          @elmos04 wenn du auf ein NAS sicherst, warum dann noch ftp?
          Das macht kein Sinn.
          Aber selbst wenn musst du für ftp deine Zugangsdaten und IP prüfen.
          Da stimmt was nicht
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          • E elmos04
            iobroker update -i
            Habe ich so gemacht
            [EXIT] 26
            Kommt noch immer
            @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
            Habe ich so gemacht
            das gepostete ist doch nicht die Ein- und Ausgabe von dem Befehl iobroker update -i
            • simatecS simatec
              Da stimmt was nicht
              elmos04
              @simatec ftp hatte ich gerade getestet. ist wieder raus. geht aber noch nicht es gibt nur ein neues backup vom Zigbee und Java
              • E elmos04
                @elmos04
                NAS ist eine Fritzbox?
                Dann sind die Mountoptionen falsch.
                  @elmos04
                  elmos04
                  Hallo
                  Nein mein Backup geht an eine Synology. dort kommen auch neue Backups an. Zigbee und Java. Sonst kommt noch ein iobroker backup in das Verzeichnis. jetzt nicht mehr
                  • E elmos04
                    Hallo
                    @elmos04
                    Dann muss 'noserverino' ausgeschaltet sein und die smb-Version höher sein. Meist wird smb3 verwendet.
                      @elmos04
                      elmos04
                      #66
                      Loisverino ist an und smb 1.0
                      cifs ist ausgewählt
                      • E elmos04
                        cifs ist ausgewählt
                        #67
                        @elmos04
                        Das sehe ich im Log.
                        Das ist aber zu 100% falsch eingestellt.
                        Stell 'noserverino' aus und die smb Version auf die, die auch dein NAS spricht.
                          @elmos04
                          elmos04
                          #68
                          code_text
                          [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-12_18_53_ioBroker_backupiobroker.tar.gz
                          [EXIT] 26
                          Jetzt habe ich auf nas aus und speichere es Lokal.
                          • E elmos04
                            code_text
                            [EXIT] 26
                            #69
                            @elmos04
                            Lokales speichern ist kein Backup.
                              @elmos04
                              elmos04
                              #70
                              Ja ich wollte nur sehen bo die Einstellungen für mein Nas falsch sind. dann sollte es ja lokal gehen.
                              • E elmos04
                                #71
                                JA, die sind FALSCH.
                                Hab ich doch eben schon geschrieben.
                                Lösch alles Dateien aus /opt/iobroker/backups wieder raus, das Verzeichnis muss leer sein beim mounten
                                  elmos04
                                  #72
                                  aber trotzdem bekomme ich kein lokales backup hin.
                                  wenn das geht schau ich mir die nas Einstellungen an. java und zigbee werden auf dem nas gesichert
                                  • E elmos04
                                    #73
                                    @elmos04
                                    mal anschauen. Das ist offenbar krumm.
                                    • E Offline
                                      elmos04
                                      #74
                                      Ja wurde mir beim einspielen vom alten backup installiert. den 6fachtaster gab es da noch nicht. der wurde erst später im Zigbee installiert
                                      • E elmos04
                                        #75
                                        @elmos04
                                        Wurscht wo das herkommt, es ist offenbar kaputt.
                                          @elmos04
                                          elmos04
                                          #76
                                          Okay das dachte ich mir ja schon
                                          Nur wie bekomme ich den weg?👍
